Dayton OmniMic Precision Measurement System - Page 76 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #2251 of 2256 Old 09-02-2017, 04:45 AM
kgveteran's Avatar
Quoted: 465 Post(s)
Liked: 174
Make sure aftwards to reconfirm your audio card settings and re-enter your mic ID and you will be rockin and rollin in no time.
And those settings....... I remember dvd quality sound or something
kgveteran is online now
post #2252 of 2256 Old 09-02-2017, 12:33 PM
bwaslo's Avatar
Quoted: 68 Post(s)
Liked: 188
Excellent!
Can the downloadable Omnimic v2 Audio Test Tracks file be saved onto a flash drive and played from that?
Yeah, it will work. I don't use MP3 for distortion measurements, though, so try to save as a WAV file if you player will play from that.
I have tested with MP3 and didn't see any distortion problems, but I just don't trust it (too many variables in encoders and rates). For frequency response, MP3 or WAV would be fine.
___________________________________________
DIY Synergy horn spreadsheet Synergy horn spreadsheet and pdf
XSim -free crossover designer and simulator XSim install file
Easy and cheap sound diffusers (the "Depot Diffusers") making easy DIY depot sound diffuser-panels-step by step.html
SmallSyns - point source controlled directivity in a manageable size SmallSyns
bwaslo is offline
post #2253 of 2256 Old 09-02-2017, 12:37 PM
bwaslo's Avatar
Quoted: 68 Post(s)
Liked: 188
The original OM packages came with CD, the new ones come with both CD and DVD (I think). Hardware is the same.
Mastering a BluRay disk (for more than 5.1) is another can of worms altogether, probably won't ever happen.
bwaslo is offline
post #2254 of 2256 Old 09-02-2017, 04:11 PM
noah katz's Avatar
Quoted: 1095 Post(s)
Liked: 380
Great, thanks, Bill
noah katz is online now
post #2255 of 2256 Old 09-02-2017, 08:19 PM
kgveteran's Avatar
Quoted: 465 Post(s)
Liked: 174
Ahhhh with the DVD i can select what channel out of the 5.1, no more switching everything off, damn convienient :0)
post #2256 of 2256 Old 09-05-2017, 04:31 PM
kgveteran's Avatar
Quoted: 465 Post(s)
Liked: 174
for close mic testing, ALL or BLENDED, LP (inroom) testing ALL or BLENDED
