Lilmike's Cinema F-20 - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 27Likes
Old 07-17-2011, 09:17 AM
MKtheater's Avatar
Quoted: 1667 Post(s)
Liked: 1185
Originally Posted by Krbass View Post
I need to buy an amp for these things, I have the EP1500 on my THTs. Will an EP2000 be too much for the MFWs?
I have the perfect amp for these. They are my Ashly's. They provide 500 watts into 4 ohms and can run one channel full range and another 20-120hz. I will sell them for $200 shipped in the US.
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- TBD
subs 2 XXX ported SLLT powered by IPR2-7500.
MKtheater is offline
Old 07-17-2011, 09:19 AM
Krbass's Avatar
MK maybe in 2 weeks when I head to utica I could pick one of these up
Krbass is offline
Old 07-17-2011, 09:45 AM
MKtheater's Avatar
Liked: 1185
Hell, if you come to utica you need to come over and listen to these with a similar amp(My ada amps have the same power). Let me know
Marantz 7702 Atmos
Speakers- TBD
Old 07-17-2011, 10:11 AM
Krbass's Avatar
Yeah I will shoot ya a PM this week and let you know when I am coming. I would love to hear your setup
Krbass is offline
Old 07-17-2011, 12:14 PM
alittletank's Avatar
Liked: 26
I have a couple questions regarding mounting the Bash 300. Should I build a separate box to house the Bash 300 or should I cut out the center of the access panel and mount the bash to it? If I do build a separate enclosure is heat an issue? Should I vent it?
Sorry if I missed this in the thread somewhere.
alittletank is offline
Old 07-17-2011, 06:52 PM - Thread Starter
lilmike's Avatar
Quoted: 66 Post(s)
Liked: 171
Up to you. It fits through the cover with room to spare, but then you're locked into that amp. Both will work fine, just make sure everything is sealed up. I prefer to keep the sub amp near the receiver to eliminate ground loops personally.
lilmike is offline
Old 07-17-2011, 08:59 PM
Liked: 26
I'll just put the bash 300 in it's own box then. Its 40ft of wire from the avr to the f20. Would that cause a problem for the Bash300?
Old 07-17-2011, 09:03 PM - Thread Starter
lilmike's Avatar
Quoted: 66 Post(s)
Liked: 171
Might use a slightly larger size wire - 12 ga instead of 14 ga. Other than that, it should work fine.
lilmike is offline
Old 07-18-2011, 06:22 AM
dutchswan0311's Avatar
@lilmike (or anyone) ...
I think my amps will end up being quite a distance from my F20s. If I had to guess, I would say it will be about 60 feet of speaker cable from amp to sub. Will this present any issues? (The same really goes for just about all of the speakers except the rear surrounds.
dutchswan0311 is offline
Old 07-18-2011, 06:26 AM
chrapladm's Avatar
Quoted: 893 Post(s)
Liked: 325
I think with 12ga you should be fine. You could if you want use 10ga but dont really see why. These F20's dont look like they need every drop of power from your amp.
My .02
chrapladm is online now
Old 07-18-2011, 06:37 AM
chrapladm's Avatar
Quoted: 893 Post(s)
Liked: 325
I forgot to ask when this thread started but I saw this was ONE..... of the cinema designs you were coming out with and I wondered do you have a bigger design maybe later coming out?
Kind of goes with the PM I sent you.
Old 07-18-2011, 06:45 AM
Oklahoma Wolf's Avatar
Quoted: 20 Post(s)
12 gauge is more than big enough for a 60' run.
Oklahoma Wolf is offline
Old 07-18-2011, 07:12 AM
Krbass's Avatar
I just ordered 300ft of 12awg from monoprice. I have crappy 18awg on my thts right now, I wonder if I will notice a difference.
Krbass is offline
Old 07-18-2011, 12:22 PM
Looneybomber's Avatar
Liked: 25
If the runs are short, no.
YID DIY
Looneybomber is offline
Old 07-19-2011, 10:34 PM
Liked: 26
On off chance that anyone is reading this at this time of night.... I'm at home depot right now and need to know what size lilmike used for drywall screws.
First post of this thread in his instructions attachment- first page.
Think it's 1 1/2 " drywall screws...
Old 07-19-2011, 10:53 PM
Erich H's Avatar
Quoted: 1437 Post(s)
Liked: 1835
box of #8 x 1-5/8" drywall screws
and #8 X 1-1/4” Truss-head screws
Edit for Full list:
Materials List
2 full 4X8 sheets of ¾“ plywood
¼ sheet (24X48, with grain running along the 48” dimension) of ¾” plywood
Box of #8 X 1 5/8” drywall screws
8 10-32 X 1 ¼” socket head cap screws
8 #10 flat washers
8 10-32 Hurricane Nuts
PL Premium Construction Adhesive – 2 tubes
15” Driver (MFW or others, see build thread for discussions)
1” wide, 1/8” thick closed-cell foam weatherstripping
Input terminal (your choice – I use Speakons)
Proper hardware to mount terminal – Speakons take 2 #6 X 3/4” wood screws
2 feet of speaker wire
_______________________
The SEOS Waveguide Project
Erich H is offline
Old 07-19-2011, 11:09 PM
Liked: 26
Thanks Erich!
Old 07-20-2011, 12:37 AM
Liked: 26
I feel stupid even asking this but here goes...
10-32 X 1 ¼ socket head cap screws
5/16 x1 1/4 socket head cap screws
Are these the same thing?
Old 07-20-2011, 10:00 AM
Spec4's Avatar
Liked: 24
A 10-32 UNF screw has 32 threads per inch opposed to the 24 threads per inch of a 5/16 screw, why do you ask?
Here's a good resource for bolt/screw info.
Spec4 is offline
Old 07-20-2011, 10:23 AM
Point Source
beastaudio's Avatar
Quoted: 3792 Post(s)
Liked: 3089
He is thinking 10/32 vs 5/16 (kind of like 4/8=1/2) which is not the case here. two different systems of measurement as your link dictates
beastaudio is offline
Old 07-20-2011, 11:14 AM
Liked: 26
That clears it up. I didnt see that screw on PE so I checked at Lowes. Lowes had the 5/16 version.
Old 07-20-2011, 11:34 AM
petew's Avatar
Quoted: 26 Post(s)
Liked: 68
Be sure your "T" nuts have the same thread.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
Old 07-21-2011, 07:48 AM
Does anyone see any issues with the use of this terminal connector with my four F20s?
Old 07-21-2011, 07:54 AM
Has anyone used any grills over the horn of their F20? If so, what have you found that works the best? I realize that there is AT material that one can purchase for this, but if this is what you are using, how are you attaching it to the sub?
Old 07-21-2011, 08:37 AM - Thread Starter
lilmike's Avatar
Quoted: 66 Post(s)
Liked: 171
Looks a little light-duty to me. I prefer these and these.
They are inexpensive, easy to install, easy to use, foolproof wrt polarity, they lock in place, and there are no exposed wires.
I'm in the process of switching everything to Speakon connectors.
lilmike is offline
Old 07-21-2011, 08:56 AM
I was on those exact pages earlier today. I liked the price of my link better For the speakon, that is over $5 per. Sounds reasonable, except that I would need 19 of them.
Old 07-21-2011, 09:01 AM - Thread Starter
lilmike's Avatar
Quoted: 66 Post(s)
Liked: 171
They'll probably work OK, but the wires could loosen/get pulled out much more easily.
Actually, $5 each is not bad when you look at the typical terminals and include some banana plugs. There are plenty of options that cost more.
lilmike is offline
Old 07-21-2011, 09:04 AM
I know I know. But also remember, my speakers/subs will all permanently installed (screwed into studs) and will never move...and we don't have earthquakes in Iowa, so...
Old 07-21-2011, 09:07 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
The vibration from the bass itself can loosen up the connection. Speakons are a twist and lock design that works really well. It's cheap insurance if you ask me.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
Old 07-21-2011, 09:09 AM
I suppose. Which connectors do you use on the driver side of the equation? There seems to be a lot of options.
