Hey guys...we need a little rallying here... - Page 116 - AVS Forum | Home Theater Discussions And Reviews
 901Likes
post #3451 of 12740 Old 04-01-2012, 07:11 AM
bwaslo's Avatar
Quoted: 68 Post(s)
Liked: 188
Originally Posted by jlk103144 View Post
Do you work for the government?
Just kidding. Government employees, bureaucrats, and politicians think the same thing.
Well, hey then. I've designed a special crossover just for you! (Please close the door before you crank up the volume).
___________________________________________
DIY Synergy horn spreadsheet Synergy horn spreadsheet and pdf
XSim -free crossover designer and simulator XSim install file
Easy and cheap sound diffusers (the "Depot Diffusers") making easy DIY depot sound diffuser-panels-step by step.html
SmallSyns - point source controlled directivity in a manageable size SmallSyns
bwaslo is offline
post #3452 of 12740 Old 04-01-2012, 08:20 AM
Erich H's Avatar
Quoted: 1476 Post(s)
Liked: 1893
Originally Posted by bwaslo View Post
No issue, Erich. It's just that I know Zilch's crossovers were simpler and some folks feel like "simplest crossover is better" (which I think is just superstitious nonsense).
I actually figured the more complex crossovers were better. Harder to build, but better in the end.
I just didn't know how noticeable the "finicky" part was. Your wording threw me off a little because it sounded as if it could be used or skipped. Now I see that it's not *really* finicky at all and should be there.
The SEOS Waveguide Project
Erich H is offline
post #3453 of 12740 Old 04-01-2012, 08:29 AM
tuxedocivic's Avatar
Quoted: 2186 Post(s)
Liked: 2055
Bwaslo, nice designs. I'm wondering though, isn't the whole point of such a large design directivity and efficiency? Seems you have directivity, but the efficiency is obtainable from much smaller. And couldn't we get directivity from a SEOS 8, just higher in frequency? How much would that matter?
Not criticizing just trying to learn about directivity. I'm also a small speaker kind of guy
My youtube channel: Impulse Audio
tuxedocivic is offline
post #3454 of 12740 Old 04-01-2012, 08:29 AM
Gooddoc's Avatar
Quoted: 3106 Post(s)
Liked: 2404
How frustrating! It's pitiful that I'm so crossover illiterate I don't get the joke(although I think it is that the CD is not padded so would be so friggin' loud it would blow you out of the room?)
Sorry to put a damper on your joke. It's never as funny when you have to explain it to someone . And by the way, you don't need to bother explaining it to my ignorant *ss.
Gooddoc is offline
post #3455 of 12740 Old 04-01-2012, 08:45 AM
bwaslo's Avatar
Quoted: 68 Post(s)
Liked: 188
Main point (for me) is directivity. Efficiency is nice, but not really a big deal, really good amplifier power is CHEAP nowadays (lots of good class D amps around). But if you happen to be a SET afficiando, then efficiency is more of a requirement. Ideally you'd like directivity down to where the room modal pattern starts to dominate things (around 300Hz).
The crossover gag is just that it's just a single capacitor, won't do anything much more than keep DC out of the horn driver. Would sound horrible, in this case. Though a lot of cheap cone tweeter 2-ways in the 70s used a single cap for the crossover, and weren't horrible in response (though "flat" wouldn't exactly describe them).
bwaslo is offline
post #3456 of 12740 Old 04-01-2012, 08:56 AM
Liked: 2055
Ok, so even smooth transition directivity up around a 1.5khz cross over isn't as desirable as going big and getting pattern down below 1khz. My smaller designs seem to have a smooth transition, yet much higher directivity point. The price I pay for small 8" drivers I suppose.
post #3457 of 12740 Old 04-01-2012, 09:06 AM
bwaslo's Avatar
Quoted: 68 Post(s)
Liked: 188
Well, "ideal" and practical are two different things, there are always tradeoffs. Ideally, we'd have a time machine and go back and hear the Beatles playing in the Cavern, 1963.
bwaslo is offline
post #3458 of 12740 Old 04-01-2012, 09:46 AM
jlk103144's Avatar
LOL!
BA = Big Assed Compression Tweeter
CD = compression driver or constant directivity
OS = oblate spheroid(al). A geometric curve
SEOS = super-elliptical oblate spheroidal.
jlk103144 is offline
post #3459 of 12740 Old 04-01-2012, 10:52 AM
robseyes's Avatar
Thanks for all of your hard work! What you & Eric are doing is an amazing gift to the DIY community. I really appreciate it!
I have 200 watts into 8 ohms, so I have plenty of amp. I can't wait to try one of these CD designs. How would you compare the SEOS 12 with the Dayton DS 12 with one of the designs with a really high end woofer like the AE TD12s or JBL 2226h? Pretty close sound quality wise? I know those other woofers are a lot more efficient. Just curious from a nubee point of view.?
robseyes is offline
post #3460 of 12740 Old 04-01-2012, 11:09 AM
Thatsnasty's Avatar
Quoted: 51 Post(s)
Liked: 44
The DS12 / SEOS12 is probably one of the best value designs around for what you get. I know a price hasn't been posted but you can imagine based off the cost of parts that it's a great bang for your buck.
But with the DE250 having 108db/1w efficiency (AFAIK), it screams to be mated to a high efficiency 12/15.
Personally, I think that's what everyone is going to hold out for. I've never had mains capable of playing 115db+ so I'm really interested to see what comes next.
Thatsnasty is offline
post #3461 of 12740 Old 04-01-2012, 11:11 AM
btinindy's Avatar
Quoted: 38 Post(s)
Liked: 56
That is what is so exciting is that the designs so far are not the "High end" woofers yet and the measurements look really smooth. Looks like it will only continue to get better!
btinindy is offline
post #3462 of 12740 Old 04-01-2012, 11:41 AM
robseyes's Avatar
+1. I'm just trying to figure out the % of performance the DS12 is to one of the high end woofers. It's so darned reasonable!
robseyes is offline
post #3463 of 12740 Old 04-01-2012, 11:56 AM
bwaslo's Avatar
Quoted: 68 Post(s)
Liked: 188
Except for maybe the risk of voice coil heating (not likely an issue for home uses), the max output you can get is just based on cone area*xmax, efficiency doesn't really come into it.
I haven't heard a TD12, just a TD15M. Probably if I were building from scratch (and keep in mind I'm cheap and not impressed with "high end" things usually) I'd go with a DS12 design... and of course some subwoofers, still. Overall size is a consideration and these TD15M boxes are stupid big for my living room! Or maybe some ceiling-mount SEOS/ShadedHLA things (though no one has built or heard that yet, just expecting/hoping that to be good).
But no one has ever accused me of having golden ears. I can't even hear the effect of brilliant rocks!
bwaslo is offline
post #3464 of 12740 Old 04-01-2012, 03:16 PM - Thread Starter
LTD02's Avatar
Quoted: 2524 Post(s)
Liked: 2867
first you say...
add to that this mess...
then this is the result???
i know that you are good bwaslo, but are you really that good, or is the smoothing hiding the mess that the frequency response of the driver is?
how does it look with no smoothing, zero, none at all, even though i know this will create something that looks like an fm channel when tuned between stations.
then again, maybe we just hear wideband 1/3 octave or so, so it really doesn't matter.
scale matched responses:
Listen. It's All Good.
LTD02 is offline
post #3465 of 12740 Old 04-01-2012, 03:36 PM
rajacat's Avatar
Quoted: 52 Post(s)
Liked: 31
Too bad there isn't a 15" version of the Designer Series woofers.
rajacat is offline
post #3466 of 12740 Old 04-01-2012, 03:40 PM
Brad Horstkotte's Avatar
Liked: 72
I am running my speakers off AVR, no separate amp, so efficiency is important to me - and my LCRs are fairly high efficiency already - so I'll be scouring for high efficiency designs.
Brad Horstkotte is offline
post #3467 of 12740 Old 04-01-2012, 03:51 PM - Thread Starter
LTD02's Avatar
Liked: 2867
brad, what LCR's do you have?
LTD02 is offline
post #3468 of 12740 Old 04-01-2012, 03:54 PM
Liked: 72
Chase Home Theater - SHO-10 center, PRO-10 L/R, and 4x PRO-10 for surrounds.
post #3469 of 12740 Old 04-01-2012, 04:05 PM
bwaslo's Avatar
Quoted: 68 Post(s)
Liked: 188
It's because I use special quantum-based supersymmetric nuetrino tachyon techonology in my crossovers. The govt won't let me say more about it.
Part of it's the smoothing, but look at the scales on the datasheet graph. That 'mess' at 400 to 600 is only about 3dB deep.
Also, I'm not sure those response measurements are quite right -- they weren't measured by Dayton, but by the manufacturer (NOT using OmniMic!) overseas. I've talked to the people at Dayton about redoing the plots themselves. That peak the plot shows at 150Hz makes no sense at all, I don't know how a low fs woofer could do that. Here's what I measured on that DS12 woofer (1/48th octave res, about 20" away):
For comparison, here's what I measured on a TD15M under similar conditions:
I do tend to focus on the 6th octave type stuff, particularly for dips.
bwaslo is offline
post #3470 of 12740 Old 04-01-2012, 04:13 PM
bwaslo's Avatar
Quoted: 68 Post(s)
Liked: 188
Either of the Eminence 12 designs are high efficiency, 98dBish.
Edit: make that 96-ish. Eminence reads their sensitivity up where you'd have to bring the curve down from to get it flat.
bwaslo is offline
post #3471 of 12740 Old 04-01-2012, 04:22 PM - Thread Starter
LTD02's Avatar
Liked: 2867
"Here's what I measured on that DS12 woofer (1/48th octave res, about 20" away)"
ahh...that is a big difference.
if you were to slice a line through that frequency response up to the crossover point, it would be more like +/- 2.5 which is good by most measures and stellar by the budget standards here.
LTD02 is offline
post #3472 of 12740 Old 04-01-2012, 04:27 PM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 191
first you say...
Well this one only goes to 150 and gets a little wonky before that, prob b/c of the box size........
Really though I dont understand why we're not looking all the way down to a reasonable crossover point.....??
NicksHitachi is offline
post #3473 of 12740 Old 04-01-2012, 04:32 PM
Thatsnasty's Avatar
Quoted: 51 Post(s)
Liked: 44
This is true. How is the low end for the eminence drivers?
I'd imagine they need to be crosser higher and have less bass then the designer woofers.
I'm curious how the designs using 15" drivers will do. Lower response and high efficiency. I guess it's possible with something like the 2226h? but that's really pricey.
You read my mind.
post #3474 of 12740 Old 04-01-2012, 04:39 PM
bwaslo's Avatar
Quoted: 68 Post(s)
Liked: 188
Because:
(1) I'd have to go outside to measure it all in one curve. My indoor anechoic chamber is closed for remodelling. And these things are heavy and my heavy lifting personnel is managing his lawn business.
and
(2) The low end below about 200Hz is all Thiele and Small and room/box. You can get the driver response there from the T&S parameters. The box I measure in isn't the box design you're likely to use (at least not without some porting; though the Designer12 was pretty well matched to the sealed box, might be why it sounded so good).
Edit: well, maybe the box was ok for the Eminence drivers, I just ran them on WinISD (as did someone else previously here). But the bass sure sounded light compared to the DS12. I remain ignorant of why.
bwaslo is offline
post #3475 of 12740 Old 04-01-2012, 04:54 PM
chrapladm's Avatar
Quoted: 937 Post(s)
Liked: 350
Is that the Delta and Deltalite series?
I was thinking of trying to get as efficient as possible by using one of the Delta series. Not saying my idea will work but I am hoping to use a small amount of power, say 50-100 watts, for indoor and outdoor situations.
chrapladm is offline
post #3476 of 12740 Old 04-01-2012, 05:05 PM
bwaslo's Avatar
Quoted: 68 Post(s)
Liked: 188
I've been playing all of them with a 50W amp, even the Designer12 version. Just one listener, not playing disco levels or anything. If you're splitting at 85Hz or so to a sub, 50W should be plenty for non-earbleeding home use.
The various new SEOS designs are being collected in separate threads here:
http://diysoundgroup.com/forum/index.php?board=2.0
PLEASEdon't post there, yet, though. Erich hasn't officially opened the forum, things might change, anything posted may get wiped out while the forum software gets messed with.
bwaslo is offline
post #3477 of 12740 Old 04-01-2012, 06:12 PM
Quoted: 182 Post(s)
Liked: 191
Because:
and
Gotcha, thanks for your work and your light years ahead of me on design comprehension, I ask questions so I can learn and understand better. I wasnt aware the box sizes were still not determined.
I see how the low end would be controlled by the factors you mentioned, I'll sit back and be patient.... I'm just impatient and cant wait to see a response with box dimensions and alignment determined, flat to like 80...... Am I not paying you enough?
Cheers,
Nicholas
post #3478 of 12740 Old 04-01-2012, 06:51 PM
Erich H's Avatar
Liked: 1893
Once I make some ported boxes that are the correct size for each woofer, things should look even better. A sealed Deltalite in a 2.25 cu ft box is simply holding it back from what it does best. Because the pro woofer boxes will be used with subs, I'm hoping to go around 2 cu ft tuned to 60hz or so for the Deltalite. That should get them pounding pretty good. They can handle dance club midbass, so I think they should do pretty good in a home theater.
BWaslo said he goes to dance clubs every other weekend just to check out the woofers......and "Keep my old school moves fresh for the newbs." Not sure what that means, but maybe he was a break dancer back in the day after the disco craze.
The DS series might have another box option allowing for full range if I build the right enclosure and tune it low enough.
As mentioned, things should be shipping in about 2 weeks. Not sure how long it will take to get here though.
Erich H is offline
post #3479 of 12740 Old 04-01-2012, 06:56 PM
Quoted: 182 Post(s)
Liked: 191
Once I make some ported boxes that are the correct size for each woofer, things should look even better. A sealed Deltalite in a 2.25 cu ft box is simply holding it back from what it does best. Because the pro woofer boxes will be used with subs, I'm hoping to go around 2 cu ft tuned to 60hz or so for the Deltalite. That should get the thing pounding pretty good.
Which woofer option(s) are slated for a sealed alignment? Any?
post #3480 of 12740 Old 04-02-2012, 07:33 AM
JackNC's Avatar
Quoted: 140 Post(s)
Liked: 39
No reason you guys should have all the fun. I did some simulations last night and yes the delta lite wants a big box but its hampered by its 4.9 mm xmax. I had to high pass at 50 hz and limit power to 100W to keep it below xmax but it still beat the Dayton on SPL. The Dayton with 5.5 mm xmax goes lower but not so low you don't need subs. In 22L sealed with 60 hz HP, it could take almost 2x its RMS power w/o overexcursion. It seems to me that the smaller sealed alignments will integrate well with subs and so no need for the larger ported boxes. Am I right and if not, what am I missing?
JackNC is offline
