Dayton OmniMic Precision Measurement System - Page 75 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #2221 of 2223 Old 06-24-2017, 01:16 PM
jasonmichaelh's Avatar
Quoted: 160 Post(s)
Liked: 61
Originally Posted by jasonmichaelh View Post
Anyone know what the mic level should be set at in Windows 10 properties to get an accurate SPL reading? If I adjust the level from say 100, down to 50 or 33 then the SPL changes drastically (in Omnimic 5.03 software). My guess is that it should set to 100.
I'm already set with 16-bit 2-channel stereo. Just need to know the level setting.
Nevermind. My question was answered over at PE.
Just set the app to adjust auto gain for your measurement level.
My levels were off because I adjusted the level setting from windows after auto-gain adjustment.
Sony XBR-75Z9D | Oppo BDP-203 and 103D | UBD-K8500
Mirage OMD-28 (LR) | OMD-C2 (C) | OMD-5 (SS, FH, RH)
Yamaha CX-A5100 | NAD T973 x 2
SVS PB12Plus/2 | Dayton UM18-22 Sealed x2 w/ iNuke 6000DSP
Monster Power HTPS 2000
jasonmichaelh is offline
post #2222 of 2223 Old 07-04-2017, 11:36 AM
Archaea's Avatar
Quoted: 3071 Post(s)
Liked: 2680
I'd like to use my omnimic to record the local city firework show tonight. Is this possible? Any suggestions on the best way? The omnimic is the best mic I own. Second place would probably go to a Blue Yeti.
I'd obviously like to preserve the dynamics and avoid clipping if possible. Laptop, and Windows 7, and a mic stand are the rest of the accessories.
@desertdome
@bwaslo
@Luke Kamp
@lukeamdman
Archaea is offline
post #2223 of 2223 Old 07-05-2017, 03:59 AM
derrickdj1's Avatar
Quoted: 982 Post(s)
Liked: 711
I have used the mic at several levels and get results within 1 to 2 db. It is usuall over 50 on the computer. The slider in the Omnimic GUI is adjusted if I am using high spl.
derrickdj1 is offline
