the HouseWrecker. 11hz Twin CVX-15 Tapped Horn - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #271 of 422 Old 02-21-2012, 07:07 PM - Thread Starter
dB-Kicker's Avatar
Video link
http://www.youtube.com/watch?v=iYfYZ...ature=youtu.be
Can't see the wall wave very well or the P-P movement..
loaded another..
http://www.youtube.com/watch?v=lFNNx...ature=youtu.be
Least it gives an idea...
Got Bass?
dB-Kicker is offline
post #272 of 422 Old 02-21-2012, 07:26 PM
urapnes1's Avatar
Quoted: 44 Post(s)
Liked: 39
Wow!!!!
urapnes1 is offline
post #273 of 422 Old 02-21-2012, 09:00 PM
boostick4's Avatar
Quoted: 21 Post(s)
Liked: 31
That's ridiculous!!!!
boostick4 is online now
post #274 of 422 Old 02-22-2012, 03:20 AM
the Son's Avatar
Originally Posted by dB-Kicker View Post
Video link
loaded another..
Got Bass?
Wasn't watching for it, but I sure felt my P-P movement!!!!!!!!!!!!
the Son is offline
post #275 of 422 Old 02-22-2012, 09:24 AM - Thread Starter
dB-Kicker's Avatar
Attaching waterfall, spectrogram of un equalized wrecker. Once I'm finished with the second one - I will get detailed measurements and start a new thread with all the build details - measurements, etc all in one place.
Updated with measurement vs model mouth SPL using M Audio Transit USB as a generator instead of laptop headphone output.
post #276 of 422 Old 02-22-2012, 10:43 AM
Ricci's Avatar
Quoted: 248 Post(s)
Liked: 574
Couple of questions that you might have already answered but I couldn't remember. What frequency are you planning to roll the wreckers out at? Got an EQ unit handy? Depending on your crossover choice it might be worthwhile to cut the TH peaks in the XO region down a bit. They tend to ring a little. It cleaned up my TH's sound some. What amp are you running these off of?
Ricci is offline
post #277 of 422 Old 02-22-2012, 11:49 AM
speckled hen's Avatar
this is insane! and... you plan on building 2 of these beast? you must watch the new rambo and turn that up to maximum spl during the nuke scene!!!!
speckled hen is offline
post #278 of 422 Old 02-22-2012, 01:46 PM
beastaudio's Avatar
Quoted: 4147 Post(s)
Liked: 3504
is that wall even screwed to any studs?
beastaudio is offline
post #279 of 422 Old 02-22-2012, 01:53 PM
lilmike's Avatar
Quoted: 71 Post(s)
Liked: 180
It's the whole wall.
Both sides are moving that much....
lilmike is offline
post #280 of 422 Old 02-22-2012, 02:20 PM - Thread Starter
dB-Kicker's Avatar
Yep - Mike is right, it is the entire wall. 2x4's, and both sheets of sheetrock..
Bass is guuuud. Deep bass is even better. I dubbed these theHouseWreckers for a reason.
With less l/f capability in the past I've broken neighbors chandeliers, windows (3 stories up), dumped entire kitchen cupboard contents onto the floor (unawares) cracked drywall seams, knocked anything you can imagine off shelves in other rooms, dropped plants, and pictures hanging from walls, and popped screws through drywall..
Thought some of ya'll would appreciate 'seeing' what real Bass can do.
post #281 of 422 Old 02-22-2012, 02:20 PM
filtor1's Avatar
Quoted: 212 Post(s)
Liked: 166
Whoa!! :O
filtor1 is online now
post #282 of 422 Old 02-24-2012, 12:01 AM
damn bro... can i have the box design? this insane!!! death by bass!!!!
post #283 of 422 Old 02-24-2012, 05:02 AM - Thread Starter
dB-Kicker's Avatar
post 233 by Lil-Mike contains the cut list and sketchup files. If you wait a bit - Mikes cooking up a slightly smaller Lil-Wrecker variant that is a bit more efficient, and only loses a couple dB. Neat thing - you can stack two in an 8' ceiling room.
post #284 of 422 Old 02-24-2012, 11:23 AM
i wanna build one of these. is this bass really that sickening... make somebody throw-up? do you have a link to the drivers your using in this horn? wow!!!
post #285 of 422 Old 02-24-2012, 04:19 PM - Thread Starter
dB-Kicker's Avatar
No it doesn't make you throw up. Drivers are detailed throughout the thread - look at title of the thread.
post #286 of 422 Old 02-28-2012, 04:55 PM - Thread Starter
dB-Kicker's Avatar
Short clip of the other side of the wall. That's a lotta air. This is a 20hz signal - meter is on C-weighting. The piece of paper didn't make it for another shot - poor thing.
http://www.youtube.com/watch?v=Sfzbi...ature=youtu.be
post #287 of 422 Old 03-01-2012, 04:04 PM
gbal4's Avatar
DAM that is insane I would love to hear this beast !!!!
gbal4 is offline
post #288 of 422 Old 03-01-2012, 04:31 PM
chrapladm's Avatar
Quoted: 944 Post(s)
Liked: 351
How many watts were you sending to the 15?
Was wondering how much more room this sub had to go.
chrapladm is offline
post #289 of 422 Old 03-01-2012, 04:50 PM - Thread Starter
dB-Kicker's Avatar
No clue - the wall vids were generated with REW coming from a Transit USB. I couldn't get enough signal for full power and I didn't measure voltage. Probably a good 70 to 80% of what the amp was capable of - but I don't want to speculate. Driving amp is only capable of 900 watts.
Watching Pulse last night from the receiver - it was definitely maxing out the 15 to 20hs swept 'pulses' and trying to bring down the house.
post #290 of 422 Old 03-01-2012, 05:16 PM
chrapladm's Avatar
Quoted: 944 Post(s)
Liked: 351
I remember listening to my fist horn build(THT) and couldn't believe it was only 100 watts going to the 15 while listening to a sine wave.
Amazing how much air is coming from your horn vid.
post #291 of 422 Old 12-03-2012, 10:51 AM
stormwind13's Avatar
Quoted: 62 Post(s)
Liked: 96
UPDATES!!!!!!
stormwind13 is offline
post #292 of 422 Old 12-03-2012, 11:20 AM
lilmike's Avatar
Quoted: 71 Post(s)
Liked: 180
Waiting on some sawdust and measurements...
There has been yet another complete refold to apply some of the lessons learned along the way.
lilmike is offline
post #293 of 422 Old 12-03-2012, 01:13 PM
Quoted: 62 Post(s)
Liked: 96
I figured you would chime in on this, just hadn't seen db-kicker around for a while.
post #294 of 422 Old 12-03-2012, 01:20 PM
MKtheater's Avatar
Quoted: 1755 Post(s)
Liked: 1345
Any THD and frequency plots?
Marantz 7704
2 Outlaw 7140s
Speakers- my own creation!
subs 2 XXX ported SLLT.
MKtheater is online now
post #295 of 422 Old 12-03-2012, 01:59 PM
lilmike's Avatar
Quoted: 71 Post(s)
Liked: 180
Not even serious sawdust yet. Plans were not final until a few days ago.
I won't have room for these in the house till the remodel is done, and that has not even started yet - so don't hold your breath waiting for me....
lilmike is offline
post #296 of 422 Old 12-04-2012, 07:14 AM
Quoted: 62 Post(s)
Liked: 96
MK Eyeing your next upgrade?
post #297 of 422 Old 12-04-2012, 11:22 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 65
I've just seen this thread, looks like an awesome build! Will subscribe and await future updates, especially if there's going to be a 'mini' version at some point smile.gif
MemX is offline
post #298 of 422 Old 12-05-2012, 09:22 AM - Thread Starter
dB-Kicker's Avatar
theHouseWrecker.zip 115k .zip file
Originally Posted by stormwind13 View Post
UPDATES!!!!!!
We will attach new models shortly. Since I built previous unit at 16.5" internal, there is one for that. the 18" internal gives an S3 much closer to the ideal 1.3x SD, and is the preferred enclosure.
There are several different variants now based around 12" and 15" VX's. TheLilWrecker turned out awesome. Someday we'll get Mike to start that thread wink.gif
post #299 of 422 Old 12-05-2012, 10:08 AM
MKtheater's Avatar
Liked: 1345
Can these put out 130 dBs at 10hz with 11% THD in multiples? How much would it cost?
Marantz 7704
2 Outlaw 7140s
post #300 of 422 Old 12-05-2012, 12:43 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 234
Yes!
We need the new Lil' HW thread!!
Please, please!!!
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
