WMTMW Teaser - AVS Forum | Home Theater Discussions And Reviews
post #1 of 30 Old 02-07-2011, 12:34 PM - Thread Starter
SilentJ20's Avatar
Quoted: 28 Post(s)
Liked: 26
I love getting parts-express deliveries Guess what I'm gonna build!
NOTE: There are some extra parts here...
All I need is the wood and I'll get crackin.
SilentJ20 is offline
post #2 of 30 Old 02-07-2011, 01:32 PM
dawg1161's Avatar
Was the crossover ever finished or tweaked ? If i remember that thread stated they were close but needed tweeked....Or are you going to do the crossover yourself ?
I like the design but i prefer the MTMWW but thats just me. I will be keeping an eye on this one.
Thank You for posting.
John.
dawg1161 is offline
post #3 of 30 Old 02-07-2011, 02:40 PM
Cy-Gor's Avatar
I am watching this closely.
i have have a TV stand for a rear projection the WMTMW layout puts the tweeter right in place when i put it on the tv stand that i built a foot wider than needed for this reason.
Cy-Gor is offline
post #4 of 30 Old 02-08-2011, 07:35 AM - Thread Starter
SilentJ20's Avatar
Quoted: 28 Post(s)
Liked: 26
As far as the crossover, I don't think he ever did the tweaking beyond what the htguide thread discusses. I'm doing the WMTMW arrangement for half for looks and half for functionality. My center channel (To Be Built) won't have the height of the tweeter in WWMTM, and figured I'd keep them as close to the same height as I can (for what its worth).
Since my receiver (Yamaha RX-V765) doesn't have the guts to drive sub-4ohm speakers to high levels, I will be driving these with a Stewart PA1000 power amp from the pre-outs on the receiver.
Hopefully, I can keep progress on this moving quickly enough to be interesting.
post #5 of 30 Old 02-09-2011, 09:24 AM - Thread Starter
SilentJ20's Avatar
Quoted: 28 Post(s)
Liked: 26
Here is the design I have in mind:
Constructed of 3/4 inch mdf. Painted with satin or flat latex interior paint to match the color of my unfinished birch TV stand (pics in one of my older threads). The port is on the bottom of the main enclosure supported off the base by threaded rod encased by PVC pipe (also like my tv stand). The grill is TBD for now. I may like the looks without it.
I was going to go with a solid wood (knot-free pine) enclosure, but after reading lots of other people posing the same question, they were encouraged to use mdf instead to avoid problems with warping, cracking, and humidity.
I have cut most of the larger pieces, and will do some work with the radial arm saw to cut the rest this afternoon.
post #6 of 30 Old 02-11-2011, 08:01 AM - Thread Starter
SilentJ20's Avatar
Quoted: 28 Post(s)
Liked: 26
Enclosures under way! Made some progress yesterday. These things are going to be bigger and heavier than I thought they'd be.
And I never seem to have enough clamps. Thank goodness for brad nailers. I only use brads where the nail will not be routed or cut later, and there are some things that are much to difficult with clamps alone. Hope to get baffles routed and port tubes installed this afternoon.
post #7 of 30 Old 02-23-2011, 08:31 AM - Thread Starter
SilentJ20's Avatar
Quoted: 28 Post(s)
Liked: 26
The whole family has been sick for most of a week, but I finally managed to get some progress made. Time for a much needed update.
One thing I learned was that sheet mdf can have a natural bow to it. While I didn't notice when I built my tritrix speakers a while back (likely because they were much smaller), these larger towers showed some considerable bow to them when I was getting ready to clue the front/rear panels on. Had I noticed before I had done some of the construction, I would have had the curves oppose each other so it would end ups straight in the end. But I didn't, and thus they needed to be held straight for gluing. See my method of straightening below: Note, that is a piece of 3/4 in 1x6 oak that I bent against it...
I did use my 18 ga finish nailer to help move the process along here, too. Once everything was dry, I flush-trimmed all edges, cut all the driver holes, and put a 1/2 inch roundover on all sides. Here's where they stand as of now:
I used a 50/50 mix of wood glue and water to help seal the edges. I used this on my sub build and it worked quite well at preventing the paint from soaking into the cut edges. They stand 44 inches tall right now, will be 50 inches tall when done.
I was going to use regular black ABS for the ports, but didn't want to hassle with it and ordered some 3" precision ports as per mpotoka's parts list.
Next steps will be installing the ports, finishing the base-plates, then building the crossovers.
post #8 of 30 Old 02-23-2011, 12:38 PM
iconrl's Avatar
Quoted: 60 Post(s)
Liked: 25
Looks nice!! Thanks for the update.
iconrl is offline
post #9 of 30 Old 02-23-2011, 11:58 PM
goku14139268520's Avatar
+1
Lookin' good.
goku14139268520 is offline
post #10 of 30 Old 02-24-2011, 07:12 AM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1768
Wow, those are looking great! Can't wait to see how they turn out.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #11 of 30 Old 02-24-2011, 07:17 AM
Jinjuku's Avatar
Quoted: 58 Post(s)
Liked: 148
Those look killer. Working on my Statements which have a similar WMTMW layout.
You have to love that box full of stuff from Parts Express!
An audiophile likes to talk about how much they spent and how good it sounds.
A DIY'er likes to talk about how little they spent and how good it sounds.
Jinjuku is offline
post #12 of 30 Old 03-09-2011, 07:33 AM - Thread Starter
SilentJ20's Avatar
Quoted: 28 Post(s)
Liked: 26
Crossovers assembled (not soldered yet):
The two on the right are for the Woofers, and the two boards on the left are combined Mids/Tweets.
Crossovers are probably my least favorite speaker building item to spend time on. I was going to make them all pretty with the solders and wires all hidden under the boards, but said, "screw it". No one will see these anyways... I hope to solder them up this afternoon.
post #13 of 30 Old 03-10-2011, 04:23 PM - Thread Starter
SilentJ20's Avatar
Quoted: 28 Post(s)
Liked: 26
Okay, so yesterday I managed to get the crossovers soldered and do a quick speaker polarity check with a AA batt to make sure the speakers were wired correctly.
Now for a noob question. Does it matter how the wires go to the crossover from the amp? Of course I would keep both speakers identical, but does it matter which line the red/black goes to? Here's the crossover pic:
Which line off of the source is red/black, and which side of the speaker is pos/neg? The tritrix build I did before had too much info and videos for me to have gotten this wrong, but this build is a bit more demanding for me.
Brian
post #14 of 30 Old 03-10-2011, 05:39 PM
tuxedocivic's Avatar
Quoted: 1903 Post(s)
Liked: 1724
In that schematic, positive is up from the source. So all the xovers are parallel from the source. The positive/red goes to the horizontal components in series.
Ryan
tuxedocivic is offline
post #15 of 30 Old 03-11-2011, 07:01 AM - Thread Starter
SilentJ20's Avatar
Quoted: 28 Post(s)
Liked: 26
Ok, thanks. Is it standard crossover design, then, for the black/neg to be the unaltered common line to all the drivers?
post #16 of 30 Old 03-11-2011, 08:19 AM
Liked: 1724
I'm not 100% sure I understand the question, but YES. The negative typically has no components in series and goes straight to the output terminal of the drivers.
Ryan
post #17 of 30 Old 03-11-2011, 08:29 AM - Thread Starter
SilentJ20's Avatar
Quoted: 28 Post(s)
Liked: 26
That did answer my question, thanks!
post #18 of 30 Old 03-11-2011, 02:59 PM
Eddie Horton's Avatar
Are the woofers wired out of phase with the mid/tweets in that schematic?
The previous post may contain spoilers, which will make the post less aerodynamic and increase handling at high speeds.
Eddie Horton is offline
post #19 of 30 Old 03-11-2011, 03:28 PM
Liked: 1724
^ Looks like it.
What build is this anyways. Not your own I assume. Statements? Do you have a link to the design write up?
Ryan
post #20 of 30 Old 03-11-2011, 04:20 PM - Thread Starter
SilentJ20's Avatar
Quoted: 28 Post(s)
Liked: 26
This is a dayton classic wmtmw. Google it and you'll see the htguide post which has the most comprehensive thread on it's design. Credit goes to mpotoka for the design. He has a thread here too.
post #21 of 30 Old 03-11-2011, 04:23 PM - Thread Starter
SilentJ20's Avatar
Quoted: 28 Post(s)
Liked: 26
Here is the link.
http://www.htguide.com/forum/showthread.php4?t=32615
Sorry about the double post, doing this from my phone.
And the plus/minus on the schematic means in or out of phase? Good to know.
post #22 of 30 Old 03-11-2011, 08:29 PM
Liked: 1724
I'll read the build and let you know, but my first impression is that you want to wire the woofer out of phase. Not the most clear schematic :/
Ryan
post #23 of 30 Old 03-11-2011, 10:26 PM
Liked: 1724
Well, I've scanned the build and that schematic is very lacking. It seems the woofers are out of phase as it's an LR2 xo to the mids. That's out of phase to the mids, not with each other. Also, the 2 ohm resister on the mids is adjustable and you may want to use a 1 ohm pad instead if you want just a nudge more midrange. Or even no resister for a solid midrange bump. That's your choice.
The big item I found that the schematic lacks is that the mids are wired in parallel and the woofers in series. At least I think that's the case. I only scanned the thread. That changes things significantly, so if you're not sure, be sure to find out. Maybe you're ahead of me and know already.
Ryan
post #24 of 30 Old 03-11-2011, 10:32 PM - Thread Starter
SilentJ20's Avatar
Quoted: 28 Post(s)
Liked: 26
I remember the crossover having some adjustability with changing the resistors, so I'm building them per the BOM and see how they sound.
I'm still waiting on a pm from mpotoka through htguide to clarify the series/parallel wiring question.
Thanks for your interpretation. Any help from some one experienced helps.
post #25 of 30 Old 03-23-2011, 12:32 PM - Thread Starter
SilentJ20's Avatar
Quoted: 28 Post(s)
Liked: 26
Just a quick update. The base plates are ready and as soon as I get some decent weather (without any chores taking priority) I will give these things a shot of primer.
And I have received clarification about the wiring: The woofers are in parallel and the mids are in series.
So, going slower than I'd hoped, but I'll get them finished eventually...
post #26 of 30 Old 05-02-2011, 09:11 AM - Thread Starter
SilentJ20's Avatar
Quoted: 28 Post(s)
Liked: 26
DONE! For now..
They are together and functioning. I am leaving them unpainted for now. I want to give them a color that will match/blend in with my future media room. So until that happens I'll have unfinished mdf (thankfully my awesome wife doesn't mind).
They sound real good. Running them through a Stewart PA1000 power amp using the pre-outs on my receiver (with RCA to XLR adapter cables). I still need to take some time adjusting them a bit and finding a good crossover point for the sub, but first impressions have been good.
Note that I used the filter BOM as posted on htguide when I started the build. I did not notice that the posted schematic--which is the most current filter he uses--is slightly different than the BOM. But to my untrained ears, the schematic built with the BOM components still sounds good
Got to love it, though. I built these to be big, sweet home theater speakers, and the first thing they get used for is watching Backyardigans with my daughter.
post #27 of 30 Old 05-02-2011, 09:18 AM
Liked: 1724
They look awesome.
Ryan
post #28 of 30 Old 05-02-2011, 09:22 AM
Looks great. I love seeing big speakers and sub pics! Contrary to marketing and a lot of folks beliefs, when it comes to big HT sound, there's no replacement for displacement. Good job!
post #29 of 30 Old 08-24-2012, 01:54 AM
xam198's Avatar
Hi, a newbie question. I'm trying to do these dayton classic, but, because of the complex design of the box i've choosed to do (curved), i have to do a chamber for the tweeter and medium slightly different in the form (but not in volume). Is this ok with this, since the tweeter and the medium will see the same external width than the original design (in fact i've got do do a trapezoidal chamber) ?
xam198 is offline
post #30 of 30 Old 08-28-2012, 11:07 AM - Thread Starter
SilentJ20's Avatar
Quoted: 28 Post(s)
Liked: 26
I'll give my two cents: The tweeter driver itself is sealed, so changing the shape/volume shouldn't affect it at all. And for the mids, since the volume of the chamber is the same, I don't think there will be any issue. As long as the driver arrangement/spacing is the same and the baffle width isn't significantly changed, you should be fine.
