Lab Gruppen FP14000 clone amplifiers - Page 164 - AVS | Home Theater Discussions And Reviews
post #4891 of 4908 Old 01-26-2015, 04:33 PM
Quoted: 31 Post(s)
Liked: 2
Standard 15amp here also
MagnumMafia05 is online now
post #4892 of 4908 Old 01-26-2015, 04:39 PM
Red Devil 24's Avatar
Quoted: 12 Post(s)
worst case the breaker will pop, if it happens too often change the wire and socket for a 20 amp circuit
Red Devil 24 is offline
post #4893 of 4908 Old 01-27-2015, 01:19 AM
Spezzy's Avatar
Thank you everyone. Just wasn't sure if it would plug into a standard socket.
"The choices we make define our lives, because choice, not chance, determines destiny"
They call me the 18 year old DJ Audiophile-upgradeitis infected-guy!
Spezzy is offline
post #4894 of 4908 Old 01-31-2015, 08:42 AM
TMcG's Avatar
Quoted: 495 Post(s)
Liked: 382
Is there a single "sticky" post in this thread that consolidates all the knowledge and parts required to either get stable performance (trimmers, pots, resistors, etc.) or quieter operation. I've read about 700+ posts this morning and there seems to enough things to improve or watch out for that it would be convenient to have a consolidated post.
This consolidated post may exist....I just haven't made it through all 4900 posts and was looking for a potential shortcut. I was thinking about ordering two of these - one for a pair of SI 24s and another for 4 x UXL-18s.
TMcG is offline
post #4895 of 4908 Old 01-31-2015, 08:54 AM
Quoted: 31 Post(s)
Liked: 2
I been trying to find where to put my trim pot on here by a picture. Seen a post where supposedly which posts would have it but on mobile its hard to go 2 pages everytime for another 2000 posts to find it. I pmed someone asking for the picture and info. My fb14k after being on continously will start to power cycle. I notice it early this AM and once before. But when i turn off and turn back on later its fine again.
Edit.i got the trim post cellar posted on page 160 and got what notnyt got for the 80mm fan and what cellar got for his 60mm fan. I didnt use resistors for the fans. Didnt need to. My fb14k also has 1 more fan then the fp14000 and i only got enough to change all but 1 of the 60mm fans and found i dont really need to change that fan to 1 of the ones i bought to switch out with.
post #4896 of 4908 Old 02-01-2015, 09:01 AM
BassThatHz's Avatar
Quoted: 532 Post(s)
Liked: 506
That should work pretty good.
I would strongly suggest that you buy a fp10000Q for the quad UXL-18, that will give you 2.1kW x4 @ 4-ohms.
Running a FP14000 at dual 8-ohms like that might not be enough power for 4 UXL-18's. That's only 1175watts per UXL with the clone exploding.
If you risk it, you can operate the clone at dual 2-ohm which will give the UXL's 3.5kW each; I would guess that most of the time you wouldn't be north of 8kW out of the 14kW. So that's good, the amp will run cooler.
Don't say we didn't warn you.
TMcG likes this.
BassThatHz is online now
post #4897 of 4908 Old 02-01-2015, 09:07 AM
BassThatHz's Avatar
Quoted: 532 Post(s)
Liked: 506
Here is what Sanway told me, just thought I'd share the info:
"honestly, our current fp3400; fp6400; FP7000; FP9000 and FP14000 two channel amps are stable on 2 ohms load; our current FP2400W; FP6000Q and FP10000Q four channel amps are only stable on 2.67 ohms load, not stable on 2 ohms load."
Apparently the Fp14k I just bought can do north of 12kW, that is a scary amount of power though for just 1 or 2 drivers to handle.
post #4898 of 4908 Old 02-01-2015, 10:36 AM
Quoted: 31 Post(s)
Liked: 2
Also box rise helps. The FB14K manual they sent me doesn't even have 2ohm specs. I don't have the guys email just Anne. I should ask. Email trash only goes back so far but Anne keep mentioning 4ohm. i even asked about 2 ohm when i saw the manual saying on their website says 2ohm spec and it doesnt on the manual. I know they say it's the same amp, different face plate.. but mine had a extra fan..
@BassThatHz you plan on changing the fans? Maybe they also changed the FP14000 and added another fan like my FB14K? Would like to know if you do. To verify same internals like they said. Could just be am update they did to the amps for cooling
post #4899 of 4908 Old 02-01-2015, 10:25 PM
popalock's Avatar
Quoted: 771 Post(s)
Liked: 1060
Would be nice if @notnyt could get ahold of a newerish FP14K and beat the living snot out of it with a 2ohm load to put Sanways claim to the test...
Scott Simonian likes this.
popalock is offline
post #4900 of 4908 Old 02-01-2015, 10:34 PM - Thread Starter
notnyt's Avatar
Quoted: 513 Post(s)
Liked: 690
I know someone local with one, will see if they want to volunteer it for abuse.
saginawjuggalo and popalock like this.
notnyt is offline
post #4901 of 4908 Old 02-06-2015, 04:14 PM
TMcG's Avatar
Quoted: 495 Post(s)
Liked: 382
Thanks for the advice. So one FP10000Q for the 4 x UXL-18s....and if I am hearing your correctly, it would be OK to use a single FP14000K to run two separate SI HS-24 (dual 2 ohm) drivers?
TMcG is offline
post #4902 of 4908 Old 02-06-2015, 04:20 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 1212 Post(s)
Liked: 1232
Thanks for the advice. So one FP10000Q for the 2 x UXL-18s....and if I am hearing your correctly, it would be OK to use a single FP14000K to run two separate SI HS-24 (dual 2 ohm) drivers?
I'd go for it. Yeah.
Mfusick likes this.
My Dual 18" LLT subs 120dB down to 10hz
Plan9Reloaded Co-host
Listen to the Plan9Reloaded Gaming and Technology Podcast (may contain NSFW language)
https://soundcloud.com/plan9reloaded/sets/podcast - direct pod link
http://plan9reloaded.com/site/ - main website
Scott Simonian is offline
post #4903 of 4908 Old 02-06-2015, 04:40 PM
Mfusick's Avatar
Quoted: 265 Post(s)
Liked: 1235
You'll have a really hard time finding an amp with more power for less money.
"Too much is almost enough. Anything in life worth doing is worth overdoing. Moderation is for cowards."
Mfusick is online now
post #4904 of 4908 Old 02-06-2015, 11:52 PM
popalock's Avatar
Quoted: 771 Post(s)
Liked: 1060
I'm doing just that...
Wouldn't be necessary if you were going with an IB alignment. I personally have always been in the camp that I'd rather NOT be power limited. However, the more I learn about this hobby, the more I come to terms with balance being the key.
Awww f* it... I'd rather have too much power and just keep my gain in check.
Fatshaft, coolrda and blah450 like this.
popalock is offline
post #4905 of 4908 Old Yesterday, 05:31 AM
blah450's Avatar
Quoted: 34 Post(s)
Liked: 122
blah450 is offline
post #4906 of 4908 Old Yesterday, 07:19 AM
Mfusick's Avatar
Quoted: 265 Post(s)
Liked: 1235
Tim,
Couple quick thoughts. First, I think the one amp to two 24" plan is pretty solid. Keep in mind you are doing slightly smaller sealed box so your power handling should be good, and requirement increased a bit. Second, the single amp to 4 woofers is not so appealing to me. From a power standpoint I think it's fine, but from a bass mgmt and set up standpoint you could do better with individual channels.
If your 4 subs aren't equal distances from the main LP or co-located you might want the ability to add delay or tweak them individually. That is where a woofer per amp channel comes in really handy. It would cost you more $ because you need another amp but something like two amps half powerful might be a better bet. Not from cost perspective, but from tweakbility and results side of things.
post #4907 of 4908 Old Yesterday, 08:59 AM
Quoted: 31 Post(s)
Liked: 2
Tim,
Didnt he say he was going with a FP10000q which is a 4 channel amp for the 4 18" subs and the FP14000 that's a 2 channel for the two 24s?
post #4908 of 4908 Unread Today, 10:38 AM
Shreds's Avatar
Quoted: 94 Post(s)
Liked: 29
Gain? Check.
Shreds is online now
Lab Gruppen Fp 14000 , Sanway Fp 10000q
Gear in this thread - 10000q by PriceGrabber.com
