Hey guys...we need a little rallying here... - Page 390 - AVS Forum
 336Likes
post #11671 of 11679 Old 11-20-2014, 07:13 AM
coolgeek's Avatar
Quoted: 172 Post(s)
Liked: 98
Originally Posted by mikela View Post
Ah, i see. I was thinking of a simpler box. Like you said, as long as it's about 1 cubic foot internal space, it works.
coolgeek is offline
post #11672 of 11679 Old 11-20-2014, 07:57 AM
wvu80's Avatar
Quoted: 39 Post(s)
Liked: 102
The more discussion I see on Atmos, the more I think it's something that would NEVER work in my real-world environment.
My walls are asymmetrical, there are openings in the middle of the room, ceiling fans. Not to mention it would take expert level knowledge to properly install. And how many Atmos designers have taken into consideration that WIVES like to move furniture including couches, which means different listening positions?
Frankly, I don't even really think it's 5.1 or 7.1 or 9.1 that makes such a great improvement in sound, it's the QUALITY of the sound coming from quality audio gear, and properly designed speakers, wherever they are placed.
Nothing is a fact unless it agrees with my opinion.
Symmetry pleases the eye, but it usually offends the ears where low frequencies are concerned. -Yoda Fitzmaurice
wvu80 is offline
post #11673 of 11679 Old 11-21-2014, 08:59 PM
J_P_A's Avatar
Quoted: 283 Post(s)
Liked: 267
Would it be ill-advised to use a Fusion-8" in an angled box on my ceiling for ATMOS overheads? It would need to be on its side.I'm not sure about the interactions with the ceiling in an orientation like this.
I'm planning to use Volt-8's in an angled enclosure, but I'm considering backup plans if the driver continues to be out-of-stock.
The Plains Theater Has Begun
J_P_A is offline
post #11674 of 11679 Old 11-22-2014, 07:59 AM
pitviper33's Avatar
Quoted: 69 Post(s)
Liked: 39
How many rows do you have? I'd be much more concerned with lobing than with wall interaction if placed in that orientation. The wall interaction effects could be mostly equalized out.
pitviper33 is offline
post #11675 of 11679 Old 11-22-2014, 08:02 AM
J_P_A's Avatar
Quoted: 283 Post(s)
Liked: 267
Two rows (plus a third row bar). I was trying to orient the speakers to point directly at the MLP to limit issues with lobing, but it would certainly be a concern for the second row due to the narrow(er) pattern. I've almost convinced myself to optimize for the first row and let the second row get whatever it gets.
J_P_A is offline
post #11676 of 11679 Old 11-24-2014, 11:24 AM
Mfusick's Avatar
Quoted: 193 Post(s)
Liked: 1003
You doing those sketchup yourself? Where you learn those skills ?
"Too much is almost enough. Anything in life worth doing is worth overdoing. Moderation is for cowards."
Mfusick is online now
post #11677 of 11679 Old 11-24-2014, 11:47 AM
J_P_A's Avatar
Quoted: 283 Post(s)
Liked: 267
Yeah, I've been playing with sketchup since I started designing my theater. It's a pretty straightforward program. if you've got any computer skills you can probably learn enough in an hour to do a good model of a theater. It's a lot easier to see how things are going to work out with a model like this as well. It's been a huge help with speaker placement, sight lines, seating placement, etc.
J_P_A is offline
post #11678 of 11679 Old 11-24-2014, 11:49 AM
foraye's Avatar
Where else?...YouTube!!
Mfusick likes this.
foraye is online now
post #11679 of 11679 Old 11-24-2014, 12:35 PM
chalugadp's Avatar
Quoted: 1193 Post(s)
Liked: 1148
I teach sketchup and have made lots of video tutorials.
http://teachers.sd43.bc.ca/dpurych/C...Tutorials.aspx
In the sketchup tab on my website is over 40 videos. Your welcome to try them.
Mfusick, foraye and doc5150 like this.
chalugadp is online now
