Hey guys...we need a little rallying here... - Page 124 - AVS Forum | Home Theater Discussions And Reviews
 880Likes
post #3691 of 12720 Old 05-01-2012, 08:49 PM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1768
Originally Posted by orcarola25 View Post
Honestly I can humbly say that I would really be shooting in the dark trying to design my own crossover. I am personally banking on some help as it seems like there are quite a few members who have already kindly provided clarification to us newer learners. I am not completely illiterate but am not a veteran by any means.
Bosso seems to be the "go to" guy that has dedicated his time and energy in helping Erich incorporate the SEOS into a high performing loudspeaker. Although I would consider it a very small contribution, I would be willing to send bosso a TD12M and a TD15M when I receive them to run through tests and come up with a solid crossover schematic for the masses. Not sure how many members have already offered this but I just thought I would throw it put there.
I'm going to start calling him Bosso now if you don't mind!
Actually, it's BWaslo that was helping with the crossover work so far. There will be a decent number of different crossover designs by more people once everything gets here.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #3692 of 12720 Old 05-01-2012, 08:51 PM
omegaslast's Avatar
As someone who has an AE speaker pre ordered... theyre so limited release i feel like resources would be better spent on drivers you can actually buy regularly.
omegaslast is offline
post #3693 of 12720 Old 05-01-2012, 09:17 PM
robotbunny's Avatar
It matters; for same XO freq, 4 ohm requires half the value for inductors and resistors, and double the value for capacitors.
Thanks Noah. Yes, this is what I gathered from reading a bit further. Found a thread on audiokarma discussing a similar issue. Playing around with this site: http://www.apicsllc.com/apics/Misc/filter2.html Calculating a 4th order 2-way crossover, I was at least able to observe the doubling of L2 inductor on the high pass by cycling between 8 and 4ohm impedance and the doubling and halving of the low pass resistor and inductor values on C3, C4, L3, and L4. Why wouldn't L1 change in value? I noticed it is the same value as the ohmage of the tweeter.
It's not that simple most of the time. If there are notches or zobels etc. and a 4 and 8 ohm driver may measure differently othe than just the extra 3db.
So it doesn't matter if you're doing your own design. You have to figure it all out anyways. And if copying a design, I doubt halving the L and doubling the C will do it anyways. It'll still end up wrong, likely.
I read about that 3db rise and someone mentioned using an L-pad to adjust, but wasn't really sure why unless the only reason was to even the output between the cd or tweeter and the mid-driver. I understand what you're saying that it wouldn't matter to a designer, they would make the correct adjustment in the network, whereas by simply halving or doubling these values may not achieve good results without real-world measurement and know-how.
Thanks guys. I'm trying to wrap my head around it all...I'm hooked.
robotbunny is offline
post #3694 of 12720 Old 05-01-2012, 10:44 PM
robotbunny's Avatar
Originally Posted by omegaslast View Post
As someone who has an AE speaker pre ordered... they're so limited release i feel like resources would be better spent on drivers you can actually buy regularly.
Ya know, I was battling this very thing between AE and Faital Pro, but
I've gone and drank the AE cool-aid. I've monitored the pre-order list and hold quite a few of those involved in very high regard (including John
Janowitz - both on a personal and professional level) and followed many threads across several boards. I'm certain those that plunked down their cash for these had considered similar attributes between drivers currently available on the market, perhaps even comparing the 12fh520 and td12m. Eternal Velocity pointed out some impedance irregularities in a graph he posted for the Faital driver and also posted some very nice looking FR graphs here: http://www.avsforum.com/avs-vb/showp...postcount=2942. I was intrigued by the measurements Brandon Thill made with the TD12M (http://sites.google.com/site/driverv...speakers-td12m) and I was particularly impressed with the 0-40 degree frequency response and in comparing the impedance/phase vs. frequency of the AE to the Faital, I leaned toward the AE. I understand the trepidation however, AE is a very small company, but I feel with the support (and patience) this community has shown it can only get better.
-Nate
post #3695 of 12720 Old 05-02-2012, 04:11 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 189
I say this "tongue in cheek" but according to john at AE the TD12 series doesnt suffer the same lead time issues of the larger drivers.
He said they had a few week lead time but nothing like a 15" driver........
FYI.
NicksHitachi is offline
post #3696 of 12720 Old 05-02-2012, 08:34 AM
Point Source
beastaudio's Avatar
Quoted: 3487 Post(s)
Liked: 2821
FYI.
Good, I want two maybe 7...
beastaudio is offline
post #3697 of 12720 Old 05-02-2012, 10:08 AM
louisdamani's Avatar
So...What is the group go to 12 or 15 for an alternative to the AE TD12-15m's???
louisdamani is offline
post #3698 of 12720 Old 05-02-2012, 11:26 AM
tuxedocivic's Avatar
Quoted: 1903 Post(s)
Liked: 1724
Eminence has some good contenders?
Lots of budget range too.
Ryan
tuxedocivic is online now
post #3699 of 12720 Old 05-02-2012, 12:34 PM
noah katz's Avatar
Quoted: 878 Post(s)
Liked: 304
Originally Posted by louisdamani View Post
so...what is the group go to 12 or 15 for an alternative to the ae td12-15m's???
jbl 2206 imo; there are some on ebay right now
Noah
noah katz is offline
post #3700 of 12720 Old 05-02-2012, 12:56 PM
filtor1's Avatar
Quoted: 71 Post(s)
Liked: 73
Sometimes I wonder if JBL knows they would empty their inventory if they priced the 2226H at a more reasonable point. I would have build my speakers already. lol
filtor1 is offline
post #3701 of 12720 Old 05-02-2012, 01:07 PM
noah katz's Avatar
Quoted: 878 Post(s)
Liked: 304
Cheapest new is $319 here http://www.speakerfactory.net/
Noah
post #3702 of 12720 Old 05-02-2012, 01:11 PM
filtor1's Avatar
Quoted: 71 Post(s)
Liked: 73
I see $349, but even then, that is a great price. As much as used + a recone! uh oh.... my poor wallet. Thanks for the link!
filtor1 is offline
post #3703 of 12720 Old 05-02-2012, 01:11 PM
Eternal Velocity's Avatar
Quoted: 30 Post(s)
Liked: 61
I wouldn't call them "irregularities" - in fact "regularities" might be more accurate. It's the acoustic elegance drivers which are irregular!
For reference, Troels Graveson has worked with some of the finest Hi-Fi drivers on the planet from Scanspeak, Seas, etc. When it got down to developing his own driver (A High Sensitivity Seas Excel unit for the most part), which he (of course with bias) considers his personal favorite, the measurements actually showed some "impedance problems".
What you have to remember however, is that a more sensitive driver will apparently magnify the impedance issues. The impedance can make you panic, but that doesn't mean you should panic. Even this scanspeak revelator shows a pretty big bump:
And it's not as signfiicantly "visible" in a lower efficiency design.
So I do want to apologize if I gave you any apprehension. The acoustic elegance drivers are certainly irregular, but i'm not 100% sure any of those things are audible once linear response is carefully addressed.
Eternal Velocity is offline
post #3704 of 12720 Old 05-02-2012, 01:23 PM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
used ones cost nothing i got 2226s for $120 each in town with original cones and mint condition then got some sun damaged 2206 a few weeks later for $90 each dyed them black they look great and work like stock ones. both pairs off Craigslist right after sxsw. just make sure u get original cones.
cookieattk is offline
post #3705 of 12720 Old 05-02-2012, 01:44 PM
filtor1's Avatar
Quoted: 71 Post(s)
Liked: 73
I keep an eye out on CL and EB all the time. I never see them for sale around my area. You got some killer deals though for sure.
filtor1 is offline
post #3706 of 12720 Old 05-02-2012, 02:17 PM
Point Source
beastaudio's Avatar
Liked: 2821
Is anyone planning a design with the 2226H?
post #3707 of 12720 Old 05-02-2012, 03:11 PM
Carl_Huff's Avatar
Quoted: 80 Post(s)
Liked: 101
Yea, I have one.
When completed it will look much like this. My project was inspired by studio monitors designed by George Augspurger.
Each cabinet has two 2226H drivers in it along with an 18 inch SEOS and DE250 CD. Mine will have a SEOS waveguide in place of the wooden horn shown in the PIC.
I have one cabinet assembled but am sorry to admit that I haven't completed the project. I keep being drawn away by other efforts that pay the rent! I hope to get back to it soon and complete it.
Here is a PIC of a typical studio install.
_____________
Best Regards,
Carl Huff
Carl_Huff is offline
post #3708 of 12720 Old 05-02-2012, 05:22 PM
Brad Horstkotte's Avatar
Liked: 68
Those look sick Carl, looking forward to seeing yours
Brad Horstkotte is offline
post #3709 of 12720 Old 05-02-2012, 05:34 PM
Carl_Huff's Avatar
Quoted: 80 Post(s)
Liked: 101
Ha, ha, Yes!
Here is a pair with subs. Geez, I really need to finish them.
____________
Best Regards,
Carl Huff
post #3710 of 12720 Old 05-02-2012, 06:22 PM
ehoeft's Avatar
Liked: 24
If money wasn't a issue what would be the best 15" driver to use. I was set on AE but I'm rethinking it now. Would it be the 2226H? What are people going with?
ehoeft is offline
post #3711 of 12720 Old 05-02-2012, 06:47 PM
Erich H's Avatar
Liked: 1768
For what it's worth, I have some of those JBL 15's, but they're 16 Ohm models.
I can't recall how many I have from the JBL group buy last year, but it should be at least 5-7 pair? I just never got around to listing them. I'm thinking about keeping 2 pair of them myself. But not sure just yet.
Erich H is offline
post #3712 of 12720 Old 05-02-2012, 07:34 PM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
gone !
post #3713 of 12720 Old 05-02-2012, 11:52 PM
noah katz's Avatar
Quoted: 878 Post(s)
Liked: 304
That's for the 2226's.
you're welcome
Noah
post #3714 of 12720 Old 05-03-2012, 11:13 AM
jzagaja's Avatar
Hot pictures from HIGH END Munich 2012.
jzagaja is offline
post #3715 of 12720 Old 05-03-2012, 11:33 AM
Liked: 68
My first reaction was it looks like a collection of bathroom fixtures
post #3716 of 12720 Old 05-03-2012, 11:48 AM
robotbunny's Avatar
Spectacular. Oh, and I spy...one piece baffles... Front and back shot too, very nice. And I see the enclosure got some paint too. Excellent.
-Nate
post #3717 of 12720 Old 05-03-2012, 11:53 AM
jzagaja's Avatar
Yes like bidet etc.
Some say Mick Jagger mouth
jzagaja is offline
post #3718 of 12720 Old 05-03-2012, 11:53 AM
Quoted: 182 Post(s)
Liked: 189
Those are some unbelievably beautiful speakers, I'm not sure if I would like the painting on the red horn though.......
post #3719 of 12720 Old 05-03-2012, 11:58 AM
jzagaja's Avatar
A friend of Autotech wanted to try dental resins (expensive). Not everyone like them that's for sure.
jzagaja is offline
post #3720 of 12720 Old 05-03-2012, 12:16 PM
Point Source
beastaudio's Avatar
Liked: 2821
Originally Posted by Carl_Huff View Post
Ha, ha, Yes!
____________
Best Regards,
Carl Huff
would just doing a single 15" design cause any changes in the design of the crossover? Im looking more at a single 15 design, or POSSIBLY a stacked 15" design where the horn would be between the two 15's :Sweet:
