Crest CC4000 or CC5500 - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #91 of 120 Old 12-16-2013, 07:16 PM
chrapladm's Avatar
Quoted: 945 Post(s)
Liked: 352
LOL......I have seen the light Luke thanks. Whoaru99 do the CC amps have a universal power supply?
chrapladm is online now
post #92 of 120 Old 12-16-2013, 07:39 PM
johnplayerson's Avatar
Quoted: 229 Post(s)
Liked: 59
I managed to snag one of the emotiva xpr 2s 5 months old, So it will be nice to compare the toroid to the CV 5000 to see where the extra 15 lbs is. Wow and i thought Luke had the thread on ignor long ago............smile.gif Welcome back one liner LUKE. May your one liners prop yo u up to new heights of prestige and stardom in the New Year. rolleyes.gif
I just figured out what those icons next to the message box are for. smile.gif
A Good amplifier requires a adequate power supply, It does not matter what the amplifier is capable of if the power supply will not provide the power required. Most amplifiers have under rated power supplies. It is up to you to make sure you get the ones that are least under rated if at all.
johnplayerson is offline
post #93 of 120 Old 12-16-2013, 07:47 PM
Quoted: 229 Post(s)
Liked: 59
Originally Posted by johnplayerson View Post
I managed to snag one of the emotiva xpr 2s 5 months old, So it will be nice to compare the toroid to the CV 5000 to see where the extra 15 lbs is. Wow and i thought Luke had the thread on ignor long ago............smile.gif Welcome back one liner LUKE. May your one liners prop you up to new heights of prestige and stardom in the New Year. rolleyes.gif
. Happy new year and Merry christmas to all you 5000 post know it alls too. smile.gif The forum would not be here without you. Wow i just did one of those quotes everyone else like to do to. What skill i now have...
post #94 of 120 Old 12-16-2013, 07:48 PM
whoaru99's Avatar
Liked: 69
Not clear which you mean for sure.
The CC series Crest amps I believe are plain old "big iron" power supplies. If the mains voltage can be changed I don't know.
If you mean CE Crown amps then yes, the CE4000 has universal SMPS; 100-240VAC plug and play. No adjustments necessary (proper line cord plug needed, of course).
That said, there is also a CE1000 and a CE2000 but they are completely different amps inasmuch as they are conventional (big iron) power supply and conventional (non-switching) output stages; totally dissimilar from the CE4000 on the inside. About the only thing the CE1000 and CE2000 have in common with CE4000 is they are amplifiers and have somewhat of a family resemblance.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #95 of 120 Old 12-16-2013, 08:00 PM
Quoted: 229 Post(s)
Liked: 59
http://www.arizonachurchsound.com/ProAVmaxCutSheets/Crest_CC5500_Rvw_FOH.pdf
Nice review here of the CC 5500
Pros, nice bright lights for outside gigs.
Cons a little on the heavy side.
post #96 of 120 Old 12-17-2013, 01:15 AM
chrapladm's Avatar
Quoted: 945 Post(s)
Liked: 352
I have the Crest Pro 200 series and they have a universal power supply sort of. They have a jumper inside when using 110vac. So when I moved to Australia I just had to take the jumper out. I know a lot of JD designed amps have this feature but not all. I like the CC5500 amp for the value but wondered if I could still buy it from the USA or not.
Either way thanks.
post #97 of 120 Old 10-12-2015, 12:25 PM
lukeamdman's Avatar
Quoted: 1229 Post(s)
Liked: 1516
lukeamdman is offline
post #98 of 120 Old 10-12-2015, 03:18 PM
zeus33's Avatar
Quoted: 1561 Post(s)
Liked: 1406
Originally Posted by lukeamdman View Post
I did some basic output testing on my Crest CC4000 and CC5500 today:
Interesting. Looking forward to the Crest 7.5 results. Thanks for sharing.
zeus33 is offline
post #99 of 120 Old 10-12-2015, 03:39 PM
steste1122's Avatar
Quoted: 13 Post(s)
That is insane, my CC4000 recently stopped working and blew one of my 18 Sounds 21lw1400. This makes me want to see about getting it fixed.
steste1122 is offline
post #100 of 120 Old 10-12-2015, 03:41 PM
lukeamdman's Avatar
Liked: 1516
The 5 year warranty should come in handy for that.
post #101 of 120 Old 10-12-2015, 04:04 PM
steste1122's Avatar
Quoted: 13 Post(s)
Except I bought it in 2008. It sat mostly unused for the last 7 years. It could have probably used to good inspection for parts that may have went bad.
post #102 of 120 Old 10-12-2015, 06:05 PM
SpinMonster's Avatar
Quoted: 269 Post(s)
Liked: 113
http://data-bass.ipbhost.com/index.p...plifier-tests/
Thanks for the test results.
I like those models. I didn't know they existed when I bought my 2 CS4080hz's.
I may be in the game for 4 of the CC5500's if the voltage limiter will save my TC 18's.
What would it lower the output to with the lower voltage gain setting? (20 vs 40)
Thanks again for all you do.
SpinMonster is offline
post #103 of 120 Old 10-12-2015, 06:15 PM
lukeamdman's Avatar
Liked: 1516
Going from 40 to 20 will lower the output by 6db.
What voltage limiters are you referring to?
post #104 of 120 Old 10-12-2015, 06:27 PM
Quoted: 269 Post(s)
Liked: 113
There is a switch on the back of the 5500
post #105 of 120 Old 10-12-2015, 06:33 PM
lukeamdman's Avatar
Liked: 1516
That switch is basic signal attenuation, really no different than dialing the knobs on the front of the amp from all the way up to "-6".
For example, if you were to hit clipping on the amp with your receiver volume dial at -10db, pressing that switch would lower the amps output by 6db, but you'd still hit clipping if you then changed your receiver volume to -4db.
That switch won't limit the amount of voltage the amplifier is capable of outputting, it will just require more input voltage from the source to output the same levels.
LTD02 likes this.
post #106 of 120 Old 10-12-2015, 06:39 PM
Quoted: 269 Post(s)
Liked: 113
OK, I guess the 5500's would be too dangerous for the TC's. The baskets can't be replaced. I hope the Ultras are worth the worry. I'll stay with the cs4080's. They're 2000 per driver.
post #107 of 120 Old 10-12-2015, 06:43 PM
Quoted: 269 Post(s)
Liked: 113
Will the FP14000 clones allow voltage limiting with the dip switches in the back?
post #108 of 120 Old 10-12-2015, 06:47 PM
lukeamdman's Avatar
Liked: 1516
Yes, on the Sanway clones there are dip switches for both limiting output voltage and also for input voltage gain.
post #109 of 120 Old 10-12-2015, 06:52 PM
Decadent_Spectre's Avatar
Quoted: 379 Post(s)
Liked: 179
Use a bridged CC4000. Based on lukes tests it should juice the LMS about right.
Decadent_Spectre is offline
post #110 of 120 Old 10-12-2015, 06:52 PM
Quoted: 269 Post(s)
Liked: 113
I guess I'm forced to go that way (clones) but I don't have any luck with China. I'm 0-2 with mini-dsp
post #111 of 120 Old 10-12-2015, 06:54 PM
Quoted: 269 Post(s)
Liked: 113
I have OCD with buying lesser amps when bigger/better exist. I change subs often and will eventually upgrade regretting the 4000's. Given the choice, I'd get the clones
post #112 of 120 Old 10-12-2015, 09:01 PM
d_c
d_c's Avatar
Quoted: 905 Post(s)
Liked: 1052
I'm pretty happy with both my clones and I punish them on a regular basis, but I hope for a pair of 5500 for my Othorns
d_c is offline
post #113 of 120 Old 10-13-2015, 07:31 AM
Hoodcom's Avatar
Quoted: 122 Post(s)
Liked: 83
Nice to know as an owner of a CC4000. Definitely looking forward to seeing your results on the Crest Pro-LITE 7.5 too!
Yikes, I thought those amps would have pretty good protection circuitry to help prevent damage upon failure?
Hoodcom is online now
post #114 of 120 Old 10-13-2015, 07:56 PM
lukeamdman's Avatar
Liked: 1516
FYI - I just posted the results of the Pro-Lite 7.5 tests.
post #115 of 120 Old 10-13-2015, 10:11 PM
zeus33's Avatar
Liked: 1406
Thanks Luke.
Unfortunately, they are disappointing results. That's half the rated power.
zeus33 is offline
post #116 of 120 Old 10-14-2015, 06:13 AM
Hoodcom's Avatar
Quoted: 122 Post(s)
Liked: 83
Thanks Luke.
Yeah no kidding.
I'm curious to how the IPR2 5000 holds up too. I do own this model and use it for my subwoofers.
post #117 of 120 Old 10-14-2015, 07:08 AM
lukeamdman's Avatar
Liked: 1516
Thanks Luke.
Yeah no kidding.
Unfortunately I already knew what the result would be for 2ohm stereo before I ran the tests.
However, I'm confident the amp will reach rated power at 4ohm stereo and I'll run another test to find out.
post #118 of 120 Old 10-14-2015, 07:53 AM
Hoodcom's Avatar
Quoted: 122 Post(s)
Liked: 83
Should I be using my CC4000 for my subs instead of the IPR2 5000? Just curious. It's a 2 ohm load per channel.
post #119 of 120 Old 10-14-2015, 08:05 AM
lukeamdman's Avatar
Liked: 1516
I'd have to run the test to confirm, but the CC4000 should have a little more power than even the 7500 for 2ohm stereo power (~1,800w/ch vs. ~1,600w/ch). If that's true, it should definitely be stronger than the 5000.
Are you having issues with the 5000 clipping or power cycling when pushing it?
post #120 of 120 Old 10-14-2015, 08:12 AM
Hoodcom's Avatar
Quoted: 122 Post(s)
Liked: 83
I'd have to run the test to confirm, but the CC4000 should have a little more power than even the 7.5 for 2ohm stereo power (~1,800w/ch vs. ~1,600w/ch). If that's true, it should definitely be stronger than the 5000.
Not so far, but I don't know how far I've pushed it. I never measured that.
