Automatically Powering on Pro Amps via Relay (guide w/ pics) - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 34Likes
post #271 of 428 Old 02-24-2014, 02:59 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Actually this poster a few posts down has a good point. http://www.avsforum.com/t/1517353/inuke-vs-cv-5000/90#post_24378306
I'm going to test the relays and their temps with 100 watt light bulbs and a power strip. That is a guaranteed way to make sure the heat sinking is adequate and everything is safe.
pdxrealtor is offline
post #272 of 428 Old 02-24-2014, 06:04 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
For anyone who is interested I found these heat sinks. You want the 50x50-12.7 height.
They're a great price. They are almost exactly the same dimensions of the side of the deep double gang box everyone is using. And they spec out (the 12.7mm version) at 1.5 c/w while the Omron specs state a 1.6 c/w. (the lower the number the better the cooling).
After mounting the relay you will have a 1/4" on the top and bottom of the heat sink. Cut a hole in your box just big enough for the relay to fit through and use the extra 1/4" on the top and bottom to mount it to the box.
http://www.micforg.co.jp/en/cat_ze.html
Page 1 should be updated to include this info for those going the solid state route.
post #273 of 428 Old 02-24-2014, 09:35 PM
SeekingNirvana's Avatar
Quoted: 233 Post(s)
Liked: 123
^^^Did you play the song in a different format, did the relay still heat up?
My dual sealed LMS 5400 Ultra build
http://www.avsforum.com/forum/155-di...0-build-4.html
SeekingNirvana is offline
post #274 of 428 Old 02-24-2014, 09:47 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
post #275 of 428 Old 02-25-2014, 05:03 PM
HoG_FATALFIRE's Avatar
With these relay powered plugs, does it still cause the initial "pop" when powering on?
HoG_FATALFIRE is offline
post #276 of 428 Old 02-25-2014, 05:09 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
post #277 of 428 Old 02-25-2014, 05:28 PM
Originally Posted by pdxrealtor View Post
Mine did not pop at all.
Well not the relay itself, I had one of those smart strips that I had my sub amp hooked up to. Whenever it came on, my subs made a short "pop". Same thing when it turned off.
post #278 of 428 Old 02-25-2014, 05:36 PM
Anthony_Gomez's Avatar
Quoted: 61 Post(s)
Liked: 184
Will it also pop if you manually hit the button?
Anthony_Gomez is offline
post #279 of 428 Old 02-25-2014, 05:38 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
deleted for improper heat sink info
post #280 of 428 Old 02-25-2014, 05:40 PM
Quoted: 61 Post(s)
Liked: 184
What is the advantage of using this vs a smartstrip for 15A max loads?
post #281 of 428 Old 02-25-2014, 05:42 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Well for me the advantage is location. A smart strip needs power from another source in your chain, IE the AVR. My sub RCAs and power is in a different location in my room.
I'll write up a how to with parts and procedures in another thread. Notnyt has most of it covered but if you're going to use SSR (and why wouldn't you they last forever) they need to be cooled properly.
It only takes once to turn on the loud music and get sidetracked, have an emergency, etc etc.... and overheat that box laying on your carpet. Insurance isn't going to cover a box that burns your house down if it was built with a part that specs a specific heat sink and doesn't have one that is even close.
post #282 of 428 Old 02-25-2014, 05:56 PM
No they do not pop if I turn them on manually via the switch on front
post #283 of 428 Old 02-25-2014, 06:09 PM
Mike Garrett's Avatar
Quoted: 5554 Post(s)
Liked: 3539
If all of your loads together are 15 amps, then the smart strip will work, but if you run an AVR and a couple pro amps, along with the other misc equipment, then you are going to exceed 15 amps.
mjgarrett100@gmail.com
Mike Garrett is online now
post #284 of 428 Old 02-25-2014, 06:19 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
I run a dedicated 20 amp line for each 7500 watt amp I have.
15 dedicated for my AVR and miscellaneous gear. Bluray, Dune, Xbox, etc.
post #285 of 428 Old 02-25-2014, 06:30 PM
Quoted: 61 Post(s)
Liked: 184
post #286 of 428 Old 02-25-2014, 06:31 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
post #287 of 428 Old 02-25-2014, 07:11 PM
Quoted: 61 Post(s)
Liked: 184
Why not get the smart strip then?
Because I was trying to learn why not. ...if there was something I was missing.
post #288 of 428 Old 02-25-2014, 07:15 PM - Thread Starter
notnyt's Avatar
Quoted: 2152 Post(s)
Liked: 1980
If you think you're going to ever reach the lifespan of a good mechanical relay in this scenario, you're mistaken. I tried the SSRs and they lose too much power as you near 20A. Even if I didn't upgrade my amps, I would have most likely switched.
$0.02, no reason not to go mechanical. cheaper too.
notnyt is offline
post #289 of 428 Old 02-25-2014, 07:20 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Do you think they are losing power because the cooling wasn't adequate?
I do, but you seem knowledgeable in this area so I'm certainly interested in your input.
post #290 of 428 Old 02-25-2014, 07:23 PM - Thread Starter
notnyt's Avatar
Liked: 1980
As power draw increases, they'll bleed more energy, just how they work. The cooling won't really stop them from doing that, it will just keep them cooler as they do.
If you're only peaking to like 10 or 15a or so, it shouldn't be that big of a deal, but if you're pulling more, mechanical seems to be the way to go, no need for cooling.
They clack kind of loud when you trip them, but *shrug* I could care less about that.
notnyt is offline
post #291 of 428 Old 02-25-2014, 07:39 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Interesting.
I could care less about the clacking or the size. I spent money on these is the main reason. I hate tossing 45.00 in the trash.
You've got me curious now, though. How would one go about measuring the energy loss with a volt meter and a string of 100w light bulbs as a load? I would think the 20 amp relay would send out 20 amps as rated. Otherwise I want my money back. tongue.gif
post #292 of 428 Old 02-25-2014, 07:42 PM - Thread Starter
notnyt's Avatar
Liked: 1980
Interesting.
put a load on it, measure current draw at the wall and then current draw after the relay while loaded.
I have four of the ssrs sitting unused mounted to boxes, so I know how you feel.
If anyone wants them cheap let me know =]
ugh, I need to get rid of my sealed cabs now too.
notnyt is offline
post #293 of 428 Old 02-25-2014, 07:48 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Enough people on the east coast those boxes shouldn't last long.
I'll throw up the results. Just waiting on heat sinks.
post #294 of 428 Old 02-25-2014, 07:52 PM - Thread Starter
notnyt's Avatar
Liked: 1980
I'd use an amp-clamp pre and post relay, as well as measuring voltage at the wall outlet, and at the relay outlet. Put a 2000w load on it while doing this to see.
notnyt is offline
post #295 of 428 Old 02-25-2014, 08:38 PM
btinindy's Avatar
Quoted: 38 Post(s)
Liked: 56
What needs to be done is put a 20 amp constant load on the relay and heat sink accordingly to get the desired temperature.
Oh, I must not have been paying attention. I purchased all 45 amp SSR's so they could derate accordingly. Maybe that is why I have almost zero heat gain on my box where the relay is mounted.
btinindy is offline
post #296 of 428 Old 02-27-2014, 10:04 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
EDIT - inadequate heat sinking. Third time is a charm.
Here is the final, correct sized heat sink (that I chose to use because they are cheaper than specific SSR heatsinks).
The entire build thread can be found here -
Make a properly heat sinked SSR trigger box
post #297 of 428 Old 02-27-2014, 10:06 PM - Thread Starter
notnyt's Avatar
Liked: 1980
An amp clamp and some inspection plugs would be the best way... however you can put that load on it again, measure voltage at your outlet, then measure voltage from the outlet in the relay box, post results.
notnyt is offline
post #298 of 428 Old 02-27-2014, 10:08 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
I did a MWBC and separated a double receptacle. So..... each outlet has its own supply. I guess I could just leave the prongs exposed and access them with my meter. WIll do, now
post #299 of 428 Old 02-27-2014, 10:28 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
1.5 volt consistent difference between wall and relay box. Not sure what that means. Explain it for us all please.......
EDIT - these heat sinks are inadequate. For updated info see my full build here - Full build here
post #300 of 428 Old 02-27-2014, 10:51 PM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
The voltage drop across the SSR multiplied by the current draw will determine the amount of heat the SSR has to get rid of.
A9X-308 is offline
