Measurement Mic Shootout (EMM-6, WM-61A, RS 33-2055, Audyssey) - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #361 of 375 Old 04-09-2014, 06:12 PM - Thread Starter
notnyt's Avatar
Quoted: 2152 Post(s)
Liked: 1980
Originally Posted by 235 View Post
Thanks, I realize the generic files available here won't be as accurate as having my mic calibrated. However I am not looking for absolute accuracy, rather feedback for relative changes after tweeking. The hometheatershack site also seems to suggest that the generic calibration files would be good enough to use in a home theater setting:
"...so it is our opinion that it will be fine to use in a home theater in most cases"
It's too bad that page does not list the .cal file for the latest RS model mad.gif
If you read the post here you'd see that virtually every RS calibration file i've seen is inaccurate.
notnyt is offline
post #362 of 375 Old 04-10-2014, 05:15 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
Speaking of the Radio Shack SPL meters, which one is the most ideal model to get for setting and measuring SPL levels for home theater type usage? Which model? Digital or analog?
Martycool007 is offline
post #363 of 375 Old 04-10-2014, 05:20 AM - Thread Starter
notnyt's Avatar
Liked: 1980
Neither are in production anymore. This is the only one available from RS. I've yet to see it tested.
http://www.radioshack.com/product/index.jsp?productId=12680845
notnyt is offline
post #364 of 375 Old 04-10-2014, 09:56 AM
235
235's Avatar
Sorry, which post are you referring to?
235 is offline
post #365 of 375 Old 04-10-2014, 03:16 PM - Thread Starter
notnyt's Avatar
Liked: 1980
This thread. There are also large variances within the RS mics as some use different capsules.
notnyt is offline
post #366 of 375 Old 04-10-2014, 03:25 PM
235
235's Avatar
Ok thanks. So in the absence of getting a calibration you are saying I am better off using REW without any calibration file for my particular model?
235 is offline
post #367 of 375 Old 04-10-2014, 03:42 PM
MKtheater's Avatar
Quoted: 1588 Post(s)
Liked: 1116
With C-weighting.
Marantz 7702 Atmos
MKtheater is online now
post #368 of 375 Old 04-10-2014, 04:20 PM - Thread Starter
notnyt's Avatar
Liked: 1980
Originally Posted by MKtheater View Post
With C-weighting.
Well, that worked for the newer batches I tested of the 33-2055, but not the latest one they're selling, which is at this point untested. If its using the same internals, sure, but who can say.
notnyt is offline
post #369 of 375 Old 04-10-2014, 05:57 PM
MKtheater's Avatar
Liked: 1116
Yeah I am ways thinking of my digital RS meter which you tested.
Marantz 7702 Atmos
post #370 of 375 Old 04-16-2014, 10:23 AM
MKtheater's Avatar
Liked: 1116
Notnyt,
Is there a chance you can compare the Umik with Cal files and just C-weighting with it? I am curious how close they would be.
Marantz 7702 Atmos
post #371 of 375 Old 04-16-2014, 02:25 PM - Thread Starter
notnyt's Avatar
Liked: 1980
Compare the umik
Notnyt,
Compare the umik to what?
notnyt is offline
post #372 of 375 Old 04-16-2014, 02:34 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Can cross-spectrum calibrate any mic? I have a radioshack 33-4050 spl meter and wondering if that could be calibrated? If so, is it even worth to calibrate that spl meter compared to something like the UMIK-1 or Dayton UMM-6?
Mrkazador is online now
post #373 of 375 Old 04-16-2014, 02:39 PM
MKtheater's Avatar
Liked: 1116
Compare the umik
Just comparing a measurement from the Umik with the cal files and then with just C-weighting. My Behringer mic cal files are real close to just adding C-weight to it. I like the mic but I am looking for something to run with spec lab and cal files are no good as of yet. Ironmike was researching it and if I can load cal files then I need nothing.
Marantz 7702 Atmos
post #374 of 375 Old 04-16-2014, 02:40 PM - Thread Starter
notnyt's Avatar
Liked: 1980
I posted a graph of the calibration on the umik earlier. It's nowhere close to c weighting.
notnyt is offline
post #375 of 375 Old 04-16-2014, 03:02 PM
MKtheater's Avatar
Liked: 1116
Cool but no good for spec lab or I would have kept mine.
Marantz 7702 Atmos
