Hey guys...we need a little rallying here... - Page 401 - AVS | Home Theater Discussions And Reviews
 505Likes
post #12001 of 12015 Old 01-22-2015, 03:37 PM
3ll3d00d's Avatar
Quoted: 419 Post(s)
Liked: 103
I posted this question on my own thread but I think it's a more general question about how to best employ a SEOS in a room. I've tried searching this thread, and other forums, but it's hard to find a clear answer so I wonder if someone can confirm whether my thinking is accurate.
My current thinking is to build a SEOS10 over an 8" in a low profile on wall enclosure. A polar response of the SEOS10 was posted back in post #1393
As I understand it, this shows that +/- 22.5 degrees is approximately the range in which it is pretty much consistently at "full power" (i.e. minimal variation). As you get further off axis then there is some rolloff such that by +/- 45 degrees then you're 6dB down at the top end.
Applying this to an actual room then we can see the disperson of my L speaker below. The area I want to cover with sound is in blue, this requires output (from a flat on wall speaker) over 0-30 degrees. The area that produces 1st reflections off the ipsilateral wall is in red, this requires output from ~-25 to -50 degrees.
Therefore if I mount the speaker flat on wall then two things will happen
1) the 1st reflections from the L wall at the left most listening position will be strong
2) the direct sound at the right most listening position will be >3dB down
This makes me think the correct thing to do will be to angle the baffle by ~10 degrees (to point towards the opposing wall) which will mean
1) the listening position is in the -10 to +20 degree range == sweetspot!
2) the 1st reflections off the L wall will be in the -35 to -60 degree range (i.e. in the region of ~8-12dB down)
If this correct? Is there anything else I should consider with this positioning that I'm missing?
3ll3d00d is online now
post #12002 of 12015 Old 01-22-2015, 03:45 PM
HopefulFred's Avatar
Quoted: 234 Post(s)
Liked: 231
You're on the right track, but you haven't taken the idea far enough. If you toe the speaker in such that the nearest listener is outside that window by a few degrees you can enlarge the sweet spot considerably. The near wall reflections then get even lower in intensity.
Bwaslo wrote and posted a very good and compete discussion of time/intensity trading at diysoundgroup forums. Please read that.
http://www.diysoundgroup.com/forum/index.php?topic=20.0
LTD02 likes this.
HopefulFred is offline
post #12003 of 12015 Old 01-22-2015, 04:31 PM
3ll3d00d's Avatar
Quoted: 419 Post(s)
Liked: 103
Thanks for the link. What happens when you put a C speaker into the middle of such a toed in LR?
Unfortunately I cannot accommodate that degree of toe in due to the on wall mounting & my depth constraints requirement to mount on wall. I think ~10 degrees is the most I can realistically manage (needs a 2" offset on the baffle given a 12" wide speaker)
post #12004 of 12015 Old 01-22-2015, 06:11 PM
Eyleron's Avatar
Quoted: 104 Post(s)
Liked: 62
That's why acoustic transparent screens are so helpful...you can build a baffle wall shaped how you need it, and it's hidden behind screen wall.
Eyleron is online now
post #12005 of 12015 Old 01-22-2015, 06:28 PM - Thread Starter
LTD02's Avatar
Quoted: 668 Post(s)
Liked: 1259
as fred mentioned, these things do best when toed in or the speaker in front of the off axis listener will dominate and steer the sound off the center of the screen. not the end of the world if using a center though. this concept was discussed by klipsch in...1975 (see dope from hope 1975 https://community.klipsch.com/dope/D...0801_v15n2.pdf). for some reason we seem to need to keep rediscovering it. :-)
Listen. It's All Good.
LTD02 is offline
post #12006 of 12015 Unread 01-22-2015, 08:16 PM
tuxedocivic's Avatar
Quoted: 636 Post(s)
Liked: 719
As someone who has a flat baffle wall, it's ok for movies with a center. For stereo music, my stand alone speakers can make a better image when toed in.
tuxedocivic is online now
post #12007 of 12015 Unread 01-22-2015, 09:13 PM
FriscoDTM's Avatar
Quoted: 27 Post(s)
How about building out small false walls covered in decorative AT fabric at ~45 degrees in each of the bottom corners, with the L/R in the corners pointed at each opposite seat and the balance of the space serving as bass traps?
TV 2013 Samsung 75" UN75F6300
AVR 2013 Denon X2000 w/ Audyssey XT
7.2 3 DIY 1099s (LCR), 4 Yamaha NS-IC600WH + 4 Dayton ME820C (SL, SR), 2 DIY OS-MTM (BL, BR)
Subs Two 19Hz DIY Ported UXL-18s + iNuke6000DSP
Calibration CALMAN5, REW, UMIK-1
FriscoDTM is online now
post #12008 of 12015 Unread Yesterday, 02:11 AM
3ll3d00d's Avatar
Quoted: 419 Post(s)
Liked: 103
I would like to do something like this however it requires some structural changes to the room (the door needs to move) so that is a 2-3 years down the line.
post #12009 of 12015 Unread Yesterday, 02:55 AM
3ll3d00d's Avatar
Quoted: 419 Post(s)
Liked: 103
does that mean the image is absolutely poor without sufficient toe in or that it is still good, just not as good?
post #12010 of 12015 Unread Yesterday, 03:28 AM
Quoted: 16 Post(s)
Liked: 2
Why not build the toe into the baffle as you previously mentioned? It doesn't have to be a steep angle, just enough to direct the image inward towards the listening position.
Tip24/96 is offline
post #12011 of 12015 Unread Yesterday, 03:32 AM
3ll3d00d's Avatar
Quoted: 419 Post(s)
Liked: 103
that's what I was thinking, something like this
what I was asking, in the quoted post, was for a view on the relative quality of the stereo image when using markedly less toe in.
post #12012 of 12015 Unread Yesterday, 07:59 AM
Quoted: 636 Post(s)
Liked: 719
No the image is still good. Even venter channel fooling good sometimes. But not quite as wide or precise as my stand alone SEOS speakers with toe in. But I've never found it to be a factor when watching movies with LCR running. I only hear the difference in stereo.
Oh that's a completely flat baffle wall. No toe at all. So you'd be better off than me. FWIW, I'd give up my speakers before my baffle wall.
post #12013 of 12015 Unread Yesterday, 08:47 PM
SilverSPL's Avatar
Liked: 3
Was quite the undertaking to read all 400+ pages but I did it. Took me about two months of reading a little bit every day. Also looked into all the links to other pages and forums along the way. Reccomend everyone doing it, learned a lot in reading everyone's posts. You will have far less questions and more of the answers.
Erich thank you for everything you have done!
I will soon be purchasing some speakers from you for my home theater that I'm building in my unfinished basement. Once the basement get a little further along I'll start a build thread of my basement and show my integration of the speakers into the walls.
wvu80 likes this.
SilverSPL is offline
post #12014 of 12015 Unread Today, 08:12 AM
dtsdig's Avatar
Quoted: 205 Post(s)
Liked: 188
That's really awesome! I've read the majority of it "live" and I've also started at the beginning and gotten through the first 150 pages or so but to read the entire thing is quite the feet!
wvu80 likes this.
dtsdig is online now
post #12015 of 12015 Unread Today, 11:25 PM
clausdk's Avatar
Quoted: 111 Post(s)
Liked: 49
Congrats! Lets hope
they become available soon again.
clausdk is online now
