Lab Gruppen FP14000 clone amplifiers - Page 174 - AVS Forum | Home Theater Discussions And Reviews
Baselworld is only a few weeks away. Getting the latest news is easy, Click Here for info on how to join the newsletter list. Follow our team for updates featuring event coverage, new product unveilings, watch industry news & more!
post #5191 of 5191 Old 11-05-2015, 04:54 PM
PsychoM3's Avatar
Quoted: 348 Post(s)
Liked: 273
Originally Posted by mlah384 View Post
I thought 10ga on 120v was 30amp, but on 240v, doesn't it double?? or did I flunk ohm's law?
Currently I have a 30amp 120v breaker on a 10ga wire, so if I convert it to 240v, I still can only run about the same 30amp load? If that's true, then why even bother with 240v?
The current capacity of wire stays the same no matter what voltage is running through it (simplified for household voltages).
As you figured out with the same current but double the voltage you have twice the power so a dual voltage device (such as the amp) can be fed with twice the power with the same current. So 120v @ 30 amps is the same power (watts) as 240v @ 15 amps.
This is the reason power transmission lines run at 138,000 volts to 765,000 volts so the cables don't have to be many feet in diameter where typical ACSR cable is about 4 inches in diameter. (BTW a cable many feet in diameter was just for fun, the skin effect makes cables much larger than the ones used impractical since the ampacity would increase very little)
PsychoM3 is offline
post #5192 of 5191 Old 11-05-2015, 04:54 PM
mlah384's Avatar
Quoted: 364 Post(s)
Liked: 136
Originally Posted by notnyt View Post
Yes, by about half.
Thanks notnyt! I get tripped up with AC stuff... It's so simple that it's confusing!
mlah384 is online now
post #5193 of 5191 Old 11-05-2015, 06:11 PM
BassThatHz's Avatar
Quoted: 1336 Post(s)
Liked: 996
You can run two FP14k's off one 10awg wire if it is 240V @ 30amps.
If it is 120V @ 30amps and 10awg then you can only use one FP14k.
However, the more pro-amps you run the higher your monthly power bill will be.
10 FP14k's idling 24/7 for 1 month will cost about $50, and if you boom them the price goes 8-16x higher.
But if you only do say 3 hours a day and don't boom loudly very often, then it ain't so bad. $5-15 a month at most.
BassThatHz is online now
Lab Gruppen Fp 14000 , Sanway Fp 10000q
Gear in this thread - 10000q by
