Lab Gruppen FP14000 clone amplifiers - Page 157 - AVS Forum | Home Theater Discussions And Reviews
 301Likes
post #4681 of 5925 Old 11-05-2014, 11:55 PM - Thread Starter
notnyt's Avatar
Quoted: 2651 Post(s)
Liked: 2427
I cant remember if it was posted in here or not but has anyone swapped out the fans in the 10Q for some silent after market ones?
I am thinking about getting a 10Q after Xmas. BUT I also may just get a Fp14 instead. I am wanting 2400watts in 4ohms x 2 and nothing else comes close. Even if I spent500 more dollars I would not get as much power. The only other amp I would buy instead is a LOT more money than I want to spend right now. So 900 vs 2000 vs 3400. SO I think I will probably join the fray soon. Xmas I will have my 18's and then will order from there.
fans are run off the power board, same board as the fp14k, same procedure.
notnyt is offline
post #4682 of 5925 Old 11-06-2014, 12:21 AM
chrapladm's Avatar
Quoted: 927 Post(s)
Liked: 346
Thanks Notnyt. How are your amps doing?
Cant believe it has been 3 years since this thread. WOW
chrapladm is offline
post #4683 of 5925 Old 11-06-2014, 01:21 AM - Thread Starter
notnyt's Avatar
Liked: 2427
They're great. Was just beating on em tonight pretty hard. Nothing like running some audio tracks 24db+ hot to the subs
notnyt is offline
post #4684 of 5925 Old 11-06-2014, 06:38 AM
Point Source
beastaudio's Avatar
Quoted: 4002 Post(s)
Liked: 3308
^^^^ My absolute favorite
FS: BossoBass A-14K amplifier
beastaudio is online now
post #4685 of 5925 Old 11-06-2014, 06:53 AM
audiovideoholic's Avatar
Quoted: 653 Post(s)
Liked: 215
Go 3400 as I think I know what that one is ;-) =extremely quiet and built in the US? Some Cats really like them?
But my two Fp10s have been fine after I weeded out the faulty FTW that was making a channel clip super early. Thought was amp and as you know was just bad FTW. And mine have been pushed super hard with 220v and left turned on many many hours at a time ;-)
audiovideoholic is offline
post #4686 of 5925 Old 11-06-2014, 07:06 AM
chrapladm's Avatar
Quoted: 927 Post(s)
Liked: 346
I will have the 3400 some time next year. Just not right now. And ya .....you know what it is. So for now the clone is looking like my next move for amps.
post #4687 of 5925 Old 11-06-2014, 07:21 AM
Quoted: 653 Post(s)
Liked: 215
Originally Posted by padraicone View Post
whats the highest draw you've seen on the killawatt with these amps?
Bassthathz did some testing with an oscope somewhere. Has a thread that might show show if search his threads started or oscope threads started. Or maybe even search O-scope if nothing for oscope
post #4688 of 5925 Old 11-06-2014, 07:25 AM
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 906
I must be one that pounds the cr@p out of my 10000Q clone the most!
I have no problems with my 10KQ and it's been over 2 years now.
@chrapladm
I'm getting another one early next year too !
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
post #4689 of 5925 Old 11-06-2014, 07:26 AM
chrapladm's Avatar
Quoted: 927 Post(s)
Liked: 346
Well thats awesome to heat Fatshaft.
post #4690 of 5925 Old 11-06-2014, 12:52 PM
Troglidite's Avatar
I don't know if this is the right thread to ask this question on, but have you or any one else on this thread specifically used that automatic turn on/off relay set up on the FP14000 clones.
If you are using this relay setup on your four FP140000 clones, I'd like to know how you like it, if you had to modify anything on the FP14000 to make this relay set up work right, and if there is any thuds or noise on turn on or turn off.
I looked through this thread and the relay threads, and didn't see this mentioned anywhere.
Troglidite is offline
post #4691 of 5925 Old 11-06-2014, 12:57 PM - Thread Starter
notnyt's Avatar
Liked: 2427
I use the relays with my amps. No loud noises or thumps, only the mechanical relays clicking.
notnyt is offline
post #4692 of 5925 Old 11-06-2014, 01:14 PM
Troglidite's Avatar
Thank you!
post #4693 of 5925 Old 11-18-2014, 10:36 AM
Quoted: 16 Post(s)
Liked: 2
Can the clone amp be that way a quiet one? Or do you stil hear the fans after the mod?
always-ultra is offline
post #4694 of 5925 Old 11-18-2014, 10:43 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
It depends on what fans you use and how far away you are from it.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #4695 of 5925 Old 11-18-2014, 10:45 AM - Thread Starter
notnyt's Avatar
Liked: 2427
Someone should take video of the fans or something
notnyt is offline
post #4696 of 5925 Old 11-18-2014, 06:01 PM
Jeff in Canada's Avatar
Quoted: 167 Post(s)
Liked: 62
Going to China in about 2 weeks for a month. I may buy some of these and bring them back. My wife will no doubt buy alot of things so I may send them back by sea.
Worth getting a few there?
Audio: Denon AVR-4520, Fusion 12 Tempest (LCR), Fusion 8 Alchemy (4xSurrounds+2xWides+2xHeights),4 x 15" Dayton Ultimax
Video: Sony VPL-HW40ES, Darbee Darblet, SMX 2.35:1 Screen
Seating: Fusion Lagoon Chairs
Theater Build
DIY Speaker / Sub Build
Jeff in Canada is offline
post #4697 of 5925 Old 11-18-2014, 07:00 PM
chrapladm's Avatar
Quoted: 927 Post(s)
Liked: 346
I would think it may be more of a hassle to buy from China when there unless you have dealt with them before. I know , personally, I would rather not look to close to the building and what not that is putting out these value products. I dont want my ideas of a great value amp going down the drain because of that.
BUT maybe you have been there and done that so this maybe great for you.
post #4698 of 5925 Old 11-18-2014, 08:18 PM
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 906
I'm in...
Mfusick likes this.
My Build Thread
Equipment Speakers:
Fatshaft is offline
post #4699 of 5925 Old 11-18-2014, 08:41 PM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 578
Originally Posted by Fatshaft View Post
I'm in...
Don't you have a fp10000 ? What are your thoughts on it ? I've been thinking about picking one up....
Fattykidd is offline
post #4700 of 5925 Old 11-18-2014, 08:51 PM
popalock's Avatar
Quoted: 1242 Post(s)
Liked: 1736
You should meet up with Johnson and his crew at Sanway... Have a serious conversation with him about the challenges he faces with doing business in the States...
Ask for his vision of what he is trying to accomplish long term...
popalock is offline
post #4701 of 5925 Old 11-19-2014, 05:22 AM
Quoted: 167 Post(s)
Liked: 62
Are they in Beijing?
Theater Build
post #4702 of 5925 Old 11-19-2014, 05:52 AM
chrapladm's Avatar
Quoted: 927 Post(s)
Liked: 346
I thought Sanway was about 11hours by train 2 hours by flight from Beijing.
post #4703 of 5925 Old 11-19-2014, 07:16 AM
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 906
Yes I do but I need another one. I need more power and moar BASS!
Especially for my next upgrade
My thoughts? There's nothing better out there for the same price.
Fatty, There's no reason for me to say don't...They are awesome amps and the fact that they are improved over mine is a bonus.
I beat the hell out of my 10KQ. I haven't had any problems with it. 2 years now.
I'll speak for my 10KQ, it's a workhorse and really delivers!
Do it...
Fattykidd likes this.
My Build Thread
Equipment Speakers:
Fatshaft is offline
post #4704 of 5925 Old 11-19-2014, 11:00 AM
Quoted: 16 Post(s)
Liked: 2
Thank you! For some reason the link is broken but I found your post. I'm thinking about getting a FP6000Q since I don't need more power. It's for life music, monitors and one sub. Any thoughts about the FP6000Q? Someone already tried that one?
post #4705 of 5925 Old 11-19-2014, 05:35 PM
Quoted: 167 Post(s)
Liked: 62
Link to the guy you buy from? I may just buy and ship to my friends house and then bring it home from there
Theater Build
post #4706 of 5925 Old 11-20-2014, 09:43 AM
rms8's Avatar
Quoted: 492 Post(s)
Liked: 321
UPDATE.
Ended up having to purchase a new channel board for my Sanway FP14000. Got it in a week and is working GREAT at the moment!!!!
rms8 is offline
post #4707 of 5925 Old 11-20-2014, 01:40 PM
chrapladm's Avatar
Quoted: 927 Post(s)
Liked: 346
Awesome to see its fixed!!
post #4708 of 5925 Old 11-20-2014, 01:44 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
I think in CA where the cost is higher because of duties and all that perhaps.. but in the USA the cost to get one isn't very high. Shipping is reasonable so total cost is.
Mfusick is offline
post #4709 of 5925 Old 11-20-2014, 01:46 PM
Quoted: 16 Post(s)
Liked: 2
rms8, how much was the board?
post #4710 of 5925 Old 11-20-2014, 02:14 PM
MKtheater's Avatar
Quoted: 1706 Post(s)
Liked: 1238
Mine was $875 shipped.
MKtheater is online now
Lab Gruppen Fp 14000 , Sanway Fp 10000q
