Automatically Powering on Pro Amps via Relay (guide w/ pics) - Page 12 - AVS Forum
post #331 of 352 Old 06-09-2014, 11:13 AM
pdxrealtor's Avatar
Quoted: 80 Post(s)
Liked: 136
Originally Posted by Mr. Electric Wiz View Post
I like your design a lot. Will be building one of these later this summer.
Cool, have fun! If you variate from the exact heat sink I used just make sure it will do the job. A lot stuff to learn about heat sinks! I triple checked specs when I thought I had it dialed in using the smaller sinks posted above in this thread, but I was wrong.
FS- Peavey IPR 2 7500, Art Clean Box Pro, Netgear 550 .ISO player - PM me
My Gear-Pioneer, JBL Pro Cinema, Fi Car Audio 4- SP4 18", Peavey IPR2 7500 x 2, Mini-Dsp 4x10, GIK Acoustics, Seymour Screens 110" AT, Dune Smarts, uNraid Server
Theater Build and Two Sono Sub Builds Here-
pdxrealtor is offline
post #332 of 352 Old 06-09-2014, 11:18 AM
Mr. Electric Wiz's Avatar
If what you used is a known good combo, then I'm good with that! No need to deviate.smile.gif
Mr. Electric Wiz is offline
post #333 of 352 Old 06-10-2014, 03:53 AM
Sam S's Avatar
It seems almost impossible to find relay heat sinks with pre-drilled holes 30mm apart to fit the standard SSR. Most all seem to have 47.5mm spacing.
Sam S is online now
post #334 of 352 Old 06-10-2014, 08:31 AM
pdxrealtor's Avatar
Quoted: 80 Post(s)
Liked: 136
Did you read my build thread? I used thermal epoxy. You can always drill your own holes too. Power I/O has heat sink/relay combos with screws I think. They're spendy.
post #335 of 352 Old 06-10-2014, 06:44 PM
Sam S's Avatar
Yes, I read your build thread intently. I figured screws + thermal epoxy would be the ultimate in heat dissipation. I suppose I've never used "just" thermal epoxy, so I don't understand how robust the hold would be.
Sam S is online now
post #336 of 352 Old 06-10-2014, 08:43 PM
Sam S's Avatar
Sam S is online now
post #337 of 352 Old 06-10-2014, 09:46 PM
pdxrealtor's Avatar
Quoted: 80 Post(s)
Liked: 136
Thermal epoxy is all you need.
One box left for sale .
post #338 of 352 Old 06-12-2014, 01:34 PM
Kingcobra777's Avatar
PDX
Still have a box for sale ?
I just went through this entire thread , wish I knew more about electricity Great build btw..
I posted earlier today about getting an INUKE to turn on automatically with my gear. This thread has really made realize the different options people are trying...
I have a Denon X4000 that has two triggers rated at
DC 12 V 150 mA MAX
Will that work with your relay switch and an Inuke3000dsp?
Sorry for the questions, just trying to understand all the material covered in this class
Matt
Kingcobra777 is offline
post #339 of 352 Old 06-12-2014, 02:08 PM
pdxrealtor's Avatar
Quoted: 80 Post(s)
Liked: 136
Originally Posted by Kingcobra777 View Post
PDX
DC 12 V 150 mA MAX
Matt
Yes one left. Yes it will work great for the iNuke and your AVR. It draws 10 ma, so you're gtg. PM me your address for shipping quote if you're interested. Price is 50.00 plus shipping. Boxed and ready to go.
post #340 of 352 Old 06-14-2014, 10:17 AM
Excited to try this out. Total noob question: How exactly is the relay turning on the AMP? I understand the 12v trigger from the receiver is activating the relay in the DIY box but how is that electrical signal turning on the AMP opposed to having the amp plugged in to an active circuit? The Amp is plugged in to the outlet the relay box correct? Just trying to understand this method...Matt
post #341 of 352 Old 06-14-2014, 11:17 AM
Mrkazador's Avatar
Quoted: 33 Post(s)
Liked: 248
The amps power switch is always on so when the relay is activated the amp turns on. When the relay is deactivated, the amp will shut down because of the loss of power.
Mrkazador is offline
post #342 of 352 Old 06-25-2014, 06:47 PM
pdxrealtor's Avatar
Quoted: 80 Post(s)
Liked: 136
anyone else interested in a 12 volt trigger box PM me. I have a couple guys who want them and I'm trying to make it worth it for me to build them. Several would do the trick.
post #343 of 352 Old 06-25-2014, 07:29 PM
Sam S's Avatar
Solid state or mechanical relay?
Sam S is online now
post #344 of 352 Old 06-25-2014, 07:44 PM
pdxrealtor's Avatar
Quoted: 80 Post(s)
Liked: 136
Which do you want. Either or is doable.
post #345 of 352 Old 06-25-2014, 07:47 PM
Sam S's Avatar
Both have good applications, right now I'm most interested in a mechanical version for use with a high power sub.
Sam S is online now
post #346 of 352 Old 06-25-2014, 08:05 PM
pdxrealtor's Avatar
Quoted: 80 Post(s)
Liked: 136
Pm me for email address. Go from there
post #347 of 352 Old 07-05-2014, 11:08 AM
GRBoomer's Avatar
New item. Can be triggered with as little as 3mA of current.
https://www.sparkfun.com/products/12920
GRBoomer is offline
post #348 of 352 Old 07-06-2014, 04:41 PM
autox320's Avatar
Liked: 31
I finally have a few SSR's posted for sale. Still new >>> HERE ON AVS NEW Relays for sale; Crydom SSR's with Heatsinks available
"I should really see what dB levels I'm pushing. Long as it can't foam my beer during a movie we are ok "
autox320 is offline
post #349 of 352 Old 07-06-2014, 09:23 PM
MKtheater's Avatar
Quoted: 78 Post(s)
Liked: 396
My trigger powers my pro amp just fine and shuts off my projector as well, but it won't turn my projector on. It just goes to stand by mode. How do I bypass this if I can?
MKtheater is offline
post #350 of 352 Old 07-06-2014, 10:12 PM - Thread Starter
notnyt's Avatar
Quoted: 65 Post(s)
Liked: 315
Either CEC, or get a remote that can turn on your projector =] The for triggering amps remotely is because they don't have remote control.
notnyt is offline
post #351 of 352 Old 07-07-2014, 07:29 AM
Bassment's Avatar
Quoted: 64 Post(s)
There could be a setting in your projector like "turn on when power on" or something like that, which turns it on when it sees voltage on the plug.
Bassment is offline
post #352 of 352 Old 07-07-2014, 07:34 AM
MKtheater's Avatar
Quoted: 78 Post(s)
Liked: 396
Thanks guys, I have the remote I just wanted a one step solution which is a learning remote.
User Tag List
