Any Interest in Cheap "Flat Pack" Enclosures? - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 777 Old 03-15-2011, 06:50 AM
buzzardmountain's Avatar
Horngasm...
buzzardmountain is offline
post #362 of 777 Old 03-15-2011, 06:55 AM - Thread Starter
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1771
Originally Posted by buzzardmountain View Post
Horngasm...
Hey man, get your horngasm stuff out of this family oriented thread.....this is for flat packs, not horngasms!
_______________________
The SEOS Waveguide Project
Erich H is offline
post #363 of 777 Old 03-15-2011, 11:24 AM
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
Originally Posted by maxmercy View Post
Any final consensus on the name? CinemaHorn MFW?
JSS
Cinema Horn, but there will be a series of them.
I'm thinking that since it takes space to make bass, the cabinet volume is a great number to stick in there to uniquely identify these cabinets. Since I design different topologies (Tapped vs offset driver/front loaded), we could throw a "T" or an "F" in there as appropriate.
Using the dimensions I'm currently working with, The offset-driver front-loaded horn for the MFW driver is the Cinema Horn F-18. If you made it wider (say 20.5 internally), it would be an F-22. If you really wanted an F-16, you could make it 15.5" wide, but I have not found a driver for this one yet.
My single-sheet project I've been working on (The one that just got a complete refold cause I messed it up pretty bad ...and it was all me....) is a 6-cubic foot box, so I'd call it the Cinema Horn T-6.
The two-sheet Shiva fold I am working on is about 11 cubic feet, but it might grow a touch yet, have not finished the fold. That would be a T-11 (or 12...)
Now, what do we call my 12 cubic foot, 15" PA tapped horn design that does just a hair under 100 dB at a watt with a -3 of 33 Hz?
lilmike is offline
post #364 of 777 Old 03-15-2011, 11:33 AM
Quoted: 3256 Post(s)
Liked: 2743
post #365 of 777 Old 03-15-2011, 01:16 PM
F69 Horngasm...
post #366 of 777 Old 03-15-2011, 01:42 PM
Spec4's Avatar
Liked: 24
Anybody know someone with AutoCAD? That would make things a LOT faster. I could just send them the program and they could price is so much quicker.
Still looking for ACAD volunteers? I have AutoCAD 2010 and Inventor 2010, the latter is a 3D modeling program. PM me if interested...
Spec4 is offline
post #367 of 777 Old 03-15-2011, 02:30 PM
Liked: 2743
post #368 of 777 Old 03-15-2011, 02:45 PM
Fatawan's Avatar
LilMike's HornE
Fatawan is offline
post #369 of 777 Old 03-15-2011, 03:03 PM
Oklahoma Wolf's Avatar
Quoted: 20 Post(s)
The Defibrillator
Oklahoma Wolf is offline
post #370 of 777 Old 03-22-2011, 04:20 AM
CZ Eddie's Avatar
Quoted: 54 Post(s)
Liked: 32
Here's where I am at currently...
~29 3/4" X ~60" X ~19" These are external dimensions, and are not final.
According to the model, with the 15" driver Erich found, this cabinet is 92 dB 1 W 2pi, with a -3 dB point of ~17 Hz in a groundplane setting. Other drivers work well too, and lots of other drivers will fit inside.
Cool part? It is an extremely simple build. There are only 5 internal panels, not counting the bracing or reflectors.
Details are coming - I promise. I've got the plywood in the shop for the prototype, and I am nearly done with the layout.
More to come, I promise. Just don't hold your breath waiting....
I may not be any good, but I sure am slow....
So 2pi means the 17hz estimate includes room gain/boundry loading?
Are you also working on any similar format designs that extend to lower frequencies in-room? Like closing in on DTS-10 territory?
"The boom is dead, long live the bass"
CZ Eddie is offline
post #371 of 777 Old 03-22-2011, 10:21 AM
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
Nope - 2pi means sitting in the middle of a parking lot, a groundplane environment.
In room might be lower, but that depends on the room. Since we all have different rooms, I can't predict what that number might be for anyone.
Sure, I can design a horn that digs deeper than the DTS-10. It will be bigger than the DTS 10. Get me a driver that works, then find me someone that's willing to put a cabinet that size in their room. Of all of the monster sub designs I've done on and off forum, exactly ONE of the monster subs I have modeled and folded has actually been started, and even that one is not done yet (partly my fault...).
To be totally honest, not many people build these because there are just better ways to get there. If you want to reproduce 10 Hz, you're better off going for it with brute force and displacement. Multiple drivers in an IB array or sealed cabinets will get the job done, and then some, take your pick. There are several recent examples of the multiple sealed cabinet approach, which offers a lot more placement options than a single cabinet that's the size of a queen-size bed.
lilmike is offline
post #372 of 777 Old 03-22-2011, 10:35 AM
CZ Eddie's Avatar
Quoted: 54 Post(s)
Liked: 32
Wow, not bad!
OK, you had hinted at designing the MFW series with both smaller and larger sizes than the one indicated above. Was just wondering which direction the larger was headed.
CZ Eddie is offline
post #373 of 777 Old 03-22-2011, 11:10 AM
Quoted: 20 Post(s)
I can think of one dog barking at that door
Even so, like Mike said, anything competing with the DTS-10 is going to be a big 'ol subwoofer in its own right. Below 15Hz just isn't practical for horns, at least for most of us without rooms the size of gymnasiums.
post #374 of 777 Old 03-22-2011, 11:35 AM
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
Wow, not bad!
Larger = lower, but not as loud.
This is a function of displacement. I have the same amount available from the driver, so I can either go lower or louder if I make the cabinet larger, but physics says I can not do both.
As it is currently drawn up, it is 5 feet tall. That is not small. Making it 7 feet tall, which is about as big as can stand up in a typical room, adds 2 feet which nets approximately 2 meters of additional path length once the rear chamber gets adjusted for proper annulling. This gets the -3 dB low corner to 14 Hz in 2pi simulation land, at the cost of ~2 dB at a watt and a bit more cabinet. Problem is - if we're using the MFW driver, we run out of excursion before we run out of power handling.
lilmike is offline
post #375 of 777 Old 03-22-2011, 11:36 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
What about an AV15H (in theory)?
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #376 of 777 Old 03-22-2011, 12:48 PM
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
In theory??? No idea... I don't even have accurate T/S parameters for their stuff anymore... It has been unavailable for too long and there have been too many changes.
Let me get a proto built and measured with the MFW, then we'll see what else we can shove in there.
lilmike is offline
post #377 of 777 Old 03-22-2011, 01:28 PM
penngray's Avatar
Liked: 43
FWIW, AE Speakers has been shipping the AV series drivers for the past couple of weeks. Im not sure how much of the back log is cleared up but they are shipping.
penngray is offline
post #378 of 777 Old 03-22-2011, 01:38 PM
CZ Eddie's Avatar
Quoted: 54 Post(s)
Liked: 32
This actually interests me more, since I do have room for two towers in the front and one in the rear.
Problem is - if we're using the MFW driver, we run out of excursion before we run out of power handling.[/b]
Oops.
CZ Eddie is offline
post #379 of 777 Old 03-22-2011, 01:41 PM
CZ Eddie's Avatar
Quoted: 54 Post(s)
Liked: 32
Yeah, I'm keeping an eye on your upcoming Wolfhorn project also.
I dig the tall, slim towers for maximizing output while minimizing floorprint. Plus, you can make them look like faux cabinets if you want.
CZ Eddie is offline
post #380 of 777 Old 03-22-2011, 02:35 PM
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
That is excellent news. Very glad to hear this.
lilmike is offline
post #381 of 777 Old 03-22-2011, 02:42 PM
lilmike's Avatar
Quoted: 64 Post(s)
Liked: 160
Yeah, that is all in simulation-land though. I need to see what happens here in the real world. That's why I need to build a prototype. Hopefully testing will be non-destructive, though I am quite good at finding the limits of drivers in front-loaded horns. I've clanked or smoked drivers (or both...) in each FLH I've built thus far... I've had much better luck with the tapped variant in that regard - cause I can typically hear the bad things start before it goes terminal.
Other drivers will work, no worries there. Not sure which yet - have not explored that too much. Model and plans will be shared when I'm done with the prototype.
lilmike is offline
post #382 of 777 Old 03-22-2011, 03:23 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
I inquired about them, but no answer. So, who knows if we ever see them again.
How about the LMS-R 15"?
High cost, but high excursion and you probably only need one or two....
Joe = LFE Addict
jpmst3 is offline
post #383 of 777 Old 03-22-2011, 04:46 PM
optoguy's Avatar
Erich,
Sorry to squeeze in between all of the horn talk, but I'd be interested in 4 of the Statement monitors.
Thanks for all of the hard work!
Darren A.
optoguy is offline
post #384 of 777 Old 03-22-2011, 05:31 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1038
paHORNo??? now that's a name for a horn ladys lol!!
N8DOGG is online now
post #385 of 777 Old 03-22-2011, 05:59 PM - Thread Starter
Erich H's Avatar
Liked: 1771
Originally Posted by optoguy View Post
Erich,
Darren A.
Yeh, this horn talk has gone crazy!
I'm going to get prices for those next. That will be a MUCH faster turn around.
I should have the Overnight Sensation cabinets next week as well. They are going to be very cheap.
Erich H is offline
post #386 of 777 Old 03-22-2011, 06:22 PM
jaeelarr's Avatar
Quoted: 46 Post(s)
Liked: 42
Wish I was even a little bit tool savvy, cause this is an awesome idea. Anyone want to build one for me and ill kick them down the money for it?
jaeelarr is offline
post #387 of 777 Old 03-22-2011, 06:25 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
You might want to mention were your located so a local member may offer to help.
mjaudio is offline
post #388 of 777 Old 03-23-2011, 06:14 PM
Sinistre1's Avatar
Liked: 30
Thanks Optoguy, I didn't want to be the one to HORN in on the conversation but I would definitely like to make a statement or two.
Still in for monitors when they are up.
I'm getting there....!!!
Sinistre1 is offline
post #389 of 777 Old 03-25-2011, 05:27 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Any word on the Full size Statements?
Joe = LFE Addict
jpmst3 is offline
post #390 of 777 Old 03-25-2011, 09:08 PM - Thread Starter
Erich H's Avatar
Liked: 1771
Picked up the 2nd pallet of Anarchy flat packs to box up. You can see that the boxes are in the background. Getting 4 total this time around.
I also got a bunch of Overnight Sensations. They turned out very nice. To keep the price low, I didn't have them use a round over bit on the side. I figured I could run that down a router in about 1 minute before boxing them up. Everything else about them is to the original specs from the designer, no counter sinking the drivers. I did design the box so it could be put together really easy, but kept the same internal dimensions. Matter of fact, in this photo, it's holding itself together with no glue or tape.
Here's how they packed them for me:
This is a VERY easy build and will be VERY cheap. It's Baltic birch too.
Erich H is offline
