Exodus Maelstrom-18" with PR's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 04-15-2011, 08:13 AM - Thread Starter
t6902wf's Avatar
Has anyone done a sub with The 18" Mal X and 2 Exodus 18" PR's?
I seems like it would be a very potent sub in a reasonable size box for a decent price.
The 5400, 5100 with the same combination is certainly more sexy but it is quite a bit more costly.
T6
Clearwave 4TSE and 4CC build thread
http://www.avsforum.com/avs-vb/showt...1#post19489740
t6902wf is offline
post #2 of 23 Old 04-15-2011, 08:20 AM
gperkins1973's Avatar
I wouldn't be surprised all be it in a bigger box to get a better result ported. Gain more down low.
gperkins1973 is offline
post #3 of 23 Old 04-15-2011, 08:21 AM - Thread Starter
t6902wf's Avatar
For my goal which is 18-20 hz it seems like a good combination.
T6
t6902wf is offline
post #4 of 23 Old 04-15-2011, 08:30 AM
I would go for more 18hz than 20hz personally. With the added cost off PR's, is there any gain for going the PR route. I've never had PR's so don't know what they sound like. I have never had port noise so unless you get a better sound I see no gain other than added expense.
post #5 of 23 Old 04-15-2011, 08:46 AM - Thread Starter
t6902wf's Avatar
Within the context of my goals it makes sense.
Size of the box does matter.
T6
t6902wf is offline
post #6 of 23 Old 04-15-2011, 08:48 AM
spanish68's Avatar
Same tuning, PR vs Port, the PR box is going to be quite a bit smaller and no potential port noise do deal with. The downside? As mentioned before, more money and below the tuning point, a steeper roll off.
spanish68 is offline
post #7 of 23 Old 04-15-2011, 08:54 AM
do you have the t/s parameters off the PR's you can upload.
post #8 of 23 Old 04-15-2011, 09:10 AM - Thread Starter
t6902wf's Avatar
I don't the PR's disappeared off their website. I assume they will come back when they get things sorted out.
T6
t6902wf is offline
post #9 of 23 Old 04-15-2011, 09:37 AM
Ricci's Avatar
Quoted: 248 Post(s)
Liked: 574
The gain being no port noise, no port resonance, and the main one IMO is a much smaller subwoofer in the end. You can end up with an 18" pr'd sub that is a 24" cube tuned to 18hz. Try that with a port that is adequate for a long throw 18".
For the Mal X try a little bigger like 8.5 or 9 cu ft and tune the pr's to 16-20hz depending on what you want.
Ricci is offline
post #10 of 23 Old 04-15-2011, 09:37 AM
kemist1117's Avatar
Quoted: 13 Post(s)
pretty sure they had a fire sale on them because they werent selling to expectations and are discontinued
kemist1117 is offline
post #11 of 23 Old 04-15-2011, 09:53 AM - Thread Starter
t6902wf's Avatar
That would be a bummer. I think PR's are a good tool. to achieve a sub the average person can fit in a room.
There is an old expression, excuse me if I screw it up.
You can pick 2: fast, cost effective or quality, you can't have all three.
With a sub it is small, cheap or powerful. Pick two.
T6
t6902wf is offline
post #12 of 23 Old 04-15-2011, 09:58 AM - Thread Starter
t6902wf's Avatar
They have been discontinued, bummer. I will have to see what else is available.
T6
t6902wf is offline
post #13 of 23 Old 04-15-2011, 10:25 AM
Ghani99's Avatar
There's a pair for sale on another forum, $140 plus shipping.
http://www.hometheatershack.com/foru...tml#post431387
I'm sure Kevin from Exodus Audio would provide the parameters.
Ghani99 is offline
post #14 of 23 Old 04-15-2011, 10:32 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5973 Post(s)
Liked: 5036
Scott Simonian is offline
post #15 of 23 Old 04-15-2011, 11:00 AM - Thread Starter
t6902wf's Avatar
I was talking to Exodus and he suggested his 21" passives they are not on the site but they exist.
He said the specs are QMS 4.8
Sd 1550 cm^2
Starting mass 325 g
Vas 605L
CMS 0.18 mm/N
Can someone model this? I realize the 21" PR's will need a bigger box but I am curious about the output?
T6
t6902wf is offline
post #16 of 23 Old 04-15-2011, 11:17 AM
Bass Enabler
Liked: 5036
I could model that up but there is no 'Fs' listed.
So, why not use the AE PR's if not the 21's?
post #17 of 23 Old 04-15-2011, 11:18 AM
Ghani99's Avatar
What's the price on the 21" PR's?
Ghani99 is offline
post #18 of 23 Old 04-15-2011, 11:20 AM
tgse3's Avatar
tgse3 is offline
post #19 of 23 Old 04-15-2011, 11:29 AM - Thread Starter
t6902wf's Avatar
I thought you were supposed to use a PR that was larger then the Active driver. I thought you wanted the active to run out of steam before the passives?
T6
t6902wf is offline
post #20 of 23 Old 04-15-2011, 11:36 AM
Bass Enabler
Liked: 5036
Yes that is true. Most would use dual opposed PR's to cancel out the forces on the cabinet. A PR has a lot of mass and could cause rocking. You would use two 18" PR's with a single 18" driver, just fyi.
post #21 of 23 Old 04-16-2011, 07:50 PM
cinema mad's Avatar
Quoted: 18 Post(s)
Liked: 38
Here is my x2 Mal-X18/2pr18 build from A couple years ago, 15Hz Tune.
http://www.hometheatershack.com/foru...ves-build.html
sorry it appears the link is slow to load from the shack/Members DIY subwoofer DataBase
If I was to do the PR thing again id go with the M-21s ..
cheers.
cinema mad is offline
post #22 of 23 Old 04-17-2011, 10:57 AM
wackii's Avatar
I have two 18" EX PR with the mass kit that I bought but did not have time to build them... Let me know if you are interested...
Al,
"When the opponent expand, I contract,
When he contracts, I expand,
And when there is an opportunity,
I do not hit--it hits all by itself."
- Bruce Lee
wackii is offline
post #23 of 23 Old 04-18-2011, 07:08 AM - Thread Starter
t6902wf's Avatar
cheers.
Thanks for the link, did you ever do any measurements? I'd love to see them.
T6
t6902wf is offline
