Lab Gruppen FP14000 clone amplifiers - Page 171 - AVS Forum | Home Theater Discussions And Reviews
 211Likes
post #5101 of 5748 Old 07-26-2015, 07:40 AM
Quoted: 70 Post(s)
Liked: 7
My clone finally took a dump this morning. It has been 4 years of awesome bass. It keeps lighting up the mute LEDS and then back to normal, on and off. I am going to my local store to pick something up but I am not sure what else has little roll off down low. I will measure whatever I try, I don't need huge power as I am running the IB but I don't want rolloff above 5hz. My clone was good to 3hz!
Sounds like the you need a resistor pot
MagnumMafia05 is offline
post #5102 of 5748 Old 07-26-2015, 07:57 PM
MKtheater's Avatar
Quoted: 1588 Post(s)
Liked: 1116
Well after 4 years of high spl HT all it needed was a reset! Still kickin ass! Nothing is wrong, the monster cable trigger messed with it and a reboot fixed everything. I might just take that thing out of the loop and use my DIY 20 amp trigger, never had problems with that, the Monster AVS 2000 is just too cool looking though.
popalock likes this.
MKtheater is online now
post #5103 of 5748 Old 07-26-2015, 08:55 PM
popalock's Avatar
Quoted: 1232 Post(s)
Liked: 1712
That sucks man. Bass is an essential part of a balanced diet to get your day started right.
Hope you get that addressed soon.
popalock is offline
post #5104 of 5748 Old 07-26-2015, 09:38 PM
MKtheater's Avatar
Liked: 1116
See above.
post #5105 of 5748 Old 08-10-2015, 06:57 AM
Jason kiDD's Avatar
Quoted: 23 Post(s)
Liked: 25
Took the girls out to play this weekend at a sound showcase.. Had them on bass.. Played well for and took best sounding system for the day..
The look on people's faces tho was priceless they was trying to figure out what was going on and why it sounded so good.. Ill keep them as backup or for rainy days like this one where i can mix it up..
brettus, mlah384 and ronny31 like this.
Jason kiDD is offline
post #5106 of 5748 Old 08-11-2015, 05:43 AM
mlah384's Avatar
Quoted: 410 Post(s)
Liked: 176
Where's the build thread on that sumamabitch?!
mlah384 is offline
post #5107 of 5748 Old 08-11-2015, 12:54 PM
Jason kiDD's Avatar
Quoted: 23 Post(s)
Liked: 25
post #5108 of 5748 Old 08-12-2015, 08:27 PM
lz7j's Avatar
Quoted: 668 Post(s)
Liked: 645
Has anyone tried the enhanced fp10000q or fp14000 from H-y? I'm on the fence giving these clones a shot to power 4 x ported hst18's. My other option is a pair of cv5000's.
lz7j is offline
post #5109 of 5748 Old 08-19-2015, 01:43 PM
mlah384's Avatar
Quoted: 410 Post(s)
Liked: 176
mlah384 is offline
post #5110 of 5748 Old 08-19-2015, 02:21 PM
BassThatHz's Avatar
Quoted: 2030 Post(s)
Liked: 1546
My first clone is 3 years old now and still working. The newest one is 6 months old and it is also still working.
I don't clip mine though, I keep it no-higher-than just below that.
By the time they get to -10db it is already way TOO loud for the people around me.
BassThatHz is offline
post #5111 of 5748 Old 08-19-2015, 02:35 PM
GizzeGutten's Avatar
Quoted: 169 Post(s)
Liked: 75
The enhanced versions:
Merrysound charged almost $300 for shipping and were slow in replying. They wanted $845 for an enhanced FP10000Q.
HYAudio wanted approx. $200 for shipping and were initially a little slow in replying, but once they responded the ball went rolling. They wanted $880 for the enhanced FP10000Q.
I never got any of them as I got happy powering quad midbass modules with a pair of Inuke 6000's. For low bass I'm using two FP14000 from Sanway and they are excellent. Had some trouble with one of them but it was fixed by replacing boards and I am not sure if it was a manufacturing error or what, since I bought the unit that failed second hand.
If I were to go for an enhanced one I'd place my bet on HYAudio, for regular clones Sanway like everyone else. Not sure if the benefit of the enhanced version trumps the risk though. With Sanway you know what you're getting and if there are any issues you'll get help having them resolved even though it will cost you a little. Personally I would stay clear of the home theater version and get the regular one with the fans going all the time and would rather do a fan mod to lower noise.
I like bass
GizzeGutten is offline
post #5112 of 5748 Old 08-19-2015, 04:20 PM
mlah384's Avatar
Quoted: 410 Post(s)
Liked: 176
How is the fan noise on the FP14000 compared to an inuke 6000's fans? I didn't find the inuke that loud, like others have commented. My HTPC case fan is louder! (i gotta swap it out!)
mlah384 is offline
post #5113 of 5748 Old 08-19-2015, 05:35 PM
Quoted: 169 Post(s)
Liked: 75
The inuke fans appear far lower in pitch than the FP14000's so the clones appear much more noisy. Haven't done SPL readings to compare, but I don't think an SPL measurement says it all anyways as the human ear is more sensitive to higher pitched noise. It's easy to live with the hum of a noisy fridge, not so much higher pitched noise.
I like bass
post #5114 of 5748 Old 08-19-2015, 09:22 PM
FriscoDTM's Avatar
Quoted: 261 Post(s)
Liked: 243
The 14k is WAY louder than a 6000 with the stock fans, but it is great with Nyt's fans. I'd also recommend skipping the 'HT' version.
Display 2013 Samsung 75" UN75F6300 TV Media Xbox One S, Dune Solo, QNAP TS-453A NAS
Pre/Amp Marantz 7702mk2 Processor + DIY 11ch Icepower 50ASX2BTL Monoblock Amp Amp Build Link
7.2.4 Speakers DIYSG 1099s (LCR), Volt 10LX (SL, SR), Volt 8LX (BL, BR), Volt 10LX (TF, TR) Volt Build Link
Subs Dual 19Hz DIY Ported UXL-18s + FP14k Amp + MiniDSP 2x4 Balanced Tactile Crowsons + iNuke 6000DSP
FriscoDTM is offline
post #5115 of 5748 Old 08-21-2015, 03:16 AM
mlah384's Avatar
Quoted: 410 Post(s)
Liked: 176
Sounds like the FP14000 will need fan mod then... anyone have a link to the fan mod?
Also, what version is best to get? the 110V? or 220V? or does it only come in 110V? When I emailed Sanway, they only refer to it as a 110V....
mlah384 is offline
post #5116 of 5748 Old 08-28-2015, 09:56 PM
mlah384's Avatar
Quoted: 410 Post(s)
Liked: 176
mlah384 is offline
post #5117 of 5748 Old 08-29-2015, 02:40 AM
Quoted: 631 Post(s)
Liked: 111
Well, if you have a low tune enclosure you likely won't need the full power handling of the drivers to reach xmax at the desired bottom frequency. If you lets say want flat response from 10hz then as long as you reach xmax at 10hz then you only need 1/4 the xmax to have the same db at 20hz. 1/16 the xmax at 40hz.
ronny31 is offline
post #5118 of 5748 Old 08-29-2015, 08:14 AM
mlah384's Avatar
Quoted: 410 Post(s)
Liked: 176
My goal is to experience every frequency that any movie has to offer. So I figure the subs need to be capable of reaching down to 3hz. My thoughts are two nearfield enclosures with dual opposed FTW21's. But they are 4ohm each, so that's 2 ohm per enclosure. I'd love to find a 20000q clone, but don't think they exist? So I was hoping the FP14000 would work at 2ohm.
mlah384 is offline
post #5119 of 5748 Old 08-29-2015, 04:26 PM
blah450's Avatar
Quoted: 138 Post(s)
Liked: 169
I believe Not or someone did say there was a 20000 clone...just a couple months ago??
Of course, someone is selling the real LG 20000 used on Ebay...if there is an extra $5k laying around...
blah450 is offline
post #5120 of 5748 Old 08-29-2015, 09:16 PM - Thread Starter
notnyt's Avatar
Quoted: 2151 Post(s)
Liked: 1980
The FP14k is supposedly 2 ohm stable, according to Sanway, anyway.
notnyt is offline
post #5121 of 5748 Old 08-29-2015, 10:32 PM
mlah384's Avatar
Quoted: 410 Post(s)
Liked: 176
mlah384 is offline
post #5122 of 5748 Old 08-30-2015, 01:50 AM - Thread Starter
notnyt's Avatar
Liked: 1980
If you're gonna try another vendor, try from hyaudio.
notnyt is offline
post #5123 of 5748 Old 08-30-2015, 04:59 AM
Quoted: 631 Post(s)
Liked: 111
Series connected in pairs would be better I think. FP10k in bridged pairs should give that voltage gain I think.
ronny31 is offline
post #5124 of 5748 Old 08-30-2015, 10:52 PM
BassThatHz's Avatar
Liked: 1546
I've never been able to play a 1hz or 2hz tone before (all my other amps roll off at 5-7hz), but I just tried it with the FP14000.
I didn't push it to full power (because I'm chicken) but it did move the cone all the way to 1hz. Sweet their specs don't lie!
post #5125 of 5748 Old 09-02-2015, 12:41 AM
Quoted: 93 Post(s)
Liked: 48
[QUOTE=BassThatHz;36903898]I've never been able to play a 1hz or 2hz tone before (all my other amps roll off at 5-7hz), but I just tried it with the FP14000.
BassthatHZ, your nuts and I like it.
Doradoguy is offline
post #5126 of 5748 Old 09-12-2015, 11:25 AM
kbclamper's Avatar
Quoted: 93 Post(s)
Liked: 27
i need a fp14000 to run my new lms ultras which one should i get? the sanway or upgraded one? link to the best place to buy it?
kbclamper is offline
post #5127 of 5748 Old 09-12-2015, 01:34 PM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
MK did you get yours fixed or figure out what it was? Mine started doing the exact same thing which sucks and is odd as its literally been off for like 4 months (ive been stupid busy and my AVR died (HDMI Board) and i just finally got around to changing it out
will randomly cut to mute leds both channels ( i only use 1) i noticed it when doing the AVR setup with the new AVR, it seemingly comes and goes randomly, however i can make it happen every time i have it on and then power on another amp.
At first i thought maybe the miniDSP or something else was doing it but reading your post it seems this is the issue
crappy cellphone vid of whats happening
Sibuna is offline
post #5128 of 5748 Old 09-12-2015, 01:41 PM
Quoted: 169 Post(s)
Liked: 75
Sanway is the best tried and proven supplier of the clones. You contact Mr Johnson Tang through their email: sales@china-sanway.com . You basically ask for what you want and he will send you a Paypal invoice. After you've paid he will use DHL express and you'll have the amp within a week or so from paying.
I would not go with the home theater version with temperature controlled fans. Go with the ones that run all the time and do a fan mod instead if you need to lower the noise.
As far as I know Sanway does not offer Enhanced versions of the FP clones. Some months back I contemplated an enhanced amp from another supplier, but I did not grow confident with their communication, response rate and one company's inflated shipping rates, so I chose to stick with what I know which is Sanway (own two FP14k's and will eventually get a FP10kQ). The suppliers in question were HYAudio and Merrysound. If I absolutely wanted an Enhanced version, I'd place my bet on HYAudio.
I like bass
post #5129 of 5748 Old 09-12-2015, 01:42 PM
mlah384's Avatar
Quoted: 410 Post(s)
Liked: 176
I think I remeber someone having an issue with theirs and they did a reset? and fixed it? Not sure how that's done though.... I don't own a clone yet. I'm curious if the 20000q will do 1hz too?
mlah384 is offline
post #5130 of 5748 Old 09-12-2015, 01:51 PM
BassThatHz's Avatar
Liked: 1546
Sounds like you've had a undervolt or power surge on your electrical grid, or perhaps when the AVR blew it damaged the clone.
These things usually happen in pairs+ for a reason... cascade failures.
Lab Gruppen Fp 14000 , Sanway Fp 10000q
