MFW-15 Project Advice Needed - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 100 Old 12-14-2012, 07:18 PM
petew's Avatar
Quoted: 26 Post(s)
Liked: 68
Originally Posted by Tom Bley View Post
I have 8 MFW-15's that I purchased from Erich H in July 2011 that I still have not done anything with.
Oh that's so tempting. I would love to convert my four MFW-15 sealed boxes to dual opposed. The damn things need to be chained down to keep them from walking across the room.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #92 of 100 Old 12-14-2012, 08:42 PM
Tom Bley's Avatar
Quoted: 604 Post(s)
Liked: 536
biggrin.gif How do you like the 4 you have now?
Tom Bley is offline
post #93 of 100 Old 12-15-2012, 06:48 AM
petew's Avatar
Quoted: 26 Post(s)
Liked: 68
I couldn't be happier with them. Best bang for the buck HT upgrade I've ever done. I'm running them 3 to 5 dB hot and they have no trouble keeping up, even with my low power amp. I don't usually listed at reference though.
petew is offline
post #94 of 100 Old 12-15-2012, 09:25 AM
pgwalsh's Avatar
Quoted: 403 Post(s)
Liked: 292
I have 2 dual opposed and they don't move at all.
Nice setup.
Diy Sound Group - Information & Tips
Builds: Maelstrom 21 Ottoman Build, Dual Opposed MFW's x 2, Statements, SEOS-12/TD12M x 5.
pgwalsh is online now
post #95 of 100 Old 12-15-2012, 09:28 AM
N8DOGG's Avatar
Quoted: 1001 Post(s)
Liked: 1065
Rubber feet will keep them from walking around. I have to use it on my sub upstairs for the same reason and it's 140lbs lol
N8DOGG is online now
post #96 of 100 Old 12-15-2012, 09:29 AM
petew's Avatar
Quoted: 26 Post(s)
Liked: 68
Nice setup.
I get amazingly flat response with four boxes and no EQ. I need (want) more DIY speakers!
I'll probably staple some area rug underlay padding to the bottom feet. Should do the trick.
petew is offline
post #97 of 100 Old 12-15-2012, 05:13 PM - Thread Starter
Scott C.'s Avatar
What size boxes do you have for yours petew?
Sounds Good to Me... keeping track of my audio projects.
Scott C. is offline
post #98 of 100 Old 12-16-2012, 08:24 AM
petew's Avatar
Quoted: 26 Post(s)
Liked: 68
The boxes are just a hair under 4 ft^3. I built them big to use a 145 watt per channel amp I had on my spare parts shelf. Surprisingly (to me at least), air pressure has a big effect on xmax for a given volume. We're at 5,200' here in the ABQ.
petew is offline
post #99 of 100 Old 12-16-2012, 10:37 AM
vitaminbass's Avatar
I haven't heard much talk about altitude's effects. So in theory do you need a smaller box at higher elevation, all else equal?
vitaminbass is offline
post #100 of 100 Old 12-16-2012, 11:10 AM
petew's Avatar
Quoted: 26 Post(s)
Liked: 68
Yup, less air to compress, smaller box. There's a field to enter air pressure in winISD. I designed my bracing to let me cut another driver hole in the back baffle to go dual opposed, and I have plenty of box to handle two drivers.
petew is offline
