Hey guys...we need a little rallying here... - Page 418 - AVS | Home Theater Discussions And Reviews
 802Likes
post #12511 of 12532 Old 04-20-2015, 07:37 PM
tuxedocivic's Avatar
Quoted: 906 Post(s)
Liked: 880
3 way facilitates a center orientation nicely also.
tuxedocivic is online now
post #12512 of 12532 Old 04-20-2015, 07:39 PM
W00lly's Avatar
Quoted: 21 Post(s)
Liked: 35
Erich
So we should be able to order some Volt 10"s soon ?
Scott
The CopperFields Cinema
          Current Photo's
W00lly is offline
post #12513 of 12532 Old 04-20-2015, 07:40 PM
Erich H's Avatar
Quoted: 736 Post(s)
Liked: 974
Quick Update and photos on a New Speaker!
I don't normally like to post too much info about upcoming projects, but this is a something I've been wanting to get started for a long time. Different ideas for this speaker were floating around for about 1.5 years until I finally gave up looking for off the shelf parts and decided to go a different route. Couldn't find woofers that would work, or a waveguide......so new things needed to be made.
This took quite a bit of work to get to this point, but I'm happy to say that the 1099's little brother is now in the works.
My goal was an 8 ohm speaker using 8" woofers that could do 70hz in a smaller sealed enclosure or 'full range' in a tower and get down in the mid 30's. Eminence offered to help out and I got some different samples made up. One seemed to have a good mix of power handling, X-max, frequency response, and would work in a sealed or ported box. So it's finally time to get this little beast started.
To me this is a great sized speaker. Roughly 10.5" x 28" and I believe about 12" deep. That's even a nice size for a regular living room. Get out a tape measure because this bugger is smaller than it looks, but should put out some big sound.
Teaser photos:
And the must have.....a rotating mid section so a center channel can be built.
ID:	676793   Click image for larger version
_______________________
The SEOS Waveguide Project
Erich H is offline
post #12514 of 12532 Old 04-20-2015, 07:56 PM
Erich H's Avatar
Quoted: 736 Post(s)
Liked: 974
More info on the 1099's little brother:
All of this has just started to come together and will still take a little time to be done. Forum member Tuxedocivic (designer of the 1099) will be handling the design on this one as well. I just worked on the flat pack last weekend and need to send him the parts.
I ordered a bunch of the mids today because they're not a stocked item and are only built to order in larger numbers. I will be ordering the 8" woofers this week. I was told the mids will take about 80-90 days to get here, woofers will take about 50 days. My guess is that Tux will have the designs done by the time the woofers show up and I will have time to get all the crossover parts and flat packs made up. There might be a preorder set up after the 8" woofers get here, I'm not sure.
Shan87 likes this.
Erich H is offline
post #12515 of 12532 Old 04-20-2015, 08:28 PM
Quoted: 76 Post(s)
Liked: 37
Those look cool. I have a room they would fit nicely in. I'm in on the preorder.
Doradoguy is offline
post #12516 of 12532 Old 04-20-2015, 08:42 PM
Liked: 3
Oh NIIIIICEEEEE!
VRausch is online now
post #12517 of 12532 Old 04-21-2015, 06:27 AM
HFGuy's Avatar
Quoted: 63 Post(s)
Liked: 41
Originally Posted by VRausch View Post
Oh NIIIIICEEEEE!
Damn that looks great !!How overkill would they be for surrounds to my soon to be 1099s.
HFGuy is offline
post #12518 of 12532 Old 04-21-2015, 07:20 AM
Quoted: 906 Post(s)
Liked: 880
Around these parts most say nothing is overkill. I'd actually agree this time, they should make a good surround provided the vertical coverage isn't to limited. I'll have to see what can be done about that.
post #12519 of 12532 Old 04-21-2015, 07:40 AM
Mfusick's Avatar
Quoted: 369 Post(s)
Liked: 1516
Can I ask a technical question regarding the design of this model. Is there a specific reason why you would use (2) side by side midranges in this new model ? I assume it's to get the sensitivity up ? But doesn't that come at a cost of coverage pattern and directivity ? and the million dollar question- is that seemingly worth it rather than using a single midrange in 3way - or a bigger CD/lower XO ? Where does the benefit of the dual mids side by side come into play?
(I don't mean to be questioning the design, I really want to know what the thinking is going into it).
"Too much is almost enough. Anything in life worth doing is worth overdoing. Moderation is for cowards."
Mfusick is online now
post #12520 of 12532 Old 04-21-2015, 07:59 AM
Quoted: 906 Post(s)
Liked: 880
Its been discussed before, but here's the brief reasoning.
- sensitivity
- low height / baffle real estate
- directivity match
- bandwidth
A large mid basically doesn't fit on the baffle properly and a single small one doesn't have directicity or sensitivity.
post #12521 of 12532 Old 04-21-2015, 08:29 AM
Quoted: 76 Post(s)
Liked: 37
Hey Erich,
I know you are super busy but wanted to throw out an idea and I hope this thread is appropriate to do so.
It would be nice to have a notifier when kits are available via email. I believe it's called, extension - notify when products arrive. Open Cart offers it or WooCommerce wait list plug in for 49.00 per year. I think this would be a tremendous addition and take away a few emails you receive.
Thanks again for all you do.
post #12522 of 12532 Old 04-21-2015, 08:50 AM
HFGuy's Avatar
Quoted: 63 Post(s)
Liked: 41
That is not the answer my wallet wanted to hear.
HFGuy is offline
post #12523 of 12532 Old 04-21-2015, 10:31 AM
FreakishlyTall's Avatar
< excitedly heads over to DIYSG >
< clicks around with great hope in his heart >
You're a tease! There's no pre-order info yet... at least that I could find.
That looks *really* interesting. Might just be my solution, too.
With the expanded range of speakers coming, the "which one???!?" emails/posts will likely go up in volume. I bet everyone's ahead of the game, though, with comparative information and/or how-to-choose guides already in development? Maybe even some kind of Choose Your Own Adventure style of guided questions?
Good luck, and, as always, thanks to Mr. H, the designers, early adopters, build-log-writers, etc! Very cool.
FreakishlyTall is offline
post #12524 of 12532 Old 04-21-2015, 10:54 AM
Liked: 4
Hey Erich (or Tux), any idea what the sensitivity will be on the 1099's little brother? Looks like a great speaker.
dorri732 is offline
post #12525 of 12532 Old 04-21-2015, 11:02 AM
Quoted: 76 Post(s)
Liked: 37
I was jumping the gun on my comment " in on the preorder" I believe he is waiting for all parts to even think about pre orders. MY BAD
post #12526 of 12532 Old 04-21-2015, 11:26 AM
No "MY BAD" required! I was grinning the whole time I wrote that. : )
In addition to a "Sarcasm" font, the webbernetz really needs a universal "I'm smiling as I type this!" font. Someone get the IEEE on that.
Go new speaker designs! Very cool! (If only lived vicariously for some of us right now....)
Can't wait to see what else springs forth from this really quite astonishingly awesome group of hobbyists.
post #12527 of 12532 Old 04-21-2015, 11:32 AM
Erich H's Avatar
Quoted: 736 Post(s)
Liked: 974
Should be around 93db. It could have been higher if a pro woofer was used, but there really aren't any pro 8" woofers with higher sensitivity that will hit 70hz in a sealed box or mid/upper 30's in a ported box.
Erich H is offline
post #12528 of 12532 Old 04-21-2015, 11:40 AM
Eyleron's Avatar
Quoted: 210 Post(s)
Liked: 103
...there really aren't any pro 8" woofers with higher sensitivity that will hit 70hz in a sealed box or mid/upper 30's in a ported box.
Looks like next year's custom Eminence design commissioning!
SEOS Fusion 10 Max, SVS PB10 and DIY SI18 subs, Denon X4000, Epson 8500 & 2.35:1 AT Screen
Eyleron is online now
post #12529 of 12532 Old 04-22-2015, 07:22 PM
W00lly's Avatar
Quoted: 21 Post(s)
Liked: 35
I was looking at the 88 special for my TV setup but the little bro of the 1099 looks like it will fit much better for my application. cant wait to see how it performs
Scott
          Current Photo's
W00lly is offline
post #12530 of 12532 Old 04-22-2015, 09:51 PM
Quoted: 906 Post(s)
Liked: 880
That's an honest 93db at 8ohm in free space down to 100hz and a slight roll off down to 70hz and sealed! Not many speaker that size can claim that.
post #12531 of 12532 Unread Today, 03:36 PM
cbarth's Avatar
Liked: 0
This new 1099 little brother (893? ) looks really good!!
So good in fact that I might just make a jump at these when they become available.
Is there a ETA of these speakers?
Does anyone know what kind of mid-drivers is being used? It look's a lot like the Omega Loudspeakers RS5 fullrange drivers...
Cbarth
cbarth is online now
post #12532 of 12532 Unread Today, 04:01 PM
Quoted: 906 Post(s)
Liked: 880
Wish I could tell you. Still in design. I never like to say how long anymore cause I might find something I don't like, or Erich mike get delayed getting parts. I wouldn't doubt mid summer though...
