Hey guys...we need a little rallying here... - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 901Likes
post #91 of 12740 Old 11-27-2010, 02:16 PM
Hot Grits's Avatar
Check this out, if you are wanting to make an exact copy of the QSC horn, (Which I would only do if you are not planning on selling these, for ethical reasons.)
You can find 3D scanners that attach to CNC routers. It scans an object and makes a file that you can then use to create a duplicate. You could also make changes to the original.
Here's an example of one, although I think it only works with the ShopBot.
Look halfway down the page.
http://www.shopbottools.com/mProducts/accessories.htm
Hot Grits is offline
post #92 of 12740 Old 11-27-2010, 02:35 PM
penngray's Avatar
Liked: 47
Originally Posted by maxmercy View Post
Doing a wood plug prototype would take tons of time, as you would be cutting many ellipses in wood, gluing them all together and filling and sanding to shape.
Unfortunately, using a CNC mill, unless it is a super one with LOTS of tool time will leave tooling marks that will also have to be hand sanded to final shape. With the wood option, you can at least see all the wood 'corners' as you are sanding to use a guide that you have sanded far enough....
Either way, you are looking at having someone that has great skill to do the final sanding....
Maybe a combination of using a CNC router table and using it to cut 1/8" wood into many ellipses would be a good compromise? Fill the 'corners' with something like Bondo (silicon microballoons and a low-shrink resin system, take your pick) and sand to final shape......then the part-making can begin....use a good, viscous resin for the 'finish', then use pigmented resin and choppped strand mat and resin would be pretty cheap and effective. you can then layer reinforcing cloth and resin on that to strengthen the build, and then peel-n-seal....the interface for the compression driver would be then added...
JSS
We should ask jzagaja on DIYAudio.com, the guy is making the best waveguides I have seen, I could maybe do the 3D modelling to start.
In this thread
http://www.diyaudio.com/forums/group...des-horns.html
To build an elliptical OS waveguide, maybe 15x10?? It would be a smaller version to his IWATA waveguide designs.
penngray is offline
post #93 of 12740 Old 11-27-2010, 02:35 PM
Erich H's Avatar
Quoted: 1494 Post(s)
Liked: 1905
I read about those earlier in the year. You can also get 3D printers as well.
It's funny, last winter I thought up a machine that could do something like that, and at the time didn't even know 3D printers existed. I felt pretty smart for about a week or so, then found that someone already made 3D printers!
It really wouldn't be too hard to duplicate the QSC waveguide if someone wanted to spend the money doing it. But as of now it's been put on hold to see if PE is going to offer them up to the public. If they don't, then someone might try to improve on that design for the DIY crowd. If they do sell it, then it doesn't make much sense to duplicate an item that may only cost $12-$15 from PE. The average person could never make them for that cheap price.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #94 of 12740 Old 11-27-2010, 02:41 PM
Erich H's Avatar
Liked: 1905
What program file would that be saved in Penngray? As mentioned, I might know a local guy that could turn your file into the prototype. I'll be calling him on Monday. If he can't, maybe the company he works for can.
Erich H is offline
post #95 of 12740 Old 11-27-2010, 02:42 PM
penngray's Avatar
Liked: 47
Now that sounds easier to DIY.....conical is not super-tough.
JSS
But its not maximizing the elimination of HOMs either. Its just not as good as the OS choice according all those waveguide discussions on Diyaudo.com
There are alreadly conical options too, not sure if any are bolt on since the only ones I know from dayton are screw on designs.
penngray is offline
post #96 of 12740 Old 11-27-2010, 02:43 PM
penngray's Avatar
Liked: 47
We would have to ask jzagaja what it is. I PMed him to get his opinion on doing at 15"x10" waveguide.
penngray is offline
post #97 of 12740 Old 11-27-2010, 02:52 PM
penngray's Avatar
Liked: 47
Originally Posted by ZilchLab View Post
H9800 is 18" wide, actually, and H4338, the enlarged version of it, arguably JBL's best TOTL biradial short of Everest II, just over 20". I'm just arguing that, in terms of practicality, 152i at 14" is a better DIY format. Abbey is 15" total cabinet width, and more in keeping with my own perception of rational scale, and going back to where I started this, I believe Earl would agree.
Yes, there's a market for K2-S9900, the scaled-down Everest II at 22" wide:
http://www.audioheritage.org/vbullet...24086-K2-s9900
Summa is 24":
http://www.gedlee.com/summa_.htm
[Just tryin' to put some numbers on real stuff here.... ]
No disagreement in the max width of choice for the most DIYers and I guess as a business case we know the Abbey width sells much better then the Summa width but Im not concerned what size the majority wants. The majority honstly wants < 8" wide baffles...we have always been the minority to start with
We also already have the 10",14", 15" wide waveguide options from 18sound, Dayton and JBL. Im all for a QSC clone but we do not need 3D modelling to do that we can just copy the existing ones out there.
If we are going to spend time and resources on modelling something then lets model something that is superior to the rest, more or less in the 3 years of waveguide design activity on the many forums the holy grail is still what Geddes did, like it or not people strive to obtain that performance so Its beyond my logic why we are not modelling the OS design. You can not match/beat the best unless you are doing what the best are doing.
I know your goals are different, you are trying to please a larger crowd and I just want the best possible waveguide designs in my room.
ellisr63 likes this.
penngray is offline
post #98 of 12740 Old 11-27-2010, 03:00 PM
3AMRecords's Avatar
... Im not concerned what size the majority wants. The majority honstly wants < 8" wide baffles...we have always been the minority to start with
I know your goals are different you are trying to please a larger crowd and I just want the best possible waveguide designs in my room.
I have been following this thread since it started.
I think that all of the ideas here are fantastic and I wholly agree with penngray here; if you are going to be starting from the design phase and from scratch, then why not aim to make the best possible WG.
Of course there are other options, such as the QSC clone etc. But why try to clone something when we all ready know how it works.
If we improve on the design, even just a little then that is progress, and that in the long run will help everyone.
I know I am very much interested in the final design here. Though I might not be much help I know that everyone including myself would benefit from this.
Max
Max
Dual Dayton RSS390HF-4 15" Sonosub Build thread:
http://www.avsforum.com/avs-vb/showthread.php?t=1223658
"You mean, you um, you built those things?"
"Yep!" "Why?" *Power on* "Oh, that's why"
3AMRecords is offline
post #99 of 12740 Old 11-27-2010, 04:17 PM
penngray's Avatar
Liked: 47
From Jack on DIYaudio.com
I'll make 3D model and someone from that forum can do CAM works. It's two days job for someone who has CNC machines.
Best,
Jack
penngray is offline
post #100 of 12740 Old 11-27-2010, 04:28 PM
coctostan's Avatar
Liked: 142
I think we are getting ahead of ourselves here. We all want a reasonably priced quality WG. We all agree the QSC is/was a great solution and value. It is gone. We have four main routes with pluses and misnues:
1. Direct QSC clone. We know it works. No engineering or prototyping. The downside is that it is a direct ripoff and I personally don't think it is appropriate but to each their own.
2. Original design similar to the QSC with some improvements in the throat. It would be slightly easier to prototype with simple tools.
3. True elliptical OS using the same dimensions as the QSC. Should be superior to the QSC in "HOMs" but would require more engineering and likely more expensive prototyping.
4. Same as 3 but wider for lower pattern control. It won't fit in prefab boxes and becomes less attractive to the masses for concerns like WAF. For others it provides a middle ground (IMO sweet spot) between the 30" wide JBL and the 12" wide JBL. Plus it would allow bolt on 1" drivers as opposed to threaded.
Number 2 sounds like it would be the easiest and cheapest (aside from 1 which I'm personally counting out). An elliptical design IMO will need a CNC'd prototype which will cost money but could be a big hit in the DIY community since there is nothing like it AFAIK. If the small EOS is done the producer could gauge doing the large size based on its success (or vice versa).
Anyway we look at it we don't even know if an elliptical is feasible. We are talking about nothing until we figure out the feasibility.
coctostan is offline
post #101 of 12740 Old 11-27-2010, 04:34 PM
ZilchLab's Avatar
Don't know why we're focused on the QSC for anything other than general prameters -- Parts Express is on it, and knows there is substantial demand for it in the DIY community, the purpose of this thread. I'm reasonably confident they'll come up with something.
The premise for "something else" here is elliptical oblate spheroid. Prolate spheroid is another option in Geddes parlance. I'm not arguing against any of that, merely debating the optimum size for such investment.
Geddes did do an elliptical for another company, Canadian, as I recall, some years ago; Penn may be able to track that down.
Also, talk to Wayne Parham about OS options -- he has expressed his own views on this in other forums....
....Crank up the SIGNAL ... cut back the noise....
ZilchLab is offline
post #102 of 12740 Old 11-27-2010, 04:36 PM
penngray's Avatar
Liked: 47
I vote for the "Nothing Like It" choice
Either way, I will get a EOS.
FWIW, Im already assuming the QSC HPR-152i choice or very similar will exist in the future so do not mistake my posts as trying to talk anyone away from the QSC option so to me we can have #2 and #3. No reason to stop at one when we have some momentum and an active discussion.
penngray is offline
post #103 of 12740 Old 11-27-2010, 04:41 PM
penngray's Avatar
Liked: 47
The premise here is elliptical oblate spheroid. Prolate spheroid is another option in Geddes parlance. I'm not arguing against any of that, merely debating the optimum size for such investment....
Are you arguing for Dayton or yourself?
Me, I already have the QSC size, JBL size, Dayton round choice, etc. People can just buy the nice looking XT1086 if they want something maybe slightly better then the QSC.
Obviously Im pushing for something that has been in demand from day 1.
I think we both agree an EOS design being sold to DIYers would be awesome. We are just looking at the size requirements from different POVs. I think its important to XO below 1kHz, more important then any CTC issue.
I do agree with your position though, you are looking out for those who do not want > 16" baffles.
penngray is offline
post #104 of 12740 Old 11-27-2010, 05:08 PM
ZilchLab's Avatar
Don't tempt me, Penn.
You'd be giving it more credence if you had some experience measuring the consequences of ignoring CTC. The notches that develop are wider and deeper than the on-axis deal-breaking one inherent in Earl's "perfect" design which he himself desires to mitigate. Yes, lower frequency crossing gets at it, but there are associated tradeoffs and compromises; I'm not so sure the vocals are as strong an argument here as many suppose, either.
Earl claims not to care about the verticals. In substantial measure, that's because he does not presently have means to deal with them other than via padding the floor and ceiling. He plays fast and loose with lots of this in his own self-interest, and it's important to sort out what's actually what in the context of who's doing and saying it....
ZilchLab is offline
post #105 of 12740 Old 11-27-2010, 05:47 PM
coctostan's Avatar
Liked: 142
Zilch, I agree with you on the CTC nulls. They are a vital design consideration and the primary impetus for the pursuit of an elliptical shape over a circular shape. By my math, once you go to a 90x50ish horn, the CTC spacing takes care of itself so long as you keep the woofer tucked as close to the center of the horn as possible and take full advantage of the horn's horizontal pattern control (requires a CD that can play that low).
Something like the JBL 1" mega-PT is less than ideal IMO at 30" wide since there aren't any 1" CDs that can play low enough to take advantage of that width and you still have to mess with that extra horn height. The 1.5" version wouldn't have that problem with a 600-700hz xover and I might give it a go versus my QSC setup.
But yes, a wider WG would require a CD that can be crossed over lower and would eliminate most of the cheaper alternatives.
If we are confident that PE will come up with something like the QSC, then I think we are basically on a tangent about developing an elliptical OS WG.
post #106 of 12740 Old 11-27-2010, 06:33 PM
ZilchLab's Avatar
Yes, until we know otherwise, in my view, but a WORTHY tangent, indeed....
ZilchLab is offline
post #107 of 12740 Old 11-27-2010, 07:22 PM
coctostan's Avatar
Liked: 142
I agree completely.
post #108 of 12740 Old 11-27-2010, 07:57 PM
penngray's Avatar
Liked: 47
I do not have to give anything credence (You are the Expert DIYer not me ). There are already speakers being sold that have round waveguides, there are speakers being built that have larger waveguides. They have had great success to their builds.
Its not only Early but Paul W built an amazing speaker using a larger waveguide. You can also look to the designs from Duke @ audiokenesis or Emerald Physics deisgns all have CTC that you wouldn't like but why still do they have amazing sounding speakers?? I just say if they can do it, we can do it. Their products look a lot nicer too, that is important to me.
I have read enough to know that in the world of DIY there is more then one way to do any design and make it sound incredible.
I will say that the CTC on the JBL horns/Selenium CD may make for an easy crossover but it does not matter when it honks and sounds like crap to me so I have to look elsewhere and the HOM discussions have pointed to OS shapes as our best choice.
If you care about verticals then worry more about CTC then other issues. That is the great thing about having many choices. I love my ribbons and they drop like a rock 10deg off the vertical axis so vertical issues may not matter that much to some people.
You also remember I think everyone should just go active and the CTC can go away. Use a steeper slope and stuff fussing over it all
penngray is offline
post #109 of 12740 Old 11-27-2010, 08:31 PM
ZilchLab's Avatar
It'd have been good if you had actually built the crossover rather than listening to the entry-level E-Wave driver/waveguide combo without the requisite HF comp.
Delay has nothing to do with the magnitude of the vertical nulls; active merely provides for easier steering of the forward axis. Of course, you can adjust that to compensate for a narrow vertical lobe every time you stand up or lie down.
Pretend that's a slam-dunk answer also, if you like, but Earl hizself told you it's not so....
ZilchLab is offline
post #110 of 12740 Old 11-27-2010, 09:42 PM - Thread Starter
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
the jbl k2 and meyer x-10 are worthy targets, though i'd close them up. even with subs, dr. g. has expressed that the large speakers, summas in his case, are just "better" than the others. he crosses at 900hz, though without details of the crossover, that doesn't mean as much as it might seem. the ae speakers td15m is down -3db at 80 hz in a medium sized sealed enclosure. john j. seems to support random projects, maybe there is a way to loop him into this project, e.g. flat packs for the enclosures and woofs (his cnc is probably idling quite a bit of the time). just some random thoughts.
Listen. It's All Good.
LTD02 is offline
post #111 of 12740 Old 11-27-2010, 10:04 PM
ZilchLab's Avatar
I'll mention again that Geddes is not doing 90° beamwidth. His included angle may be that, but the -6 dB pattern is somewhat narrower....
ZilchLab is offline
post #112 of 12740 Old 11-27-2010, 10:25 PM - Thread Starter
LTD02's Avatar
Liked: 2888
everytime that i go back to his site, his measurements change, i can't keep up.
look what he has now: http://www.gedlee.com/summa_.htm
i suppose this one wasn't generating as many sales as it was questions.
http://www.avsforum.com/avs-vb/showt...7#post17831507
with the first line being on axis and then each additional one being 7.5 degrees, the -6db point appears to be around 45 degrees at about 1khz. (purple line) it is always possible that i read this plot wrong.
LTD02 is offline
post #113 of 12740 Old 11-27-2010, 11:21 PM
ZilchLab's Avatar
Yes, but notice in the individual polars that the SPL is "normalized." That's standard practice in conventional polar plots for determining the effective beamwidth. The off-axis may be down in SPL overall, but so long as the curve itself stays within the -6 dB limit, it qualifies.
His "new" directivity presentation is deceptive in several ways -- the designs are EQ'd for flattest performance at his intended design axis, somewhere in the range of -20°, where he has "set" the white-line cursor, generating the flatish FR across the top graph. To compensate for the fact that the overall SPL is down from true axial, the color scale is offset for this "normalization," and the response anomalies there obscured; the white cursor does not pass through them.
In the exhibit shown, "0" occurs at something more like -3 dB, whereas, in his recommended extreme toe-in deployment, it's "true" zero, including those anomalies, that is illuminating the opposite wall and generating the first contralateral reflection. He might legitimately argue that since the delay is long, this is not affecting imaging, but not so effectively, tonality or timbre.
Notwithstanding these qualifications, however, the black contour line represents -6 dB for Summa, and you can see that the beamwidth varies between 70° at ~1.5 kHz and ~85° at 7.5 kHz. Nowhere within the bandwidth of interest is it 90° "nominal."
Last time I looked, Summa as shown in his directivity paper more accurately illustrates the actual behavior of the product. There's nothing dishonest here; he's merely illustrating the performance in its best light, consistent with how he has designed it and recommends that it be used. There IS a bit of sleight of hand involved in the presentation, though, obscured by a gratuitous "No other manufacturer would DARE show their data in this level of detail" smoke screen....
ZilchLab is offline
post #114 of 12740 Old 11-27-2010, 11:36 PM - Thread Starter
LTD02's Avatar
Liked: 2888
hhmmm...
LTD02 is offline
post #115 of 12740 Old 11-27-2010, 11:58 PM
ZilchLab's Avatar
hhmmm...
Look at Abbey and Nathan; 60° nominal for Abbey and collapsing to as narrow as 20° in the top octave, and 70° for Nathan, with both of them exhibiting on-axis response anomalies well above "0" -- reddish does not even appear in the color key. It's all there, just not in stark relief....
http://www.gedlee.com/abbey.htm
http://www.gedlee.com/Nathan.htm
ZilchLab is offline
post #116 of 12740 Old 11-28-2010, 12:19 AM - Thread Starter
LTD02's Avatar
Liked: 2888
z., the internet is such a f_ckup as a communication tool. when i said "hhmmm..." i was nodding my head up and down considering carefully your points not shaking my head side to side and rolling my eyes. i wasn't questioning your data. you provided some good stuff to chew on. i was just chewing...not dismissing...
LTD02 is offline
post #117 of 12740 Old 11-28-2010, 12:24 AM
ZilchLab's Avatar
I didn't interpret it as anything more than contemplation either way, rather merely saw an opportunity to expound further on the subject, since I was looking at it for the first time in such detail myself. I had previously only noted that they were not 90°, and raised that question to him directly in another forum, in which he confirmed that they are not, which carries implications with respect to waveguide size, as we are discussing here....
ZilchLab is offline
post #118 of 12740 Old 11-28-2010, 12:35 AM - Thread Starter
LTD02's Avatar
Liked: 2888
"I had previously only noted that they were not 90°, and raised that question to him directly in another forum, in which he confirmed that they are not, which carries implications with respect to waveguide size, as we are discussing here...."
i recall that as well. it seemed like sometimes the summa was a 90° horn, but then at other times it was a 60° horn. like i said, i have a hard time keeping dr. g.'s summa straight. the observation that the directionality is different for the summa, abbey and nathan is a good one. i hadn't picked up on that before. [what is the code for ° anyway?]
how the heck is one supposed to read the charts??
let's take this one from the summa.
is the red line in the top plot supposed to indicate the woofer performance?
how is that possible when the driver craps out around 2khz?
http://www.parts-express.com/pdf/294-670.pdf
LTD02 is offline
post #119 of 12740 Old 11-28-2010, 12:53 AM
ZilchLab's Avatar
If we spent more time with the actual directivity program, we could likely figure that out. I'm ignoring the red and black lines in the top plot right now, because I don't know either. The right-hand scale gives a clue.
The yellow one, I understand. It's the FR at the horizontal white-line cursor in the map below. In the program itself, you can move that around. He has set it at 18° for this screen shot, where, presumably, the FR is flattest, as that is what he wants to show for marketing purposes. The HF begins rolling off linearly at 8 kHz and is down 3 dB by 18 kHz, per the left-hand scale. That curve represents what the FR would measure at the 18° angle. The two blips just below 8 kHz may be found as the two small grey-outlined "0" dB contours in the map at those frequencies. Summa nowhere goes much above "0", but the other models do.
The iso-contours in the map represent 6 dB increments; the black one is at -6 dB below "0". The vertical dotted line in the top plot corresponds to the vertical white-line cursor in the map.
My color scale is different in CLIO, and I use substantially greater smoothing, but here's an EconoWave from a few months ago, Selenium D220Ti on the QSC 152i waveguide in a Dayton KD trapezoidal cab kit with 1.25" edge overhangs:
http://techtalk.parts-express.com/sh...07#post1658207
Pretty DUMB, violating all the rules, huh?
[Well, it gets better when I actually pay attention to them.... ]
ZilchLab is offline
post #120 of 12740 Old 11-28-2010, 01:35 AM - Thread Starter
LTD02's Avatar
Liked: 2888
"I'm ignoring the red and black lines in the top plot right now, because I don't know either."
i was wondering if i was losing my mind.
if i were to twist your arm and require you to pick a 15" to mount the proposed horns above, (crossed to subs at 80hz), would you choose the 2265h or the less expensive 265h drives? both are around -3db at 80hz in 1.75-2.00 sealed enclosures, perfect for thx crosses. have you experimented with these z.? if so what do the differential drives have over the older technology, such as the 2226h? the 265's are probably enough with 100 watt mains and crossed at 80hz.
then again, if i were to give you the ability to bring back the 1401nd's, as used here:
http://www.jblpro.com/pub/obsolete/dms-1.pdf
would you bring them back? what would you choose for a replacement today?
e145's would be nice too. well trained soldier there. why did they discontinue that majestic performer?
oh well, half the thing is choosing the low end drive. that will dictate how big/low the horn must go.
guys who want to go small have the xt1086.
let's go medium-big on this one. let's diy something that will rival the k2 or x-10.
LTD02 is offline
