Dayton OmniMic Precision Measurement System - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #991 of 2256 Old 11-09-2011, 12:01 PM
Topend's Avatar
Originally Posted by IceTBC View Post
I just downloaded v.3 of the OmniMic software off Dayton's page here http://www.daytonaudio.com/index.php...nt-system.html and my Norton Antivirus claims it's a security threat with this WS.Reputation.1 http://securityresponse.symantec.com...vid=4294919973. Is this a false detection that can be ignored? Perhaps Dayton needs to contact Symantec?
The best thing I ever did was to replace Norton with a free version of AVG. I couldn't believe how much faster my PC was without Norton.
It's been many years now and no issues at all.
Dave.
Topend
I listen to 50% HT and 50% 2 channel music.
Topend is offline
post #992 of 2256 Old 11-12-2011, 04:10 PM
laugsbach's Avatar
Quoted: 169 Post(s)
Liked: 223
I used the OM with the test tone on my AVR to set speaker levels to 75dB at the LP and then double checked with my Galaxy digital SPL meter and it was reading a SPL of 65dB. I have the level range set correctly on the Galaxy meter.
Has anyone else used the OM to set speaker levels? How did it compare to your SPL meter?
TIA...
laugsbach is offline
post #993 of 2256 Old 11-12-2011, 05:58 PM
Gooddoc's Avatar
Quoted: 3114 Post(s)
Liked: 2421
I've used OM multiple times and it is accurate to Audyssey Pro. Are you using Peak or Max on OM to set the level? Use Max and set to C slow.
Gooddoc is offline
post #994 of 2256 Old 11-12-2011, 06:13 PM
laugsbach's Avatar
Quoted: 169 Post(s)
Liked: 223
Hi Gooddoc, I am reading the dBSPL from the SPL/Spectrum Tab..there is a visual area that looks like the old analog RS meter needle...I guess that would be the same reading as the Max level.
The thing is, my room has never sounded better after using the OM. I found a quote from Bill Waslo about SPL:
"It does operate with absolute SPL (at least when measuring using Sine Sweep; it is relative dB with pink pseudo-noise)."
post #995 of 2256 Old 11-12-2011, 06:18 PM
laugsbach's Avatar
Quoted: 169 Post(s)
Liked: 223
I have OM set to "C" and "Slow" as well as my Galaxy SPL meter and there is a 10dB difference between the two using the test tone from my Onkyo 805 AVR.
post #996 of 2256 Old 11-12-2011, 06:22 PM
Gooddoc's Avatar
Liked: 2421
There are Min, Max, and Peak readings under that meter needle. That is the Max number I speak of. Be sure to press the reset button before each measurement.
Gooddoc is offline
post #997 of 2256 Old 11-12-2011, 06:32 PM
laugsbach's Avatar
Quoted: 169 Post(s)
Liked: 223
Thanks Gooddoc! I will give it a try again tomorrow and reset the reading between each speaker measurement...
post #998 of 2256 Old 11-13-2011, 05:42 AM
hometheatergeek's Avatar
Quoted: 41 Post(s)
Liked: 44
Morning all, Still on the fence about buying the OM. Anybody with the new software have a graph they can post showing the LFE can now be graphed below 20 Hz?
Hometheatergeek
aka AL
My Current System
hometheatergeek is online now
post #999 of 2256 Old 11-13-2011, 07:05 AM
GPBURNS's Avatar
Quoted: 140 Post(s)
Liked: 314
something quick
15400 Watts of Seaton Power -Quad SubMersived
GPBURNS is offline
post #1000 of 2256 Old 11-13-2011, 08:22 AM
exojam's Avatar
Liked: 33
So I have downloaded and installed the latest version of Omni Mic and started getting errors when trying to load an FDR file.
I also add something like a 1-24 or 1-6 to the file name so I can tell what smoothing was used for the measurement. Now when I try to load the saved files I get a 1-24' is not a valid floating point value message popping up. The FDR does load though. Anyone else seeing this?
Running Omni on Windows 7.
James
exojam is offline
post #1001 of 2256 Old 11-13-2011, 08:31 AM
bwaslo's Avatar
Quoted: 68 Post(s)
Liked: 188
The program is arranged to interpret numbers in the filename as indexes (usually for angles in polar plotting). Try putting a space after the '-', or use something other than '-' for the separator, such as an underscore _. The program is parsing the numerals and the negative sign, all valid number characters, and trying to interpret them as one number.
___________________________________________
DIY Synergy horn spreadsheet Synergy horn spreadsheet and pdf
XSim -free crossover designer and simulator XSim install file
Easy and cheap sound diffusers (the "Depot Diffusers") making easy DIY depot sound diffuser-panels-step by step.html
SmallSyns - point source controlled directivity in a manageable size SmallSyns
bwaslo is offline
post #1002 of 2256 Old 11-13-2011, 08:34 AM
Quoted: 41 Post(s)
Liked: 44
Originally Posted by GPBURNS View Post
something quick
Thank you very much GP.
Hometheatergeek
aka AL
My Current System
post #1003 of 2256 Old 11-13-2011, 08:46 AM
exojam's Avatar
Liked: 33
Cool, thanks Bill.
James
exojam is offline
post #1004 of 2256 Old 11-13-2011, 10:25 AM
GPBURNS's Avatar
Quoted: 140 Post(s)
Liked: 314
no problem - great product - highly recommended
The only issue I can forsee with the unit in the long run is the mini usb connection into the mic - I have already replaced it once.
You need to be really careful attaching it
as easy to damage the connection.
GPBURNS is offline
post #1005 of 2256 Old 11-13-2011, 10:29 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5973 Post(s)
Liked: 5036
Yeah, I just got my OmniMic. Installed the software but haven't taken any measurements yet.
My only complaints so far is the small usb, seems like it could break after some time. I'll have to be very careful with that connection. Also, the included mic clamp thingy ... umm.. not all that hot. Barely seems to hold the OmniMic at all. Needs a lock. May end up buying another cuz I foresee this one annoying the hell out of me.
Software looks awesome though!
Scott Simonian is offline
post #1006 of 2256 Old 11-13-2011, 10:35 AM
dormie1360's Avatar
Quoted: 131 Post(s)
Liked: 87
Thought is was just me. With the mic's connection being recessed like it is, I seem to struggle getting the connection lined up properly when inserting the cable.
John
John
dormie1360 is offline
post #1007 of 2256 Old 11-13-2011, 10:36 AM
kbarnes701's Avatar
Quoted: 6824 Post(s)
Liked: 5262
Originally Posted by dormie1360 View Post
thought is was just me. With the mic's connection being recessed like it is, i seem to struggle getting the connection lined up properly when inserting the cable.
john
+1
kbarnes701 is offline
post #1008 of 2256 Old 11-13-2011, 02:27 PM
laugsbach's Avatar
Quoted: 169 Post(s)
Liked: 223
Hi Gooddoc, I tried again today and my SPL meter is reading 65dB when my OM is reading 75dB while playing the test tone from the Onkyo 805 AVR. I found my old Avia Guide to Home Theater DVD and played the Reference Tones (85dB) at a MV of 0.0dB and the OM measured 85dB while the SPL meter measured 75dB.
I doubled checked all of the audio tests on this disc and everything measured as expected with the OM. I guess my cheapo SPL meter is bad...
Anyone else tested their OM against a SPL meter with test tones from their AVR or test disc?
post #1009 of 2256 Old 11-13-2011, 02:29 PM
laugsbach's Avatar
Quoted: 169 Post(s)
Liked: 223
John
Same here....I'm leaving it plugged in and leaving the mic in my stand until I am completely finished running all of my tests...
post #1010 of 2256 Old 11-13-2011, 04:40 PM
Phillips751's Avatar
Hi i am new to this thread
Has anyone got any bass decay (both) graphs to share.
I downloaded the new software and notice that there is a spectrogram that only goes down to 300hz(?). Is this not intended for room only speaker close micd? I see that REW Spectrogram goes down to 15hz and the time vs frequency is the other way around.
Cheers
Phillips751 is offline
post #1011 of 2256 Old 11-14-2011, 11:41 AM
Gooddoc's Avatar
Liked: 2421
Glad to hear you've worked it out. Yes I have checked the meter against a known test tone. It was accurate within 1-2 dB of an Audyssey Pro calibration.
Gooddoc is offline
post #1012 of 2256 Old 11-14-2011, 04:56 PM
Gooddoc's Avatar
Liked: 2421
Waslo,
Could you explain the Peak measurement in the SPL tab. Is it an instantaneous measurement and, how do I say this tactfully....is it accurate? .
I ask because I'm seeing 112 dB peaks in reference level soundtracks which I'm told can't exist. Just trying to figure out what's going on. The system is properly calibrated(double and triple checked by multiple methods).
Gooddoc is offline
post #1013 of 2256 Old 11-14-2011, 06:16 PM
bwaslo's Avatar
Quoted: 68 Post(s)
Liked: 188
Think in terms of a peak in the time domain waveforms. It could happen if, for instance, the instantaneous pressure from various drivers (such as tweeter signal summing with woofer signal) plus various room reflections summed to a higher peak at an instant than any one driver could do in a sine wave.
Another way, you can see that a high peak could happen if the mic were shoved right up to a single driver, right? At a distance, that same pressure buildup could also happen with a summation in reflections, similar to what could be arranged to happen broadband if a speaker were playing into a concave reflector that reflected all the radiation back to a point elsewhere (like in a "listening gallery"). While in a room that effect wouldn't be broadband, at times with all the waves reflecting around there will be instantaneous peaks and nulls occurring, with rms (averaged) values still being normal.
bwaslo is offline
post #1014 of 2256 Old 11-14-2011, 09:50 PM
BiGBADDABOOM's Avatar
Why can't a 112dB peak happen at reference level?
BiGBADDABOOM is offline
post #1015 of 2256 Old 11-15-2011, 01:51 AM
dannut's Avatar
Lets just say that soundfields in room are statistical in nature. You can have changing peaks/nulls not only where exactly you measure but also depend on temperature/humidity/convection etc.
Spatial average gets you are more meaningful reading.
Also this 105dB peak at reference is for single channel only - all channels blasted gets easly above this.
dannut is offline
post #1016 of 2256 Old 11-19-2011, 07:09 AM
Archaea's Avatar
Quoted: 3086 Post(s)
Liked: 2715
Would the fact the omnimic is on sale for $250 dollars at parts-express kick you off the fence? It did me!
Buying right now.
Archaea is offline
post #1017 of 2256 Old 11-19-2011, 02:32 PM
GPBURNS's Avatar
Quoted: 140 Post(s)
Liked: 314
be nice to see some of you DIY guys to post sweeps
showing decent flat ouput below 10Hz with the omni
my seatons are good to about 13/14hz
GPBURNS is offline
post #1018 of 2256 Old 11-19-2011, 05:26 PM
Quoted: 41 Post(s)
Liked: 44
Buying right now.
No I was thinking to give REW one more shot durning the holidays. Free vs $ 250 is still a consideration.
Hometheatergeek
aka AL
My Current System
post #1019 of 2256 Old 11-19-2011, 05:47 PM
Archaea's Avatar
Liked: 2715
ahhh, but REW isn't free.
You need a calibrated mic ($100?), you need an SPL meter ($50), you need more time invested to figure out how to use the software, many times the onboard soundcard isn't of high enough quality to use for REW I've read($50?). All of these are concerns.
omnimic is more pick up and play, soundcard built into the mic -- pre-calibrated to know exactly what's going on, and simple plug in USB interface with calibration tones on a disk that play through the dvd player.
REW may be more powerful, and is likely cheaper overall - but it can't be considered free outside of the software download itself which definately isn't all that you need.
Archaea is offline
post #1020 of 2256 Old 11-19-2011, 06:36 PM
laugsbach's Avatar
Quoted: 169 Post(s)
Liked: 223
You have that right!
