Hey guys...we need a little rallying here... - Page 325 - AVS Forum | Home Theater Discussions And Reviews
 880Likes
post #9721 of 12720 Old 03-23-2014, 09:52 AM
mobeer4don's Avatar
Quoted: 122 Post(s)
Liked: 115
Will you be using a subwoofer? Most of them don't go deep enough, in my opinion, for true full-range use.
mobeer4don is offline
post #9722 of 12720 Old 03-23-2014, 10:06 AM
tuxedocivic's Avatar
Quoted: 1907 Post(s)
Liked: 1725
Agreed with both of the above and would add that none of the designs as far as know give consideration to impedance which may affect valves. However I know little about that. Someone should do a design for tubes.
Ryan
tuxedocivic is offline
post #9723 of 12720 Old 03-23-2014, 11:45 AM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 201
Tubes prefer somewhat flat resistive impedance curves. Unlike resistive loads, capacitive loads will sound much different driven with a SS or tube amp.
Here's an example of a tube friendly high efficiency speaker: http://www.salksound.com/pharos%20high-efficiency%20-%20home.htm
Face2 is offline
post #9724 of 12720 Old 03-23-2014, 12:00 PM
blah450's Avatar
Quoted: 138 Post(s)
Liked: 169
Originally Posted by Erich H View Post
Here's a design currently being worked on. The woofers shown in the photo are not the ones that will be used. I just put them in to see what rear mounting the woofers looked like and how hard they were to install. In the end, I chose to front mount the woofers that will be used. This is a SEOS-15, DNA-360, with dual 8" woofers underneath. The box is 18" tall and I think 21" wide. Depth might get shallower than the photo, not sure yet. Also not 100% sure on the side slot ports yet.
I wanted to do a design like this so that someone could use the same exact speaker for left, right, and center without them being too tall. With an 18" height, it should please a lot of people.
Erich...what might be some notable sonic differences between this and the 1099? (If this has been answered previously, I apologize in advance)...biggrin.gif
blah450 is offline
post #9725 of 12720 Old 03-23-2014, 12:38 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
9k. ... so we could build it for 1.5k:sly:
chalugadp is offline
post #9726 of 12720 Old 03-23-2014, 02:05 PM
Anthony_Gomez's Avatar
Quoted: 61 Post(s)
Liked: 184
I'm sure that when it comes down to the details, they probably sound a bit different. Different woofer, different CD (I think), different WG, different XO frequency. If the designer is the same, they might sound related, but I wouldn't go mixing and matching this with the 1099. Just my gut feeling.
Anthony_Gomez is offline
post #9727 of 12720 Old 03-23-2014, 06:08 PM
chrapladm's Avatar
Quoted: 823 Post(s)
Liked: 286
Well this design, sort of, will be my center channel in a few months. Love the look of it and cant wait to build one. Although my parts will all be different at least it will look very similar. biggrin.gif
chrapladm is online now
post #9728 of 12720 Old 03-23-2014, 06:52 PM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1769
I wish I could tell you the difference, but I haven't heard them yet. Sorry.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #9729 of 12720 Old 03-23-2014, 07:21 PM
blah450's Avatar
Quoted: 138 Post(s)
Liked: 169
^^^^^^^^No problem. I ordered one anyway...going to 13029...check was sent yesterday.
Will you notify those who have ordered the 1099 when the cut sheet for the enclosure is available?
blah450 is offline
post #9730 of 12720 Old 03-24-2014, 12:02 PM
maxcooper's Avatar
Quoted: 13 Post(s)
Has there ever been any interest in SEOS cut-out templates? If someone wanted to use different material for their baffle, maybe it would just be simpler to buy Erich's baffle and use it as a template?
It is pretty easy to make your own template:
I followed this procedure:
http://www.exquisiteaudio.com/baffle.html
...in my SEOS center build thread:
http://www.avsforum.com/t/1440924/seos-15-dna-360-ae-td15m-center-channel#post_22756505
The template was easy to make, and it came out perfect.
-Max
robotbunny likes this.
maxcooper is offline
post #9731 of 12720 Old 03-24-2014, 04:31 PM
robotbunny's Avatar
Easy indeed. I followed the same guideline to make the template for my SEOS AT1 baffle. It took longer to protect the fiberglass waveguide with tape than it did to route the template. It's perfect.
-Nate
robotbunny is offline
post #9732 of 12720 Old 03-25-2014, 09:19 AM
Noman74656's Avatar
Quoted: 69 Post(s)
Liked: 98
I was wondering the same thing. Luckily I have save up some $$$ for a while before I decide so I have plenty of time smile.gif and I have to sell my mirages. I'm so excited about all the interesting choices!
"In nature there are neither rewards nor punishments; there are consequences."Robert Green Ingersoll
Noman74656's Martycube Builds
My Theater
Noman74656 is offline
post #9733 of 12720 Old 03-25-2014, 08:14 PM
d_c
d_c's Avatar
Quoted: 821 Post(s)
Liked: 870
Can I smooth the edges of the SEOS12 to my baffle for a seamless transition? I would use shave a 1/8" deep, 1/4" wide channel around the outside edge and fill the transition to the baffle with resin, fiberglass mat, and bondo. Or does the lip meeting the baffle serve a purpose? I'm building Bwalso's TD12m/dna360 design.
d_c is offline
post #9734 of 12720 Old 03-25-2014, 08:31 PM
Liked: 1725
I plan on doing that d_c. No problem. Maybe you can help me. Does it need fiberglass or will bondo do the trick? Also, how do you plan to finish it? I was gonna find a plastic primer of some kind and spray acrilyc paint with some polyurethane and floetrol mixed in. The poly for toughness and the floetrol to extend the open time a bit. Do you know of a primer that'll work? I have both matte and gloss SEOS to pick from. What ever will accept a finish best. Otherwise I'll just go with matte and not blend them to the baffle.
Glad to hear someone else doing this. I thought it would be more popular!
Ryan
post #9735 of 12720 Old 03-25-2014, 09:04 PM
Quoted: 61 Post(s)
Liked: 184
If you flushmount the SEOS waveguide, you will technically shift the phase of one driver relative to the other. Also, not sure if it matters, but change the diffraction patter a little (probably for the better)
post #9736 of 12720 Old 03-25-2014, 09:35 PM
Liked: 1725
You're right except all the designs already flush the waveguide. So there shouldn't be any phase shift. And the diffraction will be the same if the design is already flushed. D_c might be doing his own design too. I'm doing my own so if there's any diffraction change it won't matter.
Ryan
post #9737 of 12720 Old 03-25-2014, 11:53 PM
scotthulbs's Avatar
Originally Posted by scotsman8 View Post
Any word when the Alpha 8 center is going to be on the site?
Wondering that myself
scotthulbs is offline
post #9738 of 12720 Old 03-26-2014, 08:00 PM
d_c
d_c's Avatar
Quoted: 821 Post(s)
Liked: 870
I'm building the td12m and SEOS12/dna360 with Bill's xo. I will start with an automotive primer over the baffle with attached wg, fill the gap between the baffle and wg with bondo, use a thin strip of glass mat and resin between the two, smooth with bondo, again with the automotive primer, shoot with a charcoal with micro flake automotive paint. Wet sand and finish with a clear coat.
d_c is offline
post #9739 of 12720 Old 03-26-2014, 08:53 PM
dcgold2000's Avatar
Pics?
dcgold2000 is offline
post #9740 of 12720 Old 03-26-2014, 09:09 PM
Liked: 1725
Auto primer eh. Hmmm. I'll have to see if I can find some. It'll stick to plastic?
I assume the glass fibre is to prevent cracking in the bondo? Like tape in a drywall seam?
Ryan
post #9741 of 12720 Old 03-26-2014, 09:57 PM
d_c
d_c's Avatar
Quoted: 821 Post(s)
Liked: 870
I think it should stick. I'll test it on the back of the wg first, and my thought exactly with the seam.
No build pics yet. Still planning. But here is one from AE of my drivers on the table.
And the other goodies waiting
d_c is offline
post #9742 of 12720 Old 03-26-2014, 10:03 PM
Liked: 1725
Hmm, that seems like a lot of effort. I am still up in the air about it. I wonder if I'd be making a mistake to not do that. I haven't had bondo crack on me before, but I don't have much experience either.
Ryan
post #9743 of 12720 Old 03-26-2014, 10:19 PM
d_c
d_c's Avatar
Quoted: 821 Post(s)
Liked: 870
I could be over thinking it. Bondo would probably be enough. If I stall my build long enough, somebody else might find out first wink.gif
d_c is offline
post #9744 of 12720 Old 03-26-2014, 10:26 PM
Fattykidd's Avatar
Quoted: 488 Post(s)
Liked: 396
See if you can find a can of poly olefin adhesion promoter and some grey scotch brite it should help ensure adhesion of your primer to the plastic waveguide.
Speakers- Elusive 1099 x3, Diysg Volt 6 x8, Mach 5/Ist Uxl18 x4 (Submaximus v3 x2 & 2 Sealed nearfield)
Processing- Marantz 7702 mk2, Minidsp ddrc88a x2
Amplification- Crown Dsi1000 x2, Crown Ct875, Behringer Inuke6000dsp x3
Sources- Samsung k8500, Ps4, Odroid c2, Xbox 360
Display- Epson 5030, 138" Diy spandex Screen
Fattykidd is online now
post #9745 of 12720 Old 03-29-2014, 08:36 AM
Noman74656's Avatar
Quoted: 69 Post(s)
Liked: 98
Something like this looks like it would be excellent for sitting on top of dual subs up front and have the waveguide right at ear height. Very intriguing.
My Theater
post #9746 of 12720 Old 03-29-2014, 12:14 PM
Jeff Bagby's Avatar
Liked: 46
That's a cool look! Very "cinema" IMO. Any polars or other technical data? XO frequency? Sensitivity? I assume ports are tuned for f3 around 80hz. Who designed the crossover?
Hi. I don't follow this board closely. It moves quickly on me and there are sooooo many posts, that it makes it hard.
I designed the crossover for the speaker Erich pictured. I have completed it and am almost finished with two designs using the EOS-8 and same woofers. The crossover point with the dual 8's and the SEOS15 is at about 1000 Hz. Sensitivity is about 98 dB. The speaker is good to 60 Hz.
Jeff B.
dwaleke likes this.
Jeff Bagby is offline
post #9747 of 12720 Old 03-29-2014, 12:18 PM
Jeff Bagby's Avatar
Liked: 46
Originally Posted by lemans24 View Post
Excellent!! First center that would work well with fusion-15. Don't like the side ports though. Would look really good without those ports and slightly deeper for f3 of 80hz??
Looks good, now when will these be available with flat packs and assembled crossovers?? Lol
The ports are on the side to reduce the overall height, which is something people have been asking for. The speaker's bass extends to about 60Hz. The crossover is complete, it should be available very soon.
Jeff
dwaleke likes this.
post #9748 of 12720 Old 03-29-2014, 12:24 PM
chalugadp's Avatar
Liked: 1505
Jeff
Can you compare at all the difference in sound with this dual 8 vs your tempests ?
I also want to say a big thanks Jeff for all your work you do. I have the fusion mtm center and it sounds great, better then my previous centre channel which was three times more expensive commerncially. smile.gif
post #9749 of 12720 Old 03-29-2014, 12:29 PM
Jeff Bagby's Avatar
Liked: 46
What 8" drivers will you be using?? The same eminence ones in the fusion-8 or another brand entirely??
Erich can comment further if he wants, but I am working with a proprietary 8" that will only be available through diysoundgroup.
Jeff
post #9750 of 12720 Old 03-29-2014, 12:29 PM
Liked: 1725
Jeff, any off axis measurements? And what XO slopes? I did side by side 5" mids and found the off axis totally unusable above 2khz. Wondering about the 8" and 1000hz. Where did things get hairy?
Ryan
