Dayton OmniMic Precision Measurement System - Page 74 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
Old 06-24-2016, 06:18 AM
Point Source
beastaudio's Avatar
Quoted: 3827 Post(s)
Liked: 3134
Your decay below 30hz, while higher than the rest is still to be expected somewhat. Nothing over 300ms above 30hz is also pretty solid.
FS: BossoBass A-14K amplifier
beastaudio is offline
Old 06-24-2016, 11:51 AM
kgveteran's Avatar
Quoted: 419 Post(s)
Liked: 158
Cool thanx for the help !
kgveteran is online now
Old 07-05-2016, 03:55 AM
kgveteran's Avatar
Quoted: 419 Post(s)
Liked: 158
Whats a good test to see how loud and what distortion level my subs are doing @ LP.....
Old 08-12-2016, 04:26 PM
derrickdj1's Avatar
Quoted: 943 Post(s)
Liked: 660
I am having problems with Omnimic. Everytime I start the software, newest version, I get an error message: Runtime error 217 at 000284BA. I tried running the program on a second compter and get the same thing. Virus program, Registry cleaner and repair have been done. Also, the antivirus software was diabled to see if that was the cause.
Parts Express has no ideal of what the problem is and escalated to a higher tech. Any help appreciated. Microsoft thinks it is a software issue with the Omnimic program.
derrickdj1 is offline
Old 08-12-2016, 04:51 PM
Kal Rubinson's Avatar
Quoted: 719 Post(s)
Liked: 496
Go directly to Dayton Audio and contact Bill Waslo, the developer of Omnimic (and lots of other stuff).
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
Old 08-12-2016, 05:40 PM
derrickdj1's Avatar
Quoted: 943 Post(s)
Liked: 660
I think that is who they are contacting for the problem. I just wonder if anyone else is having the same problem?
Old 09-07-2016, 03:43 PM
derrickdj1's Avatar
Quoted: 943 Post(s)
Liked: 660
Apparent Omnimic fix in Windows 10 for Runtime error 217. Right click the app, go to properties. Then hit compatability mode in the top right corner. Select Windows XP serice pack 3 and hit apply/OK. I did this and at least got the app open. Now I just need to get the mic back from PE to see if this works.
Old 01-28-2017, 02:20 PM
calentz's Avatar
Quoted: 62 Post(s)
Liked: 44
Did you ever get your mike back?
--Carl
calentz is online now
Old 01-28-2017, 08:23 PM
derrickdj1's Avatar
Quoted: 943 Post(s)
Liked: 660
Yes, they sent it back. The fix was to use it in compatability mode for windows XP 3 if I remember correctly. I don't seem to be able to get a good waterfall graph in the bass region. The bass decay works fine but, I need to figure out the waterfall.
Here are some graphs of the house curve which is on the aggressive side.
Name:	1.23.2017 Bass Decay.png
ID:	1927313   Click image for larger version
Name:	1.26.2017 FR MV 0.png
ID:	1927321   Click image for larger version
Name:	1.24.2017 Reverb RT 60.png
Old 05-07-2017, 05:51 AM
raynist's Avatar
Quoted: 1480 Post(s)
Liked: 1421
I have been meaning to update my laptop from windows 8.1 to v10.
I see derrick had an issue.
Should I just stay on 8.1?
raynist is offline
Old 05-07-2017, 11:17 AM
derrickdj1's Avatar
Quoted: 943 Post(s)
Liked: 660
Go ahead an update. You can always use the capability mode as mentioned above.
Old 05-07-2017, 03:18 PM
raynist's Avatar
Liked: 1421
That solved the error you were getting upon opening?
raynist is offline
Old 05-07-2017, 06:54 PM
derrickdj1's Avatar
Quoted: 943 Post(s)
Liked: 660
Yes. It did not initially so maybe Dayton did something. It work as intended now. Omnimic is still the easiest system to learn and use without a lot of fuss.
Old Today, 05:28 AM
kgveteran's Avatar
Quoted: 419 Post(s)
Liked: 158
Anyone interested in a brief tutorial on Impulse Response how-to.
my goal is to map out first reflection points.
MattSPL likes this.
Old Today, 06:29 AM
MattSPL's Avatar
Quoted: 17 Post(s)
Yes interested to hear your tutorial
MattSPL is online now
Old Today, 07:14 AM
gixerking's Avatar
Quoted: 185 Post(s)
Liked: 196
Tutorials are always helpful
gixerking is offline
Old Today, 09:06 AM
kgveteran's Avatar
Quoted: 419 Post(s)
Liked: 158
Totally my bad, i never put a question mark on that post, it was a question to anyone who knows how, and how to interpret the graphs.....
