Lilmike's Cinema F-20 - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 27Likes
post #541 of 1817 Old 06-11-2011, 06:34 PM - Thread Starter
lilmike's Avatar
Quoted: 71 Post(s)
Liked: 180
Thanks. I'm actually feeling pretty good today, that or I grabbed the wrong bottle of pain meds....
The other builds are all underway, but no threads yet. Things have been mentioned here and there. Anymore, I typically finish stuff, then measure it and post.
lilmike is offline
post #542 of 1817 Old 06-11-2011, 08:09 PM
Steve_Vai_rules's Avatar
hope you are up and about soon. my dad messed up his knees playing rugby for too many years!! take care of them!!
Matt
"The main reason Santa is so jolly is because he knows where all the bad girls live." - George Carlin
Steve_Vai_rules is offline
post #543 of 1817 Old 06-13-2011, 02:06 AM
notnyt's Avatar
Quoted: 2790 Post(s)
Liked: 2569
Just cranked out two of these this weekend with Kibe29. Fairly easy build. Acquired lumber and stuff and had two built within two days. I'm sure he'll post a thread soon with all the pics and his impressions of the build. The output is fairly impressive.
Have you plotted driver excursion yet? I'd be interested to see that.
notnyt is offline
post #544 of 1817 Old 06-13-2011, 12:10 PM
diaz's Avatar
Nice build! Thanks for the pic!
diaz is offline
post #545 of 1817 Old 06-13-2011, 12:12 PM
diaz's Avatar
lilmike, after looking at your build for a while - is the F20 basically a sealed enclosure with a horn around it? This would mean that it would have the same response as a sealed enclosure, with the bandpass boost effect of the horn added to its output?
diaz is offline
post #546 of 1817 Old 06-13-2011, 01:01 PM
beastaudio's Avatar
Quoted: 4147 Post(s)
Liked: 3504
Looks great! Makes me want to build another one I miss the woodworking. I need a new project...
beastaudio is offline
post #547 of 1817 Old 06-13-2011, 07:30 PM
kibe29's Avatar
I'll start a thread soon. I'm still recovering from the crazy weekend of building. I finished painting one of them today. Hopefully I'll have a chance to try it out after work tomorrow. The second one has to be routed and the access panel installed then it will be ready to have the finish work done.
I have a question on powering it. I have a consumer amp, an Adcom 555II to be exact that I was planning to use to power it. 325watts into 4 ohms so it's perfect. I bought and received the minidsp rev A since I'm using a consumer amp. The problem is I just looked up the specs from Adcom's website and it says input sensitivity is 1.75v and gain is 27db. I think this will be a problem with the standard minidsp. Any thoughts?
kibe29 is online now
post #548 of 1817 Old 06-14-2011, 07:38 AM - Thread Starter
lilmike's Avatar
Quoted: 71 Post(s)
Liked: 180
That is a great amp.
As far as the MiniDSP? I'd try it and see - you have it already.
I agree though - the specs do indicate that the sensitivity may be an issue. According to their specs, the MiniDSP does only output 0.9 V RMS. Perhaps a preamp after the miniDSP would help?
lilmike is offline
post #549 of 1817 Old 06-15-2011, 05:35 PM
louisdamani's Avatar
Is there a time delay for this enclosure(if it's used along with sealed subs) and will the 15" version of the below subwoofer work? Thanks in advance lilmike.
http://www.kicker.com/sites/default/...C101215Man.pdf
louisdamani is offline
post #550 of 1817 Old 06-15-2011, 06:28 PM - Thread Starter
lilmike's Avatar
Quoted: 71 Post(s)
Liked: 180
Delay? Yup, it is a horn, there is an additional 420.3 CM of path in front of the driver, or about 12 milliseconds at sea level.
4.2 meters/344 meters/second = 0.012 seconds.
If those specs are accurate, those Kicker 15s will work great in this cabinet. They are basically a drop-in replacement for the MFW. The SPL plots overlay each other. Just like the MFW, the model says that there might be excursion issues right at the box tune (19 Hz) but other than that, they're power limited, just like the MFW is.
I do know that the 2010 Kicker Comp 15s have different specs. If the specs above are for the driver you have (2003 -2007 Comp Series), they will work. If you picked up drivers at Best Buy yesterday (2010 Comps), chances are they won't.
lilmike is offline
post #551 of 1817 Old 06-15-2011, 07:20 PM
Upon further investigation I have 10C154 which are the 2010 version. They have less T/S parameters listed than the previous versions .
http://www.kicker.com/sites/default/...gual%20e01.pdf
post #552 of 1817 Old 06-15-2011, 09:13 PM - Thread Starter
lilmike's Avatar
Quoted: 71 Post(s)
Liked: 180
They work better than I thought they would, but they are not that good of a fit to be honest.
New one in black, old one in gray.
That's a pretty big hole there at 30 Hz. The dip is in an excursion minima, so in theory, you could EQ it, but you run the risk of burning up the coil. Filling a 6 dB hole takes a fair bit of power, essentially a fourfold increase.
lilmike is offline
post #553 of 1817 Old 06-16-2011, 08:15 AM
Thanks Mike. I'll use a couple MFW-15 drivers out of my sealed subs when I make the F-20 cabinets.
post #554 of 1817 Old 06-16-2011, 08:19 AM
MKtheater's Avatar
Quoted: 1755 Post(s)
Liked: 1346
Hey mike, can these be turned upside down with the port on top? If so I could get my ceiling gain as well and make a bass array.
Marantz 7704
2 Outlaw 7140s
Speakers- my own creation!
subs 2 XXX ported SLLT.
MKtheater is online now
post #555 of 1817 Old 06-16-2011, 08:46 AM
beastaudio's Avatar
Liked: 3504
Driver will still be in a vertical alignment standing with the mouth on top. It will be fine. I actually did this for a bit while testing locations but really the front sub's mouth needed to be on top and I cant fit the f-20 on either side of the screen, so it laid back down
post #556 of 1817 Old 06-20-2011, 11:40 AM
MKtheater's Avatar
Liked: 1346
Another question, I have 4 JBL 2225's sitting here doing nothing, will they work in these cabinets?
Marantz 7704
2 Outlaw 7140s
post #557 of 1817 Old 06-20-2011, 05:35 PM
Rob Flanery's Avatar
No, but they will work in mine .
Rob Flanery is offline
post #558 of 1817 Old 06-20-2011, 06:16 PM - Thread Starter
lilmike's Avatar
Quoted: 71 Post(s)
Liked: 180
Not well. They have too high an Fs and a bit too much motor.
There are FAR better places to use these drivers, like in my new mains...
lilmike is offline
post #559 of 1817 Old 06-20-2011, 07:19 PM
MKtheater's Avatar
Liked: 1346
I will trade them if anyone is interested.
Marantz 7704
2 Outlaw 7140s
post #560 of 1817 Old 06-21-2011, 12:26 AM
chrapladm's Avatar
Quoted: 944 Post(s)
Liked: 351
Mk you always seem to have a bunch of good drivers. Did you make any progress on your F20s?
I am really interested in your opinion going from a pair of DTS10s.
chrapladm is offline
post #561 of 1817 Old 06-21-2011, 01:32 AM
ReneV's Avatar
Is this the stuff you use to assemble these beasts?
(The slight obscurity in my question is related to international-shipping concerns ...)
ReneV is offline
post #562 of 1817 Old 06-21-2011, 02:46 AM
That's the stuff, but it is a rather small container. You would not get far with a 4oz tube. I am not sure where you are shipping to, but I am pretty sure that you can find a suitable adhesive where you live. It is an expanding polyurethane adhesive. Pretty common in the construction industry. I have used other polyurethane adhesives to build these things as well. Go to your local hardware store and talk with the folks there. I am sure they can get something that will work for you.
If your cuts were uber precise you could use Titebond or another wood glue. But it won't help to bridge sloppy cutting gaps like the polyurethane does. With my cutting skills I definitely need it.
post #563 of 1817 Old 06-21-2011, 08:10 AM
MKtheater's Avatar
Liked: 1346
As you know, I have eD cutting the wood for me but I ended up having them build them!! They will be black when done. I had them take pics along the way to see how they go together.
Marantz 7704
2 Outlaw 7140s
post #564 of 1817 Old 06-21-2011, 08:20 AM
MKtheater's Avatar
Liked: 1346
Here are some pics
Marantz 7704
2 Outlaw 7140s
post #565 of 1817 Old 06-21-2011, 08:30 AM
Tom Bley's Avatar
Quoted: 711 Post(s)
Liked: 641
Nice! Thanks for the pics. Looks like a lower grade of ply. That's not Baltic Birch ply is it?
Tom Bley is offline
post #566 of 1817 Old 06-21-2011, 08:48 AM
MKtheater's Avatar
Liked: 1346
Auraco ply.
Marantz 7704
2 Outlaw 7140s
post #567 of 1817 Old 06-21-2011, 09:05 AM
desertdome's Avatar
Quoted: 1330 Post(s)
Liked: 1523
I try to never point a nail gun at my hand. Sometimes the nail can penatrate due to a void or soft spot in the plywood. Of course if I was making these I'd probably be doing the same.
High Impact AV
desertdome is offline
post #568 of 1817 Old 06-21-2011, 09:09 AM
MKtheater's Avatar
Liked: 1346
Well, these are the guys at eD. I would most likely shoot myself somehow. I will have more pics and once I get them up and running I will start a thread with all the pics, measurements, distortion, etc....
Marantz 7704
2 Outlaw 7140s
post #569 of 1817 Old 06-21-2011, 10:05 AM
petew's Avatar
Quoted: 27 Post(s)
Liked: 68
It really hurts when you stick a nail into that fleshy part at the base of your thumb. Insert safety glasses nag here.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #570 of 1817 Old 06-21-2011, 01:55 PM - Thread Starter
lilmike's Avatar
Quoted: 71 Post(s)
Liked: 180
Brad nail plus fingertip = lots of blood.
Yeah. It hurts....
lilmike is offline
