Clearwave 4TSE and 4CCSE Build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 100 Old 11-10-2010, 06:07 AM - Thread Starter
t6902wf's Avatar
I have begun a build of three fronts for my dedicated home theater. It is 98% movies system.
I have a Danley DTS-10 Sub and Definitive UIW RSS II rear and surround speakers. The UIW RSS II are unique, I highly recommend them if you are going to do in ceiling surrounds.
http://www.definitivetech.com/produc...UIW%20RSS%20II
I chose the Clearwave Dynamic 4TSE and 4CCSE.
Working with Jed has been good he is very responsive and patient.
4TSE
http://www.clearwaveloudspeaker.com/Dynamic/4T.html
4CCSE
http://www.clearwaveloudspeaker.com/Dynamic/4CC.html
I chose these because of Jed's reputation and it is a good form factor for my room.
Here is the room
Clearwaves business model is very interesting. Jed will sell you the plans and parts at parts express list price with an assembled crossover. He makes money on his discount from parts express. I think that is a great deal.
I own a professional cabinet shop so I have advantages over most of the DIY crowd. I give you guys a lot of credit for doing the great work you do with the tools you have. I am going to share some photos and videos of the equipment I have because I think you guys would find it interesting.
I cut the MDF on a Altendorf Sliding table saw. It is accurate to .015" over 8 feet. The blade tilt, and rise is CNC controlled. The rip fence is also digitally controlled. You can return to the same setting very accurately.
http://www.altendorf.de/en/products/...-elmo-iii.html
The carriage of the saw holds the piece and slides like a drawer. Very easy to cut full sheets.
Here is a phone video of pushing a sheet through with one hand. We have a pressure beam which holds the wood.
Video of saw.
http://bill-stan.smugmug.com/Other/F...167_gNUrR-A-LB
I then used a router to cut the internal braces. This machine is easy because it cuts simple x y coordinates and can be programed standing at the machine quickly.
This speeds things up a lot.
Video of router
http://bill-stan.smugmug.com/Other/F...361_4SshK-A-LB
I also used an automated cut off saw. This cuts repeatably to a few decimal places, very easy to be accurate with this.
Cutoff saw fence
http://bill-stan.smugmug.com/Other/F...006_TZDst-A-LB
Finally dry fit the box.
Here is one of the towers in clamps. I used pocket holes to hold the center of the braces where you can't easily get a clamp. I also used a few pin nails to hold positioning. Overall not to difficult to assemble but certainly not easy. I made the sides 1/6" oversize so I can flush trim after.
I was able to cut all the parts, rout them and do the layout in 3 hours. I don't work in the shop anymore so I am not particularly fast. My guys could do it faster.
Most builds I have seen use heat lock glue on the veneer. I am going to use a vacuum press. More reliable for sure.
I'll try some video of that when the time comes.
T6
Clearwave 4TSE and 4CC build thread
http://www.avsforum.com/avs-vb/showt...1#post19489740
t6902wf is offline
post #2 of 100 Old 11-10-2010, 06:08 AM - Thread Starter
t6902wf's Avatar
Here are some photos I am happy how they came out
T6
t6902wf is offline
post #3 of 100 Old 11-10-2010, 06:09 AM - Thread Starter
t6902wf's Avatar
I have had my Clearwave 4T and 4CC for over a month now. I am driving them with a Denon 4310CI and three Outlaw Audio M2200 Monoblocks .
I am not going to go into great detail about what I listened to but I will make some general observations. Over the last month I listened to Rock, Jazz, Classical, Pop, TV and lots of movies from chick flicks to hardcore LFE movies. The Clearwave’s sounded excellent in all cases. What these speakers do with the highs is very special, especially women’s vocals. The imaging is very good even in my narrow room. Dialog in moves was excellent, very clear and intelligible. Having a true full range center speaker certainly adds to movies. As we all know a major percent of the soundtrack is played through the center speaker.
An interesting experiment I did was to set the sub to “no” on the Denon while the speakers were set to large. The effect is to send the LFE signal to the front three speakers. I was shocked at the low frequencies the mains were able to put out.
While listening to Flight of the Phoenix, the sandstorm / crash scene I hit 109 db peaks in my seat. It was surprisingly tactile. The first time I did it I had to double check if I turned the sub off. With the sub on at my current setting the peaks are around the same.
I also noticed music in movies and even TV shows jumped out at me.
Before I built these speakers I considered my system a 95% home theater, 5% music system. I am sure I will be listening to more music with this system because it sounds so good. I am very happy with my decision to buy and build these speakers. In my opinion it is an incredible value, I am sure you would have to spend several times what the kit cost to get sound anywhere near as good as these speakers.
T6
t6902wf is offline
post #4 of 100 Old 11-10-2010, 07:48 AM
penngray's Avatar
Liked: 43
Nice build, incredible shop....
Sure rub it in....while I cram myself into my Garage with PVC/pastic enclosures to keep the dust of othe things.
penngray is offline
post #5 of 100 Old 11-10-2010, 08:01 AM
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
Wow, I don't remember the cabinets looking so big. Nice shop.
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is offline
post #6 of 100 Old 11-10-2010, 08:16 AM
zero the hero's Avatar
very nice - how far back is the listening position? how big is that room?
zero the hero is offline
post #7 of 100 Old 11-10-2010, 08:20 AM - Thread Starter
t6902wf's Avatar
The main listening position is 12 feet. Kids sit in the front row. I wish the room was bigger bit it is not.
T6
t6902wf is offline
post #8 of 100 Old 11-10-2010, 11:01 AM - Thread Starter
t6902wf's Avatar
Glued up the center at lunch.
If I am lucky I will get veneer on it by the weekend.
Further luck will have it making noise by next weekend.
T6
t6902wf is offline
post #9 of 100 Old 11-10-2010, 03:36 PM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
Mmmmm
Bessey K body clamps = Pure Joy.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #10 of 100 Old 11-10-2010, 03:53 PM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
Can't wait to hear your review of the completed project. I'm really tempted to build a set for my HT and move my B&W 804's and HTM1 to the living room. Would that be an upgrade? Downgrade? Lateral move??
petew is offline
post #11 of 100 Old 11-10-2010, 03:59 PM
gperkins1973's Avatar
Great build. What is the cost for the fronts and centre including all parts etc... They look very impressive. What is the power ratings for them.
cheers
Graham
gperkins1973 is offline
post #12 of 100 Old 11-10-2010, 06:07 PM
Jed K.'s Avatar
Here is the current pricing for all parts. Some substitutions can be made, like different binding posts . . . etc.
http://clearwave.forumotion.net/gene...d-4cc-t124.htm
Jed K. is offline
post #13 of 100 Old 11-11-2010, 05:49 AM - Thread Starter
t6902wf's Avatar
I glued the top on this morning.
A few things of note.
1.) I temporarily screwed down cleats to hold the box off the bench so the clamp heads slid under it easily. Not rocket science but important.
2.) I used cleats under the clamps to distribute pressure onto the braces, under the cleat in the middle is a shim to arch the cleat and apply pressure to the middle before the ends are tight.
All the boxes should be sealed today and I will begin veneer Friday.
T6
t6902wf is offline
post #14 of 100 Old 11-13-2010, 06:43 AM - Thread Starter
t6902wf's Avatar
All three boxes are done. I put two in the vacuum press this morning. A vacuum press is a thick bag with a platen in it.
The platen is simply a piece of melamine particle board with saw kerf cuts in it to allow air to move under the piece you are veneering. The whole speaker is put in the bag with the veneer in place using yellow glue. Turn on a vacuum pump and it applies a great deal of pressure evenly over the entire surface. Let sit in the bad for 3 hours, pull out and repeat on another side.
I am going to use a combination of phenolic backed veneer and paper backed veneer. I am using the phenolic backed anywhere there is "end grain" of MDF showing. If you do not do this (or miter the corners) the end of the MDF will telegraph through eventually. The phenolic stops this from happening. I will then use the paper backed veneer on the other faces because it has a better edge seam. No dark line. On this project the only phenolic edge showing will be on the back of the speaker. I am going to stain it dark so I don't think you would see it in any case. I got all my veneer from Oakwood Veneer here in Michigan. It was all hand selected for grain and color.
I got 4 sheets which is more then I need but we use it every day as a part of normal business. All the veneer was cut from the same tree and it was a sequence matched flitch. I selected standard flat cut cherry. I was considering ropey cherry which has a very interesting figure but I decided to go with something more mild.
Here is a photo of the back of the phenolic veneer. Its a thin plastic.
Here is the speaker in the bag.
Here is a video of me pulling on the bag. I am not sure if it conveys what is going on but I'll throw it out there.
http://bill-stan.smugmug.com/Other/F...228_UddbY-A-LB
I will get one more pass through the bag today. All next week I will do multiple passes a day to get the veneer completed.
T6
t6902wf is offline
post #15 of 100 Old 11-13-2010, 11:06 AM
Jed K.'s Avatar
Thanks for the great thread Bill. I'm finished measuring your speakers with the new RS180-8 woofers (the non shielded replacements). I'm very happy with the +/- 1.5db response in room! NOTE: This is a 5db window so the intervals are 1db. No sugar coating the response so you can really see what is going on with it.
The boxes are tuned around 36hz, which will result in an F3 around 42hz or so, but in room the response will extend to the upper 30s if near a wall. The new RS180-8s require a new port dimension versus the original shielded version. I also don't think they need as much fill as the original box. About 2" of fill on the back wall is about all that is needed to clean up the lower mids a little, versus the 3-4" of fill of the previous box.
Here's the impedance with the above fill and the new 4" flared port with a 6" length (inner and outer flare attached end to end):
Jed K. is offline
post #16 of 100 Old 11-13-2010, 11:47 AM
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
My cabinet guy used those bags to make 2" thick MDF panels for my subs. Heavy buggers they are.........
post #17 of 100 Old 11-13-2010, 12:43 PM - Thread Starter
t6902wf's Avatar
No doubt! 2", whew.
T6
t6902wf is offline
post #18 of 100 Old 11-15-2010, 05:05 AM - Thread Starter
t6902wf's Avatar
I have been trying to find a good solution for a speaker stand for the 4CC which is 43" long and heavy. I need to hold the speaker fairly high in the air. Roughly 30". Any 30" sand or stands I come up with will look spindly. I saw a thread this morning which had an old school CRT stand holding up the center.
This is one I ran across.
http://www.sanus.com/assets/VMTVb_VMTV_cut_sheet.pdf
Any thoughts on this?
T6
t6902wf is offline
post #19 of 100 Old 11-15-2010, 06:43 AM
uhh... why does this question strike me so odd? It's like a restaurant owner asking where he can get something to eat.
post #20 of 100 Old 11-15-2010, 07:17 AM - Thread Starter
t6902wf's Avatar
I am a cabinet maker not a TV hanger?
That link did not work for me here is another.
http://www.sanus.com/us/en/products/...crt-mount/VMTV
T6
t6902wf is offline
post #21 of 100 Old 11-15-2010, 08:05 AM
i'm neither, but I built my own stands :P ...
post #22 of 100 Old 11-15-2010, 08:47 AM - Thread Starter
t6902wf's Avatar
I see if you look at the first photo of the post you can see that the speaker will need to be up high. I have a clean look to the theater that I would like to keep. A stand large enough to keep the speaker stable will look horrible.
I saw this photo on a thread this morning.
That looks like a TV mount. I think it would look good and hopefully hold up my 100+ pound center speaker.
T6
t6902wf is offline
post #23 of 100 Old 11-15-2010, 09:21 AM
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
You would probably be looking more at some kind of articulating mount to hold that weight....
Why not a nice floor mounted stand ? That is a big friggin center !
post #24 of 100 Old 11-15-2010, 10:57 AM - Thread Starter
t6902wf's Avatar
That was my first thought. Here is a quick line drawing to show the scale.
I think the proportion of that stand is off. I think no matter what I did it would be fugly.
T6
t6902wf is offline
post #25 of 100 Old 11-15-2010, 11:39 AM - Thread Starter
t6902wf's Avatar
I fabricated these struts and feet for the speakers.
I think they will look pretty good. I am going to polish the brass and lacquer them so they keep their luster.
It is 1/4" cold rolled steel, Dayton spikes and studded knobs from McMaster Carr.
T6
t6902wf is offline
post #26 of 100 Old 11-15-2010, 01:31 PM
kgveteran's Avatar
Quoted: 362 Post(s)
Liked: 130
By the looks of your build and your shop, that stand will be a sinch...
post #27 of 100 Old 11-15-2010, 01:52 PM - Thread Starter
t6902wf's Avatar
Can I, yes. Do I want to no. No glory in it.
Here is my idea for a steel wall mounted stand. It would be band steel maybe 3/16 or 1/4". Black. It should hardly be noticed.
T6
t6902wf is offline
post #28 of 100 Old 11-15-2010, 02:23 PM
mrgfy6's Avatar
Quoted: 12 Post(s)
what about a nice "french cleat"? It would be completely hidden, and I KNOW the CC is super heavy, but as long as you anchor it properly, it should remain hidden...especially with your acoustic paneling on the wall...Just a thought...
mrgfy6 is offline
post #29 of 100 Old 11-15-2010, 02:43 PM - Thread Starter
t6902wf's Avatar
That would work but I need to hold it well off the wall. 15" or more.
T6
t6902wf is offline
post #30 of 100 Old 11-15-2010, 07:16 PM
mrgfy6's Avatar
Quoted: 12 Post(s)
oh, the ports are rear facing, my fault...sorry.
mrgfy6 is offline
