Automatically Powering on Pro Amps via Relay (guide w/ pics) - Page 13 - AVS | Home Theater Discussions And Reviews
 9Likes
Old 07-15-2014, 07:49 PM
A9X-308's Avatar
Quoted: 338 Post(s)
Liked: 222
Originally Posted by Sam S View Post
Just to be clear, you're saying the snubber should not be connected to a 12VDC to 120VAC contact(s), rather across the two 12VDC contacts?
Yes, across the coil, and make sure you put it the right way around. The stripe should be connected to the positive side of the DC voltage.
Sam S likes this.
A9X-308 is offline
Old 07-15-2014, 07:53 PM
Sam S's Avatar
Quoted: 38 Post(s)
Thank you. I didn't know the direction was important for this application. I'm just going to solder it across the DC tabs near their base(s), very close to the relay housing, so I can still use the quick-connect tabs for the DC input. Unless there is a better way.
EDIT: actually I'll be soldering the diode through the holes in the tabs, of course! Still plenty of room for the quick-connects if I do it right.
Sam S is offline
Old 07-19-2014, 11:34 AM
Sam S's Avatar
Quoted: 38 Post(s)
According to the Omron G7L-1A-TUBJ-BC 12V spec sheet, the relay does not have coil polarity? I know the +/- for my trigger leads, but at this point I'm not clear if the positive should go to the "0" coil/trigger tab, and negative to the "1" tab.
Sam S is offline
Old 07-19-2014, 12:00 PM
pdxrealtor's Avatar
Quoted: 133 Post(s)
Liked: 148
Sam,
Just make sure the stripe is on the positive wire of the DC trigger and you will be good. It shouldn't matter what relay tab the positive or negative wire is attached to.
If you have doubts, go hook up the 12 trigger off your AVR to the relay. You should be able to swap them and get the same result. Or you can strip a 12 volt wall wart and do the same. If the relay clicks you're good to go.
FS- Mini-DSP 4x10 - 400.00
pdxrealtor is offline
Old 07-19-2014, 12:18 PM
Sam S's Avatar
Quoted: 38 Post(s)
Originally Posted by pdxrealtor View Post
Sam,
Great, thank you. Same for the A/C tabs (doesn't matter which tab), I assume, because those are both hot.
Sam S is offline
Old 07-19-2014, 12:26 PM
pdxrealtor's Avatar
Quoted: 133 Post(s)
Liked: 148
^^ correct
Old 07-19-2014, 04:18 PM
Sam S's Avatar
Quoted: 38 Post(s)
OK, got it all assembled, and working! I reused one of the two SSR relay boxes I made to make this one with an Omron mechanical relay for use with my Seaton Submersive HP sub.
I really appreciate everyone that assisted with my questions!
Troglidite likes this.
Sam S is offline
Old 10-18-2014, 12:03 PM
Mr. Electric Wiz's Avatar
Quoted: 28 Post(s)
Liked: 27
I just built one of these per pdxrealtor's instructions.
My outlet is hot all the time and does not switch on/off with my 12V trigger on my Pioneer receiver.
I verified the trigger is putting out 12V but my relay is not working
I have it wired up like this:
1) hot wire goes to Load 1, and outlet hot to Load 2
2) neutral to neutral side of outlet
3) grounds all together then screwed to box
4) 1/4" negative to ring side of socket
5) 1/4" positive to tip side of socket
Is this correct?
Mr. Electric Wiz is offline
Old 10-18-2014, 12:13 PM
Quoted: 28 Post(s)
Liked: 27
I wired my jack like this:
Old 10-18-2014, 12:19 PM
Quoted: 28 Post(s)
Liked: 27
Terrible picture, I know but can anyone see anything that I wired up incorrectly?
Old 10-18-2014, 12:37 PM
Quoted: 28 Post(s)
Liked: 27
Old 10-20-2014, 06:07 AM
Quoted: 28 Post(s)
Liked: 27
Does anybody have any ideas about my SSR issue listed in my previous post?
Old 10-20-2014, 09:30 AM
Sam S's Avatar
Quoted: 38 Post(s)
I looked carefully at yours, and it is wired the same as mine. Bad relay? Can you try with a different receiver? I know one of my receivers acts goof with the 12V output.
Sam S is offline
Old 10-20-2014, 10:02 AM - Thread Starter
notnyt's Avatar
Quoted: 781 Post(s)
Liked: 815
SSRs are polarized, ensure the trigger section is wired properly. The cables may be reversed.
notnyt is online now
Old 10-20-2014, 01:11 PM
Quoted: 28 Post(s)
Liked: 27
The way I have it wired now, the trigger section goes to 11.5 volts when measured at the SSR input terminals.
If I wire it the other way, it goes to -11.5 volts.
What's strange is that it's always on, even when I unplug the trigger.
If it turns out my relay is bad it totally sucks because it's already glued to the heat sink and outlet box. :-(
Old 10-20-2014, 06:43 PM
Quoted: 28 Post(s)
Liked: 27
If the input side is disconnected completely, the outlet should be dead right?
Mine is not.
Bad relay?
Old 10-20-2014, 07:06 PM - Thread Starter
notnyt's Avatar
Quoted: 781 Post(s)
Liked: 815
Mine is not.
Bad relay?
right, but not quite so simple. If you measure with a meter and there's no load on it, it will show some voltage. However, if you plug in a light bulb, it will quickly turn off.
Old 10-20-2014, 07:19 PM
btinindy's Avatar
Quoted: 30 Post(s)
Liked: 56
Yes, the SSR's have to have a load to "switch". Plug something into it to test, not just a meter...
BT1
btinindy is offline
Old 10-20-2014, 07:53 PM
Quoted: 28 Post(s)
Liked: 27
Well apparently my circuit tester (plug with lights to tell if circuit is wired correctly) wasn't enough of a load to trip the SSR.
Everything seems to be working correctly when I plug a lamp into it.
Geez, I was getting worried.
Thanks notnyt and BT1!
Old 10-20-2014, 07:55 PM
Quoted: 28 Post(s)
Liked: 27
Completed!
Old 10-21-2014, 07:04 AM
jpmst3's Avatar
Quoted: 95 Post(s)
Liked: 231
Good job!
That should do the trick!
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
Old 10-21-2014, 06:53 PM
btinindy's Avatar
Quoted: 30 Post(s)
Liked: 56
Looks good all murdered out. That is a serious heat sink!
BT1
btinindy is offline
Old 11-27-2014, 08:34 AM
d_c
d_c's Avatar
Quoted: 358 Post(s)
Liked: 310
d_c is offline
Old 11-29-2014, 08:03 PM
duder1982's Avatar
Just came across this thread, and am wondering are people having any issues with heat. If so is it do to the mechanical relay. I had and idea, but mine was for a in wall build. But if heat is a issue I guess I would want to stay away from this. I was thinking of using this relay.
http://www.mouser.com/Search/Product...-G3E-220T-US12
duder1982 is online now
Old 11-29-2014, 10:29 PM
A9X-308's Avatar
Quoted: 338 Post(s)
Liked: 222
It's only rated to 5A w/o the heatsink and if you were planning on running near rating with no airflow in wall, I'd suggest not using it. Or getting an electromechanical.
A9X-308 is offline
Old 11-30-2014, 06:55 AM
duder1982's Avatar
So I would have to use a heat sink. Any recommendation for electromechanical relays.
Old 11-30-2014, 07:12 AM
Sam S's Avatar
Quoted: 38 Post(s)
Sam S is offline
Old 11-30-2014, 07:41 AM
duder1982's Avatar
Thanks, didn't realize that, that's the one on the first page. Plus I all ready had it in my wish list at Mouser, and its cheaper then the ssr I was looking at.
Is it necessary to use the metal boxes. I read it acts as a heat sink, do they still get a little warm.
Old 11-30-2014, 07:46 AM
Sam S's Avatar
Quoted: 38 Post(s)
You don't need a heat sink if you're using a mechanical relay, it does not get hot.
I have built 2 SSR relays, and one mechanical. I use the mechanical one for my sub, because I understand it will allow for more current to pass through, without any risk of overheating. You can see pics of one of each type of box I built, if you look at my posts in this thread.
If you're not going to use a metal box, what else would you use? They're cheap, easily available, and don't look terribly bad. If you're going to use the Omron mechanical relay, you'll need to use two metal boxes, see my pics on earlier on this page.
Sam S is offline
