Hey guys...we need a little rallying here... - Page 382 - AVS Forum
 291Likes
post #11431 of 11445 Old 10-29-2014, 11:33 PM
chrapladm's Avatar
Quoted: 212 Post(s)
Liked: 88
Are there any posted SEOS 18 builds?
chrapladm is offline
post #11432 of 11445 Old 10-29-2014, 11:48 PM
rajacat's Avatar
I've got a SEOS18/TD15M/BA750 build going. The boxes are finished and the drivers installed. I just got a miniDSP in the mail. I'm now trying to find the time to climb the DSP learning curve, get my amp situation resolved and finish the project.
Perhaps I'll do a build thread. I've documented much of the build with photos.
rajacat is online now
post #11433 of 11445 Old Yesterday, 12:07 AM
chrapladm's Avatar
Quoted: 212 Post(s)
Liked: 88
Sounds good. Was thinking about maybe ordering a SEOS 18 in 1.4".
post #11434 of 11445 Old Yesterday, 04:44 AM
NicksHitachi's Avatar
Quoted: 140 Post(s)
Liked: 161
"Perhaps"!?
NicksHitachi is online now
post #11435 of 11445 Old Yesterday, 04:45 AM
chrapladm's Avatar
Quoted: 212 Post(s)
Liked: 88
And Rajacat how did you attach the horn to the baffle?
post #11436 of 11445 Old Yesterday, 12:11 PM
Brando Yo's Avatar
I was reading a few hundred pages ago about the Radian
Radian 5312BE-NEO
Has anyone been able to put these to the test? I know it sounds crazy, but I'm thinking of building 2 of them into a "can" box style to fit on the tower of my wakeboard boat. I figure if I'm going to spend $1K+ for a mass produced design, I might as well make my own.
Any thoughts or ideas??
Brando Yo is offline
post #11437 of 11445 Old Yesterday, 12:14 PM
Brando Yo's Avatar
Radian 5312BE-NEO
post #11438 of 11445 Old Yesterday, 12:37 PM
pgwalsh's Avatar
Quoted: 70 Post(s)
Liked: 66
Radian 5312BE-NEO
Think that might garner more attention in its own thread. I do recall it being mentioned, but more eyes will see it with its own thread. That's one crazy expensive driver.
Builds: Maelstrom 21 Ottoman Build, Dual Opposed MFW's x 2, Statements, SEOS-12/TD12M x 5.
pgwalsh is online now
post #11439 of 11445 Old Yesterday, 03:50 PM
Brando Yo's Avatar
You're right, I need to start my own thread. I'll work on it next week and give specifics as to what I'm trying to accomplish.
Those are definitely crazy expensive drivers but instead of buying 6 or 8 of the current leading "tower speaker (WetSounds)", I can probably get away with using just 2 of the Radians with hopefully minimal work and also save a ton of room on my tower. Plus they're supposed to hold up extremely well in wet environments.
I spoke with the rep over there at Radian a few times and explained what i was trying to do. He says he will cut me a crazy deal... We'll see I guess.
post #11440 of 11445 Old Yesterday, 11:56 PM
jbrown15's Avatar
Quoted: 1009 Post(s)
Liked: 1068
I have some Reaction Audio CX-15's in my theater room right now and it uses Radian 5215B drivers and they sound awesome, but I couldn't image getting those drivers anywhere near water.
I believe the only real advantage of the Neo is the weight, being about 10lbs lighter then the standard coax driver.
jbrown15 is online now
post #11441 of 11445 Old Today, 03:02 AM
Brando Yo's Avatar
I know it crazy to invest that kind of money, but the rep said they would hold up. I had $10K wrapped up in my first boat stereo and had to replace speakers a couple times due to weathering. The first generation wake tower speakers were just car audio coax speakers in a can, so needless to say that didn't hold up over time. My new boat has an intense system in it that I will be taking to shows hopefully next year, but I'm still needing to build the tower speakers. Everyone has the same 2 brands and I wanted to be different. Why not get a serious pro audio coax that would hold up better in the bad environments instead of what everyone else has. I think a lot of guys on this forum would agree that nothing stays stock for long. Everyone is constantly ripping things apart to experiment with different Xovers and drivers. It's probably a sickness to always want to be different, but oh well!
By the way the only reason I'm gonna go with the Neo's is the weight difference. Every pound on my tower counts, so might as well go with Neo's. I want the beryllium drivers because honestly I figure why not? I've heard a few beryllium drivers and I felt I could tell a significant difference, but then again it may not be what I thought I heard. The $100 bottle of wine always tastes better than a $10 bottle, right?... Haha...
post #11442 of 11445 Old Today, 03:15 AM
chrapladm's Avatar
Quoted: 212 Post(s)
Liked: 88
Why 15" for a boat?
Just sounds HUGE for a tower.
post #11443 of 11445 Old Today, 03:56 AM
wvu80's Avatar
Quoted: 30 Post(s)
Liked: 100
I agree. The 12" woofer uses a paper cone. I think you would want some other material OTHER than paper to be near the water.
My Klipsch 12" sub uses a Cerametallic woofer. I don't know exactly what that is, but to the touch it feels like plastic.
Symmetry pleases the eye, but it usually offends the ears where low frequencies are concerned. -Yoda Fitzmaurice
wvu80 is online now
post #11444 of 11445 Old Today, 05:42 AM
JohnDean's Avatar
Quoted: 64 Post(s)
Liked: 46
Wasn't there mention of some weather resistant coaxes in the coax thread? If i was going to roll my own for a boat, that would be my direction.
JohnDean is offline
post #11445 of 11445 Old Today, 10:58 AM
rajacat's Avatar
I left a little space between the aluminum angle and the brace to allow for a degree of tightness adjustment. Do NOT over tighten the bolts. Use just enough torque to hold the WG in position. Some Mortite around the edges underneath the flange will help keep the WG in place.
I'm using the 10 lb. BA750. The angles attached to the full width brace support it securely.
User Tag List
