the HouseWrecker. 11hz Twin CVX-15 Tapped Horn - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #151 of 422 Old 08-17-2011, 06:01 PM
Ricci's Avatar
Quoted: 246 Post(s)
Liked: 574
Originally Posted by dB-Kicker View Post
It is more than enough bracing. The panels are dead at full chat. You forget - we create 170dB SPL competition vehicles....... I wasn't about to let this thing be sub par...
I will take your word for it. I only wondered how it turned out because I designed and built a very high power TH design myself with what I thought would surely be enough bracing only to find that I needed a little more after running some very high power sine sweeps. Anyway...You answered already.
Did you guys tie it into the truck bed structurally?
Mike answered the other question I had which was whether it had the mouth/s open into the truck cab. That would've been ridiculous. If you guys investigate how a large bass horn interacts when opened into a small confined cabin that would be interesting to see as well.
Ricci is offline
post #152 of 422 Old 08-17-2011, 06:39 PM - Thread Starter
dB-Kicker's Avatar
If you look at the enclosure photo's you will see that the high pressure side (narrow center section) is boxed in with two panels forming the end, un-supported panels no larger than ~~ 7"s, with 4 additional braces tying each side if the chamber to the other and providing a small amount of compression chamber effect. It is also excruciatingly well sealed and glued using PL.
The low pressure side (high velocity) mouth has the panels adequately tied together and braced for simple vibration / flexion. You don't see in the photo's the 6" tall edge panel brace running the width of the cabinet at the end opposite the drivers. We tested every panel and ran 135dB sweeps from 28hz through 80hz to verify the enclosure was adequately ‘tied together’. Then we beat the beans out of it with ‘Bass’ CD’s.
Yes.
We are in the process...... So far - the same as a sealed / ported / band-pass enclosure... (IOW roughly 35dB gain at 20hz)
The little 6.5" 30hz Tang-Band TH was insanely capable in vehicle. We're working on 10" and 12" CVX TH's for a Civic, Mustang, and PT Cruiser at the moment.....
And some other stuff.....
dB-Kicker is offline
post #153 of 422 Old 08-17-2011, 06:44 PM
kryptonitewhite's Avatar
Originally Posted by lilmike View Post
I remember what you asked. The concern I had (and still have) was simply that the "room" is not much larger than the "horn", so I doubt the complex enclosure would be worth the effort, it is easier to just brute-force it. We're working on a little test to validate (or invalidate) that concern. 600 watts, just a single 12. 7 Cubes. 30 Hz. We'll see what the SPL meter tells us regarding a tapped horn and cabin gain.
Remember - this is not ported into the cab of the truck, this is open to the world. I actually wanted to use 6 drivers initially, cause 6-packs and pickups kinda go together.
I was hoping LTD02 would help use the cabin as the last segment in the horn, basically tune the enclosure a little higher itself so that the windows would be the mouth, though they would be much too small for 25Hz I assume?
kryptonitewhite is offline
post #154 of 422 Old 08-17-2011, 07:03 PM
LTD02's Avatar
Quoted: 2530 Post(s)
Liked: 2872
i was thinking about that kw, but i didn't think it would be worth the time. :-)
one thing that might get lost in some of these frequency response plots is that the driver often runs out of xmax before it runs out of power handling.
what is the real xmax on these drivers or even better how about just the top plate thickness and coil length?
Listen. It's All Good.
LTD02 is online now
post #155 of 422 Old 08-17-2011, 07:05 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
What are the external dimensions? Why do I envision this at home bein akin to the cine monster?
gpmbc is offline
post #156 of 422 Old 08-17-2011, 07:15 PM
LTD02's Avatar
Liked: 2872
they are different. the cinemonster has a higher tuning. mike went for more extension.
attached is a very rough comparo. cinemonster marked with red arrow.
LTD02 is online now
post #157 of 422 Old 08-17-2011, 07:21 PM
lilmike's Avatar
Quoted: 70 Post(s)
Liked: 178
The drivers in the 9/11 box are power limited above the corner.
lilmike is offline
post #158 of 422 Old 08-17-2011, 07:22 PM - Thread Starter
dB-Kicker's Avatar
This unit is 90" x 16.5" x 49".
Anyone in here intimately familiar with using REW, the M-Audio Midi Sport Midi interface and the Feed Back Destroyer Pro 1124p?
I am in dire need of ..... assistance getting REW to talk to my 1124 through the Midi...
IM me offline if so......
post #159 of 422 Old 08-17-2011, 07:37 PM
LTD02's Avatar
Liked: 2872
"The drivers in the 9/11 box are power limited above the corner."
is that right? are you sure? 2000 watts into that enclosure with two drivers will push them to 33 mm at around 16 hz.
LTD02 is online now
post #160 of 422 Old 08-17-2011, 07:37 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
It's not the house wrecker but for the size and with some room gain it'd be a beast as well.
gpmbc is offline
post #161 of 422 Old 08-17-2011, 07:53 PM
lilmike's Avatar
Quoted: 70 Post(s)
Liked: 178
9/11 box is not the housewrecker.
I know this thread was about the housewrecker, but dB posted up our latest distraction. I can assure you, the 9/11 box is power limited. dB ran out of amp at 2 KW or so during testing. ~133 dB at a meter, the drivers were loafing.
lilmike is offline
post #162 of 422 Old 08-17-2011, 07:54 PM
lilmike's Avatar
Quoted: 70 Post(s)
Liked: 178
While past xmax, that 33 mm is still under xmech.
lilmike is offline
post #163 of 422 Old 08-17-2011, 07:58 PM
LTD02's Avatar
Liked: 2872
"9/11 box is not the housewrecker."
sorry mike. sometimes it gets confusing trying to keep up. did you post the 9/11 box?
i just modelled up 4 of those drivers in a th with a 25hz corner. i see what you mean when you say "power limited above the corner". those will go loud and look nice. appears to be a nice driver for a th too...nice flat reponse save that inevitable one peak at the top end that is a function of tapped horns, not your design or the driver.
LTD02 is online now
post #164 of 422 Old 08-17-2011, 08:07 PM
lilmike's Avatar
Quoted: 70 Post(s)
Liked: 178
Not yet. I will.
lilmike is offline
post #165 of 422 Old 08-17-2011, 08:14 PM
Oklahoma Wolf's Avatar
Quoted: 20 Post(s)
It's a fantastic TH driver... one of the most ideal I know of. I came incredibly close to using it for Wolfhorn SDX. Not being able to easily get one at a good price was the deal killer for me. That and the fact I was really in love with the idea of a thin design.
Oklahoma Wolf is offline
post #166 of 422 Old 08-17-2011, 08:24 PM
well what do you know. TBH I was hoping with the soloX threads it would get dB-Kicker to comment on why the soloX wasnt good... how about this for a chime in?
post #167 of 422 Old 08-17-2011, 08:36 PM - Thread Starter
dB-Kicker's Avatar
The 9-11 sub is a Quad driver box. at 1kw per driver it see's less than 16mm above the corner with 1kw (IF MEMORY SERVES) I will post the models tomorrow.
It is designed for 'sound reinforcement' application - IOW outside. It will provide bass during the parade, then bounce bass of buildings in an outside environment - it was never meant to be the 'Nth degree deep bass sub".
If you're familiar enough with the driver requirements for TH's - and can model them, you'll immediately see why CVX's make ideal TH drivers - and Solo-X's are better suited to other enclosures.
I'm not here to 'sell' one or another type of driver.
post #168 of 422 Old 08-17-2011, 09:49 PM
noah katz's Avatar
Quoted: 1100 Post(s)
Liked: 381
What drivers are those in the 9/11?
I know this thread was about the housewrecker, but dB posted up our latest distraction. I can assure you, the 9/11 box is power limited. dB ran out of amp at 2.6 KW or so during testing. ~133 dB at a meter, the drivers were loafing.
noah katz is online now
post #169 of 422 Old 08-17-2011, 10:11 PM
LTD02's Avatar
Liked: 2872
"If you're familiar enough with the driver requirements for TH's - and can model them, you'll immediately see why CVX's make ideal TH drivers - and Solo-X's are better suited to other enclosures."
the solo x can work in tapped horns depending on what you want to do. while it can benefit from a higher compression ratio horn, even at a 3:1, you can get a model that looks a lot like the danley th50 with the mtx driver and that really isn't too bad. ;-)
LTD02 is online now
post #170 of 422 Old 08-17-2011, 10:46 PM
lilmike's Avatar
Quoted: 70 Post(s)
Liked: 178
Not yet. I will.
I attached the model I based the design on.
Though we looked at everything Kicker has on the shelf (even some things we'd love to see on the shelf...), the drivers we ultimately chose to use in this project are Kicker's 2010 Comp VX 15, with dual 2-ohm coils. Model number 10CVX152.
You can buy this exact driver on the street today for ~$250 shipped.
Ironically, as I was modeling options and discussing them with dB through the countless emails, texts, and phone calls during this project, this model was entry 911 in my hornresp data file. That was not intended or planned, just how it worked out.
It is an honor to have been a part of this project.
9114cvx.txt 0.4189453125k . file
File Type: txt 9114cvx.txt (429 Bytes, 58 views)
lilmike is offline
post #171 of 422 Old 08-17-2011, 10:51 PM
lilmike's Avatar
Quoted: 70 Post(s)
Liked: 178
True. It can, and it has a decent BL^2/Re/Sd number for use in a tapped horn. To be honest, that was the first driver we looked at. They can handle the compression too.
There is a little more to it than frequency response though. When you have the chance, listen to two identical tapped horns, one loaded with a driver with a Qes of 0.3, and one with a Qes of 0.7.
I have.
I know which I prefer.
lilmike is offline
post #172 of 422 Old 08-18-2011, 12:30 AM
LTD02's Avatar
Liked: 2872
"You can buy this exact driver on the street today for ~$250 shipped."
looks like there is a seller on amazon for $207 shipped. only six left in stock...order soon! ;-) somebody should send him a note to stock up before the 9/11 parade. i don't think six is going to meet demand.
"listen to two identical tapped horns, one loaded with a driver with a Qes of 0.3, and one with a Qes of 0.7."
ack...this is a tough one. do you think that such a test is possible? man, trying to control every other variable in order to narrow it all the way down to just qes and nothing else seems like it would be a beast of an engineering chore in a tapped horn. i suspect what you are preferring are many artifacts that attend a particular design, not simply qes, but as always, i could be wrong.
LTD02 is online now
post #173 of 422 Old 08-18-2011, 06:30 AM - Thread Starter
dB-Kicker's Avatar
" i suspect what you are preferring are many artifacts that attend a particular design, not simply qes, but as always, i could be wrong.
High QES drivers have less electromagnetic control of the woofer cone / air in enclosure than lower QES drivers... They take longer to 'Start' and 'Stop', and more time to develop full cycle's.
In system they sound less articulate, have worse transients, tend to 'drone', or sound 'muddy' when asked to drive resonators or horns.
post #174 of 422 Old 08-18-2011, 06:35 AM
Ricci's Avatar
Quoted: 246 Post(s)
Liked: 574
I just noticed that the SoloX has >940g of moving mass. That is a little over 2lbs.
Deon mentioned QES. I tend to agree with him that high QES drivers, especially those with heavy moving assemblies, do better when in sealed enclosures, or when used for mainly the very lowest bass frequencies.
Ricci is offline
post #175 of 422 Old 08-18-2011, 06:38 AM - Thread Starter
dB-Kicker's Avatar
I just caught this. The 9-11 truck sub is not theHouseWrecker. As mike said it's our latest 'distraction'. Uh...... Finished distraction anyway. This sub design is a tapped horn ~~30hz TH – That HR says will generate 215 Acoustic Watts, or uh…. get Really loud….
This is also with only 4 CVX 15’s, and 1,000 watts per CVX. At its highest efficiency it clocks in at ~~65% efficiency
post #176 of 422 Old 08-18-2011, 06:48 AM - Thread Starter
dB-Kicker's Avatar
Couple more pix.
post #177 of 422 Old 08-18-2011, 07:37 AM
Quoted: 20 Post(s)
Yeah, TH designs do best with a Qes closer to 0.3. I haven't tried one with drivers at 0.7, but I can pretty much imagine what it would sound like.
Couple more pix.
That thing is just sick looking. I love it
post #178 of 422 Old 08-18-2011, 10:18 AM
lilmike's Avatar
Quoted: 70 Post(s)
Liked: 178
That was a quick post from my phone last nite - guess I could have worded it better. I do think a test such as this is possible, I've done several that are quite similar already, and will do more. What I have done (so far) is use several different (but still appropriate) drivers in the T-6 design, as well as a precursor to it that was similar to the Insubnia that Erich flat-packed.
While the frequency response modeled flat, and measured similarly, the drivers with higher Qes just did not sound as detailed or accurate. This was not just my ears either - several others noticed immediately. The sub was muddy and simply not able to articulate music as well.
So - I tried a little science project. After making sure that all else was as equal as I could make it (same horn, same amp, same measurement gear, same day, same setting, just different drivers), I measured things again to try and figure this out.
I'm still not 100% sure that I have, but I do have a theory. In a simple frequency response plot, I can definitely tell you that this difference is not evident - the higher Q driver actually has a flatter response, and "should" sound better as a result, but that was simply not the case.
Look at a waterfall plot for both measurements though - the difference is as clear as day. Once excited, the horn's resonances take longer to decay with a high Qes driver, cause it "has weak brakes", which leads to a muddier sound with real-world content. I also found that my little amp did not like driving the higher Qes driver, it actually overheated and shut down. The DC resistance and impedance of the drivers was similar, and appropriate for the amp. When I switched up to a much stronger amp, the sound improved, but so did the sound of the lower Qes driver.
Anyhow - this is a work in progress.
The more I learn, the more I find out that I need to learn more......
lilmike is offline
post #179 of 422 Old 08-18-2011, 01:02 PM - Thread Starter
dB-Kicker's Avatar
Qes defines the electrical Q of the driver at Fs. It is a measure of the driver's resonance at Fs, based on its electromagnetic properties. The driver's overall resonance (Qts) characteristics are usually dominated by Qes. Qe / Qt is an electrical circuit analog representation of the motors force to area / mass and resistances.
Think of a drag strip, and a pair of cars. 1. A bracket drag racing car might weigh 3,000 lbs and get slammed down the strip with 800 bhp or more at the wheels. 2. Your average Joe Grocery Getter, might weigh 4,000lbs, and wheeze down the track with only 200bhp... Which one will accelerate down the track quicker? Qe is an expression of pounds per horsepower in effect
Lower Qe / Qt motor's have a higher ratio of electromotive force to mass / area. I.O.W. the Motor (Engine) is stronger relative to the forces it has to act against.
Lower Qe motors (more horsepower per pound so to speak) will as mentioned above, Stop and Start the cone faster.
Higher Qe / Qt motors will resonate longer.
post #180 of 422 Old 08-18-2011, 01:20 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
This is very interesting discussion regarding the effect of the individual parameters and their effect on sound quality in spite of measuring flat. I've read where many achieve flat and think it's the be all end all and call it a day. There's always a lot of subjective discussion about speakers but with subs it's usually criticized without graphs to make sure everything lines up.
gpmbc is offline
