Hey guys...we need a little rallying here... - Page 406 - AVS Forum | Home Theater Discussions And Reviews
 880Likes
post #12151 of 12720 Old 02-12-2015, 09:37 AM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 201
Originally Posted by Nate Hansen View Post
Actually Geddes argues against normalization. Like tux says I think either way can be useful depending on what you're looking at. I prefer none.
I also prefer none.
Face2 is offline
post #12152 of 12720 Old 02-12-2015, 03:26 PM
3ll3d00d's Avatar
Quoted: 1566 Post(s)
Liked: 542
I pushed an update that does both normalised and unnormalised circular polars
3ll3d00d is online now
post #12153 of 12720 Old 02-12-2015, 08:04 PM
Scaramoucheii's Avatar
very impressive concept, I like it
Scaramoucheii is offline
post #12154 of 12720 Old 02-13-2015, 05:20 PM
bwaslo's Avatar
Quoted: 66 Post(s)
Liked: 182
BTW, the OmniMic software can do those polars as well (give it a list of FRD files, you can assign angles to each), and will do it even if you don't have the OmniMic hardware. Download the software and install, Windows computers. http://www.daytonaudio.com/index.php...nt-system.html
You can actually do a lot with the OmniMic software, for display and curve math, without having to buy an Omnimic. I'm not sure whether Dayton audio publicises that fact, I wish they would
LTD02, Eyleron, 3ll3d00d and 1 others like this.
___________________________________________
DIY Synergy horn spreadsheet Synergy horn spreadsheet and pdf
XSim -free crossover designer and simulator XSim install file
Easy and cheap sound diffusers (the "Depot Diffusers") making easy DIY depot sound diffuser-panels-step by step.html
SmallSyns - point source controlled directivity in a manageable size SmallSyns
bwaslo is offline
post #12155 of 12720 Old 02-13-2015, 08:22 PM
mtg90's Avatar
Quoted: 413 Post(s)
Liked: 783
That's what I've done in the past, thanks Bill!
One trick I found is that if you put the measurement angle at the end of the name when saving the frd file example: "SEOS-15 DNA-360 2.83v 1m 30.frd" Omnimic will automatically assign it to that angle, in this case 30 degrees.
Though I have also found it does not like importing files with all the text data that REW puts before the measurement data in its exported frd files. So you have to go in and remove all that first, a quick highlight, backspace and save in notepad does the trick.
Eyleron, Face2 and EarlK like this.
mtg90 is offline
post #12156 of 12720 Old 02-17-2015, 07:52 PM
lemans24's Avatar
Quoted: 20 Post(s)
Liked: 41
Excellent design!!
1) will the dual woofer version use a slot port?
2) since you may offer a fl-450 based center speaker, will there be a fl-450 based surround speaker? Basically top half of Maximus 12
3) what will the dual woofer version be tuned to?
4) what is the max power of the dual woofer? 2000 watts?
lemans24 is offline
post #12157 of 12720 Old 02-17-2015, 08:27 PM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1771
No decisions on the dual woofer model yet. The woofers were designed to hit 80hz in a small sealed enclosure or killer midbass in small ported enclosures. And of course can run 'full range' in a medium sized enclosure.
I don't really see much reason to put two of them in a large box and tune down around 40hz or less. If two are used, they will either be sealed or tuned higher for massive midbass because people will be using subwoofers either way.
Yes, there will be a matching surround, even though there's really no reason to have matching surrounds like that.
I'm not sure what the max power will be until a decision is made on ported, sealed, etc. It will be well more than anyone would ever use though. I believe Jeff said duals would allow for a sensitivity of 99db from 40hz on up, which of course is pretty crazy.
The design is pretty much done, it's just being tweaked a little.
The SEOS Waveguide Project
Erich H is offline
post #12158 of 12720 Old 02-17-2015, 08:37 PM
lemans24's Avatar
Quoted: 20 Post(s)
Liked: 41
Sensitivity of 99db from 40hz from duals...sounds like mid bass madness!!
Definitely tune the duals for mid bass rather than extension especially since the size of the lower half cabinet will not be changing.
lemans24 is offline
post #12159 of 12720 Old 02-17-2015, 11:25 PM
Quoted: 93 Post(s)
Liked: 48
Mid bass, mid bass, mid bass.
Doradoguy is offline
post #12160 of 12720 Old 02-18-2015, 04:01 AM
Quoted: 456 Post(s)
Liked: 47
Originally Posted by lemans24 View Post
Excellent design!!
Is that the 1899 or the Seos Maximus?
Tip24/96 is online now
post #12161 of 12720 Old 02-18-2015, 07:00 AM
chrapladm's Avatar
Quoted: 825 Post(s)
Liked: 286
WAY to small for the 1899 or Maximus.
chrapladm is online now
post #12162 of 12720 Old 02-18-2015, 01:02 PM
lemans24's Avatar
Quoted: 20 Post(s)
Liked: 41
Another great design would be a MTM with dual 12 tuned to around 60hz.
If this outputs around 99db, it may give 90% of the performance of a JTR 212 noesis for less than a third of the price.
lemans24 is offline
post #12163 of 12720 Old 02-18-2015, 01:19 PM
LastButNotLeast's Avatar
Quoted: 1480 Post(s)
Liked: 1077
Sure, let's come up with MORE stuff for Erich to do.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #12164 of 12720 Old 02-18-2015, 01:48 PM
tuxedocivic's Avatar
Quoted: 1907 Post(s)
Liked: 1726
Why only 90%
tuxedocivic is offline
post #12165 of 12720 Old 02-18-2015, 01:59 PM
lemans24's Avatar
Quoted: 20 Post(s)
Liked: 41
Why only 90%
Eric mentioned in the diysg forum, a dual 12" MTM with a BA-750 cd and seos 15 waveguide. Don't know how this compares with bms coaxial cd used in the JTR Noesis 212. Just putting out 90% as a guess for now.
lemans24 is offline
post #12166 of 12720 Old 02-18-2015, 06:41 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
That BMS 4593 coax compression driver is crazy expensive!....LOL
jbrown15 is offline
post #12167 of 12720 Old 02-18-2015, 06:49 PM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 201
And that one is the least desirable of BMS's coax CDs.
Face2 is offline
post #12168 of 12720 Old 02-18-2015, 07:00 PM
FreakishlyTall's Avatar
Quoted: 23 Post(s)
Liked: 24
Oooh, that'd be slick... but how about a stupid-cheap one, too, (Dayton 12s + DNA-150?) for we cheapskates and/or tin ears lusting after all the awesome builds 'round this joint? : )
Why only 90%
I'm sure many would love a super-quality, zillion% option... but how about 70% -- for 10% of the cost, too?
I can't help but think there'd be some revenue opportunities in an easily-fulfilled format for DIYSG: Something like "CD + confidential XO diagram and build instructions/options; you source the rest of the parts from wherever you like, and build your own baffle, ya' cheapskate" for some -super- low-cost / entry-level-but-interesting designs.
But maybe I'm the only cheapskate around here?
Heck, I'd volunteer to do order fulfillment for a few models like that; CDs + printouts would probably even fit safely in fixed-rate USPS boxes. Some of us have more space than audio budget, and I'd be happy to help!
FreakishlyTall is offline
post #12169 of 12720 Old 02-18-2015, 07:13 PM
rhodesj's Avatar
Quoted: 852 Post(s)
Liked: 471
Erich is already selling kits at or below cost, thanks to him getting bulk pricing on components. Cheapskate or not, I'm not sure you can beat him on price or quality.
rhodesj is offline
post #12170 of 12720 Old 02-18-2015, 07:45 PM
Liked: 1726
Tall freak, there has been designs done with some of the cheap waveguides and $50 woofers and stuff. Nobody is in to them.
post #12171 of 12720 Old 02-18-2015, 07:56 PM
Erich H's Avatar
Liked: 1771
I thought about doing a B-Stock kit. One or two that used some waveguides that have imperfections that don't actually effect sound quality and some DNA-205's that have a little blip in their frequency response up over 15khz. No one would notice the slight dip at that range but I sit them aside anyway.
I don't have a lot of them but they would make for some good but cheap speaker kits. Just not sure what woofers to pair them up with.
Erich H is offline
post #12172 of 12720 Old 02-18-2015, 08:40 PM
wvu80's Avatar
Quoted: 320 Post(s)
Liked: 285
You would have been a good candidate for the Cheap Thrills, which featured a 12" SEOS and a 15" woofer. This had an incredible sound for $112 per speaker kit with CD, horn, XO and baffle, and I had to buy the $50 woofer and make my own box, $45 per sheet of 3/4" MDF.
http://www.diysoundgroup.com/forum/i...hp?topic=221.0
I wouldn't presume to intrude on Bill Waslo's XO, but I don't see any reason why the DNA-205 ($34) couldn't replace the kit's DNA-360 ($79). In fact, I like the slightly smoother sound of the 205 better.
wvu80 is offline
post #12173 of 12720 Old 02-18-2015, 09:01 PM
wvu80's Avatar
Quoted: 320 Post(s)
Liked: 285
You mean like the Klipsch CF-4? The CF-4 is a phenominal 2-way design, has a huge sound, and is highly sought after by Klipsch guys on the used market, even today.
These were $2500 a pair when new in 1994. My $500 per pair Fusion 10 Pure when paired with a sub comes 95% as close in every way, except the Fusion 10's are more accurate.
wvu80 is offline
post #12174 of 12720 Old 02-18-2015, 09:31 PM
corradizo's Avatar
Quoted: 1039 Post(s)
Liked: 695
I thought the CT's could no longer be made as the buyout woof is gone, no?
corradizo is offline
post #12175 of 12720 Old 02-18-2015, 09:48 PM
Liked: 1077
There's ALWAYS a buyout woofer:
http://www.parts-express.com/promo/c...2)]&PortalID=1
post #12176 of 12720 Old 02-18-2015, 10:23 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
I dont see the point in using a buyout. The design will go dead in short order and all the work that went into it only benefited a limited audience.
The problem with using a smaller CD like the 205 is crossing it low enough to a large driver like a 15". A 12" woofer might make more sense for that CD (not sure what the low end is on the 205 though?). The Dayton PA310 looks like a good option at $65. it has a fairly smooth response which should keep crossover cost down.
Looking at 15"s the Tymphany FSL-1520R02-08 also has a very smooth response for $75, but you probably wouldnt want to go above around 1200hz
Jay1 is offline
post #12177 of 12720 Old 02-19-2015, 03:32 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Celestion ?
Mfusick is offline
post #12178 of 12720 Old 02-19-2015, 05:28 AM
mobeer4don's Avatar
Quoted: 122 Post(s)
Liked: 115
Bull. They were just too cheap to pull the trigger and order them.
mobeer4don is offline
post #12179 of 12720 Old 02-19-2015, 10:50 AM
Quoted: 23 Post(s)
Liked: 24
I have absolutely no doubt about the quality and value of DIYSG designs. None. Nothing but wonderful things to be read about DIYSG projects. In fact, I should just jump in the pool and buy F10s.
And that raises an excellent point: Why kit and ship anything that -isn't- fabulous? Even with a caveat of "[design] prioritizes final cost over ALL else," there would certainly be people buying, then complaining. Because people suck. There's a reason Tiffany's doesn't sell cubic zirconia.
But the F12, just as an example, is $700/pr just for parts, using a $140 woofer and $80 CD. Is a passable 12" two-way not possible, say, with a $50 woofer and a $20-40 CD? The results would -certainly- not be comparable, but might still best anything you can buy in a store for $300/pr? There's a -big- difference between $800/pr and $400/pr... and if ya' think about 7.x.....
Or maybe that's just not possible?
Would that be known for sure? The enthusiasts will post about their awesome builds... but would the more modest not possibly just build on their own, without fanfare? I have to wonder how many SEOS12s PE would ship if there was a link to a < $150-200/each design right there on the product description page?
Of course, I can -certainly- see it being counterproductive to offer them as a time- and resource-consuming kit at DIYSG or elsewhere, with "well, it's just another [$x00] to get a 'better' product..." thinking among purchasers.
Maybe it is just me. I'll work to accept that. I'm weird. *I* can't get past thinking something like "$75 gets you a waveguide, CD and parts list to build a [$200 12-91, or $150 12" 2way, etc]" would be an easily-shipped, interesting offering. But I am cheap and like old, weird cars, older, weirder boats, and masochism.
I guess I'm just frustrated that the public designs I've found all seem to use NLA drivers (DNA-150s, say, which may or may not return for sale outside a kit (and almost certainly aren't worth dealing with individually for Mr. H); or the Cheap Thrills), or are outdated (Econowave's D220 has been surpassed, from what I read, as has its WG been improved upon by the SEOS 12), or defeat the frugality aspect with a numerous-part XO (e.g. Mr. Waslow's Dayton 12-based design available at the DIYSG forum is, I am sure, fantastic, and uses "only" a $75 woofer, but $50+ in XO parts and a $100 CD).
Honest question: Have a missed a public, "here's a screamin' cheap, simple, all-parts-readily-available way to get the intellectually and philosophically super-cool SEOS12 into your life" design?
I wouldn't presume to make demands, or even suggestions, but I know at least *I* am a little frustrated by the idea that you have B-stock that could turn into cash and go to a good home, but no (public) way to use it super-frugally.^ There may not be many of us, but am I really the only one who would jump on "$100 B-stock kit: B-stock waveguide, XO schematic, CD, enclosure dimensions; no baffle, no emails, no support, no free shipping"? At least it'd turn some inventory back into cash....
^ I may have bought a pair of B-stock SEOS12s feeling like it might help the cause (and 'cuz I wanted to see them in person, 'cuz they're cool!), that are now sitting elegantly on my desk waiting for something to be done with them at some point. ; )
Well aware! I may really be the -only- case of "just found this awesome forum about two weeks after the last woofer was sold." ; ) Somehow _just_ managed to miss that ride. And that's pro'ly why I am pining for something absurd. I'll go back to sitting on my hands and hoping for another sudden surprise knockout.
But, the popularity of the CT, along with the Econowaves, does kinda lend -some- support to the notion that there might be some interest in a -super- low-budget SEOS design... and wouldn't moving SEOS-12s via PE put some money in the DIYSG research coffers with zero effort?
Then, of course, there's that. "Maybe if I wait, there'll be an even BETTER, CHEAPER thrill!" At least some of us are kindasorta self-aware. ; )
Fundamentally, and most importantly, though, many thanks to all who share their knowledge and effort, at any budget level! *No* criticism implied or intended!
post #12180 of 12720 Old 02-19-2015, 11:01 AM
Liked: 1726
They have to email me for the design, so ya I think so.
