Hey guys...we need a little rallying here... - Page 423 - AVS Forum | Home Theater Discussions And Reviews
 864Likes
post #12661 of 12681 Old 07-24-2015, 05:48 AM
3ll3d00d's Avatar
Quoted: 749 Post(s)
Liked: 229
is it possible that you are one full cycle off?
I don't see anything to suggest it's a cycle out. For one thing there is nothing in the signal chain to apply a delay but another thing is that a fixed time delay is a phase adjustment that varies by frequency, it seems pretty unlikely that such a delay would still enable a perfect fit to the response over a span of more than an octave.
edit: also, what's going on with getting more spl (cd side) with phase reversed?
it's not the nature of the phase response. The woofer being so far in front really sends it completely out of alignment with the CD, they are somewhat aligned around 1kHz with the same polarity but it shifts to around 2kHz with the CD reversed. This means that the summation is constructive around 1kHz but destructive around 2kHz in the normal polarity case but the roles reverse as polarity is flipped. A pic to illustrate
3ll3d00d is online now
post #12662 of 12681 Old 07-24-2015, 08:23 AM - Thread Starter
LTD02's Avatar
Quoted: 1359 Post(s)
Liked: 1652
Originally Posted by 3ll3d00d View Post
A pic to illustrate
out of curiosity, why would you choose such a mixed phase response through the crossover region? is there another advantage that you are trading that off against?
Listen. It's All Good.
LTD02 is offline
post #12663 of 12681 Old 07-24-2015, 10:53 AM
3ll3d00d's Avatar
Quoted: 749 Post(s)
Liked: 229
the speakers will be beneath the screen, i.e. below ear height, hence the design was to use a angled baffle to fire such that on axis is at ear height at the LP. However this means the woofer is too far forward & I can't see a way to get the phase response into line. I didn't think the AC of the woofer would be this far forward tbh.
I had been thinking of changing the design anyway so this problem is quite handy in that sense. I'm now going to go with a flat baffle for the woofer and house it in a separate enclosure. I then intend to put the horn on top in another enclosure with a slight rake to the baffle and I might also rear mount the woofer to claim back another cm or so. This should fix the phase response alignment nicely.
post #12664 of 12681 Old 07-24-2015, 10:30 PM - Thread Starter
LTD02's Avatar
Liked: 1652
I see. that shouldn't (theoretically) create a problem though--no reason why a forward aimed main lobe can't be tilted up by aiming the speaker up physically or sloping the baffle upward.
I took a shot at trying to recreate your phase reponse in winisd (as that's all I've got to work with).
while not a perfect simulation, it is pretty close.
the big problem appears to be the different "roll rate" through the crossover region.
now to try to "fix" it. first, the net slope of the woofer through the crossover region should be about the same as the total net slope for the tweeter. I used a 4th order low pass to get things going. but that still left quite a mismatch out-of-band, so I applied another 4th order up around 5500hz to match up the upper end.
now the slopes are roughly the same through the crossover region (as well as outside of it), so with a simple 180 degree phase reversal, they will overlap nicely.
those would be net acoustic slopes btw and the precise values aren't important. just provided to give some possible clues for where to look for the fix.
Name:	phase - model.png
ID:	848794   Click image for larger version
Name:	phase - fix.png
3ll3d00d likes this.
LTD02 is offline
post #12665 of 12681 Old 07-25-2015, 02:53 AM
3ll3d00d's Avatar
Quoted: 749 Post(s)
Liked: 229
Thanks for the suggestion. I will go back through some of my various sims and play around some more.
post #12666 of 12681 Old 07-27-2015, 12:00 AM
wormraper's Avatar
Quoted: 276 Post(s)
Liked: 129
well, being that this year has been VERY busy for me, and I was just plain lazy it's taken me a while (I bought the dang speakers in October 2014)... I got the first 2 of my 4 surrounds wired up (switched to 5.1 for the next week, maybe 2 until I can get the last 2 speakers up for my back surrounds)... I decided I was tired of waiting and cutting angled cuts so I bought the Flat packs from Erich over at DIYSoundgroup to finish up the boxes and let me say this. they are EASY to assemble. I'm not the woodworker, my buddy is, I'm just good at designs and tweaking stuff. long story short, I built the boxes over the weekend and finished running them with duratex in 24 hours... the last 2 boxes just need duratex and I can toss in the components
I'm hanging them on my side walls with french cleats from Home Depot and they blend seamlessly with my SEOS 15 Cheap Thrills. the clarity on these things are WAAAAAAAAAAAAAAAAAY better than my Polk M30's, giving off effortless detail that I didn't realize was in the audio track before. absolutely love that they're hung up near the ceiling and angled down so I don't have to have my sides on stands anymore taking up space. here is the pics I took to show the process
I'll be sure to listen to them for the rest of the week and post a review over at Diysoundgroup.
Mfusick, LTD02 and asarose247 like this.
wormraper is online now
post #12667 of 12681 Old 07-27-2015, 09:09 PM
asarose247's Avatar
Quoted: 319 Post(s)
Liked: 154
Flatpacks are just simply wonderful ,
some smart guy with a good idea looked around for the laziest man he could find and explained what he wanted.
Lazy guy to the rescue.
In the last 25 months I have built 6 subs and helped on another 2, all from full sheets and I had fun (I keep telling myself) . .
but those volts 6 kits were just so sweet, nice to feel working smarter rather than harder.
Waiting for your review . . .
what's next?
DIY FAN Denon X5200 , Emotiva UPA7, for 7.3.4 ATMOS/DSU/NEO:X SHARP 80" LED/LCD
FL/FR: DIYSG Fusion 15's , C: DIYSG 88 Special , SL/SR: RC3II , SRL/SRR: F-3Towers, TF & TR: SLX, FW: Volt 6
2 30" BF THTLP'S , SUBMAXIMUS, & 2 LOWARHORNs
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is offline
post #12668 of 12681 Old 07-27-2015, 09:10 PM
asarose247's Avatar
Quoted: 319 Post(s)
Liked: 154
what's next?
post #12669 of 12681 Old 07-27-2015, 09:18 PM
steste1122's Avatar
Originally Posted by asarose247 View Post
what's next?
Self assembling crossovers.
steste1122 is offline
post #12670 of 12681 Old 07-30-2015, 01:19 PM
rajacat's Avatar
Quoted: 27 Post(s)
Are the plastic SEOS12 and the AutoTech SEOS12 waveguide dimensions the same?
I noticed that the AutoTech SEOS12 is 70mm deep whereas the plastic DIY Sound Group is 88.9mm deep. Were there changes to the original design after AutoTech started production and before the DIY Sound Group SEOS12 went into production?
rajacat is online now
post #12671 of 12681 Old 07-30-2015, 01:37 PM
tuxedocivic's Avatar
Quoted: 1134 Post(s)
Liked: 1047
My guess is there's a mistake. I'm not at home or I'd measure mine.
tuxedocivic is online now
post #12672 of 12681 Old 07-30-2015, 02:13 PM
rajacat's Avatar
Quoted: 27 Post(s)
I was over on another forum and got into a mini debate about the merits of the H290c to the SEOS12. He claimed that the SEOS was too shallow and thereby had more ripple and less pattern control. I recalled that this debate was aired somewhere else but I couldn't remember where. After looking at the depth measurements, I thought that there might have been some changes to the basic design prior to the plastic ones going into production.
post #12673 of 12681 Old 07-30-2015, 02:24 PM
Liked: 1047
Was it audio circle? I think Wayne hangs out over there. He cherry picked some bad measurements and spouted off some bad info about the seos. Which was about it being to shallow and having ripples in the response. Exactly what you were hearing. It was quite a blatant rip off unfortunately. I lost all respect for him as one of the measurements he took was of someone I helped. The person had never measured before. I took one look and said there's a problem with this measurement and it's wrong. Despite this Wayne insisted it was right and used it in his attacks on seos. Pathetic really.
That's my guess. Sounds like a repeat of the same story used here except on a forum he's popular on.
Face2 likes this.
post #12674 of 12681 Old 07-30-2015, 02:44 PM
rajacat's Avatar
Quoted: 27 Post(s)
Yeah, It was audio circle. It wasn't Wayne.
Here's the link to the discussion.
http://www.audiocircle.com/index.php?topic=136205.0
post #12675 of 12681 Old 07-30-2015, 05:58 PM
Erich H's Avatar
Quoted: 870 Post(s)
Liked: 1041
The fiberglass and plastic versions are the same.
The H290c is bigger than the SEOS-12 and should be compared to the SEOS-15.
The reason there are multiple SEOS sizes is to give the end user multiple choices when pairing it with different sized woofers. If they're going to be compared, they should pick the right size to compare against.
_______________________
The SEOS Waveguide Project
Erich H is online now
post #12676 of 12681 Old 07-30-2015, 08:27 PM
Liked: 1047
That guy seems to have based his opinion on Wayne's misleading threads on his forum. He uses faulty measurements to endorse his own product. I use to be nicer about it, but that's pathetic.
LitoGeorge and HT Geek like this.
post #12677 of 12681 Old 07-31-2015, 05:22 AM
LitoGeorge's Avatar
Quoted: 37 Post(s)
And...... you boys have bigger fish to fry. Like...... the subject of my wet dreams which is a certain 1899. And a 893. And....
I'd slap up some all important "Atta Boys" here, but I donseenobuttunz
tuxedocivic likes this.
LitoGeorge is online now
post #12678 of 12681 Old Today, 08:57 AM
atabea's Avatar
Quoted: 74 Post(s)
Liked: 83
Looks like the Maximus 12 and Maximus 12 LXE have received their pricing.
http://www.diysoundgroup.com/maximus...us-12-lxe.html
atabea is online now
post #12679 of 12681 Old Today, 09:49 AM
Erich H's Avatar
Quoted: 870 Post(s)
Liked: 1041
Those prices will probably fluctuate around a bit until I see how much is needed to cover the 'free shipping'. I estimated $40 per speaker but the panels are pretty big and that 12" woofer weighs about 25lbs by itself. I'm guessing about 2 packages per speaker.
I also need to get the options listed for those models because they can be made into just one big floor stander, or broken up into 2 cabinets like the photo shows. Round plastic ports, or slot ports and then there can also be a center channel as well.
post #12680 of 12681 Old Today, 09:54 AM
atabea's Avatar
Quoted: 74 Post(s)
Liked: 83
Erich, can you please estimate the dimensions of the different versions (single cab vs the dual cab)? Also, are there any advantages to going single cab vs dual cabs?
thanks
post #12681 of 12681 Old Today, 09:56 AM
atabea's Avatar
Quoted: 74 Post(s)
Liked: 83
..............And while you are answering questions; any plans for assembled crossovers and flat packs?
