Anyone have a Dayton SA230 amp? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-26-2011, 02:38 PM - Thread Starter
MisterMichigan's Avatar
http://www.parts-express.com/pe/show...number=300-813
Saw this at PE, anyone have one? Thinking this might be a cost-effective option if you don't want/need a plate amp. No reviews yet so I thought I'd toss it out here and see if anyone has any info.
MisterMichigan is offline
post #2 of 7 Old 01-27-2011, 05:58 AM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
I suspect that it is a new amplifier. I purchased two PE plate amplifiers in the last 14 months and have never seen this model (and I looked at all the PE amps).
http://www.parts-express.com/pe/show...number=300-805 - their 240w at the ~$100 sale price appears to be more cost effective than the above 230w amp at ~$220.
wwinkler is offline
post #3 of 7 Old 01-10-2013, 12:07 PM
dmuckle's Avatar
It has a lot of nice features you don't have on most of the plate amps. However, unless it's a typo the rated THD is a whipping 1%, which is ten or more times what one would expect.
dmuckle is offline
post #4 of 7 Old 01-10-2013, 12:12 PM
brian6751's Avatar
Quoted: 878 Post(s)
Liked: 673
i had two powering two THTLP's. perfect for that aplication IMO. the power LED is VERY bright though.
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #5 of 7 Old 01-10-2013, 12:24 PM
dmuckle's Avatar
Thanks for the info.
Re the LED pilot, take a felt tip pen and mark the LED. You might need to let it dry and then reapply. It won't blacken it out but it will substantially dim it. That's a lot easier than trying opent he box and solder a small resistor in series or fitting a a piece of tape etc.
dmuckle is offline
post #6 of 7 Old 01-10-2013, 12:25 PM
dmuckle's Avatar
dmuckle is offline
post #7 of 7 Old 01-10-2013, 12:37 PM
brian6751's Avatar
Quoted: 878 Post(s)
Liked: 673
i put tape over it when i had them . they were sold with the THT's
Rivers Edge Theater
