DIY Sound Diffusers - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 64Likes
post #361 of 406 Old 08-08-2014, 11:42 PM
Deep Sea Sound
dgage's Avatar
Quoted: 1663 Post(s)
Liked: 1480
So I have a question related to one of these DIY QRDs or one of the other options mentioned. Is there a somewhat rigid material that would diffuse some of the sound while also being somewhat absorbent to certain, likely higher, frequencies? Just think some diffraction is good but so is some absorption. Thanks.
dgage is offline
post #362 of 406 Old 08-09-2014, 12:16 AM
aackthpt's Avatar
Quoted: 16 Post(s)
Liked: 26
Originally Posted by dgage View Post
aackthpt - first I thought for sure you were making up **** when you mentioned tortuosity...so thanks for the education.
LOL... I kind of wish I was making things up. Acoustics can turn into a very deep rabbit hole.
Cool link from diyaudio - thanks. Pearlite etc makes sense too; I'll have to read the thread.
You mean diffusion... diffraction is a whole other thing... and yes there are acoustical devices meant to do it too. Anyway there are ways to do what you ask but you're thinking about it the wrong way when you ask for it in one material - it's just done with clever combinations of materials. You can't put anything in front of a QRD or it doesn't work right, so QRDs are sometimes made with some absorption at the bottom of the wells. Another way to do what you want is a thin layer of absorption over a diffusing device, for example a half inch of fiberglass on top of a very large polycylindrical diffuser. Also perhaps the MyRoom concept contains some of what you're looking for. Also the BAD (binary amplitude diffuser) panels (the absorber with a hard facing perforated in a specific pattern) shown earlier in the thread have some of the combination effect you're thinking of I think.
Neither absorption nor diffusion (nor diffraction for that matter) are "good" or "bad", they are just physical phenomena that can be useful to some end depending on one's philosophy and take on psychoacoustics as well as the situation one finds oneself (e.g. speaker dispersion pattern).
dgage likes this.
aackthpt is offline
post #363 of 406 Old 08-09-2014, 12:28 AM
Deep Sea Sound
dgage's Avatar
Liked: 1480
Thanks for the info...yes I was thinking about combining materials but I have a living room theater that I want to perform as much like a theater as possible while looking like a normal living room. I like the challenge but obviously that means compromises and more asethetic treatments. My wife and I were looking at different treatments last night and discussing what we might put on the front wall and front ceiling. We've already picked out some art pictures that I will print onto fabric and make art treatments with Roxul Rockboard 60. (DIY Custom-Printed Movie Poster Acoustic Panels - cheap!). But that's just the start and I want to do more treatments so I'm really interested in where this thread goes. Thanks again.
dgage is offline
post #364 of 406 Old 08-09-2014, 04:47 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
I currently have several 2ft by 4ft panels that are constructed out of two layers of 2" think (for a total of 4" thick) OC703 that I have spaced 4" off the wall. As my theater room is nearing completion, and being that it is so much larger than my previous listening area, I need to make some new absorption panels, but, unfortunately I can not afford any OC703 as Home Depot wants way more than I can spend.
With that in mind, I can get Roxul Safe-N-Sound for much less at my local Lowes. I have read that Safe-N-Sound is very similar to OC703, and with it being significantly cheaper, I want to go with that. What do you guys think would be the most optimal thickness of the Safe-N-Sound that would work similar to the 4" OC703 + 4" air gap?
I was thinking about building the S-N-S panels to be 6" thick with a 3" to 4" air gap. Does that sound ok?
Martycool007 is offline
post #365 of 406 Old 08-09-2014, 11:07 AM
Lonely Raven's Avatar
Quoted: 34 Post(s)
Liked: 42
Well said, these are just tools. One thing I see coming up over and over, is a cheap 2" diffuser for example, and why we can't just use that vs an elaborate (read deep) diffuser. Just having diffusers is not the same as having broadband diffusers. It's like saying, why use a 1000 watt sub amp when I can get this 100 watt one cheaper. Different tools for different needs.
I don't have my chart of insulation acoustic specs handy - there is a great one that someone keeps up somewhere on the web (I don't recall where right now) where you can quickly look up and compare one type to another - if you can find one of those charts, or look up the acoustic absorption specs of both materials you can probably answer that for yourself. Chances are it's going to be pretty close to 1:1. All the quality materials are pretty close, and the placement and number of the devices you install will have far more impact than the exact specs.
Back onto the DIY subject - I picked up some foam last night. that pink stuff has gone way up in price since the last time I bought it. A 1" sheet used to only be $7-$8 and my local menards had it for $12! So I only got one sheet of that, and one sheet of the cheap plane white EPS which was still like $8. I'm working on some garage projects now, but once I get some space cleared I'm going to take a guitar string, some plywood, and make a 12" X 12" hot wire cutter I can mount to my table saw and turn big pieces of foam into little pieces. We'll see what becomes of that!
Lonely Raven is offline
post #366 of 406 Old 08-09-2014, 11:47 AM
aackthpt's Avatar
Quoted: 16 Post(s)
Liked: 26
There are much better places to get OC703 than home depot. The industrial insulation contractors are usually much less since it's not really a special order for them. But SNS will work well too. Here are some posts you may find useful:
http://www.gearslutz.com/board/7529309-post7.html
http://www.gearslutz.com/board/7532995-post14.html
http://www.gearslutz.com/board/9172736-post18.html
and you can use this tool with that last bit of data to play with alternatives: http://www.acousticmodelling.com/porous.php
depending on your goals with said panels.
aackthpt is offline
post #367 of 406 Old 08-09-2014, 11:50 AM
aackthpt's Avatar
Quoted: 16 Post(s)
Liked: 26
http://bobgolds.com/AbsorptionCoefficients.htm
aackthpt is offline
post #368 of 406 Old 08-09-2014, 12:08 PM
aackthpt's Avatar
Quoted: 16 Post(s)
Liked: 26
I've had half a plan to put a hole through one of my IKEA tables with the corrugated core, rig up some kind of arm, and use something like
http://www.harborfreight.com/50-inch...ide-66581.html
, or a modification thereof, for a fence. The object would be to able to cut nearly any depth desired... who likes limitations?
Unfortunately my theatre room is really too small to use diffusion with good bandwidth - both from the "distance from the diffuser" standpoint as well as from the "reasonable space usage" standpoint. I'd love to have the space and possibility to put a really deep QRD array at the rear of my room.
aackthpt is offline
post #369 of 406 Old 08-09-2014, 01:48 PM
noah katz's Avatar
Quoted: 1100 Post(s)
Liked: 381
... I could design a diffuser that works from 272Hz to 13kHz. But it would be 12" deep, and roughly 36" X 36" with 1" wide wells. Being realistic. lets look at 6"-8" deep, 1"-2" wide wells. 24" X 24" - something like what I built for my ceiling, but deeper.
Do we really need them to work that low?
Unless the speakers are huge, those freq are more or less omnidirectional.
But that raises a question I've never considered - what effect does diffusion have on room modes? Though I guess the 300 Hz range is around where they stop being an issue.
Originally Posted by bwaslo View Post
I had a book shelf in my room (before clearing it out to make the house ready for showing according to realtor!) that actually had a very noticeable diffusing effect. ... It might have been a case of "better than nothing" maybe, but quite effective subjectively.
How did you determine the benefit was from diffusion, as opposed to absorption or interfering with a first reflection that might have been problematic?
Re the charcoal, most interesting.
I just read a little from the links, but it sounds like it works by essentially "solidifying" (adsorbing means they stick to the surface of the carbon) some of the air molecules so that they don't contribute to gas pressure.
What I don't understand is how that would work on both halves of the compression/rarefaction cycle.
I can see how pressure increase would be reduced by the molecules being impressed into the carbon surface, bur what about rarefaction?
Ah, it must be that at atmospheric pressure there is a portion of adsorbed air,some of which is released on rarefaction.
noah katz is online now
post #370 of 406 Old 08-09-2014, 02:25 PM
aackthpt's Avatar
Quoted: 16 Post(s)
Liked: 26
As low as 272 Hz? Well, presumably yes. Because a diffuser is more or less by definition something you use in the specular range, which as you noted more or less happens above 300Hz in the average room. And if you believe Toole, who more or less says all devices treating the specular range should extend to the bottom of it for the given room.
Toole, p. 507 "All absorbers, wherever they are located, must be not less than 3 to 4 in. deep." And later when discussing diffusers "To assist listeners in the perception of immersion or envelopment, engineered surfaces should be not less than about 8 in. deep, and of the type that disperses sound horizontally. Many curved and multifaceted convex geometric shapes will work, so considerable artistic freedom exists, as long as they are not less than about a foot deep."
All reasons why I'm more interested in test results more than understanding the mechanism. Tortuosity etc is just geometry, and that I understand. But I'm completely not qualified to judge the veracity of any claims of adsorption etc. It's not as though one is concerned about how fiberglass works when deciding how to design an acoustical device with it either - just about being able to predict what it does to the sound waves.
aackthpt is offline
post #371 of 406 Old 08-09-2014, 07:35 PM
noah katz's Avatar
Liked: 381
Fair enough.
Re fabrication, I find that a bandsaw works great for foams of all types and OC 702; the narrow blade gives less waste and particle generation, and lower blade speed doesn't throw it as far.
Also, had an idea of perhaps questionable merit and fabrication practicality -a QRD made from rigid fiberglass.
It would give some absorption at freq below the diffusion range.
To keep it from absorbing in the diffusion range the face could be sprayed with something goopy that would set relatively hard; maybe just thinned drywall compound would do it.
post #372 of 406 Old 08-09-2014, 07:48 PM
Quoted: 34 Post(s)
Liked: 42
That's the one I was thinking of - thanks!
post #373 of 406 Old 08-09-2014, 08:39 PM
aackthpt's Avatar
Quoted: 16 Post(s)
Liked: 26
Actually latex paint does this. Jens Eklund (from Gearslutz) sells an EPS diffuser (QRD-ish but without fins, designed with AFMG Reflex, made on a CNC hot wire machine) and he's tested the amount of absorption reduction based on painting. It was not small, but I don't have the reference handy nor the will to find it... should be easy to Google.
aackthpt is offline
post #374 of 406 Old 08-10-2014, 07:50 AM
Quoted: 34 Post(s)
Liked: 42
That's another guy that has a great grasp of room treatments.
post #375 of 406 Old 08-10-2014, 05:07 PM
noah katz's Avatar
Liked: 381
I was concerned that too much might get sucked up by the porous fiberglass.
post #376 of 406 Old 08-10-2014, 05:16 PM
aackthpt's Avatar
Quoted: 16 Post(s)
Liked: 26
Ohhh durr. Somehow "rigid fiberglass" translated to me as something more like "fiberglass layup" at that moment.
Yeah the combination devices I've seen have the typical frame, wooden bottom, and then use the rigid fiberglass to set the well height but I think they have some sort of plastic or other membrane on top of the rigid fiberglass at the well bottoms.
aackthpt is offline
post #377 of 406 Old 11-11-2014, 03:04 AM
dennisfoley's Avatar
Quoted: 18 Post(s)
I asked him directly and he dodged that question (or missed the E-mail I don't know). From what I gather from talking to him, it's an aquarium/pond filter material to clean the water. But activated carbon for filtering aquariums and ponds come in many forms. I had assumed it was the sheets of filter material, like a roll of insulation, but Dennis had said something about 45# of pellets in one of his designs...which confuses me.
Activated carbon pellets looks like this :
I can't wrap my head around how that would absorb bass. Unless all the micro-pockets of air in the material is catching the waves, and the friction of the pellets is turning all that energy to heat...almost like a micro-to-macro scale version of what the insulation we typically use for absorbers does. I'm just speculating though - as I said, Dennis never answered my question and I didn't buy his plans for the bass traps.
If you spring for his plans it has the source and type of carbon, I'd like to know!
Sorry if I missed replying to your point. Please PM your email and I'll check back and see where I missed it. I obviously can't give the house away as to our technology as it took years in R&D to come up with. That said I hope this Q&A video helps answer your question as to where the carbon fits in in the process:
http://www.acousticfields.com/opinio...und-absorbers/
When used as the fill material in the diaphragmatic absorption process...well then you have the hot rod power. It's like gas in a car engine, sat in a can it can't do its job without being put in the engine.
The process of absorption involves two main variables: surface area and porosity. The surface area and the pores or holes for carbon is the same for foam. Air movement across foam enters the open cells of the foam, friction occurs, a heat transformation is created and this is an energy form conversion which results in sound absorption. The same mechanical process works for carbon. Activated carbon just has more pores and more surface area. A gram of carbon has 2,000 square meters of absorption surface area according to the literature on activated carbon.
Dennis
amo76 likes this.
Chief Acoustic Engineer at Acousticfields.com. Listen to your music...without hearing your room!
dennisfoley is offline
post #378 of 406 Old 12-04-2014, 11:33 AM
Romans828's Avatar
Quoted: 141 Post(s)
Liked: 71
I found DIY binary amplitude diffusers very helpful in my room. They are much easier to manufacture/ship. IDK about the patenting stuff as several companies use this technique in their panel products but since Erich has the access to the CNC its worth a look.
I contracted a local CNC guy to pop all the holes in 1/8" hardboard and used the panels as membranes over BB absorption like RPG's BAD panels.
My version:
Is there something special about the pattern that would make this perform better than random holes? Is that what is patented?
Romans828 is offline
post #379 of 406 Old 12-04-2014, 01:27 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
the pattern is not patented. my understanding is that any pseudo random binary sequence with more or less equal distribution of ones and zeros should do.
But the specific application (properly perforated board over porous absorber) is patented
zheka is offline
post #380 of 406 Old 12-04-2014, 01:35 PM
zheka's Avatar
Quoted: 29 Post(s)
Liked: 26
Here are some templates for BAD panels if interested.
http://static.cpsws.net/gene/bad.pdf
http://static.cpsws.net/gene/bad_inverse.pdf
These are good for 2'x2' panels. The holes are 1/2". Normally it is done from 1/8" hardboard or similar material.
If anybody can produce these in Chicago area, please let me know.
zheka is offline
post #381 of 406 Old 12-04-2014, 01:45 PM
Romans828's Avatar
Quoted: 141 Post(s)
Liked: 71
That is cool. On the surface, it doesn't seem like it would be that difficult.
post #382 of 406 Old 01-13-2015, 08:55 AM
bwaslo's Avatar
Quoted: 68 Post(s)
Liked: 188
I just found this thread today. I had posted on a few other forums about a VERY inexpensive and easy to make (but computer optimized and good-performing) step diffuser design and construction technique that I ran across (and adapted) from Tim Perry at http://arqen.com/sound-diffusers/. You can find details at http://www.diysoundgroup.com/forum/i...hp?topic=493.0 and/or at http://www.diyaudio.com/forums/multi...diffusers.html.
Highly recommended as a minimum-tools, no sawdust 1 or 2 day project.
Bill
ellisr63, zheka and bimmaguy like this.
___________________________________________
DIY Synergy horn spreadsheet Synergy horn spreadsheet and pdf
XSim -free crossover designer and simulator XSim install file
Easy and cheap sound diffusers (the "Depot Diffusers") making easy DIY depot sound diffuser-panels-step by step.html
SmallSyns - point source controlled directivity in a manageable size SmallSyns
bwaslo is offline
post #383 of 406 Old 01-13-2015, 09:00 AM
ellisr63's Avatar
Quoted: 993 Post(s)
Liked: 414
Bill
Looks like a simple way to make them... I like em! Question though... Shouldn't there be some absorption in the .7x 1.5" cavity? I would think it would resonate.
ellisr63 is offline
post #384 of 406 Old 01-13-2015, 09:13 AM
rlhaudio's Avatar
Quoted: 310 Post(s)
Liked: 96
I am interested in the 24x24 piece. The type you can simply rotate to add larger sections of wall.
Marantz 7702mk2, Panasonic 8000 w/ 130" AT Screen HTPC w/30 tb
DIY QSC SC-2150 L,C,R (10) QSC SR-8101 sides, rears & atmos/dst-x
DIY (4) Fusion Tempest
DIY (2) UM 15 "Sub's (4) SI 18's (2) PA460 mbm
(3) 15" woofers for QSC 2150 for sale, (1) Inuke 6000dsp
rlhaudio is online now
post #385 of 406 Old 01-13-2015, 09:29 AM
bwaslo's Avatar
Quoted: 68 Post(s)
Liked: 188
Probably, but I haven't noticed any issue so far. Probably just some fiber at both ends would be enough to kill any resonances that might occur.
ellisr63 likes this.
bwaslo is offline
post #386 of 406 Old 01-13-2015, 09:29 AM
Quoted: 34 Post(s)
Liked: 42
Yeah, I would put some acoustic blanket in there or something. That's a great, simple design, I like it!
post #387 of 406 Old 10-23-2016, 01:51 AM
Liked: 0
Is it possible to make binary BAD hole pattern on 50 cm wide doors on a closet/cabinet?
Hornlyd is offline
post #388 of 406 Old 11-16-2016, 02:36 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Anything is possible so sure.
Mfusick is offline
post #389 of 406 Old 01-21-2017, 05:27 AM
12B4A's Avatar
Quoted: 367 Post(s)
Liked: 262
So I decided to take the general build strategy described by @kgveteran (link) & @bwaslo (link) and I ran with it.
Here are the main design characteristics:
  • 2ft x 2ft 2D diffuser with 144 unique well depths
  • 7 inch max well depth with 2 inch well width
  • A not-quite-a-primitive-root configuration (156 well design with a row removed)
  • 3lb/foot EPS foam
  • Water jet cut of an 8ftx4ftx2inch sheet with no material wasted
  • One sheet yields 4 panels total with 2 identical panels and the inverse cut for the other 2
The customary AVSforum before photo:
In box:
One 24" by 8" 'module':
Identifying and labeling the panels:
Sorting done!:
Dry fitting 2 panels before gluing together:
Name:	2D shipped boxes.jpg
ID:	1909617   Click image for larger version
Name:	2D in box.jpg
ID:	1909625   Click image for larger version
Name:	2D module.jpg
ID:	1909633   Click image for larger version
Name:	2D label and sort.jpg
ID:	1909641   Click image for larger version
Name:	2D sorted stacks.jpg
Name:	2D dry assembled.jpg
ellisr63, dgage, GPM and 5 others like this.
Life is Lambertian
12B4A is online now
post #390 of 406 Old 01-21-2017, 06:12 AM
gworrel's Avatar
Quoted: 371 Post(s)
Liked: 329
That looks amazing. So more details please about how you managed to get this done. I assume this was done with some sort of expensive CNC water jet. Who typically has these things and how much might they charge?
Edit: I'm in Detroit and a quick google search shows several places in the area that specialize in water jet cutting. Or how many would I have to make and sell to pay for one of these: http://www.ebay.com/itm/Par-Model-Ve...-/272138605858
Edit2: This guy on craigslist only charges $1: http://detroit.craigslist.org/okl/hvo/5952780109.html
ellisr63 and Grott77Ralph like this.
gworrel is offline
