Torq on bolts with sub. - AVS Forum | Home Theater Discussions And Reviews
Old 03-16-2011, 09:35 PM - Thread Starter
pgwalsh's Avatar
Quoted: 394 Post(s)
Liked: 286
Hey,
I was just wondering how much torq you should apply when installing a driver for a sub.
I'm using baltic birch with tnuts and hex bolts. Like this:
I want to tighten them, but not strip them and have the fear of the t-nut coming loose. I installed them with liquid nails to increase their grab, but I'm worried I could tighten them too much and cause them to spin. I have a torq wrench with hex bolt attachment.
Diy Sound Group - Information & Tips
Builds: Maelstrom 21 Ottoman Build, Dual Opposed MFW's x 2, Statements, SEOS-12/TD12M x 5.
pgwalsh is online now
Old 03-16-2011, 10:18 PM
RobG5589's Avatar
You will be able to "feel" when they are tight enough. It does not take a bunch of torque, just enough to compress the gasket some. To make it easier, try and use a nut driver as opposed to a wrench which could over-torque the nuts/screws.
RobG5589 is offline
Old 03-16-2011, 10:20 PM
homank76's Avatar
Another thing you can do if you have left over wood is test it. See how pressure it takes till your happy or till it gives.
Panasonic TC-P58S2, Onkyo TX-NR1007, Onkyo DV-SP1000, Onkyo DV-HD805, Onkyo BD-SP807, Onkyo DX-V801, Onkyo UP-A1, Onkyo TA-RW411, Onkyo EQ-201, Yamaha Speakers NS700/750 Series, Blue Jean Cables
homank76 is offline
Old 03-16-2011, 10:23 PM - Thread Starter
pgwalsh's Avatar
Quoted: 394 Post(s)
Liked: 286
I used my drill set to 5, just 1 under the max. I then tightened a bit more by hand. I thought with a torq wrench I could measure the pressure precisely for each bolt.. The gasket has compressed a fair amount, so it may be sufficiently tightened, but I thought there may be a standard gauge for it.
Old 03-16-2011, 10:36 PM
notnyt's Avatar
Quoted: 2168 Post(s)
Liked: 1988
Don't rely on a torque wrench. You need to do this by feel. Those t-nuts are cheaply made and often bind up.
notnyt is offline
Old 03-16-2011, 10:56 PM
RobG5589's Avatar
You are probably good. If you see the metal "frame" of the driver start to deform you have gone too far.
RobG5589 is offline
Old 03-17-2011, 07:32 AM - Thread Starter
pgwalsh's Avatar
Quoted: 394 Post(s)
Liked: 286
This is a big driver, so I don't think I'll see it deform, but I'll keep an eye on it.
Old 03-17-2011, 07:38 AM
pocketcash's Avatar
Put all the bolts in first, use the star patten, no need to over tighten Go around in the star patten tightening alittle each time, it should take 3 or 4 times.
If you see or hear something, its than to late..
Its all in the ""feel""
pocketcash is offline
Old 03-17-2011, 10:14 PM - Thread Starter
pgwalsh's Avatar
Quoted: 394 Post(s)
Liked: 286
Well it's tightened and tested the sub tonight. All is well, thanks.
Will post build pictures in a new thread later. Test through the weekend and then stain.
