8x 18" LMS Ultra 5400s in 4 sealed enclosures - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
Old 02-16-2011, 11:52 PM - Thread Starter
notnyt's Avatar
Quoted: 2178 Post(s)
Liked: 2000
These things are huge
All installed.
notnyt is offline
Old 02-16-2011, 11:55 PM
kryptonitewhite's Avatar
not only does it apparently sound so much better, but looks much better. there's the dream right there.
kryptonitewhite is offline
Old 02-16-2011, 11:57 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5340 Post(s)
Liked: 4228
Scott Simonian is offline
Old 02-17-2011, 12:29 AM
TnTBigman's Avatar
A pet peeve of mine is when logos are not alligned . But heck, if I could afford a full setup like that, I'll be more than happy live with it. Awesome build. I was quite surprised how dense the stuffing was for each cabinet. Looking foward to some measurements. Again...awesome build.
You'll rarely hear anyone say, "I wish I'd gotten less Sub."
$ubwoofer$ and premium mango tree cultivar$
TnTBigman is offline
Old 02-17-2011, 12:32 AM - Thread Starter
notnyt's Avatar
Liked: 2000
Way smoother than the maelstroms.
This is without any smoothing, one pass of audyssey for the eq'd plot.
I'm waiting for whatever truck is outside to leave so I can run a full 8 audyssey passes.
notnyt is offline
Old 02-17-2011, 12:54 AM
Bass Enabler
Liked: 4228
Damn. That's pretty good right there.
Old 02-17-2011, 01:26 AM
audiovideoholic's Avatar
Quoted: 596 Post(s)
Liked: 192
We all know what you have went through in the past weeks with this. My question is, "Are you glad that you had to go through it?" You went through mental states of who knows what, pissed of states I'm sure, thoughts about how much more money was going to be spent on these, and down time as well. So, if the Mals would have worked just fine but the seller came to you with an offer to change them for the price difference would you go through it all again?
audiovideoholic is offline
Old 02-17-2011, 01:27 AM
Quoted: 596 Post(s)
Liked: 192
what all do you have going on down in the sub 10hz area?
Old 02-17-2011, 01:47 AM - Thread Starter
notnyt's Avatar
Liked: 2000
Most likely a bit of room gain there.
I'm glad I ended up with the LMS at the moment. I'll update this thread as time progresses
notnyt is offline
Old 02-17-2011, 02:45 AM - Thread Starter
notnyt's Avatar
Liked: 2000
THD @ 10hz. I'll take a louder one when the wife isn't asleep. I also notice due to the limited range of the radio shack mic, as you change levels, it increases the noise floor. I calibrated in the 100db range, and the noise floor was much higher.
Anyway, 10hz, there is no audible distortion. I think I may have been hitting the limits for this calibration range as well. Even 10db past here it just sounds perfectly clean. Incredible.
notnyt is offline
Old 02-17-2011, 02:50 AM - Thread Starter
notnyt's Avatar
Liked: 2000
Me too, but my cabinets already had holes drilled in them from the maelstroms. I didn't think there was a need to add more, especially since you can't even see the logos with the lights on high unless you're standing right in front of the subs. The large surrounds cast a shadow over them. The pictures that show the logos are two second prolonged exposures. Keep in mind this is my theater room, and as such, is dark
As for stuffing, I went for about 1lb per cuft.
notnyt is offline
Old 02-17-2011, 03:02 AM - Thread Starter
notnyt's Avatar
Liked: 2000
Originally Posted by mjaudio View Post
They have pretty stiff suspension when new so they will fill out even more after they loosen up. Not sure exactly how long it takes, I just remember playing the same music about a week later at the same level and feeling the bass hit Much harder from my office on the other side of the house, definitely got my attention.
Outstanding build once again notnyt!
Thank you Having two spiders will definitely do that I'll be re-eqing in a week anyway once I get the right couch that I ordered, instead of the one they gave me that doesn't recline. That happened the same time I got the maelstroms running about a month ago. Two clusterfcuks at once, I was a bit mad.
notnyt is offline
Old 02-17-2011, 06:09 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Awesome!
Congrats on a great setup!
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
Old 02-17-2011, 06:24 AM
t6902wf's Avatar
Wow, subs check. It looks like you never have to consider subs again. The only possible upgrade is more power. I doubt you would need it at real world listening levels.
Enjoy.
T6
Clearwave 4TSE and 4CC build thread
http://www.avsforum.com/avs-vb/showt...1#post19489740
t6902wf is offline
Old 02-17-2011, 06:49 AM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 167
WOW. Over reference at 10Hz with little to no distortion. Very nice, notnyt. As someone mentioned above, you will never again want for subwoofage. If you do, you will likely never be satisfied until you essentially detonate claymore mines inside the room....
Now throw in the Incredible Hulk and give us listening impressions, and more THD graphs....
JSS
maxmercy is offline
Warpdrv's Avatar
Excellent NotNyt - as stated give it a week or two depending on how much usage and youll def notice a difference after they loosen up, maybe even a bit longer.... I was givin a number like 50-100 hours, which seemed awefully long, but I did notice things opening up and becoming more effortless after a good deal of time went by. Congrats on the sizable upgrade !!! Once you have the LMS's theres no going back, everything else is just sloppy IMO
Warpdrv is offline
Old 02-17-2011, 09:05 AM
FYI mounting logos upside down adds 3dB, jus so you know...
sigh
it just doesnt stop
Old 02-17-2011, 09:09 AM
Warpdrv's Avatar
That also ends up leading to pushing things a bit further then you would with the Mal-X's... It just sounds so much cleaner that you end up running it hotter and wanting more...
At least thats the way my habit tends to have taken me....
Warpdrv is offline
Old 02-17-2011, 09:24 AM
t6902wf's Avatar
That is an interesting phenomenon. How hot is hot? Do you run the subs 3db hot and then listen at a louder volume then normal or are the subs several db hot?
I struggle with this. My current thinking is that I run the sub 3db hot. I have headroom for more but it can get odd with certain movies...car door slam hits you in the chest type stuff.
T6
t6902wf is offline
Old 02-17-2011, 09:46 AM
desertdome's Avatar
Quoted: 1130 Post(s)
Liked: 1229
sigh
it just doesnt stop
I would think that bad drivers might sound and measure poorly regardless of when they actually quit working. It isn't like there are necessarily multiple problems with the Maelstrom drivers. One problem can lead to multiple symptoms. You really can't come to any conclusion about the Maelstrom sound quality vs the LMS unless good drivers are being compared.
High Impact AV
desertdome is online now
Old 02-17-2011, 09:52 AM
Warpdrv's Avatar
Remember now, my room is open - think 15-20,000^3 so any of that slam or punch in the chest stuff is a bit lost in that type of arena - so I typically am running about 5-10db hot, sometimes more depending on the material... 5db hot is absolutely the minimum in order to match the feeling I'm getting at the LP in comparison to how the mains are with the material... I know that everyone likes to be txt book about stuff but it just doesn't work for me in my room with it being so open...
In my secondary system (1800^3 basically closed off) not really more then then 5db hot is my general pref, which is plenty impactful with good clean bass (LMS's) and 5-10db hot becomes, not unbearable, but it starts to cloud over the vocals with music or movies, again depending on the material - so for me its totally room dependent. I'll be looking to see how things go when I change from the Submersive to the LMS in there....We'll see if my opinion sticks, but honestly - the dirtier the bass, the more presence, or to me thickness it has which as it gets louder, less bass is needed to get the presence.... That is not always a bad thing unless your getting into solid on terrible sounding enclosures or less then acceptable sloppy drivers...
I was at my buddies house not too long ago and he has 2 subs, one right on top of the other an a rather spacious area open all over - a small sunfire dual opposed 8" I think and some ported 12", can't remember but it was just downright thick in there and I couldn't believe the amount of perceived bass that was there, thick and muddy, tons of note overhang - you could almost cut it with a knife.... IMO more distortion leads to a more perceived heaviness, giving me that less is more thought, but certainly not as accurate.
Warpdrv is offline
Old 02-17-2011, 10:09 AM - Thread Starter
notnyt's Avatar
Liked: 2000
Actually, you can, since the problem was related to the short rings not having enough epoxy. They only came loose after a few heat cycles. The drivers still functioned as normal, even after they started to vibrate.
notnyt is offline
Old 02-17-2011, 10:17 AM
MKtheater's Avatar
Quoted: 1596 Post(s)
Liked: 1123
It depends on where the car shutting the door is. It is funny how everyday things makes me think about my system. The other day getting home from the airport I was taking the kids out of their seats when my wife opened and then closed her passenger side door, it made a thump and moved my hair. This was in my garage. I thought to myself that how many people here always say that when a car door hits you it is over exaggerated, that is not true, it happens!
OK, back to this awesome build. Looks fantastic and I am jealous. It looks like I maybe changing something. That THD is awesome and the reason for these crazy builds. 1.78% at 10hz over reference is insane and perfect! I love it.
I need to measure my system to see what I get. Sorry, maxmercy, I know you have posted this but can you or NYT PM the settings so I can take some THD measurements?
Again, awesome!!!!! Hey, do you guys notice how impressive those JBL's look next to the subs They are as big as 2 subs.
Marantz 7702 Atmos
MKtheater is offline
Old 02-17-2011, 10:30 AM - Thread Starter
notnyt's Avatar
Liked: 2000
The settings are in the title of the window capture I posted
mode spectrum, 4 samples, hanns window, 131072 point, and (missing) 87.5% max overlap
notnyt is offline
Old 02-17-2011, 10:38 AM
MKtheater's Avatar
Liked: 1123
Cool thanks!!! I will do this tonight.
Marantz 7702 Atmos
Old 02-17-2011, 10:51 AM
Bass Enabler
Liked: 4228
*laughs* Thank you, MK! I laugh about this all the time. Car door slams are loud AND have a ton of deep bass.
Old 02-17-2011, 11:04 AM
t6902wf's Avatar
Sounds like there is going to be some sawdust flying at MK's house. Those last subs did not last long......
By the way I want to see a picture of your wife. I wonder what the most understanding women in the world looks like?
T6
t6902wf is offline
Old 02-17-2011, 11:20 AM
MKtheater's Avatar
Liked: 1123
She is not understanding, I just do it. I always argue and then tell her she has the rest of the house, I have my theater. Anyways, My subs are awesome and I will measure the THD tonight which I have never done before. I assume that it will be low because it is all room gain down low.
Marantz 7702 Atmos
Old 02-17-2011, 11:21 AM - Thread Starter
notnyt's Avatar
Liked: 2000
Hah, my wife thinks all these upgrades are great and loves the theater
notnyt is offline
Old 02-17-2011, 11:35 AM
MKtheater's Avatar
Liked: 1123
She gets over it fast and loves the room.
Remember guys, my room is less than half the size.
Marantz 7702 Atmos
