Group Buy for 6.5" Anarchy Tapped Horn. - Page 15 - AVS Forum | Home Theater Discussions And Reviews
post #421 of 424 Old 11-30-2011, 02:15 PM
englehmj's Avatar
Still alive Erich? I have sent multiple PMs and messages through your site over the last few weeks/moth to no avail...thought I might see if you have a thread subscription...
englehmj is offline
post #422 of 424 Old 11-30-2011, 03:42 PM
NEO Dan's Avatar
Sit tight
Last I heard Erich was planning to be BUSY, and then some other responsibility's got added on top. The man has his hands full. He will be back.
Dan
NEO Dan is offline
post #423 of 424 Old 04-28-2012, 07:16 AM
gnumadic's Avatar
Originally Posted by lilmike View Post
That amp is only 45 watts at 8 ohm, so it is a little light on power.
This one would do the job for only a few bucks more, and might even fit into the cabinet. Information as to highpass and all that is pretty light though. Looks like a 25 Hz highpass with 3 dB of boost at 40 Hz. Not a bad fit, might actually help things to be honest.
Depending on what you're after - an old-school stereo receiver can be a fine amp for these - all you need is 100 W into 8 ohms. I've scored some good stuff at the local thrift stores.
You could maybe even run these off the extra channels in a 7.1 receiver if you only run it as a 5.1 and the receiver has preamp inputs like mine does.
Would mounting that Apex Jr C-6 into the back of the cabinet ruin the tuning?
Scott
gnumadic is offline
post #424 of 424 Old 04-28-2012, 04:53 PM
handsomepete's Avatar
I built a pair of these subs but the output was just not enough. I can see how with four it may be great but I don't have the room for them. I also found that they were easily pushed to much and would get "funky" but that's on me.
I will say that I ripped out the drivers and put them in some 0.5ft^3 cabs tuned to 45hz and they rock! So I would caution anyone looking for medium to high output. That said they would make a great computer sub sitting next to a desk.
handsomepete is offline
