Hey guys...we need a little rallying here... - Page 369 - AVS Forum | Home Theater Discussions And Reviews
 901Likes
post #11041 of 12740 Old 08-22-2014, 01:04 PM
pitviper33's Avatar
Quoted: 267 Post(s)
Liked: 117
Ya I tested the DNA-360 on the back of the Beta 10CX and was like, blah...
Tux are you working on your own coax design now?
pitviper33 is offline
post #11042 of 12740 Old 08-22-2014, 01:05 PM
tuxedocivic's Avatar
Quoted: 2202 Post(s)
Liked: 2078
No. Was just playing around to see what it could do. I bought a Beta 10CX to build a monitor or something and figured why not try.
tuxedocivic is online now
post #11043 of 12740 Old 08-23-2014, 04:06 PM
Erich H's Avatar
Quoted: 1494 Post(s)
Liked: 1905
I'm happy to say that the final piece of the puzzle is done and the Fusion Line is nearly complete.
Typical bad photo for all my friends here to make fun of:
This model took a while due to woofer changes, getting the correct ports, other projects, etc. But I think it will prove to be worth the wait. MTG90 did a great job on this model, spent a lot of time tweaking things, and of course put up with too many emails from me over the past 6 months.
I'll try to design a flat pack and get it cut fairly soon.
Measurements:
On Axis:
Check out the SEOS-15 showing it's off axis performance:
_______________________
The SEOS Waveguide Project
Erich H is offline
post #11044 of 12740 Old 08-23-2014, 04:46 PM
chalugadp's Avatar
Quoted: 1674 Post(s)
Liked: 1532
Matt says midrange is better then my v2 minions so it is stellar. Way to go guys. Can't wait to see a build thread for these.
chalugadp is offline
post #11045 of 12740 Old 08-23-2014, 05:04 PM
J_P_A's Avatar
Quoted: 651 Post(s)
Liked: 484
If that retail cost is correct, I may very well be the first to build a set! I can't wait for these to available!
chalugadp likes this.
The Plains Theater Has Begun
J_P_A is offline
post #11046 of 12740 Old 08-23-2014, 05:09 PM
chalugadp's Avatar
Liked: 1532
Go for it...
I love spending other peoples
post #11047 of 12740 Old 08-23-2014, 05:14 PM
J_P_A's Avatar
Quoted: 651 Post(s)
Liked: 484
Hopefully you guys will help with me with the measurements. I'll need verticals to go with those off axis plots.
How does the 15" driver compare to the 12" driver in the Fusion 12?
J_P_A is offline
post #11048 of 12740 Old 08-23-2014, 06:12 PM
Erich H's Avatar
Liked: 1905
The Deltalite is a great woofer with very low distortion. It has a curvilinear cone which was one thing I was hoping to use in the Fusion-15. The Cheap Thrills woofer cone also had that shape.
The Fusion-15 goes pretty low, but still probably shouldn't be considered full range. It could be if the box was bigger, but I figure most people building the Fusion line are guys that will be running subwoofers anyway, so the box was made smaller and tuned higher.
PE was out of Deltalites a couple weeks ago so I couldn't order one and get the pictures. Then they came in stock.....but only had 2. I grabbed those, but they only have 2 in stock again. Maybe that's all they keep in stock for that woofer. I'll have to order a larger amount than that so they get them in quicker.
J_P_A likes this.
Erich H is offline
post #11049 of 12740 Old 08-23-2014, 06:21 PM
mtg90's Avatar
Quoted: 496 Post(s)
Liked: 974
I don't have nice verticals graphs yet, just because it's a pain to setup the speaker hanging off one side of my turntable so that the center between the drivers is on the axis of rotation. +- 20 degrees vertical should still be within +-3dB.
But I'll see if I can get those soon.
J_P_A likes this.
mtg90 is offline
post #11050 of 12740 Old 08-23-2014, 07:14 PM
J_P_A's Avatar
Quoted: 651 Post(s)
Liked: 484
I see the 12" woofer is rated for a little more power. Can I still expect the same (or better) bass from the 15" woofer? I'm planning to run a sub and cross it around 80 Hz, but I still want to get that "midbass" punch.
J_P_A is offline
post #11051 of 12740 Old 08-23-2014, 07:28 PM
Erich H's Avatar
Liked: 1905
What are you going to be powering them with?
Have you ever heard a 15" pro audio woofer in your home with a few hundred watts?
Erich H is offline
post #11052 of 12740 Old 08-23-2014, 07:35 PM
J_P_A's Avatar
Quoted: 651 Post(s)
Liked: 484
Initially I'll probably run them off of an AVR, but I have a pair of Sherbourn PA 7-350 amps I'm planning to use for my theater.
And no, I've never owned a set of speakers anywhere near the quality of these. Can you tell me what I should expect? I'm hoping you'll tell me I'll be impressed
J_P_A is offline
post #11053 of 12740 Old 08-23-2014, 09:13 PM
mtg90's Avatar
Quoted: 496 Post(s)
Liked: 974
The 2515 has more displacement and higher sensitivity in bass range, meaning it can play louder and also do so with less power. You'll be well above 120dB with that Sherbourn but even a cheap AVR should drive them above reference in most rooms with plenty left in the tank. With an 80hz crossover it should survive 1000w peaks though you might want to upgrade a couple things in the crossover if using more then 400-500w.
But at that wattage you are closing in on 130dB and no one "needs" that
bg40403 likes this.
mtg90 is offline
post #11054 of 12740 Old 08-23-2014, 09:28 PM
doc5150's Avatar
Quoted: 43 Post(s)
Liked: 34
Will these go well with a cinema88 center?
doc5150 is offline
post #11055 of 12740 Old 08-23-2014, 09:30 PM
atabea's Avatar
Quoted: 609 Post(s)
Liked: 430
Matt, if you had to point out the major differences between this version of the Sentinels and the previous one, what would they be?
atabea is offline
post #11056 of 12740 Old 08-23-2014, 09:52 PM
mtg90's Avatar
Quoted: 496 Post(s)
Liked: 974
The Deltalite woofer in this one has lower distortion and I feel a better midrange though that could just be the better crossover implementation. It does not have quite the excursion or thermal dissipation capability of the B&C but for most this is a non issue.
The SEOS-15 gives a better directivity match to the woofer and allows for a lower crossover point.
Big crossover improvements across the whole range, better balance, smoother, more detailed and the improved midrange.
2.83v sensitivity is 2-3dB higher at the expense of some loss of low end extension <60 Hz.
mtg90 is offline
post #11057 of 12740 Old 08-23-2014, 10:01 PM
atabea's Avatar
Quoted: 609 Post(s)
Liked: 430
Thank you Matt, this sounds fantastic. I am especially intrigued about the substantial crossover improvements resulting in your comments about the "midrange." Since the majority of owners will likely be using at least one sub and, am sure in many cases, several subs, that "loss" in the low end will be inconsequential.
Bravo on a job well done, Matt!!
atabea is offline
post #11058 of 12740 Old 08-24-2014, 04:46 AM
J_P_A's Avatar
Quoted: 651 Post(s)
Liked: 484
I'll take three
J_P_A is offline
post #11059 of 12740 Old 08-24-2014, 05:01 AM
erwinfrombelgium's Avatar
Quoted: 446 Post(s)
Liked: 239
Same SEOS-15 and same tweeter, so I'd say very well indeed.
doc5150 likes this.
Building a 9.3.4 HT: DIYSG Titan LX [LCR] • Cinema 10 Max [6 Surrounds] • Beta 10CX custom [TF+TR] • LLT Mal-x 18" subs [2] • XPR-5 • MM8003 [8ch] • XMC-1 [RMC-1 wanted] • PT AT6000E • 130" Seymour Center XD • Oppo 103EU • WTB: 1 extra Mal-x 18" SW
erwinfrombelgium is offline
post #11060 of 12740 Old 08-24-2014, 05:20 AM
bg40403's Avatar
Location: where the appallachians rise from the bluegrass
The Eminence factory isn't that far from Dayton, OH...
AE GB $$$ sent 10-18-11; TD15M arrive 01-16-13, ...454 days
bg40403 is offline
post #11061 of 12740 Old 08-24-2014, 06:28 AM
Erich H's Avatar
Liked: 1905
Eminence is only about 1.5 hours from me. I drove my dump truck there a few years ago to pick up pallets of the old MFW-15 subwoofers for the big group buy. I think I can fit 6 pallets in the back.
Betting it was the first time they ever loaded woofers into a dump truck!
eggmansr71 likes this.
Erich H is offline
post #11062 of 12740 Old 08-24-2014, 06:59 AM
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 449
you want need that much power to get these to play LOUD
assuming the preform similar to the orig version, you wont need more than a AVR. Rillas are getting like 200 WPC and will go to deafening levels
J_P_A likes this.
Sibuna is offline
post #11063 of 12740 Old 08-24-2014, 12:14 PM
kapone's Avatar
Quoted: 260 Post(s)
Liked: 209
Erich (or anybody else, if they know) - The 3cuft box on the site lists only the measurements for two of the options, in terms of outer baffle diameter and recess. Do you happen to have the numbers for the rest of the options, handy?
  • Dayton Reference Series 15" woofer
  • Dayton Titanic 15" woofer
  • Stereo Integrity 15" woofer
  • Dayton DVC385 15" woofer (or MFW)
  • Dayton 15" Ultimax
kapone is offline
post #11064 of 12740 Old 08-24-2014, 04:55 PM
Manamb's Avatar
Quoted: 35 Post(s)
Put me down for two!!! Can we Pre-order?
Manamb is offline
post #11065 of 12740 Old 08-25-2014, 08:26 AM
J_P_A's Avatar
Quoted: 651 Post(s)
Liked: 484
As I mentioned above, I'm in for three. I'd pre-order as well if it helps. Not sure if that makes it any easier on Erich or not.
Mfusick likes this.
J_P_A is offline
post #11066 of 12740 Old 08-26-2014, 05:14 AM
kapone's Avatar
Quoted: 260 Post(s)
Liked: 209
Anybody?
kapone is offline
post #11067 of 12740 Old 08-26-2014, 05:45 AM
chrapladm's Avatar
Quoted: 945 Post(s)
Liked: 352
Are you trying to order this from Erich or know the dimensions for yourself to build a box?
chrapladm is online now
post #11068 of 12740 Old 08-26-2014, 06:27 AM
kapone's Avatar
Quoted: 260 Post(s)
Liked: 209
I will be ordering these from Erich, but the woofers I plan to use are not in that list, hence why I need the measurements. The inner baffle cutout at 14.1" is perfectly fine, it's the outer baffle cutout and recess that I need to look at.
kapone is offline
post #11069 of 12740 Old 08-26-2014, 07:55 AM
Erich H's Avatar
Liked: 1905
That question is probably best for the flat pack thread. But either way, I'm not 100% sure what the dimensions are because they are tweaked to fit the woofer listed. Best bet is to check what the manufacturer says the diameter of their woofer is.....that would be the cut out size on those boxes.
Erich H is offline
post #11070 of 12740 Old 08-26-2014, 05:26 PM
bhazard's Avatar
Quoted: 89 Post(s)
Liked: 58
My SEOS 15's from awhile ago have been aching for a new speaker to go into.
In honest opinions, would I be better keeping my TD12X custom towers, or would the new Fusion 15 provide better performance? I don't need full range, as I have two 18" subs. I could also use a little less height right now than the 40" of the towers, as I just installed a projector and the tower speaker height is keeping me from reaching "optimal" screen size.
bhazard is offline
