Dayton OmniMic Precision Measurement System - Page 71 - AVS | Home Theater Discussions And Reviews
 2Likes
post #2101 of 2126 Old 09-29-2014, 06:51 AM
primetimeguy's Avatar
Quoted: 319 Post(s)
Liked: 184
Originally Posted by Nabs17 View Post
Just received my Omnimic V2 system...got it setup and ran a FR for my LCR with test tracks 2,6 and 12 as recommended. I'll post the results here and ask if anything stands out to folks who are more familiar with interpreting results. A couple of things I think stand out...my LR are pretty similar but I have a couple of peaks in the center channel and a big dip at 10K.
So what stands out to you all?
Do you by chance have a receiver with Audyssey Dynamic eq and have it turned on? As another poster mentioned, you have some major bass boost going on.
primetimeguy is online now
post #2102 of 2126 Old 09-29-2014, 11:24 AM
Nabs17's Avatar
Quoted: 248 Post(s)
Liked: 93
Originally Posted by jkasanic View Post
Are you using any form of EQ? Your bass looks boosted quite a bit but the general slope of your full range response looks pretty good. If you want to get more feedback on the measurements, your best bet might be to try using your OM mic with REW and post some spectrograms, waterfalls etc. in the REW thread. This isn't a knock against OM (I used to own it as well and still keep tabs on the thread for any updates) just that this thread doesn't get a lot of activity and when it does, it's mostly related to the software, test disc etc. and not evaluating in-room response. Be sure to read AustinJerry's guide before posting though. It will make taking measurements as simple as it is with OM and you'll know the guidelines for the graphs and charts which will facilitate the feedback from other members.
Thanks for the feedback. I looked at REW before but Omnimic just seemed easier....even though more expensive. I will look into the REW forum for information on reading/deciphering graph data because that's what I need.
The bass boost is man made I forgot that I had turned the gain up on my subs....so that's what is causing that. I also thought my general slope looked pretty good as well but wasn't sure.
Thanks again and I'll start reading the REW forum.
Nabs17
Nabs17 is online now
post #2103 of 2126 Old 10-06-2014, 12:20 PM
KB1
KB1's Avatar
Taking Measurements Questions
Hi all,
I recently bought the OminiMic v2 kit, which also came with a free tripod and 5.1 DVD as part of a Parts Express promotion.
I am mostly interested in 1) finding the best possible location for my subwoofer, and 2) helping with room treatments selection and analyzing the before and after room treatments effects on frequency response and Bass Decay.
To that end, I tried to take measurements using the Bass Decay tab but I got stuck pretty quickly with some basic questions. I did go through the thread but did not find (or maybe simply did not understand) what I was looking for so apologies in advance for the stupid questions.
When I use the Bass Decay tab, it asks me to play tracks 4, 10, 6. Each track seem to be about 3 and a half minutes long.
- Am I supposed to play each entire track and in succession, or just one beep/cycle per track?
- Do I pause the graph in between tracks to take measurements?
- Does anyone have a glossary of which track correspond to what frequencies? (e.g. track xx measures 20 to 80Hz). I am mainly interested in the bass region of the frequency response and may not want/need to plot a full response.
- Is it possible to just measure a segment of the frequency response, e.g. 20hz to 200hz?
Likewise the Frequency Response Tab requires to have tracks 2, 6, 12 (7, 8, 13, 14) played.
- What does this mean exactly? Play the tracks in succession? Why are some of the tracks in parentheses?
By the way, interesting enough, the DVD operates differently from the CD. For Bass Decay, for instance, there is only one track to play per speaker.
Sorry, basic stuff, but I have never used a measurement software and I am totally confused. What I did in the past was playing a test CD (with either sinewaves or pink noise at specific frequencies) that I have and measure each level with an SPL meter (Galaxy) to plot a curve. A very laborious process, which I was trying to avoid.
Many thanks in advance for the help.
KB1 is offline
post #2104 of 2126 Old 10-06-2014, 12:25 PM
Quoted: 319 Post(s)
Liked: 184
I thought the track listing was provided, or maybe check the help within the application. I know I have a printout of the tracks I keep with my kit. There can be multiple tracks that can be used for a given measurement/plot type, you use which ever one's you want. But for any measurement you just play the track and when you get your measurement saved you can stop it. Tracks are long just to allow you to make multiple measurements and tweaks without having the play the track many, many times.
post #2105 of 2126 Old 10-06-2014, 12:30 PM
KB1
KB1's Avatar
Thanks Primetimeguy. I did not find the track listing in the manual but will look again. I thought maybe each track only tests a specific frequency range? Thanks for your answer on playing a track only long enough to take a measurement. That's what I thought but I was not sure, very helpful. If you find the track listing anywhere, please let me know. Much appreciated!
KB1 is offline
post #2106 of 2126 Old 10-06-2014, 12:44 PM
KB1
KB1's Avatar
Thanks Primetimeguy, I actually found the listing! It was a link on the first page in the manual, totally missed it...That's great. Do you know what the end points are for bass, and mid-range when it mentions "bass" or "bass removed"? Bass goes from 20hz to 500 hz maybe? and mid range from 500 hz to 3khz? Thx.
KB1 is offline
post #2107 of 2126 Old 10-06-2014, 01:52 PM
Quoted: 319 Post(s)
Liked: 184
I usually only do full range measurements so not sure. But quick measurement will tell you.
post #2108 of 2126 Old 10-06-2014, 02:01 PM
KB1
KB1's Avatar
Got it . I will look at the parameters in the FRD file, should tell me what I need to know.
Do you know how loud the tones are recorded? I have been trying at -20db off reference level to be careful but not sure. My problem also is that the SPL readings are about 5-7db lower than my Galaxy SPL meter of RS. So I am not sure I can trust them. Weird no?
KB1 is offline
post #2109 of 2126 Old 10-06-2014, 02:04 PM
KB1
KB1's Avatar
And I did use the correct calibration file using the serial number. The weird thing is measuring ambient noise in the room gives me about 40db (so normal) and about 2db less than my Galaxy meter. But measuring tones coming out of my receiver, the levels are almost 7 db off from the Galaxy or RS meters, 69.4db as opposed to 75db or 77 db using Galaxy or RS.
KB1 is offline
post #2110 of 2126 Old 10-06-2014, 02:28 PM
jima4a's Avatar
Quoted: 96 Post(s)
Liked: 76
Quick question. The mic should be pointed up like an Audyssey mic?
jima4a is online now
post #2111 of 2126 Old 10-06-2014, 02:56 PM
KB1
KB1's Avatar
I think most folks point it upwards (reading the thread). Someone was also mentioning that for subwoofer measurements bass is fairly non directional so up is ok but measuring in the higher range position matters more.
KB1 is offline
post #2112 of 2126 Old 10-06-2014, 07:48 PM
KB1
KB1's Avatar
Well Lo and behold, I took some SPL measurements tonight and everything was fine! My readings were right on top of my Galaxy meter . No more deviations. Maybe just closing the software and reopen it did the trick. I had not closed it after importing the calibration file so maybe things needed to be reset. I can now take some frequency response measurements knowing that the readings are accurate
KB1 is offline
post #2113 of 2126 Old 01-20-2015, 02:21 PM
kgveteran's Avatar
Quoted: 129 Post(s)
Liked: 80
Starting from scratch here, havent used my omni mic in two years.
Im starting with checking near field of my four subs. How do i save each response onscreen so they over lay...
kgveteran is online now
post #2114 of 2126 Old 01-20-2015, 02:21 PM
kgveteran's Avatar
Quoted: 129 Post(s)
Liked: 80
Im using track 2
post #2115 of 2126 Old 01-20-2015, 04:03 PM
bwaslo's Avatar
Quoted: 42 Post(s)
Liked: 124
File-> save FRD
Then in Added Curves, Add the FRD files for the curves you want to show. (Non-live curves for frequency response are called "Added Curves" in Omnimic).
DIY Synergy horn spreadsheet http://libinst.com/SynergyCalc/
XSim -free crossover designer and simulator http://libinst.com/Xsim/XSimSetup.exe
Easy and cheap sound diffusers (the "Depot Diffusers") making-easy-diy-depot-sound-diffuser-panels-step-step.html
bwaslo is offline
post #2116 of 2126 Old 01-20-2015, 05:10 PM
Archaea's Avatar
Quoted: 1140 Post(s)
Liked: 1110
The manual states the mic is omnidirectional and the only difference is a slight dip at 13,000hz if you have the mic in either a horizontal or vertical implementation for measurement --- or any other angle for that matter.
"Without subs it's just background music - with subs it's the main event!"
Archaea's Theatre Room
2011 KC Sub Shootout
2012 KC Blind Sub Shootout
My Subwoofer Recommendations by Pricepoint
Archaea is online now
post #2117 of 2126 Old 01-21-2015, 09:16 AM
kgveteran's Avatar
Quoted: 129 Post(s)
Liked: 80
Originally Posted by bwaslo View Post
File-> save FRD
Ty, lots more questions coming
post #2118 of 2126 Old Today, 05:49 AM
DaveyMac's Avatar
Quoted: 116 Post(s)
My system sounds like crap in spite of buying a second good subwoofer. I'm looking for the EASIEST a rta available. This seems like it might fit the bill.
I see 'omnimic v2' on Amazon. Is this what I need?
Is there anything else I will need (other than ht system and laptop)?
Will this device help time align speakers and sub?
DaveyMac is online now
post #2119 of 2126 Old Today, 05:52 AM
eljaycanuck's Avatar
Quoted: 295 Post(s)
Liked: 677
Originally Posted by DaveyMac
My system sounds like crap in spite of buying a second good subwoofer. I'm looking for the EASIEST a rta available. ... I see 'omnimic v2' on Amazon. Is this what I need? Is there anything else I will need (other than ht system and laptop)?
The OmniMic is an all-in-one, microphone + software solution to let you see your in-room FR in real time. A less-expensive alternative is the UMIK-1 mic + free REW software.
But you'll still need something with which to make adjustments to the FR. A popular and relatively inexpensive option is the miniDSP 2x4 ($105 + shipping) + 2Way Advanced plug-in ($10).
eljaycanuck is online now
post #2120 of 2126 Old Today, 06:23 AM
DaveyMac's Avatar
Quoted: 116 Post(s)
What is FR?
Using a spl meter, 40hz and 63hz are both registering up to 8db lower than the other sub frequencies. And yes I've done sub crawl. They are really good subs so I'm disappointed. I'm assuming those 2 frequencies playing so low are the problem.
So i need a mini DSP too? Are they hard to figure out? Would I need one for each sub?
post #2121 of 2126 Old Today, 06:45 AM
Quoted: 295 Post(s)
Liked: 677
Originally Posted by DaveyMac View Post
What is FR?
Frequency response.
To make adjustments to the FR, yes.
Not that hard to figure out, IMO, although there is a bit of a learning curve.
Here's a good tutorial for using a miniDSP to EQ two subs.
One miniDSP 2x4 can handle up to four subs (2 inputs, four outputs).
DaveyMac likes this.
post #2122 of 2126 Old Today, 07:43 AM
exojam's Avatar
Liked: 29
It is frequency response, and no you do not need a mini DSP at this time. You first need to see what you room-speakers-subs show and go from there.
exojam is offline
post #2123 of 2126 Old Today, 07:56 AM
Kal Rubinson's Avatar
Quoted: 205 Post(s)
Liked: 201
I agree. First, get good measurements of the situation. Variations in FR can often be corrected by repositioning the speakers/subs.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #2124 of 2126 Unread Today, 09:54 AM
DaveyMac's Avatar
Quoted: 116 Post(s)
Thank you! After further searching it looks like XTZ might be the easiest/plug n play option. Now I just need to find a site that sells it and isn't in Swedish language, lol.
Or is omnimic just as easy? I'd prefer to buy it since it's cheaper and on Amazon.
post #2125 of 2126 Unread Today, 10:17 AM
Quoted: 295 Post(s)
Liked: 677
When it comes to taking FR measurements, the OmniMic is (IMO) quite straightforward to use.
There is a learning curve to using some of its more complex functions, but I suspect that would be the same for any similar product.
post #2126 of 2126 Unread Today, 10:56 AM
bear123's Avatar
Quoted: 605 Post(s)
Liked: 1096
What is FR?
The good news is that you are on the right track for getting the best sound quality possible by being willing to measure and correct things. No matter how good the subs are, your room and placement is going to determine how they sound.
bear123 is online now
