Hey guys...we need a little rallying here... - Page 355 - AVS Forum | Home Theater Discussions And Reviews
 901Likes
post #10621 of 12740 Old 07-06-2014, 02:48 PM
cuzed2's Avatar
Quoted: 200 Post(s)
Liked: 256
Originally Posted by tential View Post
This is the same story every time I've heard the Klipsch brought up, and since I orignally was shopping the Klipsch Reference Series vs the SEOS I specifically have looked for those comparisons.
The best way I've been able to sum up comparisons after looking at them for so long is that once you build an SEOS build you won't look back at most commercial brands.
My Klipsch - vs - SEOS 2 cents worth:
I was quite pleased with my budget RF35s.
Then fired up my SEOS12's with Deltalight 2512s :
  • Nice rich "mid-low range", drums etc..
  • and the biggest PLUS: Having them toed-in to the recommended 45 degrees resulted in a very wide sweet spot for all 4 front row seats (~8 away from my mains)
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #10622 of 12740 Old 07-07-2014, 12:04 PM
realtight's Avatar
Quoted: 31 Post(s)
Liked: 77
I'll throw in my two cents worth as well. I've compared my Seos Tempests to my father's Klipsch Forte II's which I think were the last truly great Klipsch speaker made - nothing has even come close to it in quality since. That being said, I feel the Seos is the clear winner from 80hz and up. I'm usually not a horn person in general and think most Klipsch sound extremely harsh and also have a "honky" type sound which none of the Seo's design's I've heard have. From 80hz down the Forte is the winner with more bass then the Tempest. I'm not sure if this is because the Eminence driver needed more breaking in or not but it didn't compete at all in that department.
Listening to music, the Forte became fatiguing very quickly with some music due to the honky/bright highs - the Tempests do not. The Tempests sound great with all types of music where as the Forte's really only shined with a rock/jazz type sound.
For movies it's the same old dance, both speakers are very dynamic and sound great but the Forte's simply hurt leaving me tired and fatigued after too long. The Tempest seem to have more mid bass kick then the Forte's and might be a tad cleaner as well.
Overall both speakers are great but the Seos Tempest wins in all categories except deep bass. I don't think either speaker excels in the midrange though both are still very good.
saginawjuggalo likes this.
realtight is offline
post #10623 of 12740 Old 07-07-2014, 12:48 PM
Erich H's Avatar
Quoted: 1491 Post(s)
Liked: 1901
The Tempest aren't meant for full range and were designed to be used with a subwoofer. They were tuned to give more midbass than the lower bass provided by your subwoofer.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #10624 of 12740 Old 07-07-2014, 11:02 PM
SpinMonster's Avatar
Quoted: 269 Post(s)
Liked: 112
Originally Posted by dlipter View Post
Question: How well do the SEOS kits like the Fusion series do with recreating sound stage depth?
Years ago I recall BMW 801 Matrix speakers doing a spectacular job of creating a deep layered sound stage with orchestral music.
The interesting thing about them is the depth seems dipole-like. Width isn't anything staggering but that's controlled by moving the speakers apart.
Controlled directivity speakers when toed in to cross in front of the listener gets rid of anything that would have hit the side walls and actually can have more reflected off the rear wall. If the speakers are more than 4' from the rear walls, they can have the delayed rear reflection that increases depth. That is how I hear it. I have owned the Apogee stage which had depth mastered. It appears I have that characteristic as good as I had it before.
I doubt you will find a bad SEOS design. If you can fit the 12" then you have several great designs to choose from. I built a SEOS10/BMS 4550 with a TD10M. I'm loving life.
SpinMonster is offline
post #10625 of 12740 Old 07-08-2014, 06:16 AM
dlipter's Avatar
What is dipole-like depth?
dlipter is offline
post #10626 of 12740 Old 07-08-2014, 06:37 AM
realtight's Avatar
Quoted: 31 Post(s)
Liked: 77
I'm definitely aware of this but I thought it was a valid test to run them both full range considering all the reviews stating how much bass they have. Like you and many said, they need a subwoofer to really fill in the lower frequencies.
post #10627 of 12740 Old 07-08-2014, 07:49 AM
Quoted: 269 Post(s)
Liked: 112
Dipoles reflect 1/2 the radiated sound off the rear wall exaggerating depth of image.
post #10628 of 12740 Old 07-09-2014, 09:58 PM
chalugadp's Avatar
Quoted: 1674 Post(s)
Liked: 1532
Hey,
I have had a 5.2 system for quite awhile.. Never had the space/ desire to go to 7.2.
The only spot I could place the back surrounds would be 1-2' behind me and 4' above me. If I put the volt 10 up there would it be a decent spot. I can't put them any lower. I don't want to buy another amp and speakers if its such a poor spot.
I'm posting here cuz I like the crowd
chalugadp is offline
post #10629 of 12740 Old 07-10-2014, 04:07 PM
Ross Kirshner's Avatar
Quoted: 23 Post(s)
Which of these 4 would lend to a better front stage?
3 tux 1099
2 tux 1099, + Cinema 88 Special - for center channel
3 Cinema 88s
2 fusion tempest + Cinema 88 Special - for center channel
in all scenarios it would probably be crossed at 80hz so below that is not really an issue
I didn't pick the fusion 15 because I don't think i need a 15inch woofer if I have 2 martycubes
Ross Kirshner is offline
post #10630 of 12740 Old 07-10-2014, 04:15 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
I don't think anyone has been able to compare any of those models to each other especially with the 88 and 1099 being relatively new. The 15" woofer in the fusion is targeting a different range of frequencies than your Marty cubes, more midbass.
gpmbc is offline
post #10631 of 12740 Old 07-10-2014, 04:24 PM
lemans24's Avatar
Quoted: 20 Post(s)
Liked: 41
3 tux 1099
3 Cinema 88s
Definitely would pick fusion 15 because of the killer midbass from 50hz -150hz even with 2 Martycubes!! You really need to listen to a system with killer mid-bass like the tempest speakers. Bass on lfe only goes to max of 120hz. You can have full range mid-bass on LR channel from 50hz up which the lfe channel only partially passes thru. A good full range speaker should have great midbass.
lemans24 is offline
post #10632 of 12740 Old 07-10-2014, 04:45 PM
chalugadp's Avatar
Liked: 1532
3 tux 1099
3 Cinema 88s
I'm ordering the cinema 88 for my new center channel tomorrow. I want the best possible dialogue for movies coming through the center channel and I think the seos 15 gives that possibility.
for fronts I am waiting until after gtg to make a decision. I want my fronts to be great for music too. some want all three to be the same.
it depends upon what you want out of your front stage.
post #10633 of 12740 Old 07-10-2014, 04:55 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1995
I would think any speaker using the SEOS-15 waveguide would make an excellent front speaker and should give a larger soundstage.
jbrown15 is offline
post #10634 of 12740 Old 07-10-2014, 04:56 PM
WereWolf84's Avatar
Quoted: 297 Post(s)
Liked: 113
How much improvement in mid bass the Fusion-15 Sentinel has over the Fusion-12 Tempest?
WereWolf84 is offline
post #10635 of 12740 Old 07-10-2014, 05:12 PM
Quoted: 23 Post(s)
Thats why i thought the cinema 88 would be great for a center channel, its also 98.5 efficient, so its not that far behind the 1099 (which is in stock btw at this time), I'm sure it would be a great LCR but I wonder if it would be better to have something else for left and right,
post #10636 of 12740 Old 07-10-2014, 05:17 PM
chalugadp's Avatar
Liked: 1532
For what you have described I think fusion 12 or 1099 would be best for left and right. The cubes give great midbass up to 120 hz. From 120hz and up I don't think sentinel is much better then the others. All of them are good. Really splitting hairs without hearing them.
post #10637 of 12740 Old 07-10-2014, 05:43 PM
lemans24's Avatar
Quoted: 20 Post(s)
Liked: 41
The fusion-15 will be at $100 more per speaker and I think it will have a little more mid-bass, lower distortion and wider soundstage from the 15" waveguide.
If I was getting the 88 special for center then the fusion-15 would make the best LR...
lemans24 is offline
post #10638 of 12740 Old 07-10-2014, 05:51 PM
chalugadp's Avatar
Liked: 1532
you got that sub up and running yet
post #10639 of 12740 Old 07-10-2014, 05:55 PM
HopefulFred's Avatar
Quoted: 522 Post(s)
Liked: 484
3 tux 1099
3 Cinema 88s
I think this question is over-thinking the situation. The best practices for selecting speakers hasn't changed, and Erich's advice is still good. Three matching is best, and when choosing SEOS speakers, choose based on size and budget.
So, I can't compare the Cinema 88 Special directly to the 1099 (and I don't think anyone can at this point). If I were picking three to go with an acoustically transparent screen, I'd go with the 1099s. If I needed to fit them around a display, I'd go with the 88s and be glad to save the money. If the 88 is still too tall to fit around the display, then I'd go with two vertical 1099s and one horizontal. Three tempests would be great as well, but unless the price difference is important compared to the 1099, I bet you can fit the 1099 in pretty much any place that you can fit the tempest.
HopefulFred is online now
post #10640 of 12740 Old 07-10-2014, 06:02 PM
Quoted: 23 Post(s)
what was his advice? also any updates on the new fusion 15?
post #10641 of 12740 Old 07-10-2014, 06:13 PM
chalugadp's Avatar
Liked: 1532
I have never really understood the three matching for front stage. I have most of the time had different speakers ( still in the same product line.) And I very rarely hear any differences. If cinema 88 is better then tempest for dialogue ( as first two who have cinema 88,with tempests feel) which it should be with larger seos and lower xo. I would be more concerned with my center channel having great voices coming out of it.
I have minions as fronts and fusion mtm as center and I can't hear timbre difference in panning scenes. I don't have golden ear so if someone does I can see why you would want all three the same.
post #10642 of 12740 Old 07-10-2014, 06:19 PM
JohnDean's Avatar
Quoted: 470 Post(s)
Liked: 207
Can someone explain to me how an eq'd flat 15 has more midbass than an eq'd flat 12 from 80hz up?
Edit: I guess I should clarify, at the same spl.
JohnDean is offline
post #10643 of 12740 Old 07-10-2014, 06:42 PM
chalugadp's Avatar
Liked: 1532
you wouldn't think it would
post #10644 of 12740 Old 07-10-2014, 07:02 PM
Quoted: 522 Post(s)
Liked: 484
I paraphrased as "buy based on size and budget."
post #10645 of 12740 Old 07-10-2014, 07:12 PM
atabea's Avatar
Quoted: 609 Post(s)
Liked: 430
I am wondering the same thing.....The Fusion 15s that is.
atabea is online now
post #10646 of 12740 Old 07-11-2014, 04:33 AM
mobeer4don's Avatar
Quoted: 137 Post(s)
Liked: 131
They should be essentially the same assuming the EQ is applied based on actual in-room response. The 15 has more capability so, assuming your amplification is not the limiting factor, you can get higher maximum SPLs and/or lower distortion at the same SPL. Will you actually run your system at high enough SPL to clearly hear a difference? That is a good question given that you will be well into the stupid loud range before the 12 starts to run into serious distortion, compression, or other audible distress. And that is why we keep coming back to considering size/budget to select your SEOS design rather than which one is "better".
Hope that helps!
mobeer4don is offline
post #10647 of 12740 Old 07-11-2014, 05:07 AM
JohnDean's Avatar
Quoted: 470 Post(s)
Liked: 207
Hope that helps!
Yep. So what you're saying is that a 15 won't have more midbass (80-200ish hz) than a 12, but that it will have less distortion/compression at the upper spl limits. Which even most of us crazy diy fans wont even realize.
JohnDean is offline
post #10648 of 12740 Old 07-11-2014, 06:27 AM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
I agree, front stage timbre match is over-emphasized for importance IMO. It's important for SACD, DVD-A, and concert DVD/Blu-ray's though.
Bassment is offline
post #10649 of 12740 Old 07-11-2014, 06:29 AM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
From what I understand the fusion 12 is just as good as the 15 until you're hitting the max SPL's, then the 15 can take the mid bass up a few dB compared to the 12. That was the old Fusion 15 though, I'm sure the SEOS 15 is a bit better than the 12 now too.
Bassment is offline
post #10650 of 12740 Old 07-11-2014, 06:35 AM
rhodesj's Avatar
Quoted: 942 Post(s)
Liked: 533
What I want to know is which design gives the widest horizontal performance. My seating area is wide, and I'd need speakers that give good frequency response on a +-45 degree cone for all three fronts. So a horizontal 1099 is right out for the center. I'm trying to imagine a Tempest as a center above my TV. TV is a 62" DLP, so depth isn't an issue at all, but it will be pretty high up. An 88 Special would be more practical, but I don't know how the side-by-side woofers work out is the listening area is near 90 degrees wide.
rhodesj is offline
