MFW-15 Dual Opposed Build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 319 Old 03-04-2011, 05:00 PM - Thread Starter
wembley2000's Avatar
Well I finally got my build completed. I was looking at replacing my THT's and SVS PB12-nsd with some sealed subs. I wanted to try to get to 10hz with some db's.
I was first looking at the Tempest X2's or some AV15H's, after posting some ideas on here I was getting recommendations for the FI drivers, Mach 5's, and the Dayton 390HF's. So I got to modeling, I was starting to like the Daytons for the price (1000$ budget for the drivers) I wanted to build at least 4 cabs so I could spread them around if I needed to.
One day I got on here and I had a PM from coctostan telling me to take a look at the MFW-15 drivers in a dual opposed sealed setup. So I got to modeling them, 8 looked real good in 4 dual opposed cabs at right around 6 cubes each. 6 cubes was a little small and gave me a Q of .82 but it did help control excursion (i have an EP 4000), and I figured I could stuff the cabs to give it a boost in apperent volume.
After I figured out this is what I wanted to try I ordered 10 drivers from Danny at GR research (I only needed 8 but what the heck), shipping took about 4 days to Ohio. Bought me 6 sheets of 3/4 aruaco ply, I should only need 5, but I had to borrow the truck, so I picked up 1 extra sheet (never did need it, I may use it for one of the other drivers).
So I started building:
wembley2000 is offline
post #2 of 319 Old 03-04-2011, 05:01 PM - Thread Starter
the outside dimensions for each cab are 23.5 x 23.5 x 26.5, with double baffles, and 2 window braces. I added 6lbs of polyfil to each cab, which should have gave me around a 25% increase in cabinet volume. The build was pretty straight forward and everything went together well, I used PL premium and an air nailer for everything but the baffles which I used regular wood glue and screwed them together and let them dry over night.
post #3 of 319 Old 03-04-2011, 05:01 PM - Thread Starter
Reserved2
post #4 of 319 Old 03-04-2011, 05:01 PM - Thread Starter
Reserved 3
post #5 of 319 Old 03-04-2011, 05:02 PM - Thread Starter
Reserved 4
post #6 of 319 Old 03-04-2011, 05:15 PM - Thread Starter
Having trouble posting pics in the reserved spots.
Drivers arrived:
post #7 of 319 Old 03-04-2011, 05:18 PM - Thread Starter
More build Pics:
post #8 of 319 Old 03-04-2011, 05:19 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Nice work man!
This is really a dual-dual opposed build.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #9 of 319 Old 03-04-2011, 05:21 PM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1771
How did the sub boxes get shipped? Were they double boxed? Or did he tape 2 of them together? Just curious.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #10 of 319 Old 03-04-2011, 05:22 PM - Thread Starter
All most completed:
post #11 of 319 Old 03-04-2011, 05:26 PM - Thread Starter
Originally Posted by jpmst3 View Post
Nice work man!
Yeah I guess it is
They were not double boxed, they probably should have been, Some of the foam gaskets on the front were slid from there normal spots and rubbing the surrounds. But this most likely wasn't from shipping just the way they are packed with only foam on the motor side. I just removed the foam and used a marker to color the paper material black, you cant tell the difference.
Yeah they were 2 boxes taped together.
post #12 of 319 Old 03-04-2011, 05:33 PM - Thread Starter
I use 1/2" roundover on the top and the front(s), I think it looks pretty good. I am thinking of painting them with Duratex, I used the truck bed liner on my THT's, while it looks good, the bed liner is just a little to rough for my tastes.
post #13 of 319 Old 03-04-2011, 05:41 PM - Thread Starter
Now for some measurements:
I have both a DCX and the BFD. I used a LP12db slope filter (10db boost)centered at 20 to boost the low end and used the BFD to EQ and apply the cuts needed to bring the 80hz end back down to reasonable levels. I watched WOTW with it at my normal listening volume and didn't hear any crazy sounds from the drivers. Here is my current EQ'd graph, no smoothing at listening position.
Edit: I messed up on my rew graph, forgot to reload my ecm8000 calibration file........
I will post a new graph tomorrow, the good thing is I shouldn't need to boost as much, embarrassing.........
post #14 of 319 Old 03-04-2011, 06:08 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Not bad at all!!
Joe = LFE Addict
jpmst3 is offline
post #15 of 319 Old 03-04-2011, 07:06 PM
chrapladm's Avatar
Quoted: 827 Post(s)
Liked: 286
Wow seems as of lately there are quite a few people replacing their THT's. And I just built a dual opposed sealed Fi SSD sub. Small world.
Nice build.!!
chrapladm is offline
post #16 of 319 Old 03-04-2011, 07:18 PM
UNICRON-WMD's Avatar
That is a great deal on the drivers. The FR looks great too.
Do you have 2 EP4000 or one?
Also, what kind of SPL peaks are you getting from the LP?
God loves me, but everyone else thinks I'm an a$$hole.
My small dedicated theater.
UNICRON-WMD is offline
post #17 of 319 Old 03-04-2011, 07:31 PM
Erich H's Avatar
Liked: 1771
Those measurements look great. I'm glad I was able to pick up so many of them for the next group buy. Should be awesome to see what people build with these cheaper drivers. Lilmike is working with them on a neat project for the masses too.
Erich H is offline
post #18 of 319 Old 03-04-2011, 08:04 PM - Thread Starter
WMD, I am only using 1 ep4000, during wotw I hit 120 a couple times. I am eqing out a couple of 10db peaks at 40 and 70 hz, I had the same modes with my other subs also. I havent pushed them to their limit yet, dont want to bust anything yet.
Erich,
They are one heck of a deal, I cant wait to see what lilmike comes up with he is a hornresp master. I do have 2 drivers left over.......
post #19 of 319 Old 03-04-2011, 08:08 PM - Thread Starter
Nice build.!!
Thanks, the thts are great also, I really just wanted to try to get lower. More or less the low cost drivers gave me an avenue to try it out and it worked!
post #20 of 319 Old 03-04-2011, 09:01 PM
auburnu008's Avatar
Quoted: 438 Post(s)
Liked: 596
How would 16 of those compare to 8 MalX's? with the same power (2 Marathon 5050's) and same size boxes (8 cubic feet for each MalX and 4 cubic feet for each MFW15)?
auburnu008 is offline
post #21 of 319 Old 03-05-2011, 03:58 AM
louisdamani's Avatar
I like your boxes. They don't look like they are six cu. ft. I should have took the extra steps to get the Aurucoply instead of the 3/4 mdf that now cost $31 a sheet(damn). Anyway I like your room and the new additions to it.
louisdamani is offline
post #22 of 319 Old 03-05-2011, 04:27 AM
chrapladm's Avatar
Quoted: 827 Post(s)
Liked: 286
I never saw the backside of those cabinets? There is a woofer there isn't there?
post #23 of 319 Old 03-05-2011, 07:39 AM
8 MalX 18s would win but it would be triple the price.
I thought of (4) MalX 18s but went with (8) Dayton HFs instead. The drivers were alot cheaper and didn't need a ton of power. I saved at least $1,500.
post #24 of 319 Old 03-05-2011, 09:11 AM
jwh7399's Avatar
Very cool build!
Did you model these in Winisd? I can't figure out how to do dual-opposed.
Jon
jwh7399 is offline
post #25 of 319 Old 03-05-2011, 09:31 AM
Originally Posted by jwh7399 View Post
Very cool build!
Jon
It is just 2 drivers in one sealed box. It models the same as a "normal" dual driver box.
post #26 of 319 Old 03-05-2011, 09:48 AM
jwh7399's Avatar
Ahh, thanks WMD!
Jon
jwh7399 is offline
post #27 of 319 Old 03-05-2011, 10:38 AM - Thread Starter
I was going to go with MDF at first, glad I didnt the dust from the plywood was bad enough.
I can assure you there is another woofer back there, hard to take pictures of both sides ar once
post #28 of 319 Old 03-05-2011, 11:14 AM
coctostan's Avatar
Liked: 135
Awesome build Wembley. I'm glad it is working out well. Do you think you could do REW distortion measurements similar to NotNyt's? I want to hear some subjective comments too.
If you only account for overall displacement, the MX18s would win...but it isn't that simple. I'd take more surface area vs more excursion. The 16 15's will be moving less for the same amount of SPL down low. In my experience this results in a more effortless sound and better SQ. That's not to say the MX18s would sound like crap though.
The other issue is that a single EP4000 will push the MFW-15s to their limit. In the same size boxes (6 cu ft per MX18) that single EP4000 would give you about the same output if they are EQ'd to the same Q and Fc. The MX18 would pass the MFW-15's by with more power...but that means you need more circuits and more amps.
The reality is that neither setup will break a sweat at any "normal" listening level...like below 110-120db and likely all the way down to 10hz depending on room size.
A bunch of MFW-15s sealed are probably the most economical way to get down to 10hz and below.
The reality is that neither system
coctostan is offline
post #29 of 319 Old 03-05-2011, 11:43 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2577
"I'd take more surface area vs more excursion."
wisdom in that comment.
nice build wembley.
Listen. It's All Good.
LTD02 is online now
post #30 of 319 Old 03-05-2011, 12:00 PM - Thread Starter
Thanks Coctostan, you are the one that turned me on to these and I am glad you did. As for THD measurements ask and you shall receive.
I have also attached a correct REW graph. I am only using 3db of boost on the low end to get these measurements.
The MFW-15s are only rated for 225 watts so one EP 4000 will and do power 8 easily
