Mfw-15 Clone Project - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #91 of 120 Old 04-23-2012, 05:38 AM
fschris's Avatar
Quoted: 31 Post(s)
Liked: 35
more...
ASROCK H67 GE / HT/Core i3
Emotiva XPA2 Gen2 x2
Carver AV-705 5Channel AMP
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
2 x MFW 15 Clones DIY
fschris is offline
post #92 of 120 Old 04-23-2012, 05:39 AM
fschris's Avatar
Quoted: 31 Post(s)
Liked: 35
and more... anyone bored yet?
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
post #93 of 120 Old 04-23-2012, 06:27 AM - Thread Starter
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 191
nice work.
NicksHitachi is offline
post #94 of 120 Old 04-23-2012, 09:07 AM
fschris's Avatar
Quoted: 31 Post(s)
Liked: 35
i have that measurement you need.
It was Piece numbr 10
Long to long
11 3/8
Short to short
9 7/8
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
post #95 of 120 Old 04-26-2012, 06:54 PM
fschris's Avatar
Quoted: 31 Post(s)
Liked: 35
more pics...
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
post #96 of 120 Old 04-26-2012, 06:55 PM
fschris's Avatar
Quoted: 31 Post(s)
Liked: 35
wanted to glue up back and bottom today... ran out of time.
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
post #97 of 120 Old 04-27-2012, 03:09 AM - Thread Starter
Quoted: 182 Post(s)
Liked: 191
Its frustrating the way it all goes together and the inablity to clamp and move on makes this build a long process........
I think end result is worth it though..........
post #98 of 120 Old 04-27-2012, 11:42 AM
fschris's Avatar
Quoted: 31 Post(s)
Liked: 35
I'd love to see how these were manufactured and built on one of those "how its made' shows on Discovery.
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
post #99 of 120 Old 04-30-2012, 07:07 PM
fschris's Avatar
Quoted: 31 Post(s)
Liked: 35
coming along.
got it all sanded up
installed terminals
installed acoustic treatment
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
post #100 of 120 Old 05-01-2012, 07:09 PM
fschris's Avatar
Quoted: 31 Post(s)
Liked: 35
Got the Hurricane nuts installed. With my ghetto drill press guide!
Finished 2 coats of 50/50 tite bond / water
Before I did the sanding I ran some wood filler over all the seems then sanded hoping to blend the seams.
If that does not work well... Next time I will use Bondo car filler or something!
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
post #101 of 120 Old 05-02-2012, 03:16 AM - Thread Starter
Quoted: 182 Post(s)
Liked: 191
Nice Drill press! :P
post #102 of 120 Old 05-03-2012, 07:28 PM
fschris's Avatar
Quoted: 31 Post(s)
Liked: 35
almost DONE!
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
post #103 of 120 Old 05-06-2012, 05:34 AM
fschris's Avatar
Quoted: 31 Post(s)
Liked: 35
Big thanks to the OP who was able to get me started on this project.
Now I have some Towers to build!
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
post #104 of 120 Old 06-03-2012, 08:46 AM
airliner's Avatar
Quoted: 20 Post(s)
Is the volume behind the internal brace a second area or is just part of the inner volume, in other words, can I change the shape mantaining the same inner volume and vent domension and length?
airliner is offline
post #105 of 120 Old 06-03-2012, 09:13 AM - Thread Starter
Quoted: 182 Post(s)
Liked: 191
Its part of the sub enclosure, the window brace is just there for bracing.
post #106 of 120 Old 06-03-2012, 11:50 AM
airliner's Avatar
Quoted: 20 Post(s)
So as long as I understood from all my reading on the forum if I mantain the same vent dimension, the same volume, and adequate bracing, the response shouldn't be so jeopardized, am I correct? Marco
And thanks!
airliner is offline
post #107 of 120 Old 06-03-2012, 01:13 PM - Thread Starter
Quoted: 182 Post(s)
Liked: 191
And thanks!
Your logic is sound, but mileage may vary.....
post #108 of 120 Old 06-04-2012, 01:20 PM
airliner's Avatar
Quoted: 20 Post(s)
airliner is offline
post #109 of 120 Old 06-04-2012, 02:57 PM - Thread Starter
Quoted: 182 Post(s)
Liked: 191
If you mean building as close as possible to the original design and keeping to the aforementioned parameters as close as possible, yes your results should be good.
If your considering radically changing dimensions while keeping enclosure volume and port tuning the same, it might be similar it might not.......
Main Important Variables:
  1. Enclosure volume.
  2. Port volume, shape, length, and flare characteristics.
  3. Bracing.
Sorry I wasn't sure how radical a departure your considering. If your building as close as possible to the original then your results are ensured, the more you variate so will your results.
post #110 of 120 Old 06-09-2012, 11:04 AM
airliner's Avatar
Quoted: 20 Post(s)
MFW long vers.pdf 52k .pdf file
I did design the sub maintaining the same internal volume, as stated on the first page 2.75/2.9cft, The port, same width 16 3/4 by 1 1/2, same lenght.
airliner is offline
post #111 of 120 Old 06-13-2012, 09:12 AM
airliner's Avatar
Quoted: 20 Post(s)
Ok, my result building on a shape similar to the one I posted are: volume with no brace and no speaker 2.8cft, vent 44.6". It should make quite similar.
I'm building one in the next few days and will let you know
Marco
airliner is offline
post #112 of 120 Old 06-15-2012, 07:38 PM
fschris's Avatar
Quoted: 31 Post(s)
Liked: 35
airliner keep us posted and post some pics
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
post #113 of 120 Old 06-18-2012, 02:57 AM
airliner's Avatar
Quoted: 20 Post(s)
Problem: I was taking my MFW driver home from Newark airport, unfortunately TSA opened my suitcase and did not replace everythingh correctly in. Now the driver cone has a few dents, not holes. Is it going to work still? If not I have to find a new driver or a substitute one.
airliner is offline
post #114 of 120 Old 06-18-2012, 03:03 AM - Thread Starter
Quoted: 182 Post(s)
Liked: 191
It should work fine.  Is the dent in the dust cap(center bubble)?  If thats dented you can use a vacuum cleaner to attach and suck it back out.  You really won't see that much pressure on the cone of a ported sub so if there are dents elsewhere they should be fine.  I guess technically it could affect the T/S parameters of the driver, especially resonance, but In this application i don't think it will be appreciable.
post #115 of 120 Old 06-18-2012, 03:20 AM
airliner's Avatar
Quoted: 20 Post(s)
thankyou:)
airliner is offline
post #116 of 120 Old 06-19-2012, 07:26 AM
airliner's Avatar
Quoted: 20 Post(s)
I am home:)
I was checking again the cone, and in one of the dent, the stiffness of the paper seems to be damaged, I'm building anyway the sub, but in case wich driver can substitute the MFW?
airliner is offline
post #117 of 120 Old 06-19-2012, 08:14 AM - Thread Starter
Quoted: 182 Post(s)
Liked: 191
post #118 of 120 Old 07-12-2012, 10:42 AM
fschris's Avatar
Quoted: 31 Post(s)
Liked: 35
Nick,
What do you think about doing some mods to the MFW clone. You have any idea if something like this would be able to get lower and deeper and stronger bass?
I wonder If I could drop into the baffle.
TC Sounds Axis 15Q1 15" Quad VC Subwoofer
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=293-642
Chris
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
post #119 of 120 Old 07-12-2012, 11:07 AM - Thread Starter
Quoted: 182 Post(s)
Liked: 191
Nick,
Chris
Hi Chris,
Model it in 3.0ft3 tuned to 18-19Hz and see how it looks.  The TC drivers are tanks but take some juice to get them to move so youll have to factor that into their total cost.  I have modeled the Titanic 15 in this enclosure and it looks pretty good and takes a lot of power staying under excursion limits, the HF and HO would be good options too, but I can't remember how they look in the model with respect to excursion etc.
One cheap mod you could do is glue in some MDF bracing strips on edge between the baffle and window brace.  That is a rather large unbraced panel.  Also I found I preferred the sound of the MFWs with quite a bit of stuffing, Polyfill is what I used.  I stuffed the entire cavity behind the window brace pretty full, but not tight.  You could add a little on the bottom shelf under driver where port comes out front too if you wanted.  It seemed to tighten it up a little and sounded a bit deeper to me.  I didn't measure the differences and I don't think it affects extension all that much, I just preferred the sound.....  Or maybe it was psychoacoustics.
You try it and let me know what you think!
post #120 of 120 Old 07-12-2012, 11:30 AM
fschris's Avatar
Quoted: 31 Post(s)
Liked: 35
Thanks , poly fill sounds like a nice cheap mod to try. After I get My zaphs built, i will invest in a MIC to do some testing.
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
fschris is offline
