8x 18" LMS Ultra 5400s in 4 sealed enclosures - Page 18 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
Old 03-22-2012, 02:13 PM - Thread Starter
notnyt's Avatar
Quoted: 2162 Post(s)
Liked: 1986
what is the SP Mix setting?
subs are sent the same signal.
notnyt is offline
Old 03-22-2012, 03:17 PM
MKtheater's Avatar
Quoted: 1592 Post(s)
Liked: 1122
Yes but what about the HF's? Was that a single speaker, two, or all of them? That is my point, say the center channel is playing we want it to be flat, but what happens when an explosion occurs and now the front stage combines together with say a left side speaker, what does the response look like with those 4 speakers together? That is why I asked if EQing at the speakers is better or EQing each speaker individually at the LP. I am not sure what these auto setups do but just curious on what speaker or speakers were on during that sweep? Thanks again.
Marantz 7702 Atmos
MKtheater is online now
Old 03-22-2012, 03:24 PM - Thread Starter
notnyt's Avatar
Liked: 1986
that sweep was all the subs and left and right speakers. EQing anywhere but the LP is silly, since you want the response to be flat at the LP.
notnyt is offline
Old 03-22-2012, 03:35 PM
MKtheater's Avatar
Liked: 1122
Single LP or multiple? I have 7 seats but really ultilize the front 4.
Marantz 7702 Atmos
Old 03-22-2012, 03:43 PM - Thread Starter
notnyt's Avatar
Liked: 1986
It's virtually the same in any seat on my couch. I don't EQ for the seats far off to the side.
notnyt is offline
Old 03-22-2012, 03:52 PM
MKtheater's Avatar
Liked: 1122
Sounds good to me. I EQ'd my subs to the LP and every seat was very similar in response anyways. I wonder if I would be that lucky for the speakers too? Maybe all the treatments will help a bunch, I will give it a try and see what happens.
Marantz 7702 Atmos
Old 01-10-2013, 10:10 AM
cuzed2's Avatar
Quoted: 187 Post(s)
Liked: 236
Not sure why I had not seen this thread earlier - this is amazing!!
Cuzed2
CuznEddy Cinema
cuzed2 is offline
Old 10-02-2013, 05:51 PM
johnplayerson's Avatar
Quoted: 134 Post(s)
Liked: 52
I really like the total overkill here. I am still hoping to try some of those lms 5400. I guess i would need four to make two cabs and power each cap with one amp bridged at 8 ohms. All I need is around 5000 plus build costs.
LOL. I will be waiting some time, as I can't fit any more subs in my present situation. Try out the vega amps and see what a difference it makes.
A Good amplifier requires a adequate power supply, It does not matter what the amplifier is capable of if the power supply will not provide the power required. Most amplifiers have under rated power supplies. It is up to you to make sure you get the ones that are
least under rated if at all.
johnplayerson is offline
Old 12-13-2014, 05:51 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Have you even taken a full volume SPL reading?
Mfusick is offline
Old 12-13-2014, 06:32 PM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
What advantages do the LMS drivers have versus the dayton 18" drivers? I am not sure if the Dayton were available at the time you started your build. Seems like a whopper price difference but really subs this big are something folks are likely to only build once in their lifetime so why not I suppose.
What was the final wattage / resistance per channel / etc. on this build?
Having done 8x dayton ultimax in 4 boxes @ 2500 watts per channel... Im pretty damn happy with the overall sound. I cant really imagine needing a lot more bass in my room. I know some folks are more hardcore bassheads and like to go for "competition level" bass.
blazar is offline
Old 12-13-2014, 06:49 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
LMS has a better motor, less distortion, higher power handling, more xmax, more output... etc...
They are not the same.
Scott Simonian and m1ghtyun1t like this.
Mfusick is offline
Old 12-13-2014, 07:34 PM - Thread Starter
notnyt's Avatar
Liked: 1986
Can't. Mic/meter doesn't go that loud :/ I'd have to take one outside and measure further away. Needless to say I'm not moving a 400+ lb enclosure anyway. They modeled like WinISD said they would, except I picked up more on the upper end over the sealed enclosures, which it didn't show.
I'm running 4 ohms per channel. Stronger motor and other factors lets you also run a smaller enclosure and have more output near tune. The UM18 and the SI18 show a bit of weakness in that area compared to the LMS or the UXL18
This.
notnyt is offline
Old 12-14-2014, 05:53 AM
blazar's Avatar
Quoted: 716 Post(s)
Liked: 526
Excellent, thanks for the info. I wish i had room for the width and depth of the LMS drivers. They would not fit in my in my tall/shallow/narrow sealed boxes that I mounted in my specialized wall spaces. Had to settle on 8x15" dayton umax drivers. It is defintely possible to bottom the out if you go crazy. I will never push them to limit for fear of damaging them ...
blazar is offline
Old 12-14-2014, 01:37 PM - Thread Starter
notnyt's Avatar
Liked: 1986
the ultimax drivers seem like they might soft bottom, not sure, either way, they don't hit the come like the lms.
notnyt is offline
Old 02-26-2016, 08:20 AM
hatlesschimp's Avatar
Quoted: 448 Post(s)
Liked: 456
This is Awesome!
At the moment I was on the fence of buying a second SVS PC13 Ultra. I don't think I will now! I think I will sell the mine and build two of these bad boys. I'm not sure how it would fit in my room but would love to experience more bass. Only thing is I'm in Australia and everything cost more and we have less access to equipment range that you guys in the USA have.
Thanks for sharing!!!
hatlesschimp is offline
Old 02-26-2016, 09:05 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5294 Post(s)
Liked: 4178
LMS-Ultra drivers used in this system are currently out-of-production.
Scott Simonian is online now
Old 02-26-2016, 09:26 AM
Michael Mitten's Avatar
Quoted: 189 Post(s)
Liked: 164
Two questions if you know:
Think they will ever make them again?
Did anyone other than the DIY community buy these?
Michael Mitten is offline
Old 02-26-2016, 10:38 AM
Bass Enabler
Liked: 4178
Yes and yes. Assuming the second question was about the Ultra's.
TC Sounds has gone away and come back and then gone away and come back and then gone away and come before. I'm sure they will be back again.
Michael Mitten likes this.
