Lab Gruppen FP14000 clone amplifiers - Page 160 - AVS Forum | Home Theater Discussions And Reviews
 211Likes
Old 11-28-2014, 04:43 PM - Thread Starter
notnyt's Avatar
Quoted: 2156 Post(s)
Liked: 1984
Originally Posted by always-ultra View Post
Sorry, I meant continuous power vs peak power. I think too (as I stated when quoting Holland) that an effective RMS value calculated from the peak voltage of a burst's response is better. And sure, we can calculate that only having the peak voltage. I meant really continuous power over like 10secs or more vs peak power like in LG's rating. It would be better to know both. Then we could decide what an amp we need, depending on the situation. A chaotic band that kicks down mic stands with mics on? Better lesser peak power if you don't want to be buying speakers. A controlled band or maybe a HT? Then so much peak power that the crest factor of what you want to go to the speakers is taken care of well.
These amps have voltage limiters. If you're using amps that don't, your processors should.
notnyt is offline
Old 11-28-2014, 04:49 PM
Quoted: 16 Post(s)
Liked: 2
Yes, I know. But why do we need a high peak power if we are not going to use it because the voltage limiter is not going to let it happen? Slew rate? Should be already enough. I think, if we need high peak power then because we really need it because the music demands it. What would be the advantage of having a high peak power if we are to going to use it because the limiter is set so tight that is just won't reach the speakers? Maybe I didn't understand you.
always-ultra is offline
Quoted: 16 Post(s)
Liked: 2
Did you mean for adapting to different situations?
Old 11-28-2014, 04:53 PM - Thread Starter
notnyt's Avatar
Liked: 1984
Yep. I'm not running a limiter on mine. I'm running a highpass to protect drivers below tune, otherwise they're not going to hurt my subs because its a properly designed system.
notnyt is offline
Old 11-28-2014, 05:06 PM
Quoted: 16 Post(s)
Liked: 2
I see. You can do that in your situation. For the case of a PA there are trade-offs to be made, which of course are OT in a HT forum. But the ideas are aplicable to your upcoming measurements as well. What I mean is: continuous power rating and peak power rating are different specs of an amp and I think that we need both, at least generally speaking. Consider the case of an amp that can produce 100W continuous and 10kW peak (like D.Keele said) for a bass player not slapping. If the 100W continuous are enough for him: does he need 10kW peak? No way. Then why pay for it? On the other side, if the 100W continuous are not enough (very possible playing e-bass on a large stage) then he needs a more powerful amp despite the 10kW peak. That said, I would prefer to have the best amp in the world if I could afford it. If not I would prefer to be able to select the right amp I really need so I don't pay for something I don't need, like the high continuous power (or low peak power in relation) of the crest if what I need is amplifying timbales or bongos... In that case something like the FP14000 would be for sure a better choice.
Old 11-30-2014, 05:06 PM
Quoted: 16 Post(s)
Liked: 2
Quoting Mr. Holland: "These numbers are per channel in stereo mode into 4Ω. They would have been higher at 2Ω, though voltage and the SPL from your loudspeakers would be lower. Chew on that. I hate this whole watts thing – just did it for the peanut gallery – next time it’s volts like God intended."
I don't think that's true. Voltage may have been lower at 2Ω but if the total output power was higher then the total SPL must be higher too despite the lower voltage. It's not the voltage that drives the speakers but the current flowing through them. Speakers are not voltage sensitive but 100% current driven devices. No current, no electromagnetic force. A speaker rated as 4Ω will be louder than the same speaker rated at 8Ω if the same AC voltage is applied to both since the current flowing through the 4Ω speaker will be higher. And it's current what Ampere's law is about.
Old 11-30-2014, 06:14 PM
Quoted: 93 Post(s)
Liked: 30
I know less than squat... but have been reading a bit about these very dynamic amps. The whole 100 watt continuous and 10000 watt very short term (dynamic) thing.
It seems that for most non square wave (non MOST extreme) circumstances that the instantaneous voltage potential is very important to reproducing (tracking) the dynamic wave forms of real world sound reproduction.
I doubt most common large subwoofer voice coils could handle (not burn, melt, or come unwound) 2000 watts continuous (square wave) for more than a few seconds without starting to fatigue or fail. But from the measurements of real world recorded material I have seen so far that on average the voltage swings called upon have been large, while the continuous power has been much less so even for extreme material. The large voltage swing potential has been more beneficial for dynamics.
I am having fun learning about this stuff though.
All of the different power supply types and amplifier stage types (and inefficiencies) keeps me coming back for more edumication.
For 25 years I have just picked an amp with manufacture specs than matched the power rating on the speakers. That is not such a bad way to go from well known manufactures, but it appears to leave a lot on the table as far as dynamic potential... I will change my mind if I melt a good subwoofer though!
cellarnoise is offline
Old 12-01-2014, 08:04 AM
Jason kiDD's Avatar
Quoted: 23 Post(s)
Liked: 25
Originally Posted by popalock View Post
Yes.
I live close enough if you need any help. Just let me know in advance..
Jason kiDD is offline
Old 12-03-2014, 05:08 AM
Quoted: 16 Post(s)
Liked: 2
I did it again... This time the power resistors exploded so loudly on my left ear that I had to go to a scpecialist that prescribed me cortison so the hearing loss is hopefully temporary... What a mess. I need my ears.
Be careful!
ID:	399298   Click image for larger version
Old 12-03-2014, 09:19 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Be careful!
Sheesh, you are going to have to come up with a better solution for resistors before you really get hurt.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
Old 12-03-2014, 09:27 AM - Thread Starter
notnyt's Avatar
Liked: 1984
Just need to get a pail, fill it, and wire these up
You can't be air cooling at these power levels.
notnyt is offline
Old 12-03-2014, 09:46 AM
Quoted: 16 Post(s)
Liked: 2
Have you measured their resistance yet? If so I'd be interesting in knowing. Do you know how constant they stay under changing temp?
Old 12-03-2014, 09:50 AM - Thread Starter
notnyt's Avatar
Liked: 1984
Have you measured their resistance yet? How high are they? Do you know how constant they stay under changing temp?
They measure 13.3-13.4 ohms cold. Three of them in parallel gives me about 4.45 ohms. I haven't run any current through them yet, but I'll take measurements again after doing so.
notnyt is offline
Old 12-03-2014, 10:01 AM
Quoted: 16 Post(s)
Liked: 2
I know... I was really careful and measuring only for short times and controlling the temp of the resistors and everything went well. But then I saw an oscillation in the output of the Crest Pro 8200 when using square waves that got my attention (the P2500S didn't show that), and wanted to know if they became smaller or bigger with higher output... I boost the input, the wave changes, the fans of the amp speed up instantly, I go back quickly to lower input, the fans slow down again instantly. I though, interesting... So the fans react directly to the current and not temp when I higher the input like this... Hmmm.. Let's see it again... ! ! ! ! B A N G ! ! ! ! I guess that was stupid to say the least.
Old 12-03-2014, 10:04 AM - Thread Starter
notnyt's Avatar
Liked: 1984
Temp changes really fast internally when you boost signal. I'd be surprised if they ran off input and not temperature. Easy to test, boost input, lower volume knob.
Sorry about your ear, hope it heals well.
notnyt is offline
Old 12-03-2014, 10:13 AM
Quoted: 16 Post(s)
Liked: 2
I meant, they seem to be controlled by the current flow of the output, sure by temp as well. But they reacted just too fast, really instantly. It was like controlling them directly with the amplitude knob of the function generator. I guess their controlling circuit uses a mix of temp and current flowing through the amp's output (I didn't mean the input amplitude).
Thank you. I hope so too...
Old 12-03-2014, 10:30 AM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 64
Originally Posted by zeus33 View Post
Thanks for the info.
Awesome info, cheers for posting, gents
Originally Posted by cellarnoise View Post
Can a balanced minidsp 2x4 with 2 volt output drive a clone adequately?
Yes.
Dumb question...
... can a Balanced miniDSP 2x4 with a 2v output drive a CV5000 adequately?
I only ask because I can't get the input clip lights or even the input 0dB lights to light up on my CV5000 with an REW-produced -3dB 60Hz sine wave via the SW Out from my Onkyo 818, which I'm led to understand has 4.6v output... ??
MemX is offline
Old 12-03-2014, 10:43 AM - Thread Starter
notnyt's Avatar
Liked: 1984
Dumb question...
Console the minidsp and look at the signal levels while doing so. Should give you an idea what's going on.
notnyt is offline
Old 12-03-2014, 02:11 PM
BassThatHz's Avatar
Quoted: 2032 Post(s)
Liked: 1555
I'd help, but live 2400miles away.
When I see that, this thread now reminds me of photonicinduction.
He took a 240Volt 100amp breaker and dumped that into a DIY 50,000ampere RMS transformer.
and his newest 2015 DIY 20,000watt RMS transformer with over 500volts RMS of step-up.
He likes blowing stuff up with excessive electricity, both volts and amps.
(Even inside his house, like burning the carpet and all.) He's a bit nutz, but his vids are pure-winning.
Will in Blend? Will it Microwave? Who knows!
ID:	399810   Click image for larger version
kingpin111 likes this.
BassThatHz is offline
Old 12-03-2014, 04:01 PM
MemX's Avatar
Quoted: 55 Post(s)
Liked: 64
I've not watched it but '10 Second Toaster' and that freezeframe tells me everything I need to know LOL
I need to buy the miniDSP, so I'm just hoping I don't clip the hell out of it by feeding it too much from the AVR when I do get it, hence I haven't got it yet!
I understand the unbalanced RCA Out of the SW Out on the AVR will mean I can have up to 4v input into the Balanced miniDSP, so I will just need to check out signal levels and set my gain structures, as you suggest... Mission! lol
MemX is offline
Old 12-03-2014, 10:20 PM
BassThatHz's Avatar
Liked: 1555
You are worrying too much.
Hook the miniDSP up to a computer, it will tell you if it is clipping or not. Adjust the AVR and miniDSP output gain accordingly.
Just keeping it below -6db and you'll be fine.
Turn the amp's volume all the way down when you first play it so you don't blow up anything, it will quickly become apparent where you need to set it once you pump some heavy movie bass through it.
Unless you have the amp set to the highest sensitivity you are unlikely to clip its input.
MemX likes this.
Old 12-14-2014, 03:12 PM
javi404's Avatar
Anyone else notice the post numbers are off by 2?
Is it just me?
Did this thread officially break AVSforum?
javi404 is offline
Old 12-14-2014, 03:46 PM - Thread Starter
notnyt's Avatar
Liked: 1984
Is it just me?
Likely deleted posts.
notnyt is offline
Old 12-16-2014, 04:42 PM
Monkeys's Avatar
Hello all,
So I finally had one of my FP10Q's die on me last night. After many many hours of abuse it has not skipped a single beat, then suddenly last night while watching a movie on very low volume it decided to crap out on me.
It's doing a weird this where it seems like it is trying to start up but the power keeps cutting out and flicking on and off.
I've uploaded a video, if some of the experts here wouldn't mind having a look at the video and telling me what they think might be a good place to start I would really appreciate it.
BTW this is what the unit does without any signal plugged in, and I have only switched it on once, and then off once in this video (despite what it looks like).
http://vid1060.photobucket.com/album...IMG_1658_1.mp4
I haven't opened it up yet to have a look, I'm going to do that now. I figured it was worth posting it up here to see if anyone has experienced a similar issue.
Cheers
Monkeys is offline
Old 12-16-2014, 04:47 PM
WereWolf84's Avatar
Quoted: 224 Post(s)
Liked: 85
Monkeys, curious to know how long is the lifespan of your FP10Q? because my FP14K also died around last week
WereWolf84 is offline
Old 12-16-2014, 05:00 PM
Monkeys's Avatar
Not that old really, I bought three units in March this year.
They have served me very well though I must admit. I have been using them for outdoor events on a large PA running bass duty =P
I guess if I can diagnose the problem I can always contact Johnson and request a replacement board or whatever is needed since it is still technically within the 1Yr warranty
Monkeys is offline
Old 12-16-2014, 07:11 PM
Shan87's Avatar
Quoted: 16 Post(s)
Liked: 27
Mine died a week or so back finally... It started the random cycling of course but only when it was at idle... If you were playing bass heavy music through it then it would work perfectly until it came back down to idle for a few minutes but now it just cycles on and off.
Shan87 is offline
Old 12-16-2014, 08:09 PM
Quoted: 93 Post(s)
Liked: 30
I bought a dead FP14000 that was power cycling. After about 50 hours of playing with it and having a friend with a scope check it out the following post solved this particular problem for my amp. Has been working well for several months.
buy one of these:
http://ca.mouser.com/ProductDetail/P...WrX8IHli/VDQ==
check out post #3488 or #3492 and #3908 . I went with a single turn trimmer as it fit the spot correctly. There is not much room around the CAPs to fit a multi-turn variable resistor. The solder joints on these amps is not always the best....
I dialed the single turn variable resistor to 2500 ohm total resistance. Worked great after that. Also check the other resistors in the general area for proper soldering to the board.
Good luck.
Attached is a graphic showing the variable resistor installation location:
Old 12-16-2014, 10:05 PM
Fattykidd's Avatar
Quoted: 491 Post(s)
Liked: 398
So I got my fp10kq yesterday and as you can probably guess, the fans need to go... So for the 60 mm fans are the resisters only used to quiet the fans more than they already are ? I have my 80 mm fans and was going to order my 60's but wanted to check about the resisters.
Thanks in advance,
Ivor
Fattykidd is offline
Old 12-16-2014, 10:09 PM - Thread Starter
notnyt's Avatar
Liked: 1984
Thanks in advance,
Ivor
Resistors are needed to drop the noise level further.
notnyt is offline
Lab Gruppen Fp 14000 , Sanway Fp 10000q
