Dayton OmniMic Precision Measurement System - Page 56 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #1651 of 2203 Old 05-22-2012, 04:43 PM
Phillips751's Avatar
Originally Posted by goneten View Post
Anyone use XTZ Pro II, vs Omnimic? Which software/mic combo is better and more accurate? All I can say is that XTZ has a much prettier graphical interface. But perhaps the experts can explain the benefits Pro II has or doesn't have over Omnimic.
Good to see hopefully this thread is moving again.
Has discussion moved somewhere else?
Funny you bring this up, i was reading Stereophile Rotel and Bryston reviews and XTZ was used and a liitle review on one of the pages (either Rotel or Bryston).
Its not a matter of "prettier" graphical interface its a matter of easier to look at/follow + accuracy.
I believe that there has been a big improvement in the hardware, which the reviewer comments on. XTZ looks very good for room eq and straight forward operating for Rooms
Also there is a time alignment for aligning the speakers with the sub.
Phillips751 is offline
post #1652 of 2203 Old 05-23-2012, 03:17 AM
goneten's Avatar
What do you mean XTZ Pro is more suited to rooms? Isn't Omnimic also suited to rooms?
I guess I'm a little conflicted. Both programs look good, but I like the visual look of XTZ. I have no idea whether it's as accurate, or as accurate as REW or not. Perhaps someone who has the software can comment.
Thanks for the help Phillip.
goneten is offline
post #1653 of 2203 Old 05-23-2012, 06:56 AM
Kal Rubinson's Avatar
Quoted: 712 Post(s)
Liked: 487
Omnimic has better tools for speaker design, has more tools but it less convenient for the basic acoustical FR and decay measurements than is XTZ. Before buying a tool, you need to decide what your particular need is. After all, not all hammers are the same.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #1654 of 2203 Old 05-23-2012, 09:09 AM
goneten's Avatar
Hi Kal. My needs will be acoustical analysis, measuring frequency response and basic calibration (setting speaker/subwoofer levels, time alignment etc). I'm not designing speakers or anything like that.
So you reckon XTZ would be better suited for my needs?
goneten is offline
post #1655 of 2203 Old 05-23-2012, 09:18 AM
goneten's Avatar
Actually emailed the rep for XTZ and he told me that XTZ Pro II measures at 1/12th resolution (1/6 for XTZ standard) for the subwoofer analysis. That isn't that great, is it? REW measures higher than 1/48.
So basically this is going to be a very smoothed result. There is no unsmoothed option, as far as I understand it. If I'm adding acoustic treatment to my room and want to see what effect it had on frequency response then I imagine the measurement will not be very accurate.
goneten is offline
post #1656 of 2203 Old 05-23-2012, 09:25 AM
Quoted: 712 Post(s)
Liked: 487
Right. OTOH, given how we hear and what 1/12 octave constitutes in the bass range, I wonder if there is any value beyond that for standard setup/acoustics use.
Kal Rubinson
post #1657 of 2203 Old 05-23-2012, 09:57 AM
Gooddoc's Avatar
Quoted: 2914 Post(s)
Liked: 2032
The argument for high resolution, particularly in the lower Hz, ie. <20, has been argued in these forums ad nauseum. Bottom line is that some want to see the data points. They have worked hard to have numbers down there and they want to see it in all its glory .
As you said, different hammers.
But I do prefer to work at a higher resolution when trying to solve problems, then I smooth it at the end to admire my work. So my opinion is a bit biased since I don't have a whole lot to work with down there. When I add some more capability down there perhaps my opinion will change.
Gooddoc is online now
post #1658 of 2203 Old 05-23-2012, 10:07 AM
goneten's Avatar
Are you saying there is little merit in using high resolution measurements (or high data points) in the low frequency range? Not arguing with you, just curious to know why. What's the point then of using high data points?
goneten is offline
post #1659 of 2203 Old 05-23-2012, 10:15 AM
Gooddoc's Avatar
Liked: 2032
Yep. For typical HT rooms, most of what's down there is PVG as far as I understand it and there is very little that can be done to effect high Q (>1/12 octave) FR abnormalities in those regions. So I'm not sure what to do with the data if it was captured.
post #1660 of 2203 Old 05-23-2012, 10:20 AM
goneten's Avatar
Forgive me, but what is "PVG"?
goneten is offline
post #1661 of 2203 Old 05-23-2012, 10:33 AM
noah katz's Avatar
Quoted: 980 Post(s)
Liked: 329
PVG = pressure vessel gain, which is what happens when the wavelength is so long that the wave is close to in-phase throughout the room, raising the pressure simultaneously everywhere.
This happens completely only at 0 Hz, and with a perfectly sealed room with rigid boundaries; the effect diminishes from there but results in very significant room gain.
Noah
noah katz is offline
post #1662 of 2203 Old 05-23-2012, 11:15 AM
goneten's Avatar
Thanks Noah. What is your take on the high resolution measurement story? What do you use for acoustical analysis?
goneten is offline
post #1663 of 2203 Old 05-23-2012, 11:19 AM
FOH
FOH's Avatar
Quoted: 39 Post(s)
Liked: 234
In addition, when the wavelengths become too large for the space (actually half the sine-wave), they change from cyclic propagation, to pressurization. One of the rare instances of free lunch. It's a wonderful thing. Another stellar benefit is the fundamental is rendered wonderfully, yet the harmonics don't benefit from the same acoustic reciprocity due to their shorter wavelength.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #1664 of 2203 Old 05-23-2012, 11:52 AM
noah katz's Avatar
Quoted: 980 Post(s)
Liked: 329
Why in addition when it's the same thing?
Noah
post #1665 of 2203 Old 05-23-2012, 02:03 PM
FOH
FOH's Avatar
Quoted: 39 Post(s)
Liked: 234
I've shared this with many involved in audio,..explained it so many times. And oftentimes, until I say "change from cyclic propagation, to pressurization", many individuals will express that is what clears it up for them.
Also, in my experience, the effect of a room being sealed is much less important to the rooms boundary surfaces relative acoustic impedance. Admittedly, my sample size isn't enourmous,...like some installer that measures each room's LF transfer function. But, that's what I've found in each space I've measured.
FOH is offline
post #1666 of 2203 Old 05-23-2012, 02:32 PM
thrang's Avatar
Quoted: 1723 Post(s)
Liked: 1469
Does anyone have a contact at Dayton? I've emailed three three times and left two voicemails at their company, trying to followup up on my mic return (to have a cal file created), and no one is bothering to contact me...
thrang is online now
post #1667 of 2203 Old 05-24-2012, 12:07 AM
noah katz's Avatar
Quoted: 980 Post(s)
Liked: 329
gotcha
Noah
post #1668 of 2203 Old 05-24-2012, 01:23 AM
goneten's Avatar
Noah, how dare you not respond to my question. I'm Goneten, I deserve royal treatment. Okay, let me reiterate : what is your stance on the high resolution/data point position? For acoustical analysis and calibration, is higher than 1/12 octave necessary? For all intents and purposes you can leave out applied EQ. Just analysis and calibration. What software do you use?
goneten is offline
post #1669 of 2203 Old 05-24-2012, 05:26 AM
goneten's Avatar
As a matter of interest, what software do you use for measuring?
goneten is offline
post #1670 of 2203 Old 05-24-2012, 06:20 AM
exojam's Avatar
Liked: 33
Post 1549.
"As some of you know we made a recent hardware manufacturing switch from the original OmniMic to the recently introduced OmniMicV2. Unfortunately, during the changeover it appears the first batch of microphones were calibrated using a procedure that is not intended for the OmniMicV2 system. We know you are eager to use your new OmniMicV2 so today we are shipping replacement correctly calibrated V2 microphones. Since you may receive two OmniMicV2 please call Parts Express at 1-800-338-0531 so we can verify by serial number which is the right one. We will also be sending a postage paid label for returning the miscalibrated OmnimicV2 We apologize and again want you to know how much we appreciate you and your patience as we correct this problem.
Thank you.
Rich Taylor
Richt@daytonaudio.com
James
exojam is offline
post #1671 of 2203 Old 05-24-2012, 09:25 AM
Quoted: 712 Post(s)
Liked: 487
It depends on what I am measuring. If it can be done by XTZ, that is what I use. If I need more resolution and more tools (and that is rare), I use TEF25. http://www.gold-line.com/tef/t-tefkit.htm
Kal Rubinson
post #1672 of 2203 Old 05-24-2012, 09:33 AM
goneten's Avatar
Let's assume you're measuring frequency response. Do you use XTZ or TEF25? Why would you need more resolution that XTZ has to offer? Just being devils advocate here... is all.
goneten is offline
post #1673 of 2203 Old 05-24-2012, 09:35 AM
noah katz's Avatar
Quoted: 980 Post(s)
Liked: 329
Not sure I'm that qualified to answer on measurement issues, but I'd say it is.
Somewhere back in this thread Bill (bwaslo, author of OM) explained the resolution issue as regards OM, and IMO satisfactorily made the case that it is sufficient even at the lowest freq.
I have OM, no way I have the patience to deal with setting up REW.
Noah
post #1674 of 2203 Old 05-24-2012, 09:37 AM
Quoted: 712 Post(s)
Liked: 487
As I said, I rarely have reason to use the TEF25 and mostly for functions, like impulse response and noise level, that are lacking on the XTZ. I cannot recall ever requiring it just for the increased FR resolution although it is available.
Kal Rubinson
post #1675 of 2203 Old 05-25-2012, 04:48 AM
goneten's Avatar
Thanks Kal. Your input is appreciated. So basically the consensus here is that 1/12 octave resolution is good enough at low frequencies for straight analysis, unless you need to apply EQ filters, then you need finer resolution.
goneten is offline
post #1676 of 2203 Old 05-26-2012, 11:22 AM
goneten's Avatar
Bump.
goneten is offline
post #1677 of 2203 Old 05-26-2012, 11:37 AM
Quoted: 712 Post(s)
Liked: 487
I didn't say that. In fact, I used the EQ filters from XTZ to set up the PEQ in the Rotel RSP-1572 quite successfully.
http://www.stereophile.com/content/music-round-53
Kal Rubinson
post #1678 of 2203 Old 05-26-2012, 12:35 PM
goneten's Avatar
Kal, you have used Omnimic and XTZ. Of the two, which software do you prefer to use 99% of the time?
goneten is offline
post #1679 of 2203 Old 05-26-2012, 02:46 PM
Quoted: 712 Post(s)
Liked: 487
kal, you have used omnimic and xtz. Of the two, which software do you prefer to use 99% of the time?
xtz.
Kal Rubinson
post #1680 of 2203 Old 06-09-2012, 08:28 AM
goneten's Avatar
Kal, why do you prefer to use XTZ over Omnimic? Just a quick question. Can you set SPL levels for the speakers and subwoofer with Omnimic, and is it more accurate than using a Radioshack SPL meter?
goneten is offline
