Lilmike's Cinema F-20 - AVS Forum
 5Likes
post #1 of 1746 Old 04-20-2011, 01:40 AM - Thread Starter
lilmike's Avatar
Quoted: 18 Post(s)
Liked: 88
Here is the first of my Cinema Horn series. This model is pretty good sized, at just over 20 cubic feet, but has a manageable footprint of 4 square feet. Dimensions are 29.375" wide, 20" deep, and 60" tall. It cuts out of 2-1/4 4'X8' sheets of 3/4" ply, bracing is strongly recommended based on what I've learned since I designed and built this cabinet. I designed the enclosure to stand as a tower or lay on its side. The driver orientation keeps the cone in a generally vertical plane in these two orientations.
I designed this enclosure for the MFW 15, which is an American-made (Eminence) driver that was used in a ported sub a while back. This is a healthy driver, and in fact, has a larger voice coil than the venerable Dayton DVC.
This is an offset-driver front-loaded horn. This is not a complicated cabinet. Though it is big, it is a simpler build than the Insubnia, there are less pieces. There are 5 internal panels and four external ones, all the same width. Two sides complete the package. That is only 11 boards total.
Did I mention no bracing? Well, forget that I said that. A bit more experience building and measuring horns suggests that this one needs some bracing too. That being said - the test mule (pictured here) was not braced, and seemed to do OK. I would suggest bracing as discussed, it actually helps with the cabinet construction.
Working alone, I was able to cut all the wood and make the baffle in one evening, then assemble the cabinet the following evening. Final assembly and some sanding and cleanup took me a few more hours before testing today.
Here are the results of today's testing. Thanks to maxmercy and his buddy for dropping by and helping out. It was a lot of fun, we had beautiful weather, enjoyed some excellent beer, and measured a great sub.
Measured with REW 5.0, with a UCA-202 and a Lilmike mic. First sweep was set at a drive level of 2.00 volts into a 4.00 ohm load resistor, each sweep higher is +5 dB from the previous, so the final sweep is 25 dB higher than where we started, or essentially at the limit of my 300 watt amp, and past the thermal limit of the driver. I'm not sure if the compression is the limit of the amp, driver, or both. We limited the start to 20 Hz for the highest level sweep. I was well within the limits of my soundcard and mic at these levels. No mic calibration was used, the soundcard was calibrated via a loopback.
Yeah, it is flat. I measured +/- 3 dB from ~20 Hz to ~100 Hz. This is a front-loaded offset-driver horn, in a groundplane setting.
Though the noise floor was high due to the highways and industrial activities near me, we also did a little THD experiment. I just raised the drive level to compensate.....
Here is 15 Hz. As expected, distortion is pretty high, and SPL is low.
Looks a lot better at 20 Hz. Well below 10 %, and the SPL is 105.9 dB.
Look what happens at 21 Hz, same drive level...3% THD, and 107.6 dB
25 Hz = 4% at 106.7 dB
Back down to 21 Hz, but more power...113 dB, 21 Hz, 5% THD.
Erich can help with drivers, I have a complete set of dimensioned plans and cutlists done already (currently only in 2D - not spiffy like radman12 did with the Anarchy). I also have impedance measurements as well as the model to post. More to come.
Edit:
Here is the impedance and phase plot - nevermind it says SPL - that is a REW thing... As usual, I measured this with my Woofer Tester II, I'm still working on proper test leads for the REW approach.
Here is a comparison. Modeled is red, measured is blue.
Hmmm, I might have a leak yet - that low peak could be a bit higher. I have a couple ideas about where it might be. I'll report back if/when I find anything.
Here is the requested group delay plot:
And the SPL and unwrapped phase:
Edit:
I've attached the model, as well as the sketchup diagrams I used and an optimized cutlist. I am currently working on some assembly instructions
Edit 4-25 - I updated the cutlist to match the instructions I am working on
Edit 4-28 Based on review comments like this:
"The instructions on the F20 are rather concise and easy to understand. If you can't build one from these instructions you might want to get on down to Best Buy and get your HTIB on."
and
"Okay, you suck! Not really, I actually suck. Your directions even have 3d renderings."
I figured it was OK to attach some step by step assembly directions to the post..... Somehow or another - the instructions are a 12-step program....
5-12-2011 Updated Zip with an additional Sketchup showing the flange details, fixed a few typos in the instructions
Edit 11-1-2012:
Since the direct links broke, here is the 5X5 Cutsheet post:
http://www.avsforum.com/t/1329971/lilmikes-cinema-f-20/420#post_20501440
Edit 11-1-2012:
Bracing discussion starts here if you wish to use it. Again, it appears that direct linking to attachments in different posts seems to be broken, so the post is linked.:
http://www.avsforum.com/t/1329971/lilmikes-cinema-f-20/960#post_21160972
If you wish to retro-fit bracing into one that is already built, these suggestions should work too, as you can access both ends of each brace by opening the panel, removing the driver, and working through the chamber. All braces are a cut-to-fit item.
Edit 6-24-2013
Made clearer recommendations for bracing per LTD02.
cinef20.txt 0.443359375k . file
Cinema F-20 Cutlist by Mike Piechowski.pdf 6.3662109375k . file
Cinema F-20.zip 48.2529296875k . file
5-12 Cinema F-20 Instructions.zip 397.798828125k . file
MFW Specs.pdf 126.7783203125k . file
File Type: pdf Cinema F-20 Cutlist by Mike Piechowski.pdf (6.4 KB, 865 views)
File Type: txt cinef20.txt (454 Bytes, 624 views)
diaz likes this.
lilmike is offline
post #2 of 1746 Old 04-20-2011, 02:04 AM
SNOT's Avatar
Pretty cool,
Personally Id like to see a bit of EQ around the 80 range.
uʍop ǝpısdn sı ɹǝʇndɯoɔ ɹnoʎ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
SNOT is offline
post #3 of 1746 Old 04-20-2011, 02:54 AM
Maxjr's Avatar
Awesome work, lilmike! Great job!
Maxjr is offline
post #4 of 1746 Old 04-20-2011, 03:05 AM
notnyt's Avatar
Quoted: 422 Post(s)
Liked: 598
Looks good, are you going to post measurements so we can recreate? =]
Those should be pretty loud corner loaded =]
bigtallman34 likes this.
notnyt is online now
post #5 of 1746 Old 04-20-2011, 03:37 AM
jleonard711's Avatar
Do I see a flatpack in the future for this bad boy?
jleonard711 is offline
post #6 of 1746 Old 04-20-2011, 04:41 AM
Rob Flanery's Avatar
Must...resist...urge...to...buy...wood...
Patience.
I promise...
Rob Flanery is offline
post #7 of 1746 Old 04-20-2011, 06:38 AM
stgdz's Avatar
good job mike, nice to see all your hard work paying off.
stgdz is offline
post #8 of 1746 Old 04-20-2011, 07:29 AM
smokarz's Avatar
Quoted: 23 Post(s)
Liked: 71
wow, great job!
smokarz is online now
post #9 of 1746 Old 04-20-2011, 07:58 AM
Oklahoma Wolf's Avatar
Very nice
Oklahoma Wolf is offline
post #10 of 1746 Old 04-20-2011, 08:02 AM
MKtheater's Avatar
Quoted: 392 Post(s)
Liked: 532
Looks like a competitor for the THT. Very nice!!
AVR-Yamaha A830
amps-5 Adcom 555 in 850 watt monoblock mode
sub amp-Sanway FP14K
LCR-Dual stacked BFM DR-250's
Surrounds- Dual stacked BFM W10's
subs-12 SI 18's ported 6hz.
MKtheater is offline
post #11 of 1746 Old 04-20-2011, 08:15 AM
BruceD's Avatar
Liked: 29
Great News Mike ! Thanks !
I knew my purchase of 2 MFW 15 drivers would be put to good use.
BruceD is offline
post #12 of 1746 Old 04-20-2011, 08:19 AM
saabracer23's Avatar
Liked: 29
Looks nice! Out of curiosity, where in the NW are you located?
Dan
saabracer23 is offline
post #13 of 1746 Old 04-20-2011, 08:45 AM - Thread Starter
lilmike's Avatar
Quoted: 18 Post(s)
Liked: 88
At over two sheets of 3/4" ply, I doubt it. Shipping costs and logistics will be prohibitive. The finished cabinet is a 2-man lift.
This one is not that hard to cut out and build. The layout really only keys off of four points, and it assembles easily if you do things in the right order.
diaz likes this.
lilmike is offline
post #14 of 1746 Old 04-20-2011, 08:48 AM - Thread Starter
lilmike's Avatar
Quoted: 18 Post(s)
Liked: 88
Full plans, cutsheets and all details to make your own are coming. I want to make sure I have things clear enough for people to follow along, and I want to get a basic set of assembly instructions done, because if you do things out of order, you get to undo things.....go ahead...ask.....
I will try to get the plans posted tonight.
I ran out of amp before I hit the driver's limits, so a 300 watt amp is a great match. Highpass at 20.
lilmike is offline
post #15 of 1746 Old 04-20-2011, 08:49 AM
notnyt's Avatar
Quoted: 422 Post(s)
Liked: 598
post #16 of 1746 Old 04-20-2011, 08:49 AM - Thread Starter
lilmike's Avatar
Quoted: 18 Post(s)
Liked: 88
Dan
Tacoma, WA
lilmike is offline
post #17 of 1746 Old 04-20-2011, 08:50 AM - Thread Starter
lilmike's Avatar
Quoted: 18 Post(s)
Liked: 88
Can you show the group delay and phase from one of those measurements?
I have both, but they're on the laptop. I'll try to get that plotted up tonight, as well as the impedance data.
lilmike is offline
post #18 of 1746 Old 04-20-2011, 08:50 AM
notnyt's Avatar
Quoted: 422 Post(s)
Liked: 598
post #19 of 1746 Old 04-20-2011, 08:54 AM - Thread Starter
lilmike's Avatar
Quoted: 18 Post(s)
Liked: 88
Also, have enough welders? =]
Think so, but that's not even all of them.
My nice TIG is not in the pic...
lilmike is offline
post #20 of 1746 Old 04-20-2011, 08:58 AM
exojam's Avatar
Liked: 29
LM,
I have a quick question on this part of your setup "First sweep was set at a drive level of 2.00 volts into a 4.00 ohm load resistor". Did you set your master volume of your pre-pro at value X and then adjust the "RMS Level db FS" in REW until you reached the 2 volts? Thanks.
James
exojam is offline
post #21 of 1746 Old 04-20-2011, 09:09 AM
Erich H's Avatar
Quoted: 488 Post(s)
Liked: 752
This thing should be really nice.
Looks like I better start double boxing some MFW's for shipping before the rush gets under way!
Erich H is offline
post #22 of 1746 Old 04-20-2011, 09:24 AM
moosifee's Avatar
This thread is relevant to my interests.
moosifee is offline
post #23 of 1746 Old 04-20-2011, 09:40 AM - Thread Starter
lilmike's Avatar
Quoted: 18 Post(s)
Liked: 88
Originally Posted by exojam View Post
LM,
James
No Pre-pro in the system when I measure.
Source path:
Laptop running REW ----UCA202 Out----BASH 300----Sub
Signal Path:
Lilmike Mic-----UCA202 In-----Laptop running REW
Setup:
Connect source as described, except connect 4-ohm load resistor at end of speaker wires from amp.
Connect DVM (I use a TrueRMS DVM) across load resistor
Set amp gain to Max
Start REW, open generator
Set level to -40 dB
Select sine wave, set frequency to 60 Hz
Measure voltage, lower amp gain until you're at 2.00 volts across the load resistor
Stop generator
Connect speaker in place of resistor
Calibrate SPL at -40 dB signal level
Run measurement (may get low signal warning, but not always, data typically looks OK)
Increase REW signal level by 5 dB
Run next measurement
Repeat until you hit the amp limit or the driver limit
The Lilmike Mic makes this set of sweeps super easy, as it does not require any range settings, just set it up once and go.
lilmike is offline
post #24 of 1746 Old 04-20-2011, 09:57 AM
exojam's Avatar
Liked: 29
LM,
Thank you very much for the detailed setup steps.
James
exojam is offline
post #25 of 1746 Old 04-20-2011, 10:13 AM
Kimeran's Avatar
Liked: 115
VERY Nice! too bad it is going to be too big for my room at 5' tall.
Heck this could make a nice tv stand sub from the deminisions of it and with a very nice response curve!
Trying to enjoy the simple things in life.
Steam: madbrayniak
Kimeran is offline
post #26 of 1746 Old 04-20-2011, 10:26 AM - Thread Starter
lilmike's Avatar
Quoted: 18 Post(s)
Liked: 88
My idea was to use a pair as a 10-foot wide "stage". The mouth opening can be moved if needed (sides or bottom, just change the cutsheet).
It can also get stretched a bit without running out of driver capability, but that's for another thread.
lilmike is offline
post #27 of 1746 Old 04-20-2011, 10:47 AM
Kimeran's Avatar
Liked: 115
I see, that is similar to what I would like to do in the future as I have told you before. But one question...this is a front loaded horn and not a tapped horn correct? Why did you go with the FLH over the TH?
Steam: madbrayniak
Kimeran is offline
post #28 of 1746 Old 04-20-2011, 10:55 AM
NEO Dan's Avatar
Source path:
Hi Mike,
What filter setup are you running in the BASH?
Dan
NEO Dan is offline
post #29 of 1746 Old 04-20-2011, 10:58 AM - Thread Starter
lilmike's Avatar
Quoted: 18 Post(s)
Liked: 88
Not all horns have to be tapped....
This particular driver performs much better in a front-loaded horn, so I conjured up one for it.
lilmike is offline
post #30 of 1746 Old 04-20-2011, 11:00 AM - Thread Starter
lilmike's Avatar
Quoted: 18 Post(s)
Liked: 88
Originally Posted by NEO Dan View Post
Hi Mike,
Think I modded it to be flat to 20. Can't remember, might still be stock.
lilmike is offline
