Garage sound system... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 60 Old 01-19-2011, 07:10 AM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
So, I finally got my garage ready for audio, two channel type.
I will be using an Airport express to pipe music from my itouch and iPad. So far iheart radio, pandora and iTunes.
The space is 24 feet deep 2.5 car wide and about ten feet tall, all walls are drywalled.
I would like the system to start at around 20 to 25hz..... The rest is history.
Horn loading would keep the need for big amps down to a minimum.
I will be funding this with the sale of my JBL 2226's wink wink nudge nudge..........
kgveteran is online now
post #2 of 60 Old 01-19-2011, 07:56 AM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
Just a little more info, the wiring was done 9 years ago and it all goes back to a location in my living room where the amp will be for the DIY speakers in the garage.
My though will be to interupt that wiring in the garage with a plate amp or two that have speaker level inputs for my mains, allowing me to use the XO and to use the plate amp to power the subs, which we will need if I'm gonna have a kickin sound system in there.
Thx...
post #3 of 60 Old 01-19-2011, 09:00 AM
coctostan's Avatar
Liked: 142
Are you limited to the proceeds of the 2226? Do you want a sub?
You could build some Econowaves Standards (Pyle waveguide, D220ti CD, Dayton DC300-8 woofer) in the PE cabs. (http://techtalk.parts-express.com/sh...79#post1620779)
For the sub, you could use any of the BFM designs from the THT, THTLP or maybe even the table tuba. It just depends on how much space you have.
coctostan is offline
post #4 of 60 Old 01-19-2011, 09:26 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5973 Post(s)
Liked: 5036
*sigh*
Pullin' yer arm to make them 4pi's, man. Heheh.
So is this a design for just a bass system for you garage or are you wanting speakers too? I'd say maybe a stock 4pi or Econowave and maybe pair those up with a single or dual THT's. If overall width is an issue you can build the 12" driver version which I believe makes the cab about 15-18" in width. Or if you are willing to slightly elevate your minimum lowend corner your options would open up a bit more.
That's what I'd do. Keep it simple, rugged, and inexpensive.
Scott Simonian is offline
post #5 of 60 Old 01-19-2011, 09:48 AM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
This will be a stereo pair of DIY mains... A subwoofer or pair of subwoofers.
I like the econowaves..... Let me research that first, then maybe a nice taped horn sub.
I will be flying the whole system up on the ceiling.
post #6 of 60 Old 01-19-2011, 10:10 AM
stgdz's Avatar
personally I would just head to your local good will and pick up the biggest oldest pair of speakers they have there. Tons of good deals there.
I run some old pioneers that my dad had since the 70's, they are really loud in the garage space. No certain how well the SQ is but my garage doesn't have garage treatments in it yet
But seriously, look for old cheap speakers on CL or a good will.
stgdz is offline
post #7 of 60 Old 01-19-2011, 10:13 AM
Bass Enabler
Liked: 5036
Ahh, flying the whole thing? Okay. Well, maybe check up on that Anarchy based TH if you want to do the TH route and that goes down to 25hz-ish. I wouldn't complicate the build with a one off TH design, myself but I'd like to see what you come up with if you do.
Parts Express makes these knock down kits.... omg, they have a 15" version now, apparently. Yeesh. I could have used one of these last year.
http://www.parts-express.com/pe/show...number=245-326
There ya go!
EDIT: btw, how much were you trying to get for your 2226's?
post #8 of 60 Old 01-19-2011, 10:30 AM
radman12's Avatar
Liked: 27
here is my garage sub, and yes its way more than you need in a garage, but for less than $100 you cant really go wrong on this one...
http://www.avsforum.com/avs-vb/showthread.php?t=1289415
radman12 is offline
post #9 of 60 Old 01-19-2011, 10:45 AM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
The 2226's are going for 130.00 each, just what paid plus shipping.....
post #10 of 60 Old 01-19-2011, 12:47 PM
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
I use Bose 901's (he ducks for cover)
I like them because I can crank them to get "good" sound everywhere but not get blasted if you get close. There is a picture of my workshop/garage towards the end of my HT build link in my sig.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #11 of 60 Old 01-19-2011, 01:16 PM
Drisco Z71's Avatar
I think I would second the recommendation of just going to goodwill or some place like that and picking up the biggest old speakers they have. Then you could spend more on the sub. I've been thinking about doing a monster horn sub using cheap drivers in my shop as well since I have something like 25'x40' to work with. A setup like that could make for a pretty enjoyable place to watch a movie with a big group of people.
Drisco Z71 is offline
post #12 of 60 Old 01-19-2011, 01:28 PM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
I'm looking at some PA speakers off of craigslist......next the garage sub ?
post #13 of 60 Old 01-19-2011, 01:42 PM
coctostan's Avatar
Liked: 142
You can always convert the PA speakers using Econowave plans.
post #14 of 60 Old 01-19-2011, 04:37 PM
Manic1!'s Avatar
Quoted: 198 Post(s)
Liked: 92
Manic1! is offline
post #15 of 60 Old 01-19-2011, 06:12 PM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
Originally Posted by Manic1! View Post
http://www.zzounds.com/item--BEHB2031A
Hard to beat.
I bet. Those look great...
post #16 of 60 Old 01-19-2011, 07:17 PM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
I found some two-way horn laoded PA speakers on craigslist, trying to get them for 100.00
It would be a good start.
post #17 of 60 Old 01-19-2011, 07:48 PM
CZ Eddie's Avatar
Quoted: 69 Post(s)
Liked: 33
For a garage, I think it could be a mistake to build "normal" speakers.
In your home theater, you would always be sitting in the same spot, so normal speakers are perfect. But in a garage, you would be kneeling down, standing up, moving from spot to spot. And if you're like me, you would eventually get tired of moving in and out of various audio "sweet spots".
Have you considered speakers that would "fill a room"?
The Bose 301's are designed for something like this and have 8" woofers that offer decent amount of bass. And, they aren't tower speakers. So they would be great mounted up near the ceiling.
They have been around forever, so you can find one of the many generations available on ebay or craigslist pretty easily.
The Bose 901's are very capable, but require being mounted away from the rear wall for the best sound. Also they like to be ceiling mounted, but about 1.5' from the ceiling I think?
"The boom is dead, long live the bass"
CZ Eddie is offline
post #18 of 60 Old 01-20-2011, 08:26 AM
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
That's exactly how I have mine mounted. I just modified the floor stands to hang them from the ceiling. They really do work well in the shop. They put out a remarkable amount of "sloppy bass". My shop is ~12,000 ft^3. I'm driving them with a 120 watt per channel Rotel amp.
petew is offline
post #19 of 60 Old 01-20-2011, 11:33 AM
TestWork's Avatar
It's sloppy because they are too close to the rear wall. I hope you are at least using the Bose EQ with them.
TestWork is offline
post #20 of 60 Old 01-20-2011, 01:24 PM
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
Yeah I'm using the OEM EQ. I've got about 2' from the pointed end to the wall. I still manage to whack them once in a while with lumber or clamps. At least they're out of skull striking zone. They're sloppy compared to my B&W's in the theater.
petew is offline
post #21 of 60 Old 01-20-2011, 04:34 PM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
Any reason why 15" two-way horns would be that much better than 12" two-way horns in my system....
I'm asking because I seem to be finding more of the smaller 12" models.
KG
Keep in mind, I will be building a pair or one large tapped horn to fill in the bottom end below 60 or 80 hz......
I use to help a friend do some live sound back in the day and never really forgot how it sounded, I want it back !
post #22 of 60 Old 01-20-2011, 04:35 PM
CZ Eddie's Avatar
Quoted: 69 Post(s)
Liked: 33
Wow, in the picture it looks like 2" from the back wall.
Nice table, btw.
CZ Eddie is offline
post #23 of 60 Old 01-20-2011, 05:52 PM
Manic1!'s Avatar
Quoted: 198 Post(s)
Liked: 92
They sound even better. Some of the best speakers I have heard.
Manic1! is offline
post #24 of 60 Old 01-20-2011, 10:27 PM
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
the bose 901 were designed to try to recreate the direct vs. reflected sound of live performances.
the relections provided by the 901 are preferred by many for music, as it makes it sound very spacious/ambient, but for home theater it is a total fail, as it makes dialog slurred/sloppy/unintelligible. this is why no pro theater employs this approach.
jbl experimented with such dual systems, but it didn't really catch on.
Listen. It's All Good.
LTD02 is offline
post #25 of 60 Old 01-22-2011, 04:57 AM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
Here are my mains. http://cgi.ebay.com/ws/eBayISAPI.dll...ht_4939wt_1162
Now what sub ? Is the danely super spud still an option if I build it, haven't seen any plans the thread is HUGE..
I would rather build one big one instead of two smaller ones.....
Can't wait til I start cutting wood in my freezing garage hahahaha
post #26 of 60 Old 01-22-2011, 06:36 AM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
The Danley DTS-10 has not been available as a kit for 9 months. It can now only be purchased as an assembled unit.
Many individuals in this forum like the Bill Fitzmaurice Tuba HT front loaded horn. The plans are available for $15 at the BFM site. There are at least 8 build threads in this set of threads. The BFM THT is 3'x3'xyy where yy varies between 24.5" and 36". The THT gives solid response to 22 Hz (its tuning) and then falls off precipitously. A pair would be devastatingly loud. The cost somewhat less than $500 each to build (price includes a separate power amp such as the Parts Express 240w plate amp). You need to check the BFM site for the latest recommended 15" drivers. Previously, it was one of the 15" PE 15" drivers.
There is also the THT LP that is twice as high but as the same internal volume as the original THT. Some individuals have built it because it fits better where they want to put it.
Correction: yy upper bound changed from 48" to 36". On BFM site there are 48 Tuba HT and 60 Tuba HT but they are different beasts.
wwinkler is offline
post #27 of 60 Old 01-22-2011, 08:45 AM
dbldare's Avatar
Originally Posted by wwinkler View Post
Many individuals in this forum like the Bill Fitzmaurice Tuba HT front loaded horn. The plans are available for $15 at the BFM site. There are at least 8 build threads in this set of threads. The BFM THT is 3'x3'xyy where yy varies between 24.5" and 48". The THT gives solid response to 22 Hz (its tuning) and then falls off precipitously. A pair would be devastatingly loud. The cost somewhat less than $500 each to build (price includes a separate power amp such as the Parts Express 240w plate amp). You need to check the BFM site for the latest recommended 15" drivers. Previously, it was one of the 15" PE 15" drivers.
I didn't realize that there was a 48" version. Is there a build with this width?
dbl
Let's all go to the lobby
....Let's all go to the lobby
dbldare is offline
post #28 of 60 Old 01-22-2011, 12:34 PM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
You think the Dayton driver out in the garage would hold up to the heat and cold. Maybe in this case paper would be better than plastic..LOL
We're talking 0 degree's to minus 15, and up to 90 in the summer.....
The tuba HT with the longer version can be mounted in my ceiling with just the throat exposed. Nice !
Now what amps, it would have to be a plate amp with speaker level in's and out's as I will be using the inboard XO....budget, budget.
I did get the Sonance 60 watt amp because it has a nice auto sense power on and off.
The Dayton 240 watt plate amp is on sale at PE for 99.00....... Thoughts
post #29 of 60 Old 01-22-2011, 02:59 PM
Aaron Smith's Avatar
Quoted: 158 Post(s)
Liked: 68
Any driver spec'd for automotive use will be fine in the garage.
Not sure on your mains...did you get them yet? If I was looking I would check out eBay for some used bonafide name-brand pro speakers with horns.
I found some Renkus Heinz SR 81's for $150 that absolutely rock my 1200 sq.ft. garage with 80 wpc of stout early-90's Yamaha receiver power.
That plate amp is the exact same one I use to power a single 12" 6th-order sub in the garage...it does the job and is cheap. It was powering two of these 2.9 ohm 12" cabs in series until one died -- used to use them for the low end at my wife's bank Christmas/Halloween parties until an overzealous wanna-be roadie helping me load stepped on the wire (which was stupidly run directly to the voice coil with no terminal plate) and ripped the leads right out of the coil.
The system also has an a/d/s C1500 electronic crossover/bass controller ($50 on eBay) to high-pass the Renkus Heinz and provide some neat controls over the subs. Really allows the system to crank!
I used the PE amp's high-level ins/outs for awhile but it seriously compromised the sound.
Lilmike is belting out a nice Tapped Horn alternative to the THT for my basement family room system that would rattle your garage. The shopsub that radman12 linked to in post #8 is an awesome affordable option that is ready to build.
Aaron Smith is offline
post #30 of 60 Old 01-22-2011, 04:12 PM - Thread Starter
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
I'm really concerned about a plastic woofer in frigid conditions. The Dayton is 150.00, that's a lot of cash for a driver that mite have problems in cold weather.
Really would be a great place for an Auto driver......
