Hey guys...we need a little rallying here... - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 901Likes
post #811 of 12740 Old 12-23-2010, 07:47 AM
AudioJosh's Avatar
Quoted: 282 Post(s)
Liked: 255
OT but interesting....
http://www.supravox.fr/anglais/haut_...av_1_pouce.htm
Its not CD, but notice the shape and mouth dimensions.
JoshK on most other audio forums
Quantity only when quality is ensured.
AudioJosh is offline
post #812 of 12740 Old 12-23-2010, 07:48 AM
penngray's Avatar
Liked: 47
Originally Posted by coctostan View Post
An ideal OS design would have no conical section. Since I don't know your manufacturing techniques I'm can't speak to the necessity of your conical section. The entire conical section is counterproductive.
Ideally, where I drew the green arrow, it should be 1" (25.4mm) in diameter. Are you saying you can't meet this target well enough due to shrinkage?
What are the entry and exit diameters for the conical section?
If there is a manufacturing obstacle I think we need to make sure we are doing our best to minimize or eliminate its effect.
At some point we have to transition from the 16.5deg angle to the angle of the SEOS waveguide so there is always going to be a transition point where the angles change and diffraction happens.
Is there any other way of doing this?
penngray is offline
post #813 of 12740 Old 12-23-2010, 07:52 AM
jzagaja's Avatar
Most exciting CD horn is Smith type JMLC, "Midrange" horn.
jzagaja is offline
post #814 of 12740 Old 12-23-2010, 08:07 AM
jzagaja's Avatar
This is how it should (IMHO) look like at the throat.
jzagaja is offline
post #815 of 12740 Old 12-23-2010, 08:11 AM
Erich H's Avatar
Quoted: 1470 Post(s)
Liked: 1881
Originally Posted by jzagaja View Post
Coctostan - as far as I know the driver should have no conical duct or cylindrical duct, in other words throat angle zero degrees. So in a best case radius in OS throat should continue in a phase plug. Such a driver does not exist so far. Like I said we do slightly smaller throat and grind because shrinkage cannot be controlled with hand lamination. Part marked with red arrow will be cut.
This pretty much answers the question to the new issue right?
_______________________
The SEOS Waveguide Project
Erich H is offline
post #816 of 12740 Old 12-23-2010, 09:03 AM
coctostan's Avatar
Liked: 142
Yes, I think Earl was a little off in his 6.5deg value. It should have been 7.3deg because he is only referring to the half angle of the 14.6deg conical opening.
Jzagaja, if there is no way to manufacture a waveguide that starts at the green arrow from my prior drawing I think we have a real issue.
Maybe I'm misinterpreting what you are saying. Are proposing that the conical section is cut off after manufacturing? If so, that would be fine so long as the throat matches the 1" exit of the drivers.
coctostan is offline
post #817 of 12740 Old 12-23-2010, 09:06 AM
coctostan's Avatar
Liked: 142
I don't think so. I understand that the CD exit is conical and that ideally it would be an OS profile but that is not a possibility right now. Since we have to deal with off the shelf parts we want to transition as smoothly and as soon as possible from the conical CD exit angle to the OS profile. Extending the conical portion of the CD into the WG is not a good thing.
post #818 of 12740 Old 12-23-2010, 09:17 AM
coctostan's Avatar
Liked: 142
The idea behind starting the WG throat and OS profile where the tangent angle equals the exit angle is to minimize the throat diffraction. It is the core concept behind the OS. Transitioning at this point is the smoothest possible transition point from conical to OS.
Make sense?
I agree that would make for the ideal CD exit. Basically start the OS profile in the phase plug. Even "more ideal" would be to make it ellipitical. Do you guys have the means to prototype this? If so, PM me offline when you get a chance.
I just want to make sure my posts don't make it seem like I'm knocking Jzagaja. I think what he is doing is great and he is very capable. I simply want to make sure there isn't a deficiency in the design that is avoidable. J, please keep up the good work.
Max
post #819 of 12740 Old 12-23-2010, 09:42 AM
jzagaja's Avatar
It will start - this extension is only technological step required for different drivers with slightly different throat diameter. Without it every horn is useless.
jzagaja is offline
post #820 of 12740 Old 12-23-2010, 10:59 AM
coctostan's Avatar
Liked: 142
Are you saying the conical section is there to help match up to variances in the CD exit diameters?
post #821 of 12740 Old 12-23-2010, 01:13 PM
jzagaja's Avatar
Yes it takes into account material shrinkage, mold wearing, throat diameter variations in drivers.
jzagaja is offline
post #822 of 12740 Old 12-29-2010, 10:32 PM
3AMRecords's Avatar
Bump.
I know that there are things happening with this project that are happening in the background, but I was wondering if we could hear about it.
Even if it is simple as: Yep we are still working on this.
Given that it has been a week.
Max
Dual Dayton RSS390HF-4 15" Sonosub Build thread:
http://www.avsforum.com/avs-vb/showthread.php?t=1223658
"You mean, you um, you built those things?"
"Yep!" "Why?" *Power on* "Oh, that's why"
3AMRecords is offline
post #823 of 12740 Old 12-29-2010, 11:00 PM
Erich H's Avatar
Liked: 1881
I was told they might have time to start on it this week. Obviously at this time of year, things can change so I didn't want to bother them for a few days. Maybe I'll send them an e-mail tomorrow just to see how things are progressing.
Erich H is offline
post #824 of 12740 Old 12-30-2010, 09:05 AM
3AMRecords's Avatar
I knew that we were waiting on this part, and obviously this time of year is hectic on everyone. I just wanted to keep everyone posted and up to date with this.
Max
post #825 of 12740 Old 12-30-2010, 10:45 AM
Erich H's Avatar
Liked: 1881
I got an e-mail from them letting me know that they're currently working on it. So it's a little ahead of schedule.
Erich H is offline
post #826 of 12740 Old 12-30-2010, 03:51 PM
jzagaja's Avatar
We can start think on another OS-18, SEOS-10, JMLC-OS-18...
jzagaja is offline
post #827 of 12740 Old 12-30-2010, 04:23 PM
bwaslo's Avatar
Quoted: 68 Post(s)
Liked: 188
I vote for a SEOS-18 90x45...
___________________________________________
DIY Synergy horn spreadsheet Synergy horn spreadsheet and pdf
XSim -free crossover designer and simulator XSim install file
Easy and cheap sound diffusers (the "Depot Diffusers") making easy DIY depot sound diffuser-panels-step by step.html
SmallSyns - point source controlled directivity in a manageable size SmallSyns
bwaslo is offline
post #828 of 12740 Old 12-30-2010, 04:39 PM
Erich H's Avatar
Liked: 1881
Earlier I thought the SEOS-10 might be a neat idea. I sent an e-mail this morning letting him know. The SEOS-12 is probably too close to the 15, so dropping down to a 10" might not be bad.
But I'm wondering if it would make sense to get testing done on the SEOS-15 first? I'm going to be sending that prototype to Zilch.
Heck if you have the machinery to do the 10" right now, and if it keeps prototype pricing down because you're doing similar designs at the same time, I'm in. I'll e-mail you later.
I think anything over a 15" baffle mount might be a tough sell. Maybe an OS-15? Not sure it's a big enough jump over the OS-12 though.
Erich H is offline
post #829 of 12740 Old 12-31-2010, 04:18 AM
penngray's Avatar
Liked: 47
2 votes now for that one.
No doubt the larger choice is not popular with this crowd and its not going to be a mass market purchase but I still want one. Its what I want in my 2011 HT re-do.
penngray is offline
post #830 of 12740 Old 12-31-2010, 07:38 AM
3AMRecords's Avatar
I am not size restricted at all, though 18 would be overkill for my room. (But who here isn't about overkill?)
I would be very interested in the 18 size, though I do agree and I think we need to measure the one that we are working on now first.
Max
post #831 of 12740 Old 12-31-2010, 07:41 AM
penngray's Avatar
Liked: 47
Eric, will have to answer it all but if they are offering a second choice for some great value then its not a bad idea to get 2 instead of 1 now. Donig one later might cost more money.
penngray is offline
post #832 of 12740 Old 12-31-2010, 10:56 AM
noah katz's Avatar
Quoted: 1032 Post(s)
Liked: 364
I think the SEOS-12 is the sweet spott.
As Geddes says about his own designs, the 12" is very close in performance to the 15" at half the box size and cost, but a significant step up in performance over the 10".
Noah
noah katz is online now
post #833 of 12740 Old 12-31-2010, 12:53 PM
3AMRecords's Avatar
This actually might be a great idea for people looking to do Surrounds in the same type of format. if the space/cost/time is right.
Max
post #834 of 12740 Old 01-01-2011, 01:10 PM
Quoted: 995 Post(s)
Liked: 522
He's talking primarily about the woofer with those comments, though, IIRC. He was also talking about doing a speaker with a 15" WG and a 12" woofer.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #835 of 12740 Old 01-01-2011, 05:56 PM
penngray's Avatar
Liked: 47
Geddes has commented several times that smaller waveguides are not as good as the larger ones. He likes to Crossover below 1KHz and he likes directivity down that low, a 10" OS waveguide gives him neither.
Im one of those that thinks larger woofers are not the best SQ choices above 1KHz. Maybe matching a 6.5" pure mid range with a smaller waveguide will work but listening to 10", 12 and 15" woofers above 1kHz has me wondering if they are as good as pure mid range smaller choices. I have some higher quality choices too so its not a question of driver choice.
I remember a discussion on DIyAudio about the size of the piston dictate the hypothetical limits where it performs the best. There was a formula used too but I can not find it right now.
penngray is offline
post #836 of 12740 Old 01-01-2011, 09:10 PM
NEO Dan's Avatar
Hi Penn,
Generally speaking the directivity control of the woofer narrows or begins beaming as the wavelength approaches the piston diameter, hence bigger woofers beam at lower frequency's than the smaller woofers. This is not taking into account cone breakup that can also limit a woofer's useful upper limit. Cone breakup is usually used to extend the response of a woofer, kind of a trick if you will. One must be careful when looking at data sheets; a "nice extended response" on a big pro driver is most commonly a byproduct of the cone breakup, it is distortion. Look for ripples in the electrical phase and impedance, also note that paper cones with the circular ribs are specifically engineered to use the breakup to extend the response.
Dan
NEO Dan is offline
post #837 of 12740 Old 01-01-2011, 10:46 PM - Thread Starter
LTD02's Avatar
Quoted: 2497 Post(s)
Liked: 2830
tad makes some of the best cd's on the market.
when they went for an application to maximize their potential, what did they choose?
td-tsm2.
after all the research in harman/jbl, they ended up with something quite close in design.
jbl-k2.
i'm not going to say that noah isn't right with respect to popularity...there, small will always win. when it comes to performance though...the 18" ~45x90 is what many smart folks have arrived at as close to optimal as possible.
Listen. It's All Good.
LTD02 is offline
post #838 of 12740 Old 01-02-2011, 08:51 AM
Erich H's Avatar
Liked: 1881
Won't be too long from now for the prototype to be completed. They want to make sure everything is cured and stabilized. The company does great work, so these should look really nice.
By the way, I'm going to try and set up a way to get all those past "Group Buys" from other websites into one package to be shipped here from Poland. That shipment won't contain these WG's, but any of the other ones they offer. Like the Iwata-300! Even the empty "mummie" cabinets.
Shipping is going to stink no matter how you slice it, but a full pallet should hopefully knock that down a bit per item. I'll drive up to Chicago to pick up the pallet, then ship each piece out. Yes, it's a long drive, but I'm still going to do it. I'll give more info on all this later.
Erich H is offline
post #839 of 12740 Old 01-02-2011, 10:55 AM
bwaslo's Avatar
Quoted: 68 Post(s)
Liked: 188
I hope this isn't going too far off the current path of this thread, but does anyone know how to progress from a styrofoam form to a usable waveguide? It occurs to me that it shouldn't be too difficult to make a series of thin elliptical shaped sheets of styrofoam, stack them, and smooth down the edges to make a form for the inside of a waveguide. (I haven't actually tried this, but it seems like that part should be pretty straightforward).
The next step isn't so straightforward, though. I'd need to make the template able to withstand the temperature and chemical effects of molding an actual guide from it. Is there something that could be used to coat it to seal, smooth, and vapor proof it? Maybe white glue? I know that a lot of chemicals turn styro into goo.
Or maybe there would have to be more steps -- make a guide in plaster from the stryo, then make another template (using ??) from the plaster guide, then fabricate from there? Any molding experts out there, or does anyone know any good books on the subject.
Yes, this is toward making an 18 or 20" EOS waveguide, if I get time to try.
bwaslo is offline
post #840 of 12740 Old 01-02-2011, 09:35 PM
noah katz's Avatar
Liked: 364
No, he was comparing the Abbey and Summa.
It's not always that bad.
If the cone profile is curvilinear and the material well damped, the high freq response isn't output from the uncontrolled breakup areas but from the center of the cone decoupling from the outer portion.
This reduces the effective mass being driven and widens dispersion.
Noah
