Hey guys...we need a little rallying here... - Page 373 - AVS Forum | Home Theater Discussions And Reviews
 901Likes
post #11161 of 12740 Old 09-16-2014, 02:38 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
I wonder how the 15" Eminense Deltalite woofer used in the Fusion-15 compares to the JBL-2226 used instead of the Eminense?
I have all of the parts to build a 2-way active version of the Fusion-15 with the JBL-2226 instead of the Eminense Deltalite.
All I need to complete this project is another iNuke1000dsp (I purchased two but one was DOA with no warranty off craigslist) and to figure out how to setup the active filters. The thing that sucks is that I am broke with barely enough money to pay my bills due to health issues, and I can not afford a mic either. Which is absolutely necessary for help with setting up the active filters, of which, I do not know how to do. (note- LTD02 has offered to help with the active crossover setup with me taking and emailing him the measurements).
So with that being said, it would be really nice to just be able to purchase the 15" Eminense Deltalite woofer, and pre-built Fusion-15 crossover. Any one care to chime in on how much I would be giving up by going with the Fusion-15 kit versus a Seos-15 + DNA-360 + JBL-2226 active setup?
Martycool007 is offline
post #11162 of 12740 Old 09-16-2014, 05:09 AM
Erich H's Avatar
Quoted: 1478 Post(s)
Liked: 1896
Have you heard any of the SEOS speakers yet?
_______________________
The SEOS Waveguide Project
Erich H is offline
post #11163 of 12740 Old 09-16-2014, 06:37 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
You won't be giving up much at all.
Mfusick is offline
post #11164 of 12740 Old 09-16-2014, 08:12 AM
tuxedocivic's Avatar
Quoted: 2193 Post(s)
Liked: 2057
You'll probably be gaining by getting a XO that's already worked out and proven.
tuxedocivic is offline
post #11165 of 12740 Old 09-16-2014, 12:35 PM
J_P_A's Avatar
Quoted: 650 Post(s)
Liked: 483
Will the preassembled Fusion-15 crossover be available soon, or should I order the Fusion-15's now to make sure I don't miss the boat?
The Plains Theater Has Begun
J_P_A is online now
post #11166 of 12740 Old 09-17-2014, 03:10 AM
Quoted: 280 Post(s)
Liked: 181
Yes, I have heard mostly all of them, and yes, I really like the way they sound, and although I can't recall which Seos design uses the Eminense DeltaLite woofer, I was pretty impressed with all of them.
post #11167 of 12740 Old 09-17-2014, 03:23 AM
Quoted: 280 Post(s)
Liked: 181
I just really hate to sell my JBL-2226's as I have doubts that the 15" Eminense Deltalite would be in the same performance category as the 2226, although, I could be wrong. Which is why I want some outside opinions.
If I sell my 2226's for say, $165 each, that would net me $230, and I would also save $200 by not having to buy an additional iNuke1000dsp, and another $100 on the mic. That is a total of $530.
I already have the Seos-15's and DNA-360's, so all that is needed would be the 15" Deltalite's ($175ea x2=$350) , the crossover parts ($60 x 2=$120) the baffles ($18ea x2=$36) terminal cups ($10 ea x2-=$20) wood, glue, and wire (=$100).
That all comes out to over $600 for the pair. Plus, I already have the wood cut for my original design with the 2226 in a tower style enclosure.
I originally assumed that if I sold my JBL-2226's I could build the Fusion-15's cheaper, but once I did some investigating, it appears that was not the case, as it would save me over $100 by sticking to what I originally intended! Oh well!
post #11168 of 12740 Old 09-17-2014, 02:22 PM - Thread Starter
LTD02's Avatar
Quoted: 2527 Post(s)
Liked: 2869
Has Matt posted a distortion measurement for the Fusion 15 yet?
Listen. It's All Good.
LTD02 is offline
post #11169 of 12740 Old 09-17-2014, 02:45 PM
clausdk's Avatar
Quoted: 214 Post(s)
Liked: 82
I've only seen the 2 graphs postet on DIYSG none of which show distortion.
clausdk is offline
post #11170 of 12740 Old 09-17-2014, 03:05 PM - Thread Starter
LTD02's Avatar
Liked: 2869
found this one, open baffle, 1 meter. not the best circumstances, but the measurement looks pretty good.
http://www.diyaudio.com/forums/subwo...s-horn-30.html
LTD02 is offline
post #11171 of 12740 Old 09-17-2014, 04:18 PM
mtg90's Avatar
Quoted: 478 Post(s)
Liked: 944
Measured at 2m, levels set to 90dB (same voltage between the two designs, they also share the same HF network)
Karma-15, Eminence CA15-4:
Fusion-15 Eminence Deltalite 2515:
mtg90 is offline
post #11172 of 12740 Old 09-17-2014, 04:25 PM
chrapladm's Avatar
Quoted: 938 Post(s)
Liked: 350
Wow distortion went down. Awesome build MTG. Will we be seeing some more videos of these on youtube.
chrapladm is offline
post #11173 of 12740 Old 09-17-2014, 04:32 PM
EarlK's Avatar
Quoted: 29 Post(s)
Liked: 25
I guess the distortion "hump" ( centered between 1K to 2K / common to both pics & @ 40db down ), is the Denovo 360 ?
EarlK is offline
post #11174 of 12740 Old 09-17-2014, 07:44 PM - Thread Starter
LTD02's Avatar
Liked: 2869
about -60db @1m 3rd through most of the woofer's passband. surprisingly good.
LTD02 is offline
post #11175 of 12740 Old 09-17-2014, 07:56 PM
Eternal Velocity's Avatar
Quoted: 33 Post(s)
Liked: 63
It seems to match the DNA360's distortion profile, yes.
Eternal Velocity is offline
post #11176 of 12740 Old 09-17-2014, 08:12 PM
Erich H's Avatar
Liked: 1896
That particular compression driver has been through a lot and opened/closed quite a few times so we knew it had some extra distortion in it because of that. It was okay on previous tests.
When MTG90 was here for the Parts Express Audio Fest a few months ago we opened the compression driver a couple times and when put it back together we heard some distortion while listening to the speaker prior to those tests. We were going to open it back up to make sure it was straight or put in a different diaphragm.....but forgot before he left. I told him I'd just send him a new one and a second diaphragm once the new batch came in. That's why the charts hadn't been posted yet.
Sometimes if the back plate is opened up and put back together you can get something around the voice coil, or even have things not line up right, or screws not torqued the same, etc. That's why I make sure to test all of them before shipping.
Back when Zilch was working with waveguides and compression drivers he opened up some different models and when put back together had the same thing happen. So he just opened them back up, removed the diaphragm, put it back in, tighten the screws and all was fine. It's not uncommon, but most that use CD's don't normally open them up.
Erich H is offline
post #11177 of 12740 Old 09-17-2014, 08:43 PM - Thread Starter
LTD02's Avatar
Liked: 2869
also, keep in mind it is a 2 meter measurement, which drops spl by 6db. distortion scales pretty well with spl, so for a 1 m equivalent, "eyeball" distortion about 6db lower than in the picture, so even the peak of that 'hump' is about -45db or less than 1% distortion.
LTD02 is offline
post #11178 of 12740 Old 09-18-2014, 06:50 AM
EarlK's Avatar
Quoted: 29 Post(s)
Liked: 25
Thanks for that confirmation .
That jives quite well with my experiences for all the older generation of B&C drivers ( ie de25 , de900, etc. etc. ) .
cheers <> EarlK
EarlK is offline
post #11179 of 12740 Old 09-18-2014, 11:39 AM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 781
DIY logos
Were these ever made?
I'd like to order 3 DIY Soundgroup logos for my subwoofers and 5 SEOS logos for my Fusion-8's
Or, if there is a 3D CAD file post it and possibly at my W I can have them printed for me.
Quote: Originally Posted by brianjb
We would have to come up with different pledge levels and things like that. I've already sent the SEOS logo to a company to price out some metal emblems made of cooper but finished in an antique silver to keep the glare down. I thought about brushed aluminum or stainless steel, but that might be too shiny. If there are any thoughts on that, let me know because nothing is set in stone yet. I'll have to figure out shipping for international orders and how to go about filling those. I've already sent in drawings to get prices on each waveguide size. They're pretty reasonable.
Kudos on those logos!
I've got a 3 cu ft sub box Saturday for 15" SI D2, and soon a 2.25 cu ft sub box for my 12" Ultimate.
Any chance on having a small production run on them so we can proudly insert them into our boxes?
I'd take 2 of the "DIY Sound Group"....Brand marketing 101 stuff, nice to see.
Quote: Originally Posted by cuzed2
So last week, I mentioned some Beta-logos my son made on a 3D printer.
I made a template to allow me to route some recesses for mounting the logos
mtbdudex is offline
post #11180 of 12740 Old 09-18-2014, 06:14 PM
cuzed2's Avatar
Quoted: 200 Post(s)
Liked: 256
Mike,
You are one of a very few that showed interest in these
Sending you a PM soon!
Cuzed2
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #11181 of 12740 Old 09-18-2014, 06:22 PM
jjgear's Avatar
Quoted: 16 Post(s)
I would be interested in some of those also. Let me know on a price.
JJ
jjgear is offline
post #11182 of 12740 Old 09-18-2014, 07:04 PM
Liked: 2057
Oh ya I forgot about those. I'd like a pair. Can you post pricing or should we PM you.
post #11183 of 12740 Old 09-18-2014, 08:03 PM
cuzed2's Avatar
Quoted: 200 Post(s)
Liked: 256
Tux,
I have just enough to fix you up - send me a PM!
Unfortunately my source went away to college, and my inventory is almost depleted...
cuzed2 is offline
post #11184 of 12740 Old 09-19-2014, 05:51 AM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 781
Thx Craig, got your PM, replied.
I'm proud to show off the DIY brand!
Via Mikes brain/thumb interface, LLAP
mtbdudex is offline
post #11185 of 12740 Old 09-19-2014, 06:31 AM
J_P_A's Avatar
Quoted: 650 Post(s)
Liked: 483
I'd be interested as well. If you have any leftover, shoot me a PM.
J_P_A is online now
post #11186 of 12740 Old 09-19-2014, 06:34 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2697
Did you buy your speakers yet ?
Mfusick is offline
post #11187 of 12740 Old 09-20-2014, 09:34 AM
cuzed2's Avatar
Quoted: 200 Post(s)
Liked: 256
Back on post #11179 ;
Interest in the long-forgotten SEOS emblems resurfaced.
Those emblems were designed (and a limited number were made) by my son as High School project. He used a CAD program called Autodesk Inventor, and they were produced on the school's 3D printer. Because of the "student/school" nature of this project I do not feel good about selling or accepting $'s for the few I had left. Therefore; the few I had left will soon be shared and mailed away (PMs sent).
The good news ; even though my son is now away from home in college - I just found the original CAD files for the following images. The Autodesk files (.ipt) appear to be small enough to be easily emailed and shared.
If someone here has Autodesk Inventor (64 bit version) and access to a 3D printer and would like to try to produce some more, please drop me a PM and I will email the files.
ID:	271106   Click image for larger version
Name:	SEOS-Autodesk Image.jpg
mtbdudex and J_P_A like this.
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #11188 of 12740 Old 09-20-2014, 11:01 AM
Liked: 2057
Very cool cuzed. At least let us pay shipping for them? I'm excited to get a pair. I was looking at my speakers today wondering where to install them. My baffle doesn't have much space and I'd hate to put them on the back. I might build a new pair of speakers
dolanjp, popalock and NWCgrad like this.
post #11189 of 12740 Old 09-21-2014, 08:27 PM
J_P_A's Avatar
Quoted: 650 Post(s)
Liked: 483
Ordered them tonight!
Mfusick and NicksHitachi like this.
J_P_A is online now
post #11190 of 12740 Old 09-21-2014, 10:00 PM
mrevo2u's Avatar
Quoted: 54 Post(s)
Ballpark of when fusion 15 will be back in stock?
mrevo2u is offline
