Lilmike's Cinema F-20 - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 27Likes
post #901 of 1817 Old 09-22-2011, 11:06 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Originally Posted by lilmike View Post
Just a heads up, the Dayton RSS 390 HF is on sale for $150.
Often it can be had for ~$120 (shipped) on ebay as well.
There was a pair for $250 including shipping a couple of months ago.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #902 of 1817 Old 09-22-2011, 09:10 PM
alittletank's Avatar
Liked: 26
What did you guys use for covering all of the screw holes and evening out the edges prior to primer?
Wood filler? Bondo? What name to look for exactly?
What is available for me to get at Lowes/Home Depot?
I have Had the urge since I finished mine to rubberize it. If I could find an affordable option I would rhino guard it just like a truck bed. :-). I'm not sure what if anything that would do to the sound.
alittletank is offline
post #903 of 1817 Old 09-23-2011, 02:40 AM
maxcooper's Avatar
Quoted: 13 Post(s)
The auto bondo or the other stuff.....which brand do you use?
Auto bondo and the 'home' stuff both work great. Make small batches -- it hardens pretty quickly.
-max
maxcooper is offline
post #904 of 1817 Old 09-23-2011, 07:10 AM
Brad Horstkotte's Avatar
Liked: 69
I certainly would not put a trap in the same corner as I am trying to load the sub into - seems like that would sort of defeat the purpose of corner loading.
When I built my THT LP, I asked that question of BFM, and he said it wasn't an issue at all, and in practice it hasn't been - my THT LP lays horizontally behind my screen wall, firing into the left wall about 18-24" away - right into a 24" SuperChunk.
Brad Horstkotte is offline
post #905 of 1817 Old 09-23-2011, 07:11 AM
Liked: 69
-max
I used it too - I used the 5 minute variety, it hardens too fast really, use 20 minute instead.
post #906 of 1817 Old 09-25-2011, 06:53 PM
HuskerOmaha's Avatar
Quoted: 55 Post(s)
Liked: 55
Should have used Bondo, but the wood filler worked well enough, then Michael brought over a belt sander.
We are getting there. The Sealed Dual Opp MFW15s and the F-20s.
Magic Black paint.
Hopefully have some pics of them installed soon.
HuskerOmaha is offline
post #907 of 1817 Old 10-01-2011, 12:16 AM
Danielson99's Avatar
Quoted: 85 Post(s)
Liked: 71
Just got my Dayton Audio DVC385-88 15" driver and Bash 300w amp tonight. Gonna likely get things started tomorrow by going and getting all my materials and then get things started.
Danielson99 is offline
post #908 of 1817 Old 10-01-2011, 10:37 AM
Nardokor's Avatar
Let me know how they work. I am planning to build a pair with the same driver.
Nardokor is offline
post #909 of 1817 Old 10-02-2011, 07:25 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Has anyone tried the LMS-Rs in the F-20?
Joe = LFE Addict
jpmst3 is offline
post #910 of 1817 Old 10-02-2011, 09:11 AM
maxmercy's Avatar
Quoted: 63 Post(s)
Liked: 168
I just wanna say thanks again to lilmike for this design. It has brought REAL 20Hz performance to many who cannot afford hi-spl, 20Hz, low distortion sound by conventional means (sealed/ported).....
Seeing folks' impressions when they first fire up their F20s reminds me of the first time I fired up a horn sub w/ proper EQ.....and the eye-opening that happened....."so THAT's what it's supposed to sound like!"
JSS
maxmercy is offline
post #911 of 1817 Old 10-02-2011, 09:42 AM
MKtheater's Avatar
Quoted: 1679 Post(s)
Liked: 1199
JSS
I agree these things are beast and can not be beat for the money.
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- TBD
subs 2 XXX ported SLLT powered by IPR2-7500.
MKtheater is offline
post #912 of 1817 Old 10-02-2011, 10:29 AM - Thread Starter
lilmike's Avatar
Quoted: 66 Post(s)
Liked: 171
The 15 is not a good fit.
lilmike is offline
post #913 of 1817 Old 10-02-2011, 10:32 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
I see. Thanks for the info Mike. I thought it was worth asking after the DTS swap results.
Joe = LFE Addict
jpmst3 is offline
post #914 of 1817 Old 10-02-2011, 10:57 AM - Thread Starter
lilmike's Avatar
Quoted: 66 Post(s)
Liked: 171
The DTS is a tapped horn, the F-20 is a conventional front-loaded offset driver horn. They require very types of different drivers.
lilmike is offline
post #915 of 1817 Old 10-02-2011, 11:05 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Thanks for the clarification, ya, an oversight on my part.
Joe = LFE Addict
jpmst3 is offline
post #916 of 1817 Old 10-03-2011, 04:30 PM
t6902wf's Avatar
MK pm is full I'll take 2
T6
Clearwave 4TSE and 4CC build thread
http://www.avsforum.com/avs-vb/showt...1#post19489740
t6902wf is offline
post #917 of 1817 Old 10-03-2011, 05:25 PM
MKtheater's Avatar
Liked: 1199
2 are yours then.
Marantz 7702 Atmos
Speakers- TBD
post #918 of 1817 Old 10-03-2011, 05:29 PM
t6902wf's Avatar
2 are yours then.
Clear our your pm's I need to get some info to and from u
T6
t6902wf is offline
post #919 of 1817 Old 10-03-2011, 06:22 PM
MKtheater's Avatar
Liked: 1199
Just did
Marantz 7702 Atmos
Speakers- TBD
post #920 of 1817 Old 10-09-2011, 03:19 PM
Quoted: 85 Post(s)
Liked: 71
Well, after putting in a half-hour here and an hour there for the past week I finally got it all together and running. It's just breaking in now but after running a few quick tests I can say this sub performs just as advertised. Clean, loud and low.
It was quite easy to build and I can't see how you could beat the clean spl for the money one of these costs. Very happy with the performance.
$129 driver
$149 amp
$150 all other materials.
I haven't finished the exterior although I did use pre-finished birch so it's not just sanded plywood sitting in my living room. For a few bucks more I can easily give it a flat black finish to go with the man-cave theme I have going.
Thanks Lilmike for the time you invest in this hobby, it's appreciated.
post #921 of 1817 Old 10-09-2011, 05:35 PM
mrgfy6's Avatar
Quoted: 12 Post(s)
$129 driver
$149 amp
Danielson, what amp did you end up getting? Nevermind, I'm assuming it was the Bash300...Get some pictures and more info when you can!
mrgfy6 is offline
post #922 of 1817 Old 10-09-2011, 09:15 PM
Quoted: 85 Post(s)
Liked: 71
Yes it is the 300w Bash amp. I didn't bother taking pics of the build considering it's simplicity and pics already posted by other members builds. Needless to say, it looks exactly like all the others
post #923 of 1817 Old 10-11-2011, 06:43 PM
mrgfy6's Avatar
Quoted: 12 Post(s)
Cool, thanks. Sort of off topic, but is it important that this driver remain vertical? I know at the beginning of this thread, lilmike says the orientation remains fairly vertical...is this imperative? Also, can the horn length be "simply" lengthened to get more extension, or would it require a complete rework of the design? Thanks for any help people can provide...not that the extension is needed, but something I've sort of wondered...
matt
mrgfy6 is offline
post #924 of 1817 Old 10-12-2011, 06:56 AM
Point Source
beastaudio's Avatar
Quoted: 3827 Post(s)
Liked: 3131
It is better that the driver remain vertical, over time, cone sag can occur in a horizontal setup. which with the design isnt advisable anyways since the mouth would either be firing straight up, or into the floor.
FS: BossoBass A-14K amplifier
beastaudio is offline
post #925 of 1817 Old 10-12-2011, 04:07 PM
Quoted: 85 Post(s)
Liked: 71
matt
Sure, more extension likely means more excursion which means more power which might mean different driver.
If you want a horn that goes lower a good model might be the one on the CSS website seen HERE
I thought about building it until I realized it won't even fit vertically into my room.
As I sit here listening to music on my system I can't help but look over at the F-20 and think to myself "WTF was I thinking!"
Needless to say it's a beast, in size and output.
post #926 of 1817 Old 10-13-2011, 06:44 AM
Point Source
beastaudio's Avatar
Liked: 3131
corner on that still seems to be 20, maybe 18. MK will vouche as well that the f-20 is capable down to 15hz if multiples are built, perhaps even with a single. LilMike stresses a HPF at 20hz but give it a gradual rolloff, and it should play just as low as that gigantahorn
post #927 of 1817 Old 10-13-2011, 11:19 PM - Thread Starter
lilmike's Avatar
Quoted: 66 Post(s)
Liked: 171
matt
With a big, heavy driver, cone sag can cause issues over time. For that reason, I like to keep the coils on as close to a horizontal axis as I can.
Longer = more extension, which also means the horn gets bigger and more demands are placed on the driver. I already reworked the design as the F-24. Add 4 cubic feet. Gain ~3 Hz of extension. Lose ~3 dB of sensitivity.
The bulk of the plots discussing that CSS horn are not in a 2pi environment. To be fair, it is clearly stated. No doubt that it is a good horn, and it is a clever design, but comparing those plots to what I have posted is not an apples to apples comparison. There is really not much difference between the two when they are compared on a level playing field, maybe a Hz or two.
I highpass because I run things hard, and also because when a bandwidth-limited sub is driven with an out of band signal, it results in distortion even if it does not make the driver go clank. I don't like asking drivers to operate outside of their intended passbands. We do the same with our midbasses (we don't ask them to be a subwoofer (well - some of us don't...) or ask them to tweet) and our tweeters (we certainly don't expect them to woof), why treat our subs any differently? It is just much more effective to handle sub crossovers actively rather than passively.
lilmike is offline
post #928 of 1817 Old 10-24-2011, 05:59 AM
t6902wf's Avatar
I bought 2 of MK's units. I searched the first few pages and could not come up with a weight for one. Did anyone weigh one? I need to know for shipping.
T6
t6902wf is offline
post #929 of 1817 Old 10-24-2011, 08:13 AM - Thread Starter
lilmike's Avatar
Quoted: 66 Post(s)
Liked: 171
Mine was 148 lb if I recall.
Yup, 148.
lilmike is offline
post #930 of 1817 Old 10-28-2011, 06:37 AM
avted's Avatar
http://www.avsforum.com/avs-vb/showt...1#post21133971
Looks like the F20 didn't fare as well as I was expecting over at Subfest2011 (if you disregard value for a moment). The comments seem to follow the line "lots of output, but muddy sound". I just finished physical construction of 2 of these (sans finish), and I'm wondering if anybody has ideas on what might have contributed to the lack of clear sound that the Subfest team observed. The subs were EQ'd fo Subfest, which would seem to reduce basic frequency response anomalies, so I'm wondering if perhaps the lack of cabinet bracing, internal sound absorption, or the raw physics of a horn design (which I won't pretend to understand yet) contribute to distortion in the time domain that could be corrected. I have noticed that the cabinets are not "dead" sounding when I knock on them.
Thoughts?
avted is offline
